[Ovmsdev] OVMS v2.5.3 CHARGEBY doesn't seem to have any effect
Mon Sep 23 14:47:58 HKT 2013
Curt,
If, for example, you are 5 hours west of GMT, you should set timezone to -05:00. That appears to be what you have set.
After setting a 'ACC PARAMS CHARGEBY 08:00', the 'ACC STAT' should show '08:00:00'. If it doesn't, something is wrong.
Can you also set the chargelimit (even if it is the same as the wall limit) - that is required in order to be able to estimate charge time.
On 23 Sep, 2013, at 5:17 AM, Curt Harpold <curt.harpold at gmail.com> wrote:
> Mark,
> Sorry for all of the emails, I just figured you would want to know how testing is going.
> Never mind the earlier ones - TPMS data has re-appeared. I think that I needed to do a drive after the module was re-installed to get the data read in (not sure about that). I have opted in to charge logging, so you can see what is happening.
> Output of "SMS STAT" for the specified location
> STAT?
> Standard - Charging
> 232V/40A
> Full: 88 mins
> SOC: 73%
> Ideal Range: 133 mi
> Est. Range: 125 mi
> ODO: 22,715.3 mi
> CAC: 147.76
> ACC STAT
> ACC Status #1
> 39.072536, -77.131168
> Enabled
> Cooldown
> Charge by time 03:44:00
> Mode: standard (0A)
> Your vehicle id
> ROADSTER76
> Output of base64 parameter string (from the cellphone app)
> AqkrEWe+Gt4BQwAA4AAAAAAAAAA=
> Date/Time you entered the ACC location (with timezone)
> 22 September 2013 15:41 EST
> Date/Time you plugged in at the ACC location (with timezone)
> 22 September 2013 approx 16:45 EST
> In the smartphone app, call up the Features and Parameters screens (so the server logs those, and I can check)
> Done.
> Description of the problem you have
> I set the ACC params for Cooldown, Chargeby 08:00, and Standard mode. When I plugged in, the charge started immediately, with no cooldown phase (probably expected, since the battery is already below the threshold). Further attempt to request a cooldown made no change. Standard mode charge proceeded, even though I would have expected a timed charge to start some time tomorrow morning (and the STAT? command now reports time to full at just 88 minutes).
> Also, I set CHARGEBY for 08:00, but the ACC STAT return seems to indicate it is set for 44 minutes after the time specified. If it were working, it would be late.
> Now that I look at it again, I don't understand the time setting at all. I followed your insructions to use a leading "-" as I am West of GMT. I would expect the reported CHARGEBY time to be either 08:00 (local) or 13:00 (GMT), but I'm seeing 03:44.
> Many thanks - will try to help with any testing you need in a timely manner.
> ......curt
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130923/618df46c/attachment.html>
