[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Thu Sep 26 16:54:58 HKT 2013
Matt:
I believe you are right. From datasheets the range is rated to 150 km with
16 KWh and 14.5 KWh battery. I believe the battery is the same, and 16 KWh
is theoretical capacity and 14.5 KWh is usable capacity.
For the 2013 i-Miev the rated range is 160 km with the same battery as
previous MY.
Regards, Thomas
2013/9/24 Matt Beard <matt at beard.tv>
> You can tell how many cells from the 6en messages, but I heard that the
> range is the same, but the unused capacity is less so the batteries don't
> last as well.
> This needs to be confirmed.
> Matt
> On Tuesday, September 24, 2013, Thomas Bergo wrote:
>> There is delivered some Citroen C-Zero with a smaller battery pack (13
>> KWh VS 16 KWh.) The ideal range for the 13 KWh battery I believe is 80
>> miles and for the 16 KWh battery the ideal range is 150km (93 miles).
>> To calculate the ideal range correctly for both battery size we need a
>> way to distinguish between them.
>> Do you think that there will be any issues by using the Feature 14, Car
>> bits, to indicate which battery pack the car has?
>> Regards, Thomas
>> I'm using a Global SIM.
>> I may try the diag port if I can find something that reads RS-232 in this
>> day and age! I must try and get a USB adapter.
>> Matt
>> On Tuesday, 24 September 2013, Nikki Gordon-Bloomfield wrote:
>> Great. In addition, you might want to try and attach something to the
>> diagnostics port. You should be able to read through the port any AT
>> commands, to make sure it's working correctly.
>> I believe there's a list somewhere of the messages you'll get from the
>> diagnostic port for that chip.. 901 is it? (I can't remember, but it's
>> what we used to diagnose the SIM card was at fault.)
>> Nikki.
>> P.S. What SIM are you using? Global? O2?
>> On 24 Sep 2013, at 09:16, Matt Beard <matt at beard.tv> wrote:
>> Actually, running it with stock firmware as OBDII in our ICE is next on
>> my list of checks.
>> Matt
>> On Tuesday, September 24, 2013, Nikki Gordon-Bloomfield wrote:
>> The other suggestion I would have is to plug the ODBII module into
>> another car -- or power it from a bench supply using the method detailed in
>> the development guide?
>> Nikki.
>> On 24 Sep 2013, at 08:08, Mark Webb-Johnson <mark at webb-johnson.net>
>> wrote:
>> Matt,
>> I have modules with me for replacement, if necessary.
>> I am concerned about your comments regarding soldering. All the v2
>> modules are supposed to be machine soldered, and we have had almost zero
>> returns of broken modules.I would be grateful if you could let me know the
>> serial number of your module, the approximate date you received it, and if
>> possible a picture of the soldering issues.
>> I too am perplexed why the module would work SMS but not GPRS. Perhaps
>> you can try setting the vehicle type to 'XX', which would eliminate any can
>> bus/message issues, and see if the problem still occurs.
>> Please eMail me, off list, as mark (at) openvehicles (dot) com, and I'll
>> work through this with you.
>> On 24 Sep, 2013, at 5:13 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
>> Thanks Thomas,
>> That has confirmed for me that my hardware has died.
>> Looking at the circuit board the soldering on the GSM modem is shocking,
>> but I don't understand how it can work for SMS, but crash with GPRS. Looks
>> like I will be spending most of my effort in the coming days trying to get
>> the hardware replaced!
>> I have confirmed that the unit functions perfectly (though is pretty
>> useless) with the GPRS switch set to disabled. If it is booted with the
>> switch enabled it dies as soon as I set the GPRS parameters, then enters an
>> endless reboot loop.
>> Matt
>> On 23 September 2013 21:18, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> Attached is the hex file, this is the exact same that is running om my
>> module now.
>> Regards, Thomas
>> 2013/9/23 Matt Beard <matt at beard.tv>
>> Thomas,
>> That would be really useful. I am worried that the module may have failed.
>> I did not keep a copy of the last working hex file (lesson learned!) but
>> did save the sources. Rebuilt from previous sources and loaded. It still
>> fails.
>> Matt
>> On Monday, September 23, 2013, Thomas Bergo wrote:
>> Matt:
>> I can send you the hex file i'm running in my OVMS module, so you can try
>> if that woking in your module?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130926/24f28370/attachment.html>
