[Ovmsdev] How to remove temperatures from app?
    Rolf Welde Skeie
    rwskeie at gmail.com
    Wed Oct 30 16:22:57 HKT 2013
Darn, now the ball is back in my yard... ;)
I'll try to cook up some JS code to utilize this..
Brilliant Mark, thanks!
Rolf
On 10/30/2013 01:04 AM, Mark Webb-Johnson wrote:
> Rolf,
> The thing about good ideas... They get prioritised!
> (and great ideas get done even quicker)
> Try:
>     curl -v -X GET -c cookiejar
>     'http://tmc.openvehicles.com:6868/api/cookie?username=USERNAME&password=PASSWORD'
>     curl -v -X GET -b cookiejar
>     'http://tmc.openvehicles.com:6868/api/historical/VEHICLEID/*-OVM-ServerLogs'
> Retention period is configurable on the server. TMC server is currently
> set to 2 days. I'm not logging everything at the moment, but the core
> protocol messages from the car and apps, as well as major events, are
> logged.
> On 29 Oct, 2013, at 5:51 pm, Rolf Welde Skeie <rwskeie at gmail.com
> <mailto:rwskeie at gmail.com>> wrote:
>> Do I have to run my own server to get these kind of logs?
>> These are output from perl scripts dumping mysql info?
>> Would be brilliant if we could authenticate and get this in a simple
>> JSON format via the existing server..
>> Rolf
>> On 10/29/2013 07:46 AM, Mark Webb-Johnson wrote:
>>> Thomas,
>>> Logs for the past 24 hours:
>>>    2013-10-28 02:01:37.789458 -0400 info  main: #94 C NO1597 rx msg D
>>>    92,0,0,10,11,9,0,142698,0,32341,-127,1,60,-1,14.1,0,0.0,16
>>>    2013-10-28 02:08:08.103328 -0400 info  main: #94 C NO1597 rx msg D
>>>    92,0,0,11,12,9,0,142698,0,32733,-127,1,60,-1,14.1,0,0.0,16
>>>    2013-10-28 02:11:42.434139 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,11,25,9,0,142698,9,0,-127,1,60,-1,14.1,0,0.0,0
>>>    2013-10-28 02:12:26.919845 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,11,25,9,0,142698,53,0,-127,1,60,-1,14.1,0,0.0,0
>>>    2013-10-28 02:12:45.456334 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,11,25,9,0,142698,60,0,-127,1,60,-1,14.1,0,0.0,0
>>>    2013-10-28 02:21:44.364167 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,47,9,0,142723,70,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:25:32.903433 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,29,10,0,142754,71,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:25:46.520334 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,29,10,0,142754,61,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:26:47.982158 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,14,15,10,0,142754,0,20,-127,1,60,-1,14.0,0,0.1,0
>>>    2013-10-28 02:27:21.460335 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,13,15,10,0,142754,0,51,-127,1,60,-1,14.0,0,0.1,0
>>>    2013-10-28 02:27:52.930666 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,13,16,10,0,142754,0,80,-127,1,60,-1,14.0,0,0.2,0
>>>    2013-10-28 02:28:52.183727 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,18,10,0,142754,18,0,-127,1,60,-1,14.0,0,0.2,0
>>>    2013-10-28 02:28:55.788600 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,18,10,0,142754,20,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:29:57.449858 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,22,10,0,142760,10,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:30:08.700287 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,13,20,10,0,142760,0,1,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 02:56:13.505716 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,12,13,9,0,142760,0,1570,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 02:56:35.905548 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,12,13,9,0,142760,0,1591,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 02:56:59.381402 -0400 info  main: #94 C NO1597 rx msg D
>>>    64,0,0,12,13,9,0,142760,0,1612,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 02:57:08.861660 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,12,13,9,0,142760,0,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 02:58:04.260598 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,12,31,10,0,142760,45,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 02:59:06.582665 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,12,29,10,0,142760,20,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:00:07.822062 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,21,10,0,142766,71,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:01:09.182873 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,21,10,0,142772,68,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:02:52.403081 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,26,10,0,142785,76,0,-127,1,60,-1,13.9,0,12.6,0
>>>    2013-10-28 03:09:33.833266 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,12,28,11,0,142828,23,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:09:53.354538 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,12,28,11,0,142828,20,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:10:54.903897 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,13,34,11,0,142828,12,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:11:56.574191 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,16,25,11,0,142828,16,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:12:56.994019 -0400 info  main: #94 C NO1597 rx msg D
>>>    128,0,0,14,21,11,0,142835,6,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:14:08.212271 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,14,24,11,0,142835,16,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 03:34:04.973814 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,17,32,11,0,142866,30,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 04:13:58.010509 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,1875,-127,0,0,-1,12.6,0,12.6,0
>>>    2013-10-28 05:13:46.798825 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,5475,-127,0,0,-1,12.5,0,12.6,0
>>>    2013-10-28 05:44:24.494621 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,7318,-127,0,0,-1,12.5,0,12.6,0
>>>    2013-10-28 05:44:43.927915 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,7335,-127,0,0,-1,12.5,0,12.6,0
>>>    2013-10-28 06:13:38.127476 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,9075,-127,0,0,-1,12.4,0,12.6,0
>>>    2013-10-28 07:06:51.650353 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,12279,-127,0,0,-1,12.4,0,12.6,0
>>>    2013-10-28 07:13:27.418850 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,12675,-127,0,0,-1,12.4,0,12.6,0
>>>    2013-10-28 08:13:16.010617 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,16275,-127,0,0,-1,12.4,0,12.6,0
>>>    2013-10-28 09:13:04.102502 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,19875,-127,0,0,-1,12.4,0,12.6,0
>>>    2013-10-28 10:12:52.439569 -0400 info  main: #66 C NO1597 rx msg D
>>>    64,0,0,18,30,12,0,142890,0,23475,-127,0,0,-1,12.3,0,12.6,0
>>>    2013-10-28 10:20:41.493072 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,14,24,12,0,142890,23,0,-127,1,60,-1,13.2,0,12.6,0
>>>    2013-10-28 10:20:53.909454 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,14,29,12,0,142890,17,0,-127,1,60,-1,13.7,0,12.6,0
>>>    2013-10-28 10:21:55.622992 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,14,31,12,0,142897,22,0,-127,1,60,-1,13.9,0,12.6,0
>>>    2013-10-28 10:22:57.222058 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,14,35,12,0,142897,35,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:23:58.908252 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,15,26,13,0,142903,56,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:25:00.464144 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,15,27,13,0,142909,44,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:29:34.345650 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,16,39,13,0,142915,43,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:30:02.062238 -0400 info  main: #66 C NO1597 rx msg D
>>>    128,0,0,16,35,13,0,142922,24,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:33:02.483345 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,18,40,13,0,142922,46,0,-127,1,60,-1,13.9,0,12.6,0
>>>    2013-10-28 10:33:35.944363 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,19,37,13,0,142922,0,0,-127,1,60,-1,13.9,0,12.6,0
>>>    2013-10-28 10:34:07.782275 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,20,40,13,0,142928,50,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:35:07.245676 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,20,42,13,0,142928,6,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:36:08.816298 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,18,30,13,0,142934,32,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:37:10.473768 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,19,36,13,0,142934,45,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:38:12.074445 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,19,35,13,0,142934,3,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:40:52.943180 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,19,33,13,0,142946,10,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:43:13.235572 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,20,44,13,0,142946,24,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 10:53:11.563699 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,18,28,13,0,142996,69,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:33:04.440903 -0400 info  main: #55 C NO1597 rx msg D
>>>    64,0,0,16,19,13,0,143040,0,52,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:37:12.049751 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,41,14,0,143052,66,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:38:07.866655 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,17,38,14,0,143058,71,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:39:08.104809 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,18,38,14,0,143064,64,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:40:09.749288 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,28,14,0,143071,24,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:41:11.086759 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,29,14,0,143077,53,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:42:12.751231 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,34,14,0,143077,59,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:43:14.287137 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,18,32,14,0,143083,44,0,-127,1,60,-1,14.0,0,12.6,0
>>>    2013-10-28 11:44:15.966778 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,17,22,14,0,143089,0,0,-127,1,60,-1,13.4,0,12.6,0
>>>    2013-10-28 11:45:17.261018 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.9,0,12.6,0
>>>    2013-10-28 11:46:18.603295 -0400 info  main: #55 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.7,0,12.6,0
>>>    2013-10-28 11:47:19.642043 -0400 info  main: #35 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.6,0,12.6,0
>>>    2013-10-28 12:19:15.231832 -0400 info  main: #35 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.5,0,12.6,0
>>>    2013-10-28 12:25:26.110217 -0400 info  main: #35 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.2,0,12.6,0
>>>    2013-10-28 12:31:36.778275 -0400 info  main: #35 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.4,0,12.6,0
>>>    2013-10-28 12:34:47.477545 -0400 info  main: #35 C NO1597 rx msg D
>>>    128,0,0,16,21,14,0,143089,0,0,-127,1,0,-1,12.0,0,12.6,0
>>>    2013-10-28 12:40:44.320436 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,16,25,14,0,143102,64,0,-127,1,60,-1,13.9,0,12.6,0
>>>    2013-10-28 13:30:38.057867 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,18,19,13,0,143120,0,1848,-127,1,60,-1,13.3,0,0.0,16
>>>    2013-10-28 13:40:36.395565 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,18,19,14,0,143120,0,2448,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 13:50:34.603549 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,20,21,14,0,143120,0,3048,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:00:32.914930 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,22,22,14,0,143120,0,3648,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:10:31.229113 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,23,24,14,0,143120,0,4248,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:20:29.581578 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,24,25,15,0,143120,0,4848,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:30:27.792639 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,25,25,15,0,143120,0,5448,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:40:26.466264 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,25,26,15,0,143120,0,6048,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 14:50:24.596817 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,26,26,15,0,143120,0,6648,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:00:23.005242 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,27,27,15,0,143120,0,7248,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:10:21.099014 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,27,27,15,0,143120,0,7848,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:20:19.514800 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,27,28,16,0,143120,0,8448,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:30:17.844274 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,16,0,143120,0,9048,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:40:16.234939 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143120,0,9648,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 15:41:19.680458 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,27,36,16,0,143120,15,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 15:41:24.497559 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,27,47,16,0,143127,26,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 15:42:25.977341 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,58,16,0,143127,54,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-28 15:44:45.245261 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,26,29,16,0,143139,0,20,-127,1,60,-1,13.9,0,0.0,0
>>>    2013-10-28 15:44:49.112265 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,27,28,16,0,143139,0,21,-127,1,60,-1,13.9,0,0.0,0
>>>    2013-10-28 15:44:59.611737 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,27,29,16,0,143139,0,29,-127,1,60,-1,13.9,0,0.1,0
>>>    2013-10-28 15:45:35.950416 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,41,16,0,143139,0,0,-127,1,60,-1,13.9,0,0.1,0
>>>    2013-10-28 15:45:49.288738 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,36,16,0,143139,0,0,-127,1,60,-1,13.9,0,0.1,0
>>>    2013-10-28 15:46:26.713502 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,50,16,0,143139,21,0,-127,1,60,-1,13.8,0,0.0,0
>>>    2013-10-28 15:47:09.413151 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,46,16,0,143139,19,0,-127,1,60,-1,13.9,0,0.0,0
>>>    2013-10-28 15:47:16.747566 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,26,43,16,0,143139,0,1,-127,1,60,-1,13.9,0,0.0,0
>>>    2013-10-28 15:48:14.909097 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,26,42,16,0,143139,0,56,-127,1,0,-1,13.3,0,0.1,0
>>>    2013-10-28 15:48:35.203613 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,26,42,16,0,143139,0,75,-127,1,0,-1,13.0,0,0.2,0
>>>    2013-10-28 15:48:37.445275 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,26,42,16,0,143139,0,77,-127,1,0,-1,13.0,0,0.2,0
>>>    2013-10-28 16:04:35.190522 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,26,42,16,0,143151,60,0,-127,1,60,-1,13.8,0,1.5,0
>>>    2013-10-28 16:07:50.450057 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,24,28,16,0,143158,0,91,-127,1,60,-1,13.6,0,0.0,16
>>>    2013-10-28 16:14:37.841022 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,25,25,16,0,143158,0,499,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:20:26.961611 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,26,26,16,0,143158,0,849,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:20:39.561686 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,26,26,16,0,143158,0,859,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:21:40.877249 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,25,26,16,0,143158,0,919,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:24:41.073798 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,26,26,16,0,143158,0,1099,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:31:14.777641 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,26,27,17,0,143158,0,1494,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:34:40.207942 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,27,27,17,0,143158,0,1699,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:44:38.537636 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143158,0,2299,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 16:54:36.809205 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143158,0,2899,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:04:35.143908 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143158,0,3499,-127,1,60,-1,14.0,0,0.3,0
>>>    2013-10-28 17:14:33.552575 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143158,0,4099,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:24:31.804373 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,29,17,0,143158,0,4699,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:29:07.866159 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,29,17,0,143158,0,4976,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:29:33.582180 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,29,17,0,143158,0,4999,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:34:33.218400 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,29,29,17,0,143158,0,5299,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:38:18.739655 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,30,30,17,0,143158,0,5525,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:38:35.294759 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,29,29,17,0,143158,0,5539,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:44:34.751786 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,29,29,17,0,143158,0,5899,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 17:54:33.142458 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,30,30,17,0,143158,0,6499,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:04:31.495579 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,30,30,17,0,143158,0,7099,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:14:29.651669 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,30,30,17,0,143158,0,7699,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:24:28.145272 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,31,31,17,0,143158,0,8299,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:34:26.492196 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,31,31,18,0,143158,0,8899,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:44:24.743884 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,30,30,17,0,143158,0,9499,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 18:54:22.954240 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,29,29,17,0,143158,0,10099,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 19:04:21.368906 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,29,29,17,0,143158,0,10699,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 19:14:19.678499 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,28,28,17,0,143158,0,11299,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 19:24:18.051337 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,27,27,17,0,143158,0,11899,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 19:34:16.424640 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,25,26,17,0,143158,0,12499,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-28 20:04:16.495625 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,14299,-127,0,0,-1,12.6,0,12.7,0
>>>    2013-10-28 21:04:04.351233 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,17899,-127,0,0,-1,12.6,0,12.7,0
>>>    2013-10-28 22:03:53.329866 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,21499,-127,0,0,-1,12.5,0,12.7,0
>>>    2013-10-28 23:03:41.912844 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,25099,-127,0,0,-1,12.5,0,12.7,0
>>>    2013-10-29 00:03:30.467621 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,28699,-127,0,0,-1,12.4,0,12.7,0
>>>    2013-10-29 01:03:18.697335 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,25,25,17,0,143158,0,32299,-127,0,0,-1,12.4,0,12.7,0
>>>    2013-10-29 01:43:14.287179 -0400 info  main: #21 C NO1597 rx msg D
>>>    92,0,0,11,12,13,0,143158,0,34699,-127,1,60,-1,14.0,0,0.0,16
>>>    2013-10-29 01:53:18.231583 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,13,38,13,0,143189,72,0,-127,1,60,-1,14.0,0,0.0,0
>>>    2013-10-29 02:03:16.584934 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,242,-127,0,0,-1,12.9,0,0.5,0
>>>    2013-10-29 02:15:58.041642 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,1006,-127,0,0,-1,12.7,0,12.7,0
>>>    2013-10-29 02:16:16.658637 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,1022,-127,0,0,-1,12.7,0,12.7,0
>>>    2013-10-29 02:20:01.677284 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,1248,-127,0,0,-1,12.7,0,12.7,0
>>>    2013-10-29 02:20:18.191610 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,1262,-127,0,0,-1,12.7,0,12.7,0
>>>    2013-10-29 02:23:23.066029 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,14,17,13,0,143220,0,1444,-127,0,0,-1,12.7,0,12.7,0
>>>    2013-10-29 02:24:17.179677 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,12,14,13,0,143220,0,1498,-127,1,60,-1,12.7,0,12.7,0
>>>    2013-10-29 02:24:23.876393 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,12,14,13,0,143220,0,1502,-127,1,60,-1,13.4,0,12.7,0
>>>    2013-10-29 02:25:08.738714 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,12,14,13,0,143220,0,1547,-127,1,60,-1,13.4,0,12.7,0
>>>    2013-10-29 02:25:28.134283 -0400 info  main: #21 C NO1597 rx msg D
>>>    64,0,0,12,14,13,0,143220,0,1562,-127,1,60,-1,13.8,0,12.7,0
>>>    2013-10-29 02:26:13.356853 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,12,22,13,0,143220,49,0,-127,1,60,-1,13.8,0,12.7,0
>>>    2013-10-29 02:30:20.574366 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,13,27,13,0,143238,73,0,-127,1,60,-1,14.0,0,12.7,0
>>>    2013-10-29 02:30:31.569144 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,13,28,13,0,143245,73,0,-127,1,60,-1,14.0,0,12.7,0
>>>    2013-10-29 02:31:33.229855 -0400 info  main: #21 C NO1597 rx msg D
>>>    128,0,0,13,19,13,0,143251,70,0,-127,1,60,-1,14.0,0,12.7,0
>>> Comma-separated fields (after " D ") are:
>>>    car_doors1, car_doors2, car_lockstate, car_tpem, car_tmotor,
>>>    car_tbattery, car_trip, car_odometer, car_speed, park,
>>>    car_ambient_temp, car_doors3, car_stale_temps, car_stale_ambient,
>>>    car_12vline, car_doors4, car_12vline_ref, car_doors5
>>> Looks like car_stale_ambient is always -1, but car_stale_temps is 60
>>> or 0.
>>> Can you also try to set car_doors3bits.CoolingPump=1 in your car module
>>> when the temperatures are not stale (and =0 when stale)? I think the
>>> apps still require that (for backwards compatibility) - but I can remove
>>> that check in the Apps for the next update as it is not really required
>>> any more.
>>> On 29 Oct, 2013, at 2:29 pm, Thomas Bergo <thomas.bergo at gmail.com
>>> <mailto:thomas.bergo at gmail.com>
>>> <mailto:thomas.bergo at gmail.com>> wrote:
>>>> Mark
>>>> I'm using 64.111.70.40 server in my configuration. I belive this is
>>>> the same server?
>>>> My vehicle id is NO1597
>>>> Regards, Thomas
>>>> tirsdag 29. oktober 2013 skrev Mark Webb-Johnson følgende:
>>>>    Thomas,
>>>>    That should be all.
>>>>    Are you using the tmc.openvehicles.com <http://tmc.openvehicles.com>
>>>>    <http://tmc.openvehicles.com/> server? If so, what is your vehicle
>>>>    id? I will look at the logs.
>>>>    Regards, Mark.
>>>>    On 29 Oct, 2013, at 2:15 pm, Thomas Bergo <thomas.bergo at gmail.com
>>>>    wrote:
>>>>>    The temperatures are always light gray on my iPhone!? The stale
>>>>>    timer is updated on temperature read and decried every second.
>>>>>    Are there more that needs to be done to update the stale status?
>>>>>    Regards, Thomas
>>>>>    mandag 28. oktober 2013 skrev Mark Webb-Johnson følgende:
>>>>>        Should be light gray if they are stale, bright white if ok.
>>>>>        Regards, Mark
>>>>>        On 28 Oct, 2013, at 5:55 pm, Thomas Bergo
>>>>>        <thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>> wrote:
>>>>>>        Mark,
>>>>>>        The code is implemented as your example, so the temperatures
>>>>>>        will be indicated as stale by the code.
>>>>>>        Is there a visual indication in the app to show that the
>>>>>>        temperature are updated or stale? Now the app show the last
>>>>>>        temperature before the car was parked/stop charging.
>>>>>>        Regards, Thomas
>>>>>>        2013/10/24 Mark Webb-Johnson <mark at webb-johnson.net
>>>>>> <mailto:mark at webb-johnson.net>>
>>>>>>            Matt,
>>>>>>>            In the iMiev, the CAN bus stops when the car is parked
>>>>>>>            and not charging, which means that the temperatures go
>>>>>>>            stale.
>>>>>>>            I want to flag this to the app, but I'm not sure how to
>>>>>>>            do that. I assumed that setting them back to their
>>>>>>>            "default" state would return the app to displaying "-"
>>>>>>            Use:
>>>>>>                ovms.{h,c}:
>>>>>>                  signed char car_stale_ambient; // 0 = Ambient
>>>>>>                temperature is stale
>>>>>>                  signed char car_stale_temps; // 0 = Powertrain
>>>>>>                temperatures are stale
>>>>>>            Most common method is that every time you receive a CAN
>>>>>>            bus message with the temps (motor, pem, battery), set
>>>>>>            car_stale_temps=60 (or car_stale_ambient=60 for ambient).
>>>>>>            Then, in your one-second-ticker function, just:
>>>>>>                if (car_stale_ambient>0) car_stale_ambient--;
>>>>>>                if (car_stale_temps>0) car_stale_temps--;
>>>>>>            That will automatically signal them as stale after 60
>>>>>>            seconds of no update.
>>>>>>>            P.S. Now we have iMiev support (although a bit beta)
>>>>>>>            and are about to get Leaf support - when do we get
>>>>>>>            these car picture in the app? ;-)
>>>>>>            Can you hold a few weeks for this? I am working on the
>>>>>>            Apps to re-work how we do the vehicle images. They are
>>>>>>            just too large (13MB+ already!), so I am working on a
>>>>>>            better way of handling the multiple colours and making
>>>>>>            it easier to add them to the Apps. Once I have this
>>>>>>            working, I'll let you know what format we need the
>>>>>>            images in.
>>>>>>            Regards, Mark.
>>>>>>            On 23 Oct, 2013, at 11:48 pm, Matt Beard <matt at beard.tv
>>>>>> <mailto:matt at beard.tv>>
>>>>>>>            stale.
>>>>>>>            This doesn't seem to work. Should it?
>>>>>>>            Matt Beard
>>>>>>>            _______________________________________________
>>>>>>>            OvmsDev mailing list
>>>>>>> OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>>>>>        <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
>> Rolf Welde Skeie
>> Solåsen 27, 5223 Nesttun, Norway
>> +47 92403016 / rwskeie at gmail.com <mailto:rwskeie at gmail.com>
Rolf Welde Skeie
