[Ovmsdev] 12V battery alerts
    Rolf Welde Skeie
    rwskeie at gmail.com
    Wed Oct 30 16:52:24 HKT 2013
Somehow I feel a few fingers pointing my way.. :)
I can have a go, but do not have time until sometime next week.
The algorithm I envision goes something like this:
cold_lim = 10; // celcius that is..
batt_diff = 2; // max difference between charged and non-charged
batt_definitely_low = 12;  // definite low level limit
volts_per_degree = 0.05;
// add cold weather component
if (env_temp < cold_lim) {
   batt_diff += (cold_lim - env_temp)*volts_per_degree;
if ((batt_now < batt_definitely_low) || ((batt_charged - batt_now) >
batt_diff))) {
   alarm_low();
} else {
   alarm_cleared();
Any thoughts?
Actually we should probably look at the server logs and create some
statistics to measured correlated 'batt_now' and 'env_temp' to properly
calibrate 'volts_per_degree'. Also look at peak highs and lows to see
how the batteries out there are performing :)
Regards
   Rolf
On 10/30/2013 12:54 AM, Mark Webb-Johnson wrote:
> Can someone try it at 2.0V (rather than 1.5V) and see if it solves the false-alerts problem?
> On 29 Oct, 2013, at 5:10 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
>> Ok, it seems like a few have similar issues.
>> The logic behind the calculations seems to be reasonable, it is the assumption that there is a 1.5V difference between charging/non-charging state which is not generally applicable.
>>  From my observations it seems like increasing this to 2.0V would take care of most mis-firing events.?..
>> Disclaimer: I'm not an expert on batteries...
>> Running on 2.5.5 experimental/TC
>> Rolf
>> On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
>>> Yup, I also get this message and it would be great if it were working
>>> properly, but it actually fires at 13.1V which is far too high.
>>> Matt
>>> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
>>> <mailto:rwskeie at gmail.com>> wrote:
>>>     I have the following features set:
>>>     #0=1, #8=1, #9=1, #15=1, all others =0.
>>>     Can't remember which one made it work, but one of them did, my guess
>>>     would be #9 :)
>>>     Rolf
>>>     On 10/29/2013 09:38 AM, Håkon Markussen wrote:
>>>         I never get this alert.
>>>         I have a Think City (as Rolf Skeie) and use the iOS-app.
>>>         I have tested on both an exhausted aux-battery and on a brand new
>>>         battery in perfect condition.
>>>         Br.
>>>         Håkon
>>>         2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
>>>         <mailto:thomas.bergo at gmail.com>
>>>         <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>__>>
>>>              I'm also get this alert.
>>>              Regard, Thomas
>>>              tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
>>>                  Hi,
>>>                  I'm getting 12V battery alerts ala:
>>>                  "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V, ref=14.7V)"
>>>                  So the 1.5V hardcoded difference between charged and
>>>         non-charged
>>>                  state seems to be too low. The battery is working just
>>>         fine and
>>>                  has been tested without any issues, but seems to
>>>         stabilize at
>>>                  approx. 12.8V.
>>>                  Is this a global issue; are others experiencing this as
>>>         well?
>>>                  If this is a issue only relevant to my car: would it
>>>         make sense
>>>                  to allow for controlling some of these kind of values
>>>         through
>>>                  parameters?
>>>                  BTW, I believe the Think City module could be put in the
>>>                  production builds, it seems to be working fine.
>>>                  Best regards
>>>                  Rolf Welde Skeie
>>>                  Solåsen 27, 5223 Nesttun, Norway
>>>         +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
>>>         rwskeie at gmail.com <mailto:rwskeie at gmail.com>
>>>                  ___________________________________________________
>>>                  OvmsDev mailing list
>>>         OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>         http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
>>>         <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
>>>         <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
>>>         <mailto:OvmsDev at lists.__teslaclub.hk
>>>         <mailto:OvmsDev at lists.teslaclub.hk>>
>>>     Rolf Welde Skeie
>>>     +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
>> Rolf Welde Skeie
>> +47 92403016 / rwskeie at gmail.com
Rolf Welde Skeie
