[Ovmsdev] Can-re tool
support at nirvtek.com
Sun Nov 3 14:05:51 HKT 2013
Hi
I’ve put the .pm modules into the plugins directory. The script does an @INC with the plugins directory.
Not sure how to add it to the default library path of PERL. The environment variables for PERL don’t appear to exist/.
Thanks
Sharanga
On Nov 3, 2013, at 7:41 AM, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Sharanga,
> How have you installed EV and Common::Sense?
> They need to be installed into the perl system on the box. It sounds like you may have put them in the plugins directory of CAN-RE-TOOL?
> On 1 Nov, 2013, at 10:36 pm, support at nirvtek.com wrote:
>> Hi
>> I don't know whether this is the right list for this.
>> I can't get the can-re tool to run on Windows. I downloaded EV.pm and common::sense, but it yields this:
>> common/sense.pm did not return a true value at ../plugins/EV.pm line 121, <DATA>
>> line 451.
>> BEGIN failed--compilation aborted at ../plugins/EV.pm line 121, <DATA> line 451.
>> Compilation failed in require at canretool.pl line 38, <DATA> line 451.
>> BEGIN failed--compilation aborted at canretool.pl line 38, <DATA> line 451.
>> !help
>> Thanks
>> Sharanga
>> Nirvtek
