[Ovmsdev] OVMS CAN-USB Call for Assistance
HONDA S-2000
s2000 at sounds.wa.com
Sat Sep 7 04:44:39 HKT 2013
I seem to recall that Mark wanted to keep the CAN-USB simple and
cheap. Adding space for a Bluetooth module could double the size and
cost of the PCB. It's not an 8-pin IC.
Is there any reason you can't use the OVMS v3 for whatever you want
the Bluetooth for? The CAN-USB is supposed to be a single-function,
cheap, giveaway piece of electronics.
Brian
On Sep 6, 2013, at 00:52, Mastro Gippo wrote:
> Just a quick request: there should be enough space on the pcb to add a
> bluetooth module. Please add at least the footprint for
> [http://www.ebay.it/sch/i.html?
> _odkw=hc-05&_sop=15&_osacat=0&_from=R40&LH_PrefLoc=2&_trksid=p2045573.
> m570.l1313&_nkw=hc-05+-74hc05&_sacat=0]
> This would add the need for an independent power supply, but as I
> recall you were already planning to place the footprints on the pcb.
> I found myself in need for a wireless connection a lot of times,
> usually to get a quick log with my phone. For example, this weekend
> I'm doing a few tests with a tesla model s and I'd love a more stealth
> method to get the data.
> About being stealth, I found myself using ELM327 adapters to get CAN
> data more than a few times, but I have to include a lot of filtering
> due to the slowness of the adapter. That said, the STN1170 is an
> "elm327 on steroids", and may have enough horsepower to log unfiltered
> can data, while being a very good diagnostic tool to interface with
> Torque. http://batman.homelinux.com/blog/stn1170-bluetooth-obdii-
> adapter/
> I still have not tested it, but maybe will soon. Single chips are
> available for 10$ in single quantities.
