[Ovmsdev] v2.5.3 Call for Testing
Thu Sep 19 15:20:06 HKT 2013
Tom,
DId you configure that before plugging in?
I think the way it is at the moment, you would need to configure this before you open the charge port door. Then, when you open the door and plugin you would expect the cooldown charge to start immediately and run for up to 1 hour. Then, the car would sleep and wake up during the night, to complete the desired charge before 6am.
On 19 Sep, 2013, at 1:56 PM, Tom Saxton <tom at idleloop.com> wrote:
> I installed 2.5.3, then did these commands:
> // set time zone to PDT
> PARAMS 23 -07:00
> // set cooldown temp to 27C, time limit to 60 minutes
> PARAMS 15 27:60
> // setup ACC
> ACC HERE
> ACC PARAMS COOLDOWN CHARGEBY 06:00 LIMIT 32 MODE STA
> ACC ENABLE
> We'll see what happens in the morningŠ
>    Tom
