[Ovmsdev] 12V battery alerts
Wed Oct 30 07:54:44 HKT 2013
Can someone try it at 2.0V (rather than 1.5V) and see if it solves the false-alerts problem?
On 29 Oct, 2013, at 5:10 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
> Ok, it seems like a few have similar issues.
> The logic behind the calculations seems to be reasonable, it is the assumption that there is a 1.5V difference between charging/non-charging state which is not generally applicable.
> From my observations it seems like increasing this to 2.0V would take care of most mis-firing events.?..
> Disclaimer: I'm not an expert on batteries...
> Running on 2.5.5 experimental/TC
> Rolf
> On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
>> Yup, I also get this message and it would be great if it were working
>> properly, but it actually fires at 13.1V which is far too high.
>> Matt
>> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
>> <mailto:rwskeie at gmail.com>> wrote:
>>    I have the following features set:
>>    #0=1, #8=1, #9=1, #15=1, all others =0.
>>    Can't remember which one made it work, but one of them did, my guess
>>    would be #9 :)
>>    Rolf
>>    On 10/29/2013 09:38 AM, Håkon Markussen wrote:
>>        I never get this alert.
>>        I have a Think City (as Rolf Skeie) and use the iOS-app.
>>        I have tested on both an exhausted aux-battery and on a brand new
>>        battery in perfect condition.
>>        Br.
>>        Håkon
>>        2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
>>        <mailto:thomas.bergo at gmail.com>
>>        <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>__>>
>>             I'm also get this alert.
>>             Regard, Thomas
>>             tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
>>                 Hi,
>>                 I'm getting 12V battery alerts ala:
>>                 "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V, ref=14.7V)"
>>                 So the 1.5V hardcoded difference between charged and
>>        non-charged
>>                 state seems to be too low. The battery is working just
>>        fine and
>>                 has been tested without any issues, but seems to
>>        stabilize at
>>                 approx. 12.8V.
>>                 Is this a global issue; are others experiencing this as
>>        well?
>>                 If this is a issue only relevant to my car: would it
>>        make sense
>>                 to allow for controlling some of these kind of values
>>        through
>>                 parameters?
>>                 BTW, I believe the Think City module could be put in the
>>                 production builds, it seems to be working fine.
>>                 Best regards
>>                 Rolf Welde Skeie
>>                 Solåsen 27, 5223 Nesttun, Norway
>>        +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
>>        rwskeie at gmail.com <mailto:rwskeie at gmail.com>
>>                 ___________________________________________________
>>                 OvmsDev mailing list
>>        OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>>        http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
>>        <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
>>        <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
>>        <mailto:OvmsDev at lists.__teslaclub.hk
>>        <mailto:OvmsDev at lists.teslaclub.hk>>
>>    Rolf Welde Skeie
>>    +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
> Rolf Welde Skeie
> +47 92403016 / rwskeie at gmail.com
