[Ovmsdev] OVMS Leaf Support
    Robert Sharpe
    robert.sharpe at evergreen-consulting.co.uk
    Mon Oct 14 22:01:15 HKT 2013
Hi Kevin,Thanks a lot for your kind offer.I should set expectations that I am an out of practice and slow coder, but I will do what I can to help.  I can probably help more with test, debug and coordination.So if you are still happy then, as I dont have any OVMS kit, I will need an OVMS and correct cable.Can someone point me to a developer beginner's instructions for what else is required to develop/test, e.g. programmer, sniffer, code repository login, CM procedures, etcIt helps me, and hopefully anyone else working on the project, if we can agree the breakdown of work.  As you may have already seen I have suggested a post for the Leaf development at http://www.openvehicles.com/node/111 Nikki/Mark shall we use that as a way of planning and tracking the work ?Regards,RobOn Oct 14, 2013, at 2.21PM, Nikki Gordon-Bloomfield wrote:Hi Kevin, That's very generous. Happy to test OVMS in my LEAF, so I guess another OVMS kit with a righty cable? Nikki. On 14 Oct 2013, at 13:47, Kevin Sharpe ZCW kevin.sharpe at zerocarbonworld.org> wrote:
Rob, Mark (C), Nikki,
If it helps, I'm happy to provide each of you with OVMS hardware FOC in return for your efforts on the Leaf development :-)
Let me know what you need,
Kevin Sharpe | Founder & Patron
Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
kevin.sharpe at zerocarbonworld.org | www.zerocarbonworld.org | twitter.com/zerocarbonworld
Zero Carbon World is a UK Registered Charity #1141347
From: Robert Sharpe robert.sharpe at evergreen-consulting.co.uk>
Reply-To: OVMS Developers ovmsdev at lists.teslaclub.hk>
Date: Monday, 14 October 2013 13:41
Subject: Re: [Ovmsdev] OVMS Leaf Support
Hi Mark,
This looks very interesting.
I am out today but will look in more depth tomorrow.
Rob
---- On Mon, 14 Oct 2013 10:08:41 +0100 Mark Webb-Johnson mark at webb-johnson.net> wrote ----
I think the leaf spy app shows what can be done. It only uses standard OBDII, with just one can bus. It could also be using the other non-can OBDII buses, but I doubt it.
Shame it is not open source, but the leaf codes are pretty well documented now.
On 14 Oct, 2013, at 4:00 pm, Nikki Gordon-Bloomfield nikki at aminorjourney.com> wrote:
Oh yes, there are multiple CAN busses on the LEAF. The standard one, which is where all the data below comes from, an the EV can -- that would require some clever doodads, since both are on the same physical connector -- just different pins.
Nikki.
On 14 Oct 2013, at 04:50, Mark Webb-Johnson mark at webb-johnson.net> wrote:
Robert,
Sorry for the delay in response - I’ve been off grid parenting for the past 24 hours.
I think @Nufkin has done some preparation work, and we have a stub vehicle support file (vehicle_nissanleaf.c), but nothing working yet.
This App shows what can be done:
https://play.google.com/store/apps/details?id=com.Turbo3.Leaf_Spy_Pro
using just the OBD-II port (I assume all the single master CAN bus, but perhaps also other buses on OBD-II).
I’m very excited by this, and more than willing to help, but I don’t have the car here so am limited in what I can do.
Can you work with @nufkin (and his other half) on this?
You would need some sort of CAN bus decoder (perhaps just an OBD-II dongle, or CAN-USB adaptor), plus an OVMS module and PICKIT for firmware download. If you use MAC OSX, the development environment is simple to setup - for windows there are a few more
 hoops to jump through. Lastly, a RS232-USB adaptor is useful (but not essential).
On 13 Oct, 2013, at 4:00 pm, Robert Sharpe robert.sharpe at evergreen-consulting.co.uk> wrote:
Hi,
ovmsdev-request at lists.teslaclub.hk>
Is anyone working on Leaf support?
I am interested in helping if I can and have started a discussion at http://openvehicles.com/comment/220#comment-220 to capture were we are with the Leaf.
Robert Sharpe (Technical Director)
07711 252971http://www.facebook.com/EvergreenConsultingLtd
http://twitter.com/EGCtechnical
http://uk.linkedin.com/in/arsharpe
www.evergreen-consulting.co.ukYour Plugged-in PartnerSupport the future and switch to a renewable energy supplier such as
Good EnergyEvergreen Consulting is the trading name of Sharpe Consultants Ltd
/ovmsdev-request at lists.teslaclub.hk>_______________________________________________
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
_______________________________________________OvmsDev mailing listOvmsDev at lists.teslaclub.hkhttp://lists.teslaclub.hk/mailman/listinfo/ovmsdev
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131014/9259d41c/attachment.htm>
