[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Thu Sep 26 17:29:33 HKT 2013
Ok, then you have the same issue.
Will look into this later.
Regards, Thomas
2013/9/26 Matt Beard OVMS <smvo at mxf.org.uk>
> My STAT? gives:
> Not charging
> SOC: 100%
> Ideal Range: 93 mi
> Est. Range 68 mi
> On 26 September 2013 10:02, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> Matt:
>> Do you get the ODO in the "STAT?" SMS message? I did until two days ago,
>> did a cleanup of the code before push to GitHub. After that i haven't got
>> ODO. Can't see any changes to the code from the previous version ether.
>> Regards, Thomas
>> 2013/9/25 Matt Beard OVMS <smvo at mxf.org.uk>
>>> Having disconnected OVMS and power-cycled the car the charge seemed to
>>> be going OK, so I connected the unit back up and let it go the last 50% or
>>> so with OVMS and it was still fine. So, looks like something set a bad
>>> value! Maybe there is a "set max % charge" CAN message and it got set due
>>> to noise on the bus. Wish I knew what it was!
>>> Matt
>>> On 25 September 2013 14:35, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>>>> How did the rest of the charging go?
>>>> Any other hick ups?
>>>> Regards,Thomas
>>>> onsdag 25. september 2013 skrev Matt Beard følgende:
>>>> The SOC was about 25%
>>>>> Matt
>>>>> On Tuesday, 24 September 2013, Thomas Bergo wrote:
>>>>> Was the SOC approximately 70% ?
>>>>> The Car takes a pause and stops charging for some time at 70%. I
>>>>> belive this is to level the charge state of the cells. After some time the
>>>>> charging will continue.
>>>>> Regards, Thomas
>>>>> tirsdag 24. september 2013 skrev Matt Beard følgende:
>>>>> More strange behaviour with my C-Zero.
>>>>> Trying to investigate charging current today I discovered that the car
>>>>> would not charge for longer than a couple of minutes with the OVMS
>>>>> connected (with Thomas' image loaded). It would start charging, then the
>>>>> current would drop to zero, but the charge light stayed on. After a while
>>>>> it stopped even trying to charge. Disconnecting the OVMS didn't fix it
>>>>> until I also turned the car on and off again (with the OVMS not connected).
>>>>> Did can noise cause problems again?
>>>>> Matt
>>>>> On Tuesday, September 24, 2013, Thomas Bergo wrote:
>>>>> The first models (2011) was delivered with a 16A cable. This was
>>>>> changed for the later models (2012 ->) to 10A cable do to firesafty.
>>>>> At home i use a 16A cable for charging, but the car only draw 13A.
>>>>> I'm not sure what is the correct info, EVSE limit or the charger
>>>>> limit. Any way the car will only draw 13A.
>>>>> The can message for current limit set by EVSE is not know for the
>>>>> i-Miev, so until this information is available we need to hardcode a value
>>>>> to be displayed in "STANDARD xxA" in the app.
>>>>> Regards, Thomas
>>>>> 2013/9/24 Håkon Markussen <hakon.markussen at gmail.com>
>>>>> Nice work Thomas,
>>>>> Your attached image reminds me that I should implement the car_time
>>>>> and car_parktime in the Think City module :-)
>>>>> Regards to max charge rate "STANDARD xxA":
>>>>> The variable car_chargelimit should contain the maximum available
>>>>> mains current, which is set by the EVSE.
>>>>> This is done in vehicle_thinkcity.c and I assume this can-message is
>>>>> available in a iMiEV and could replace the hardcoded "13A".
>>>>> The evse sends a pilot signal controlling the charger max rate, which
>>>>> can be adjusted by the user in steps depending on the evse type.
>>>>> The first evse's for iMiEV was delivered with two charging steps
>>>>> (maybe 10-16A) and got popular among Leaf-owners. Running up to 16A over
>>>>> the Schuko-connector is bad firesafety, so the later evse's were replaced
>>>>> with 13A. (I guess) limit max.
>>>>> This one is a nice one(mode 2, type 2 delivered with different
>>>>> charging connectors:
>>>>> http://salto.no/produkter/ladekabel-justerbar-13-a-type-2-shuko/
>>>>> When the max charge current is set by the evse, e.g. 13A the ac-charge
>>>>> current (which can be measured or viewed in a can-message) will never
>>>>> exceed this limit.
>>>>> Br.
>>>>> Håkon
>>>>> 2013/9/24 Thomas Bergo <thomas.bergo at gmail.com>
>>>>> I don't remember to have seen any documentation. There is a common
>>>>> understanding in Norway that the car only can drain 13A.
>>>>> I have also measured hove much current the car use when charging.
>>>>> This setting is only for information in the app, as no information is
>>>>> send to the car from the car module. There is no way that the car module
>>>>> can impact on the charge current. The voltage and current (13A) is reported
>>>>> by the car and not limited by the OVMS.
>>>>> [image: Innebygd bilde 1]
>>>>> Regards, Thomas
>>>>> 2013/9/24 Matt Beard OVMS <smvo at mxf.org.uk>
>>>>> Do you have a source for this 13A maximum claim? Mitsubishi claim
>>>>> that the on-board charger in the iMiev runs at 240V 15A in the USA.
>>>>> If you want to use the output rating of the charger you need to reduce
>>>>> the figure to 9A as the output is 330V.
>>>>> What does the Roadster version set - does it use the input current, or
>>>>> some version of the output curre
>>>> OvmsDev mailing list
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130926/7e9bfb4e/attachment-0001.html>
