[Ovmsdev] Change to API for vehicle poll0 and poll1 functions
Michael Jochum mikeljo at me.com
Fri Nov 8 22:29:20 HKT 2013
Hi mark,
i did this in "vehicle_voltampera.c:" in 2.2.7
else if (id == 0x7e9)
    switch (pid)
      case 0x2487:  //Distance Traveled on Battery Energy This Drive Cycle
          edrive_distance = KM2MI((can_databuffer[5] + ((unsigned int)can_databuffer[4] << 8)) / 100); // German Volt Report im KM
          if ((edrive_distance > va_drive_distance_bat_max) && (car_chargestate == 4)) va_drive_distance_bat_max = edrive_distance;
        break;
cause the return value is placed on 2 Bytes.
I think it is necessary to implement a parameter how much return byte expected.
Bye
Am 02.11.2013 um 14:14 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> I just committed a change to all vehicle modules, to change the api for the poll0() and poll1() functions.
> 1aaa0a3 Move can bus low level register access to vehicle.c, out of individual vehicle modules
> The new API sets up:
> unsigned int   can_id;                    // ID of can message
> unsigned char  can_filter;                // CAN filter
> unsigned char  can_datalength;            // The number of valid bytes in the can_databuffer
> unsigned char  can_databuffer[8];         // CAN message bytes
> prior to the calls to poll0() and poll1(). So, the individual vehicle modules no longer need to (and no longer are able to) access the low-level CAN bus registers in any way.
> I tried to move all the vehicle modules to the new mechanism, but there seemed to be significant differences in the way each module did things. Hopefully the work I did was ok and hasn’t broken anything, but please check your respective modules to make sure they still work.
> Overall, we’ve saved about 500-to-600 bytes of flash doing this.
> I’ve labelled this 2.6.1, as it has the capacity to break things.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131108/327a747a/attachment.htm>
