[Ovmsdev] Connection issues
Nikki Gordon-Bloomfield nikki at aminorjourney.com
Mon Sep 30 14:34:21 HKT 2013
If the carrier was the problem, it would be concurrent with the problems I had when I tried to put a non-compatible SIM in the unit.
Matt, I can recommend O2… if you're having problems with signal in the area.
I would suggest you run it on the bench for a dummy test in generic mode? See if it connects then -- as Mark says, with GSM Lock…
On 30 Sep 2013, at 07:24, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Matt,
> One thing glaring is the flapping between Orange and TMO. Can you try to GSMLock to just one (preferred) provider (using PARAM_GSMLOCK, #13)?
> The log itself shows "PDP: DEACT" - which means it can't establish GPRS. The COPS gets through ok, so it managed to connect to GSM ok - which would seem to indicate the antenna and basic network reception was ok.
> On 30 Sep, 2013, at 3:54 AM, Matt Beard <matt at beard.tv> wrote:
>> I have been having issues with my OVMS module not connection.
>> When it does connect I tend to find it has very good signal strength, but it often will not connect when I power it on and I find that it drops off quite often.
>> I received my RS232/USB adaptor so logged the following data, any use?
>> P.S. This is with a Global GeoSIM, in the UK
>> ==== LOG ====
>> GPS Ready
>> ATREG: 5
>> OK
>> AT+CGPSPWR=1;+CGPSRST=0;+CSMINS?
>> +CSMINS: 0,1
>> OK
>> AT+CCID;+CPBF="O-";+CPIN?
>> 89234185500007905230
>> +CPIN: READY
>> OK
>> AT+IPR?;+CREG=1;+CLIP=1;+CMGF=1;+CNMI=2,2;+CSDH=1;+CIPSPRT=0;+CIPQSEND=1;E0
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"Orange"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"TMO UK"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"Orange"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"TMO UK"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"Orange"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"TMO UK"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"Orange"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"TMO UK"
>> OK
>> SHUT OK
>> OK
>> OK
>> +PDP: DEACT
>> ERROR
>> OK
>> +CSMINS: 0,1
>> OK
>> +CPIN: READY
>> OK
>> +IPR: 9600
>> OK
>> +COPS: 0,1,"Orange"
>> OK
