[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Tue Sep 24 04:18:15 HKT 2013
Attached is the hex file, this is the exact same that is running om my
module now.
Regards, Thomas
2013/9/23 Matt Beard <matt at beard.tv>
> Thomas,
> That would be really useful. I am worried that the module may have failed.
> I did not keep a copy of the last working hex file (lesson learned!) but
> did save the sources. Rebuilt from previous sources and loaded. It still
> fails.
> Matt
> On Monday, September 23, 2013, Thomas Bergo wrote:
>> Matt:
>> I can send you the hex file i'm running in my OVMS module, so you can try
>> if that woking in your module?
>> Regards, Thomas
>> 2013/9/23 Thomas Bergo <thomas.bergo at gmail.com>
>> I did a rebuild from clean to ensure that i running the exact same code.
>> My OVMS module is booting as expected, and only the green led is blinking
>> OK (one blink]
>> Which version of the OVMS FW are you running? I have only tested with the
>> 2.5.2 FW.
>> Are there any significant changes from 2.5.2 that can impact the code to
>> constantly reboot?
>> Regards, Thomas
>> 2013/9/23 Matt Beard OVMS <smvo at mxf.org.uk>
>> OK - either this code is broken, or my OVMS is.
>> I flashed the code and set the unit up - no go, kept rebooting and the
>> GPRS does not work.
>> Rebuild from clean. Reflashed, reloaded settings and still constant
>> rebooting and GPRS does not work.
>> Matt
>> On 23 September 2013 10:24, Thomas Bergo <thomas.bergo at gmail.com> wrote:
>> Have tested and fixed a lot of errors this weekend. and i believe that
>> the code is now in a state where it can be merged into the main project.
>> Have pushed a release 1.3 to my fork on GitHub.
>> Changes:
>> 1.3 23.09.13 (Thomas)
>> - Fixed charging notification when battery is full, SOC=100%
>> - TODO: Fix battery temperature reading.
>> 1.2 22.09.13 (Thomas)
>> - Fixed Ideal range
>> - Added parking timer
>> - Added detection of car is asleep.
>> 1.1 21.09.13 (Thomas)
>> - Fixed ODO
>> - Fixed filter and mask for poll0 (thanks to Matt Beard)
>> - Verified estimated range
>> - Verified SOC
>> - Verified Charge state
>> - Added battery temperature reading (thanks to Matt Beard)
>> 1.0 Initial release
>> Regards, Thomas
>> 2013/9/21 Thomas Bergo <thomas.bergo at gmail.com>
>> Thanks to you all for participate.
>> Managed to spend some time on this project yesterday and this this
>> evening.
>> Yesterday i was able to fix the ODO. And thanks to Matt i was able test
>> the SOC, ideal range and Charge state.
>> Added the battery temperature reading form Matt's code.
>> My car is reporting range and ODO in Km, so added support to handle both
>> miles and Km for ODO and Range based on can_mileskm.
>> *"To receive all 0x3nn messages we could use filter SID 0x300 and mask
>> 0x700, but I am worried that may cause a flood of messages."*
>> The current code runs with this filter and mask, ans seems to be stable
>> so far.
>> Still see some errors with the ideal range and the temperature reading.
>> The app is reporting PEM: -125C, Motor: 144C and Battery: 5C
>> Pushed the code with updates from Matt to GitHub.
>> Regards, Thomas
>> 2013/9/21 Michael Jochum <mikeljo at mac.com>
>> Hi,
>> You can only set the Mask and Filter in a Configuraton Mode.
>> From Datasheet:
>> 2
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130923/f43cae43/attachment-0001.html>
Type: application/octet-stream
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130923/f43cae43/attachment-0001.obj>
