[Ovmsdev] Connection issues
Nikki Gordon-Bloomfield nikki at littlecollie.com
Mon Sep 30 15:10:18 HKT 2013
What's the coverage map in your area like, Matt?
Sent from my iPhone
> On 30 Sep 2013, at 08:06, Kevin Sharpe ZCW <kevin.sharpe at zerocarbonworld.org> wrote:
> I use giffgaff (O2 network) and it works like a charm all over the UK.
> I couldn't get GEO-sim to work although I gave up quickly because giffgaff was easy.
> Kevin
>> On 30 Sep 2013, at 07:34, "Nikki Gordon-Bloomfield" <nikki at aminorjourney.com> wrote:
>> If the carrier was the problem, it would be concurrent with the problems I had when I tried to put a non-compatible SIM in the unit.
>> Matt, I can recommend O2… if you're having problems with signal in the area.
>> I would suggest you run it on the bench for a dummy test in generic mode? See if it connects then -- as Mark says, with GSM Lock…
>>> On 30 Sep 2013, at 07:24, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>>> Matt,
>>> One thing glaring is the flapping between Orange and TMO. Can you try to GSMLock to just one (preferred) provider (using PARAM_GSMLOCK, #13)?
>>> The log itself shows "PDP: DEACT" - which means it can't establish GPRS. The COPS gets through ok, so it managed to connect to GSM ok - which would seem to indicate the antenna and basic network reception was ok.
>>>> On 30 Sep, 2013, at 3:54 AM, Matt Beard <matt at beard.tv> wrote:
>>>> I have been having issues with my OVMS module not connection.
>>>> When it does connect I tend to find it has very good signal strength, but it often will not connect when I power it on and I find that it drops off quite often.
>>>> I received my RS232/USB adaptor so logged the following data, any use?
>>>> P.S. This is with a Global GeoSIM, in the UK
>>>> ==== LOG ====
>>>> GPS Ready
>>>> ATREG: 5
>>>> OK
>>>> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
>>>> +CSMINS: 0,1
>>>> OK
>>>> AT+CCID;+CPBF="O-";+CPIN?
>>>> 89234185500007905230
>>>> +CPIN: READY
>>>> OK
>>>> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;E0
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"Orange"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"TMO UK"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"Orange"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"TMO UK"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"Orange"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"TMO UK"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"Orange"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"TMO UK"
>>>> OK
>>>> SHUT OK
>>>> OK
>>>> OK
>>>> +PDP: DEACT
>>>> ERROR
>>>> OK
>>>> +CSMINS: 0,1
>>>> OK
>>>> +CPIN: READY
>>>> OK
>>>> +IPR: 9600
>>>> OK
>>>> +COPS: 0,1,"Orange"
>>>> OK
>>>> OvmsDev mailing list
