[Ovmsdev] i-Miev/C-Zero/iOn
Matt Beard OVMS
smvo at mxf.org.uk
Tue Sep 24 02:24:49 HKT 2013
OK - either this code is broken, or my OVMS is.
I flashed the code and set the unit up - no go, kept rebooting and the GPRS
does not work.
Rebuild from clean. Reflashed, reloaded settings and still constant
rebooting and GPRS does not work.
Matt
On 23 September 2013 10:24, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Have tested and fixed a lot of errors this weekend. and i believe that the
> code is now in a state where it can be merged into the main project.
> Have pushed a release 1.3 to my fork on GitHub.
> Changes:
> 1.3 23.09.13 (Thomas)
> - Fixed charging notification when battery is full, SOC=100%
> - TODO: Fix battery temperature reading.
> 1.2 22.09.13 (Thomas)
> - Fixed Ideal range
> - Added parking timer
> - Added detection of car is asleep.
> 1.1 21.09.13 (Thomas)
> - Fixed ODO
> - Fixed filter and mask for poll0 (thanks to Matt Beard)
> - Verified estimated range
> - Verified SOC
> - Verified Charge state
> - Added battery temperature reading (thanks to Matt Beard)
> 1.0 Initial release
> Regards, Thomas
> 2013/9/21 Thomas Bergo <thomas.bergo at gmail.com>
>> Thanks to you all for participate.
>> Managed to spend some time on this project yesterday and this this
>> evening.
>> Yesterday i was able to fix the ODO. And thanks to Matt i was able test
>> the SOC, ideal range and Charge state.
>> Added the battery temperature reading form Matt's code.
>> My car is reporting range and ODO in Km, so added support to handle both
>> miles and Km for ODO and Range based on can_mileskm.
>> *"To receive all 0x3nn messages we could use filter SID 0x300 and mask
>> 0x700, but I am worried that may cause a flood of messages."*
>> The current code runs with this filter and mask, ans seems to be stable
>> so far.
>> Still see some errors with the ideal range and the temperature reading.
>> The app is reporting PEM: -125C, Motor: 144C and Battery: 5C
>> Pushed the code with updates from Matt to GitHub.
>> Regards, Thomas
>> 2013/9/21 Michael Jochum <mikeljo at mac.com>
>>> Hi,
>>> You can only set the Mask and Filter in a Configuraton Mode.
>>> From Datasheet:
>>> 23.3.1 CONFIGURATION MODE
>>> The CAN module has to be initialized before the activation. This is only
>>> possible if the module is in the Configuration mode. The Configuration mode
>>> is requested by setting the REQOP2 bit. Only when the status bit, OPMODE2,
>>> has a high level can the initial- ization be performed. Afterwards, the
>>> Configuration registers, the Acceptance Mask registers and the Acceptance
>>> Filter registers can be written. The module is activated by setting the
>>> REQOP control bits to zero.
>>> The module will protect the user from accidentally violating the CAN
>>> protocol through programming errors. All registers which control the
>>> configuration of the module can not be modified while the module is on-
>>> line. The CAN module will not be allowed to enter the Configuration mode
>>> while a transmission or reception is taking place. The Configuration mode
>>> serves as a lock to protect the following registers:
>>> • ConfigurationRegisters
>>> • FunctionalModeSelectionRegisters • BitTimingRegisters
>>> • IdentifierAcceptanceFilterRegisters •
>>> IdentifierAcceptanceMaskRegisters • FilterandMaskControlRegisters
>>> • MaskSelectionRegisters
>>> In the Configuration mode, the module will not transmit or receive. The
>>> error counters are cleared and the interrupt flags remain unchanged. The
>>> programmer will have access to Configuration registers that are access
>>> restricted in other modes.
>>> I don't believe that it will work without bad sideeffects.
>>> Bye
>>> michael
>>> Am 21.09.2013 um 11:32 schrieb Matt Beard OVMS <smvo at mxf.org.uk>:
>>> I may also try modifying the RX0 mask during the 1-second poll so that
>>> it cycles through filtering a single SID each time, meaning that it will
>>> take 4 seconds for a full update. I don't think this will be an issue as
>>> none of this data is fast changing.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130923/aa160291/attachment.html>
