[Ovmsdev] i-Miev/C-Zero/iOn
Thomas Bergo
thomas.bergo at gmail.com
Mon Sep 16 05:02:02 HKT 2013
Finally got some time to work on the i-Miev implementation.
But I'm facing some issues setting up the car module.
- SMS is working and are able to send messages to the car module and get
answers.
- Problem getting the GPRS to work. Get "Not connected" and "Not connected
(0x0041) when sending GPRS?
- No connection from the iOS app to server. Only red flashing antenna.
Any advise?
Still has some debugging to do on the i-Miev code, as i'm only get "SOC:
0%" from STAT?
Regards, Thomas
2013/5/1 Mark Webb-Johnson <mark at webb-johnson.net>
> I've created a stub file (vehicle_mitsubishi.c), and pushed to github. If
> you pull head you'll get it. This is just a stub. You'll need to setup the
> CAN IDs you want to receive (in the filters), and then add the decoding
> logic to update the car_* variables.
> On 30 Apr, 2013, at 5:29 AM, Thomas Bergo <thomas.bergo at gmail.com> wrote:
> Hi,
> So far the following CAN messages is discovered by Priusfan published on
> myimiev forum:
> SOC
> RPM
> Range
> Battery current
> Battery voltage
> Speed
> Odo
> Battery cell voltage
> Battery cell temperature
> So we still have to find Car On/Off and the charging status.
> Those messages are available as Mitsubishi has made a CAN Gateway where
> those data is provided.
> http://www.pref.nagasaki.jp/ev/ev&its/120614/navi/gateway_gaiyou.pdf
> Regarding the two-character abbreviation I think Brand-Model (MI) as TR
> and RT is most intuitive. So my vote goes to MI.
> I'm interested in using the OVMS v1 HW for logging of CAN messages. How to
> pay for postage?
> Regards, Thomas
> mandag 29. april 2013 skrev Mark Webb-Johnson følgende:
>> Thomas,
>> Earlier this year, Matt Beard mentioned he was interested in doing i-Miev
>> support, but I'm not sure of his status. He is on this list, so should see
>> this. There are also several OVMS users who have that car in their stable,
>> so the requirement is definitely there.
>> It is probably worth firstly doing a quick feasibility check, to see what
>> level of OVMS support is possible:
>> Firstly, What are the specs for the CAN bus? What baud rate is it, and
>> what is the connector? There are just three messages that are key to
>> feasibility:
>> 1. SOC - battery state of charge - *car_SOC*
>> 2. Car On/Off (ignition switch, or Park/Drive gear lever) - *car_doors1
>> [bit7]*
>> 3. Car Charging (true or false) - *car_doors1 [bit 4]*
>> If those three are available, and readable by the OVMS hardware, then the
>> project is most likely feasible. There are lots of other parameters (range,
>> temperature, odometer, speed, vin, tpms, etc) that are nice to have, but
>> are either optional (nice-to-have) or can generally be derived from these
>> three key messages - so long as they can be found. For example, on the
>> Volt/Ampera we don't know the detailed charge messages, but do know whether
>> the car is charging or not - we can assume charge interrupted if the charge
>> finishes before 95% complete. Similarly, if the range of the car is XXkm,
>> we can estimate the current range based on XX * SOC%. If the car has no GPS
>> details on the CAN bus, then we can use the GPS in the OVMS module itself.
>> What vehicle two-character abbreviation do you think is suitable: IM or
>> MI? Examples are RT (Renault Twizy), VA (Volt/Ampera), TR (Tesla Roadster).
>> If you can let me have the can bus specs and information on the above 3
>> messages, I will create you a stub vehicle implementation.
>> P.S. With reference to the development guide (
>> https://raw.github.com/markwj/Open-Vehicle-Monitoring-System/master/docs/OVMS_Development.pdf),
>> these are the current set of parameters that OVMS supports.
>> Vehicle Module Development Checklists Development Checklists
>> You can use these checklists to know what vehicle parameters the OVMS
>> system supports, and how you can map a specific vehicle to these.
>> *Parameter*
>> *Purpose*
>> *Vehicle Support Notes*
>> *Vehicle Identification*
>> car_type****
>> Vehicle type identified****
>> car_vin****
>> Vehicle VIN****
>> *Parameter*
>> *Purpose*
>> *GPS Status*****
>> Vehicle GPS****
>> Does the vehicle have a built-in GPS? If so, complete the following.****
>> car_gpslock****
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130915/d1df3950/attachment-0001.html>
