[Ovmsdev] i-Miev/C-Zero/iOn
Håkon Markussen
hakon.markussen at gmail.com
Wed Sep 25 06:14:48 HKT 2013
I'm not sure what type of home charger you have Thomas, but having a 16A
label gives no guarantee for its pilot signal to actually request 16A.
To be 100% sure you have to read the pwm duty-cycle of the evse pilot,
eighter by a scope or by connecting your evse to a car with available
(known) can-message for charge current limit.
If you have this wall mounted "pod-point" evse's, I would expect the pilot
signal to request 16A. In that case the iMiEV-charger does overwrite the
pilot.
This was done on the early Think City A306 cars (gen0 PCU), which had a
weak charger.
Br.
Håkon
2013/9/24 Thomas Bergo <thomas.bergo at gmail.com>
> The first models (2011) was delivered with a 16A cable. This was changed
> for the later models (2012 ->) to 10A cable do to firesafty.
> At home i use a 16A cable for charging, but the car only draw 13A.
> I'm not sure what is the correct info, EVSE limit or the charger limit.
> Any way the car will only draw 13A.
> The can message for current limit set by EVSE is not know for the i-Miev,
> so until this information is available we need to hardcode a value to be
> displayed in "STANDARD xxA" in the app.
> Regards, Thomas
> 2013/9/24 Håkon Markussen <hakon.markussen at gmail.com>
>> Nice work Thomas,
>> Your attached image reminds me that I should implement the car_time and
>> car_parktime in the Think City module :-)
>> Regards to max charge rate "STANDARD xxA":
>> The variable car_chargelimit should contain the maximum available mains
>> current, which is set by the EVSE.
>> This is done in vehicle_thinkcity.c and I assume this can-message is
>> available in a iMiEV and could replace the hardcoded "13A".
>> The evse sends a pilot signal controlling the charger max rate, which can
>> be adjusted by the user in steps depending on the evse type.
>> The first evse's for iMiEV was delivered with two charging steps (maybe
>> 10-16A) and got popular among Leaf-owners. Running up to 16A over the
>> Schuko-connector is bad firesafety, so the later evse's were replaced with
>> 13A. (I guess) limit max.
>> This one is a nice one(mode 2, type 2 delivered with different charging
>> connectors:
>> http://salto.no/produkter/ladekabel-justerbar-13-a-type-2-shuko/
>> When the max charge current is set by the evse, e.g. 13A the ac-charge
>> current (which can be measured or viewed in a can-message) will never
>> exceed this limit.
>> Br.
>> Håkon
>>> I don't remember to have seen any documentation. There is a common
>>> understanding in Norway that the car only can drain 13A.
>>> I have also measured hove much current the car use when charging.
>>> This setting is only for information in the app, as no information is
>>> send to the car from the car module. There is no way that the car module
>>> can impact on the charge current. The voltage and current (13A) is reported
>>> by the car and not limited by the OVMS.
>>> [image: Innebygd bilde 1]
>>> Regards, Thomas
>>> 2013/9/24 Matt Beard OVMS <smvo at mxf.org.uk>
>>>> Do you have a source for this 13A maximum claim? Mitsubishi claim that
>>>> the on-board charger in the iMiev runs at 240V 15A in the USA.
>>>> If you want to use the output rating of the charger you need to reduce
>>>> the figure to 9A as the output is 330V.
>>>> What does the Roadster version set - does it use the input current, or
>>>> some version of the output current?
>>>> I notice that the Volt/Ampera code sets 16A as the charge limit.
>>>> Matt
>>>> On 24 September 2013 19:58, Thomas Bergo <thomas.bergo at gmail.com>wrote:
>>>>> The charger is only able to deliver 3 KW to the battery, so the car
>>>>> will maximum use 13A from the grid. I therefor hardcoded the charging to
>>>>> "STANDARD 13A"
>>>>> Regards, Thomas
>>>>>> I think my hardware may have a dodgy connection as it is working
>>>>>> again!
>>>>>> I am using the hex file Thomas sent (one that failed yesterday!)
>>>>>> I noticed that the charge level is reported wrongly. I am using a 16A
>>>>>> charger (and the car does charge at > 13A) yet the C-Zero code is reporting
>>>>>> the charge type as "STANDARD 13A" and the charge current is showing as 12A.
>>>>>> Matt
>>>>>> On 24 September 2013 19:22, Thomas Bergo <thomas.bergo at gmail.com>wrote:
>>>>>>> I read some rumors that some cars imported from Denmark to Norway
>>>>>>> had a smaller battery pack.
>>>>>>> Have to look some more to find where i read about this.
>>>>>>> Regards, Thomas
>>>>>>> 2013/9/24 Matt Beard <matt at beard.tv>
>>>>>>>> You can tell how many cells from the 6en messages, but I heard
>>>>>>>> that the range is the same, but the unused capacity is less so the
>>>>>>>> batteries don't last as well.
>>>>>>>> This needs to be confirmed.
>>>>>>>> Matt
>>>>>>>> On Tuesday, September 24, 2013, Thomas Bergo wrote:
>>>>>>>>> There is delivered some Citroen C-Zero with a smaller battery pack
>>>>>>>>> (13 KWh VS 16 KWh.) The ideal range for the 13 KWh battery I believe is 80
>>>>>>>>> miles and for the 16 KWh battery the ideal range is 150km (93 miles).
>>>>>>>>> To calculate the ideal range correctly for both battery size we
>>>>>>>>> need a way to distinguish between them.
>>>>>>>>> Do you think that there will be any issues by using the Feature
>>>>>>>>> 14, Car bits, to indicate which battery pack the car has?
>>>>>>>>> Regards, Thomas
>>>>>>>>> I'm using a Global SIM.
>>>>>>>>> I may try the diag port if I can find something that reads RS-232
>>>>>>>>> in this day and age! I must try and get a USB adapter.
>>>>>>>>> Matt
>>>>>>>>> On Tuesday, 24 September 2013, Nikki Gordon-Bloomfield wrote:
>>>>>>>>> Great. In addition, you might want to try and attach something to
>>>>>>>>> the diagnostics port. You should be able to read through the port any AT
>>>>>>>>> commands, to make sure it's working correctly.
>>>>>>>>> I believe there's a list somewhere of the messages you'll get from
>>>>>>>>> the diagnostic port for that chip.. 901 is it? (I can't remember, but it's
>>>>>>>>> what we used to diagnose the SIM card was at fault.)
>>>>>>>>> Nikki.
>>>>>>>>> P.S. What SIM are you using? Global? O2?
>>>>>>>>> On 24 Sep 2013, at 09:16, Matt Beard <matt at beard.tv> wrote:
>>>>>>>>> Actually, running it with stock firmware as OBDII in our ICE is
>>>>>>>>> next on my list of checks.
>>>>>>>>> Matt
>>>>>>>>> On Tuesday, September 24, 2013, Nikki Gordon-Bloomfield wrote:
>>>>>>>>> The other suggestion I would have is to plug the ODBII module into
>>>>>>>>> another car -- or power it from a bench supply using the method detailed in
>>>>>>>>> the development guide?
>>>>>>>>> Nikki.
>>>>>>>>> On 24 Sep 2013, at 08:08, Mark Webb-Johnson <mark at webb-johnson.net>
>>>>>>>>> wrote:
>>>>>>>>> Matt,
>>>>>>>>> I have modules with me for replacement, if necessary.
>>>>>>>>> I am concerned about your comments regarding soldering. All the v2
>>>>>>>>> modules are supposed to be machine soldered, and we have had almost zero
>>>>>>>>> returns of broken modules.I would be grateful if you could let me know the
>>>>>>>>> serial number of your module, the approximate date you received it, and if
>>>>>>>>> possible a picture of the soldering issues.
>>>>>>>>> I too am perplexed why the module would work SMS but not GPRS.
>>>>>>>>> Perhaps you can try setting the vehicle type to 'XX', which would eliminate
>>>>>>>>> any can bus/message issues, and see if the problem still occurs.
>>>>>>>>> Please eMail me, off list, as mark (at) openvehicles (dot) com,
>>>>>>>>> and I'll work through this with you.
>>>>>>>>> Regards, Mark.
>>>>>>>>> On 24 Sep, 2013, at 5:13 AM, Matt Beard OVMS <smvo at mxf.org.uk>
>>>>>>>>> wrote:
>>>>>>>>> Thanks Thomas,
>>>>>>>>> That has confirmed for me that my hardware has died.
>>>>>>>>> Looking at the circuit board the soldering on the GSM modem is
>>>>>>>>> shocking, but I don't understand how it can work for SMS, but crash with
>>>>>>>>> GPRS. Looks like I will be spending most of my effort in the coming days
>>>>>>>>> trying to get the hardware replaced!
>>>>>>>>> I have confirmed that the unit functions perfectly (though is
>>>>>>>>> pretty useless) with the GPRS switch set to disabled. If it is booted with
>>>>>>>>> the switch enabled it dies as soon as I set the GPRS parameters, then
>>>>>>>>> enters an endless reboot loop.
>>>>>>>>> Matt
>>>>>>>>> On 23 September 2013 21:18, Thomas Bergo <thomas.bergo at gmail.com>wrote:
>>>>>>>>> Attached is the hex file, this is the exact same that is running
>>>>>>>>> om my module now.
>>>>>>>>> Regards, Thomas
>>>>>>>>> 2013/9/23 Matt Beard <matt at beard.tv>
>>>>>>>>> Thomas,
>>>>>>>>> That would be really useful. I am worried that the module may have
>>>>>>>>> failed.
>>>>>>>>> I did not keep a copy of the last working hex file (lesson
>>>>>>>>> learned!) but did save the sources. Rebuilt from previous sources and
>>>>>>>>> loaded. It still fails.
>>>>>>>>> Matt
>>>>>>>>> On Monday, September 23, 2013, Thomas Bergo wrote:
>>>>>>>>> Matt:
>>>>>>>>> I can send you the hex file i'm running in my OVMS module, so you
>>>>>>>>> can try if that woking in your module?
>>>>>>>> OvmsDev mailing list
>>>>>>>> OvmsDev at lists.teslaclub.hk
>>>>>>>> http://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130925/b7c287eb/attachment-0001.html>
