[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Mon Sep 23 17:24:04 HKT 2013
Have tested and fixed a lot of errors this weekend. and i believe that the
code is now in a state where it can be merged into the main project.
Have pushed a release 1.3 to my fork on GitHub.
Changes:
1.3 23.09.13 (Thomas)
- Fixed charging notification when battery is full, SOC=100%
- TODO: Fix battery temperature reading.
1.2 22.09.13 (Thomas)
- Fixed Ideal range
- Added parking timer
- Added detection of car is asleep.
1.1 21.09.13 (Thomas)
- Fixed ODO
- Fixed filter and mask for poll0 (thanks to Matt Beard)
- Verified estimated range
- Verified SOC
- Verified Charge state
- Added battery temperature reading (thanks to Matt Beard)
1.0 Initial release
Regards, Thomas
2013/9/21 Thomas Bergo <thomas.bergo at gmail.com>
> Thanks to you all for participate.
> Managed to spend some time on this project yesterday and this this evening.
> Yesterday i was able to fix the ODO. And thanks to Matt i was able test
> the SOC, ideal range and Charge state.
> Added the battery temperature reading form Matt's code.
> My car is reporting range and ODO in Km, so added support to handle both
> miles and Km for ODO and Range based on can_mileskm.
> *"To receive all 0x3nn messages we could use filter SID 0x300 and mask
> 0x700, but I am worried that may cause a flood of messages."*
> The current code runs with this filter and mask, ans seems to be stable so
> far.
> Still see some errors with the ideal range and the temperature reading.
> The app is reporting PEM: -125C, Motor: 144C and Battery: 5C
> Pushed the code with updates from Matt to GitHub.
> Regards, Thomas
> 2013/9/21 Michael Jochum <mikeljo at mac.com>
>> Hi,
>> You can only set the Mask and Filter in a Configuraton Mode.
>> From Datasheet:
>> 23.3.1 CONFIGURATION MODE
>> The CAN module has to be initialized before the activation. This is only
>> possible if the module is in the Configuration mode. The Configuration mode
>> is requested by setting the REQOP2 bit. Only when the status bit, OPMODE2,
>> has a high level can the initial- ization be performed. Afterwards, the
>> Configuration registers, the Acceptance Mask registers and the Acceptance
>> Filter registers can be written. The module is activated by setting the
>> REQOP control bits to zero.
>> The module will protect the user from accidentally violating the CAN
>> protocol through programming errors. All registers which control the
>> configuration of the module can not be modified while the module is on-
>> line. The CAN module will not be allowed to enter the Configuration mode
>> while a transmission or reception is taking place. The Configuration mode
>> serves as a lock to protect the following registers:
>> • ConfigurationRegisters
>> • FunctionalModeSelectionRegisters • BitTimingRegisters
>> • IdentifierAcceptanceFilterRegisters • IdentifierAcceptanceMaskRegisters
>> • FilterandMaskControlRegisters
>> • MaskSelectionRegisters
>> In the Configuration mode, the module will not transmit or receive. The
>> error counters are cleared and the interrupt flags remain unchanged. The
>> programmer will have access to Configuration registers that are access
>> restricted in other modes.
>> I don't believe that it will work without bad sideeffects.
>> Bye
>> michael
>> Am 21.09.2013 um 11:32 schrieb Matt Beard OVMS <smvo at mxf.org.uk>:
>> I may also try modifying the RX0 mask during the 1-second poll so that it
>> cycles through filtering a single SID each time, meaning that it will take
>> 4 seconds for a full update. I don't think this will be an issue as none of
>> this data is fast changing.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130923/bd04c773/attachment-0001.html>
