[Ovmsdev] 12V battery alerts
Thu Nov 14 16:43:44 HKT 2013
Håkon,
Thanks for your work on this. Most helpful.
I have broken vehicle.{h,c} at the moment, trying to get the OBDII polling stuff working. I'll merge your changes in later this week.
P.S. Who'd have guessed that "+" has higher precedence than "<<", and that I'd waste 3 nights of my life chasing down a stack corruption in an interrupt handler :-(
On 14 Nov, 2013, at 4:39 pm, Håkon Markussen <hakon.markussen at gmail.com> wrote:
> Testing of false 12V alerts was successfully. No false notifications has arrived from my Think City.
> The conclusion is that car_doors1bits.CarON and car_doors5bits.Charging12V have to be correctly sett according to the 12V-battery charging state and car-state (in the vehicle-specific file).
> No changes have to be made at net.c (car_12vline_ref -15).
> Br.
> Håkon
> 2013/11/13 Håkon Markussen <hakon.markussen at gmail.com>
> I have now rolled back locally the net.c to «car_12vline_ref - 15» and added
> car_doors1bits.CarON = 0;
> car_doors5bits.Charging12V = 0;
> to vehicle_thinkcity.c when:
> - discharge is not allowed AND charge is not enabled
> In addition to car_doors5bits.Charging12V = 1;  when:
>  - charge is enabled
>  - End of Charge is detected AND plug is attached
> Some quick tests gives positive result that no 12V Critical Alert is send.
> I’ll keep you posted.
> Br.
> Håkon
> 13. nov. 2013 kl. 08:51 skrev Håkon Markussen <hakon.markussen at gmail.com>:
> False 12V alerts disappeared when triggering alert from ref - 2,0V.
>     // Trigger 12V alert if voltage <= ref - 1.5 V:
>     if (!(can_minSOCnotified & CAN_MINSOC_ALERT_12V)
>             && (car_12vline <= (car_12vline_ref - 20)))
>       can_minSOCnotified |= CAN_MINSOC_ALERT_12V;
>       net_req_notification(NET_
> NOTIFY_12VLOW);
> Br.
> Håkon
> 2013/11/12 Håkon Markussen <hakon.markussen at gmail.com>
> When setting Notifications (parameter #3) to "IP" or "SMSIP" I finally receive alerts - including Minimum SOC (feature #9) ;)
> The 12V Critical Alert triggers quite often, even if my 12V-battery is new and in top condition.
> I've measured that the car_12vline reports ~0,5V less than the real battery voltage, so I plan to change the file net.c (line 1458) from:
>             && (car_12vline <= (car_12vline_ref - 15)))
>       net_req_notification(NET_NOTIFY_12VLOW);
> to:
> and compile it to a local hex-build and test in on my Think City.
> Keep you posted about the result.
> Best regards.
> Håkon
> 2013/10/30 Mark Webb-Johnson <mark at webb-johnson.net>
> Can someone try it at 2.0V (rather than 1.5V) and see if it solves the false-alerts problem?
> On 29 Oct, 2013, at 5:10 pm, Rolf Welde Skeie <rwskeie at gmail.com> wrote:
> > Ok, it seems like a few have similar issues.
> > The logic behind the calculations seems to be reasonable, it is the assumption that there is a 1.5V difference between charging/non-charging state which is not generally applicable.
> > From my observations it seems like increasing this to 2.0V would take care of most mis-firing events.?..
> > Disclaimer: I'm not an expert on batteries...
> > Running on 2.5.5 experimental/TC
> > Rolf
> > On 10/29/2013 10:00 AM, Matt Beard OVMS wrote:
> >> Yup, I also get this message and it would be great if it were working
> >> properly, but it actually fires at 13.1V which is far too high.
> >> Matt
> >> On 29 October 2013 08:46, Rolf Welde Skeie <rwskeie at gmail.com
> >> <mailto:rwskeie at gmail.com>> wrote:
> >>    I have the following features set:
> >>    #0=1, #8=1, #9=1, #15=1, all others =0.
> >>    Can't remember which one made it work, but one of them did, my guess
> >>    would be #9 :)
> >>    Rolf
> >>    On 10/29/2013 09:38 AM, Håkon Markussen wrote:
> >>        I never get this alert.
> >>        I have a Think City (as Rolf Skeie) and use the iOS-app.
> >>        I have tested on both an exhausted aux-battery and on a brand new
> >>        battery in perfect condition.
> >>        Br.
> >>        Håkon
> >>        2013/10/29 Thomas Bergo <thomas.bergo at gmail.com
> >>        <mailto:thomas.bergo at gmail.com>
> >>        <mailto:thomas.bergo at gmail.com <mailto:thomas.bergo at gmail.com>__>>
> >>             I'm also get this alert.
> >>             Regard, Thomas
> >>             tirsdag 29. oktober 2013 skrev Rolf Welde Skeie følgende:
> >>                 Hi,
> >>                 I'm getting 12V battery alerts ala:
> >>                 "MP-0 PAALERT!!! 12V BATTERY CRITICAL (13.2V, ref=14.7V)"
> >>                 So the 1.5V hardcoded difference between charged and
> >>        non-charged
> >>                 state seems to be too low. The battery is working just
> >>        fine and
> >>                 has been tested without any issues, but seems to
> >>        stabilize at
> >>                 approx. 12.8V.
> >>                 Is this a global issue; are others experiencing this as
> >>        well?
> >>                 If this is a issue only relevant to my car: would it
> >>        make sense
> >>                 to allow for controlling some of these kind of values
> >>        through
> >>                 parameters?
> >>                 BTW, I believe the Think City module could be put in the
> >>                 production builds, it seems to be working fine.
> >>                 Best regards
> >>                 Rolf Welde Skeie
> >>                 Solåsen 27, 5223 Nesttun, Norway
> >>        +47 92403016 <tel:%2B47%2092403016> <tel:%2B47%2092403016> /
> >>        rwskeie at gmail.com <mailto:rwskeie at gmail.com>
> >>                 ___________________________________________________
> >>                 OvmsDev mailing list
> >>        OvmsDev at lists.teslaclub.hk <mailto:OvmsDev at lists.teslaclub.hk>
> >>        http://lists.teslaclub.hk/____mailman/listinfo/ovmsdev
> >>        <http://lists.teslaclub.hk/__mailman/listinfo/ovmsdev>
> >>        <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>>
> >>        <mailto:OvmsDev at lists.__teslaclub.hk
> >>        <mailto:OvmsDev at lists.teslaclub.hk>>
> >>    Rolf Welde Skeie
> >>    +47 92403016 <tel:%2B47%2092403016> / rwskeie at gmail.com
> > Rolf Welde Skeie
> > +47 92403016 / rwskeie at gmail.com
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131114/3abfa64f/attachment.htm>
