[Ovmsdev] OVMS Leaf Support
Mon Nov 4 11:46:43 HKT 2013
Jeremy,
We are using the gateway function at the moment, that bridges the CAN and EV buses. Seems to work well - but it only bridges extended PID requests and replies (not most normal passive bus traffic). This allows us to access the EV bus from the CAN bus.
On 4 Nov, 2013, at 11:09 am, Jeremy Whaling <jeremy.whaling at gmail.com> wrote:
> Hi All,
> According to the service manual, the current Telematics is located on the EV bus. My can to USB arrives Tuesday, hope to be listening to the TCU can messages soon.
> I've attached a page to show what's on the EV and car can busses.
> Jeremy
> On Sunday, November 3, 2013, Kevin Sharpe ZCW wrote:
> OVMS hardware is currently in UK customs and should be released this week.
> Have you obtained the programmer and any other dev tools?
> On 3 Nov 2013, at 08:53, "Robert Sharpe" <robert.sharpe at evergreen-consulting.co.uk> wrote:
>> Hi Kevin,
>> I am keen to start helping out on the Leaf development.
>> It's been 3 weeks and I just wandered what the progress with the OVMS hardware is ?
>> Rob
>> ---- On Mon, 14 Oct 2013 15:01:15 +0100 <robert.sharpe at evergreen-consulting.co.uk> wrote ----
>> Hi Kevin,
>> Thanks a lot for your kind offer.
>> I should set expectations that I am an out of practice and slow coder, but I will do what I can to help.  I can probably help more with test, debug and coordination.
>> So if you are still happy then, as I dont have any OVMS kit, I will need an OVMS and correct cable.
>> Can someone point me to a developer beginner's instructions for what else is required to develop/test, e.g. programmer, sniffer, code repository login, CM procedures, etc
>> It helps me, and hopefully anyone else working on the project, if we can agree the breakdown of work.  As you may have already seen I have suggested a post for the Leaf development at http://www.openvehicles.com/node/111
>> Nikki/Mark shall we use that as a way of planning and tracking the work ?
>> Rob
>> On Oct 14, 2013, at 2.21PM, Nikki Gordon-Bloomfield wrote:
>> Hi Kevin,
>> That's very generous. Happy to test OVMS in my LEAF, so I guess another OVMS kit with a righty cable?
>> Nikki.
>> On 14 Oct 2013, at 13:47, Kevin Sharpe ZCW <kevin.sharpe at zerocarbonworld.org">target="_blank">kevin.sharpe at zerocarbonworld.org> wrote:
>> Rob, Mark (C), Nikki,
>> If it helps, I'm happy to provide each of you with OVMS hardware FOC in return for your efforts on the Leaf development :-)
>> Let me know what you need,
>> 		Kevin Sharpe | Founder & Patron
>> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
>> kevin.sharpe at zerocarbonworld.org | http://www.zerocarbonworld.org/ | twitter.com/zerocarbonworld
>> Zero Carbon World is a UK Registered Charity #1141347
>> From: Robert Sharpe <robert.sharpe at evergreen-consulting.co.uk">target="_blank">rob
> <photo.jpg>_______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20131104/3d8d15c5/attachment.htm>
