[Ovmsdev] OVMS Leaf Support
Tue Oct 15 22:03:58 HKT 2013
CarCAN bus is 512kbps on standard OBD-II pins. An OVMS OBD-II cable should be able to connect.
Here are the parameter check lists, for the virtual vehicle.
I’ve filled in what I know, but really am not familiar with the vehicle.
Can someone more knowledgeable go through this, and fill-in / correct where appropriate?
Development Checklists
You can use these checklists to know what vehicle parameters the OVMS system supports, and how you can map a specific vehicle to these.
Parameter
Purpose
Vehicle Support Notes
Vehicle Identification
car_type
Vehicle type identified
 NL
car_vin
Vehicle VIN
OBD-II PID has this, but messy to get
Parameter
Purpose
GPS Status
Vehicle GPS
Does the vehicle have a built-in GPS? If so, complete the following.
 NO. Use OVMS GPS
car_gpslock
Set to record GPS lock
car_stale_gps
Denotes GPS data staleness
car_latitude
Latitude of the vehicle
car_longitude
Longitude of the vehicle
car_direction
Direction of the vehicle
car_altitude
Altitude of the vehicle
Parameter
Purpose
Tire Pressure Monitoring System
TPMS
Does the vehicle have a TPMS? If so, complete the following.
car_stale_tpms
Denotes TPMS data staleness
 OVMS countdown timer on last updated
car_tpms_t
The temperatures of each wheel
car_tpms_p
The pressures of each wheel
 ID 385 (brad370)
Parameter
Purpose
Driving Status
car_doors1 [bit7]
Set if the car ignition is ON
 ID 216? (brad370)
car_speed
The speed of the vehicle
 ID 280 B6,B7 (brad370)
car_trip
The vehicle trip counter
car_odometer
The vehicle odometer
 ID 5C% (CARcan)
Parameter
Purpose
Vehicle Environment
car_stale_ambient
Ambient temperature staleness
car_ambient_temp
Ambient temperature
 ID 510 B8 (CARcan)
car_stale_temps
Other Temperature staleness
car_tpem
Temperature of the PEM
car_tmotor
Temperature of the MOTOR
 ID 551 B1 (brad370)
car_tbattery
Temperature of the BATTERY
car_doors1 [bit 0]
Set if front left door OPEN
 ID 60D (brad370)
car_doors1 [bit 1]
Set if front right door OPEN
 ID 60D (brad370)
car_doors2 [bit 6]
Set if bonnet is OPEN
car_doors2 [bit 7]
Set if trunk is OPEN
 ID 60D (brad370)
car_doors1 [bit 2]
Set if charge port is OPEN
car_doors1 [bit 6]
Set if handbrake is ON
car_doors2 [bit 5]
Set if headlights ON
 ID 358 B8 (brad370)
car_doors3 [bit 1]
Set if vehicle is AWAKE (or if not supported just follow ignition)
car_doors2 [bit 4]
Set if valet mode is ENABLED
car_doors2 [bit 3]
Set if vehicle is LOCKED
 ID 60D (driver+passenger door)
car_lockstate
4=locked, 5=unlocked (deprecated)
car_doors4 [bit 2]
Set if alarm SOUNDING
car_time
Time (in seconds)
 internal OVMS counter
car_parktime
Time (seconds) vehicle parked
 count based on ignition state
Parameter
Purpose
Battery Status
car_SOC
State of charge percentage
 ID 5B3 contains SOH and Gids, but how to convert to SOC%?
car_idealrange
Ideal range
car_estrange
Estimated range
car_cac100
Calculated Amp Hour capacity
  ID 5B3 contains SOH and Gids, but how to convert to CAC?
Parameter
Purpose
Charging Status
car_doors1 [bit 3]
Set if pilot signal ON
car_doors1 [bit 4]
Set if vehicle CHARGING
car_linevoltage
Line voltage while charging
car_chargecurrent
Line current while charging
car_chargemode
Vehicle Mode
car_chargestate
Charging state
car_chargesubstate
Charging sub-state
car_chargelimit
Charge current limit
car_chargeduration
Charge duration (minutes)
car_chargekwh
Charge kWh put into battery
car_chargefull_minsremaining
Mins remaining for full charge
car_chargelimit_minsremaining
Mins remaining for limited charge
car_chargelimit_rangelimit
Desired range for limited charge
car_chargelimit_soclimit
Desired SOC% for limited charge
car_stale_timer
Charge timer staleness
car_timermode
Charge timer mode
car_timerstart
Charge timer schedule
On 15 Oct, 2013, at 1:00 pm, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Barry,
> Thanks for the history. I really think we can get what we need from the single car CAN bus.
> I'll extract the relevant sections from the developers guide tonight, and post them here. The first step is to see which of those 'virtual car' pieces of information are available on the car CAN bus, and see if they match-up.
> I really would like to see a dump (and dump) of the car CAN bus, as well as a trace from the leaf spy program. The captioned google docs spreadsheet for leaf can bus messages is quite confusing - it would be good to be able to compare that against what is actually seen on the bus.
> P.S. I'm trying to find a friendly Leaf owner in Hong Kong to co-operate with this. There are 200+ Leafs here, and no carwings coverage at all, but most are in government service and relatively few in private hands.
> On 15 Oct, 2013, at 11:45 am, Barry Gershenfeld <gbarry42 at gmail.com> wrote:
>> Early development assumed you had to get the EV info from the EV-CAN buss.  Somewhere during the development of Leaf Spy they kept finding desirable info on the car-CAN buss and so eventually determined that all if could be gotten from the car-CAN.  As a bonus, the ELM dongle no longer has to be modified to read the EV buss.
>> The original reporting efforts started with the "GID" meter, and the early work involved Gary G. building a data recorder as well as a program to analyze the logs.  I'm sure that's precisely what you have in mind as well.  There were downloadable logs--he invited others to install the analyzer and try to find meaningful messages therein.  But as it was early development, they were probably gotten from the EV-CAN.  I don't know if any more recent logs from the car CAN buss are posted.
>> As a matter of fact, I suspect Gary would be happy to have his analyzing program used.  It would be nice output the data into the same format that it uses.  Or at least write a converter.
>> I naturally have some interest, being a LEAF owner and PIC hacker.  I'll see if I can make head or tail of the developer's guide.
>> On Mon, Oct 14, 2013 at 7:04 PM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
>> Developers guide is here:
>> https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf?raw=true
>> I would rather the actual development discussions take place here on this list. A lot of smart people here, with experience getting these vehicle modules working.
>> The biggest concern for me is whether we can get everything we need off one CAN bus...
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131015/b37e98d7/attachment-0001.html>
