[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard OVMS
smvo at mxf.org.uk
Wed Sep 25 02:33:55 HKT 2013
I think my hardware may have a dodgy connection as it is working again!
I am using the hex file Thomas sent (one that failed yesterday!)
I noticed that the charge level is reported wrongly. I am using a 16A
charger (and the car does charge at > 13A) yet the C-Zero code is reporting
the charge type as "STANDARD 13A" and the charge current is showing as 12A.
Matt
On 24 September 2013 19:22, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> I read some rumors that some cars imported from Denmark to Norway had a
> smaller battery pack.
> Have to look some more to find where i read about this.
> Regards, Thomas
> 2013/9/24 Matt Beard <matt at beard.tv>
>> You can tell how many cells from the 6en messages, but I heard that the
>> range is the same, but the unused capacity is less so the batteries don't
>> last as well.
>> This needs to be confirmed.
>> Matt
>> On Tuesday, September 24, 2013, Thomas Bergo wrote:
>>> There is delivered some Citroen C-Zero with a smaller battery pack (13
>>> KWh VS 16 KWh.) The ideal range for the 13 KWh battery I believe is 80
>>> miles and for the 16 KWh battery the ideal range is 150km (93 miles).
>>> To calculate the ideal range correctly for both battery size we need a
>>> way to distinguish between them.
>>> Do you think that there will be any issues by using the Feature 14, Car
>>> bits, to indicate which battery pack the car has?
>>> Regards, Thomas
>>> I'm using a Global SIM.
>>> I may try the diag port if I can find something that reads RS-232 in
>>> this day and age! I must try and get a USB adapter.
>>> Matt
>>> On Tuesday, 24 September 2013, Nikki Gordon-Bloomfield wrote:
>>> Great. In addition, you might want to try and attach something to the
>>> diagnostics port. You should be able to read through the port any AT
>>> commands, to make sure it's working correctly.
>>> I believe there's a list somewhere of the messages you'll get from the
>>> diagnostic port for that chip.. 901 is it? (I can't remember, but it's
>>> what we used to diagnose the SIM card was at fault.)
>>> Nikki.
>>> P.S. What SIM are you using? Global? O2?
>>> On 24 Sep 2013, at 09:16, Matt Beard <matt at beard.tv> wrote:
>>> Actually, running it with stock firmware as OBDII in our ICE is next on
>>> my list of checks.
>>> Matt
>>> On Tuesday, September 24, 2013, Nikki Gordon-Bloomfield wrote:
>>> The other suggestion I would have is to plug the ODBII module into
>>> another car -- or power it from a bench supply using the method detailed in
>>> the development guide?
>>> Nikki.
>>> On 24 Sep 2013, at 08:08, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>> Matt,
>>> I have modules with me for replacement, if necessary.
>>> I am concerned about your comments regarding soldering. All the v2
>>> modules are supposed to be machine soldered, and we have had almost zero
>>> returns of broken modules.I would be grateful if you could let me know the
>>> serial number of your module, the approximate date you received it, and if
>>> possible a picture of the soldering issues.
>>> I too am perplexed why the module would work SMS but not GPRS. Perhaps
>>> you can try setting the vehicle type to 'XX', which would eliminate any can
>>> bus/message issues, and see if the problem still occurs.
>>> Please eMail me, off list, as mark (at) openvehicles (dot) com, and I'll
>>> work through this with you.
>>> On 24 Sep, 2013, at 5:13 AM, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
>>> Thanks Thomas,
>>> That has confirmed for me that my hardware has died.
>>> Looking at the circuit board the soldering on the GSM modem is shocking,
>>> but I don't understand how it can work for SMS, but crash with GPRS. Looks
>>> like I will be spending most of my effort in the coming days trying to get
>>> the hardware replaced!
>>> I have confirmed that the unit functions perfectly (though is pretty
>>> useless) with the GPRS switch set to disabled. If it is booted with the
>>> switch enabled it dies as soon as I set the GPRS parameters, then enters an
>>> endless reboot loop.
>>> Matt
>>> On 23 September 2013 21:18, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>>> Attached is the hex file, this is the exact same that is running om my
>>> module now.
>>> Regards, Thomas
>>> 2013/9/23 Matt Beard <matt at beard.tv>
>>> Thomas,
>>> That would be really useful. I am worried that the module may have
>>> failed.
>>> I did not keep a copy of the last working hex file (lesson learned!) but
>>> did save the sources. Rebuilt from previous sources and loaded. It still
>>> fails.
>>> Matt
>>> On Monday, September 23, 2013, Thomas Bergo wrote:
>>> Matt:
>>> I can send you the hex file i'm running in my OVMS module, so you can
>>> try if that woking in your module?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130924/38f88926/attachment-0001.html>
