[Ovmsdev] 12V battery alerts
Rolf Welde Skeie rwskeie at gmail.com
Tue Oct 29 17:10:31 HKT 2013
Ok, it seems like a few have similar issues.
The logic behind the calculations seems to be reasonable, it is the
assumption that there is a 1.5V difference between charging/non-charging
state which is not generally applicable.
 From my observations it seems like increasing this to 2.0V would take
care of most mis-firing events.?..
Disclaimer: I'm not an expert on batteries...
Running on 2.5.5 experimental/TC
Rolf
On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
> Yup, I also get this message and it would be great if it were working
> properly, but it actually fires at 13.1V which is far too high.
> Matt
> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
> <mailto:rwskeie at gmail.com>> wrote:
>     I have the following features set:
>     #0=1, #8=1, #9=1, #15=1, all others =0.
>     Can't remember which one made it work, but one of them did, my guess
>     would be #9 :)
>     Rolf
>     On 10/29/2013 09:38 AM, Håkon Markussen wrote:
>         I never get this alert.
>         I have a Think City (as Rolf Skeie) and use the iOS-app.
>         I have tested on both an exhausted aux-battery and on a brand new
>         battery in perfect condition.
>         Br.
>         Håkon
>         2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
>         <mailto:thomas.bergo at gmail.com>
>         <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>__>>
>              I'm also get this alert.
>              Regard, Thomas
>              tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
>                  Hi,
>                  I'm getting 12V battery alerts ala:
>                  "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V, ref=14.7V)"
>                  So the 1.5V hardcoded difference between charged and
>         non-charged
>                  state seems to be too low. The battery is working just
>         fine and
>                  has been tested without any issues, but seems to
>         stabilize at
>                  approx. 12.8V.
>                  Is this a global issue; are others experiencing this as
>         well?
>                  If this is a issue only relevant to my car: would it
>         make sense
>                  to allow for controlling some of these kind of values
>         through
>                  parameters?
>                  BTW, I believe the Think City module could be put in the
>                  production builds, it seems to be working fine.
>                  Best regards
>                  Rolf Welde Skeie
>                  Solåsen 27, 5223 Nesttun, Norway
>         +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
>         rwskeie at gmail.com <mailto:rwskeie at gmail.com>
>                  ___________________________________________________
>                  OvmsDev mailing list
>         OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
>         http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
>         <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
>         <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
>         <mailto:OvmsDev at lists.__teslaclub.hk
>         <mailto:OvmsDev at lists.teslaclub.hk>>
>     Rolf Welde Skeie
>     +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
Rolf Welde Skeie
+47 92403016 / rwskeie at gmail.com
