[Ovmsdev] OVMS Leaf Support
Matt Beard
matt at beard.tv
Wed Oct 23 13:34:08 HKT 2013
I use a PICKIT2 and have had no issues programming the V2 board. Maybe you
have a faulty unit, or your USB port can't supply the required power.
Matt
On Wednesday, October 23, 2013, Mark Webb-Johnson wrote:
> Tom,
> Strange. I checked a few PICKIT2 I have, and they all work. For my
> original testing, I tried two eBay clones, two fasttech ones, and two
> little Malaysian thumb-drive sized ones - all were ok.
> The OVMS board does have a fairly large modem, which complicates things.
> Maybe just not enough power?
> Can you try to press the little modem power button on the motherboard, to
> shut down the modem? See if that makes a difference.
> On 23 Oct, 2013, at 5:29 am, Tom Saxton <tom at idleloop.com> wrote:
> I'm not able to program the V2 board with the PICkit2 unless the board
> plugged into the car to get 12V power, so I'd recommend the PICKit3, which
> I'm assuming doesn't have this issue.
> I need to either build a cable to power the OVMS from a power supply or
> order the PICKit3 from Fasttech. For now, my laptop is living in the
> Roadster's passenger seat while I've been doing some work on the charge
> time predictor.
> Tom
> Date: Monday, October 21, 2013 11:42 PM
> Subject: Re: [Ovmsdev] OVMS Leaf Support
> Rob,
> If you are not developing code then a PICKIT2 is easier.
> The original is here:
> http://www.amazon.co.uk/Microchip-PG164120-Programmer-Pickit-2/dp/B0040ZRGCQ/ref=sr_1_4?s=electronics&ie=UTF8&qid=1382423740&sr=1-4&keywords=pickit2
> but as it is 'open source', there are lots of much cheaper clones. For
> example:
> http://www.fasttech.com/products/0/10000018/1002200-pickit-2-compatible-programmerdebugger
> Personally, I'd go with the clone.
> On 22 Oct, 2013, at 2:32 pm, Robert Sharpe <
> robert.sharpe at evergreen-consulting.co.uk> wrote:
> Hi Mark,
> Wow great work.
> For me my current status is
> Good and frequent access to a Nissan Leaf - YES
> RS232-to-USB adaptor and laptop (or laptop with RS232 port) - YES
> OVMS v2 Module - Accepted Kevin's offer of h/w waiting for delivery
> OVMS v2 OBD-II cable - Accepted Kevin's offer of h/w waiting for delivery
> PICKIT2 or PICKIT3 programmer - Will order one today (any suggestions to a
> good source?)
> Rob
> ---- On Tue, 22 Oct 2013 02:11:52 +0100 *Mark Webb-Johnson<
> mark at webb-johnson.net>* wrote ----
> OK, here's an update...
> I went through the logs we captured, and had a look at Leaf Spy. I even
> purchased a copy of Leaf Spy Pro (even though I don't have a Leaf) just as
> a donation to say thank you to Turbo3 for pushing this approach and working
> out so much of the mechanics of it.
> I spent an evening reading thro
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131023/d79e2f1d/attachment.htm>
