[Ovmsdev] OVMS Leaf Support
    Jeremy Whaling
    jeremy.whaling at gmail.com
    Wed Nov 20 17:06:47 HKT 2013
Hi all! Attached is a text file containing a recording of the EV can bus
data during a remote request for status/SOC. The first message from 68C  is
only seen once. Unfortunately sending the message from my PCAN tool had no
effect. Will try to get more data over the weekend.
Jeremy
On Wed, Nov 6, 2013 at 1:22 AM, Jeremy Whaling <jeremy.whaling at gmail.com>wrote:
> The only functions that the TCU/carwings can do is
> get the following data: # of bars,GOM range, plug/charging status, and
> estimated charging time
> invoke the following: charging now or turning on or off climate (which
> attempts to bring the cabin to 78F via heat or AC).
> Unlocking doors or other goodies might be something we can do after
> sniffing the car can bus some more! :-)
> Jeremy
> On Wed, Nov 6, 2013 at 12:36 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>> Jeremy,
>> The OBDII port carries pins for both buses. OVMS could be connected to
>> either, although the CAR CAN bus is on the standard OBDII pins for a CAN
>> bus.
>> My preference is the CAR CAN bus at the moment, because we need stuff on
>> the CAR bus, not just EV (like speed, etc), and standard cables can be
>> used. It seems to have worked out very well for LeafSpy. But, there is no
>> reason the OVMS could not be connected directly to EV bus.
>> If, as you say, the TCM module is connected to just the EV CAN bus that
>> is very good news. It should just be a matter of listening in on what
>> messages it sends on that bus to understand how it is doing things like
>> locking doors, aircon control, etc. The bridge between EV and CAR buses is
>> bi-directional, so perhaps it is also sending messages over to the CAR bus.
>> On 6 Nov, 2013, at 2:38 pm, Jeremy Whaling <jeremy.whaling at gmail.com>
>> wrote:
>> While I don't mind the OBD port route for now, eventually I'd like to
>> have the option to have an OVMS module to drop into place of the original
>> TCM which has connections to the EV can bus (only) and a built in GSM
>> antenna. My USB-CAN came in today, hope to play with it a little bit this
>> weekend.
>> Also plan to buy all the OVMS goodies soon, but those will take a few
>> weeks to get in, I think?
>> Jeremy
>> On Tue, Nov 5, 2013 at 4:45 AM, Mark Webb-Johnson <mark at webb-johnson.net>wrote:
>>> A short update:
>>> I’m working on the code to handle the Leaf PID polling via the CAR-to-EV
>>> bus bridge. It seems ok, but I’m trying to make it modular as we are now
>>> doing this same sort of polling in quite a few vehicle modules and it seems
>>> sensible to centralise it (to save code space and complexity). It is
>>> tricky, because of the relay issue, as we need to make the polling
>>> frequency configurable depending on states.
>>> I’m making progress and hope to have something within the coming week.
>>> My first version of code is going to output to the DIAG serial port lots
>>> of data to tell us what is going on. So, I need testers with a (a) laptop,
>>> (b) usb-to-serial converter, (c) Leaf, (d) PICKIT, (e) OVMS module, (f)
>>> standard OVMS OBD-II cable. Testing will be flashing the module with a HEX
>>> I provide, then putting it in the car and getting a log file of the DIAG
>>> port to send me.
>>> On 22 Oct, 2013, at 9:37 pm, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>> Nikki,
>>> Thanks for detailed explanation.
>>>    - could we put the OVMS into some form of low-power mode, so it
>>>    doesn't poll the car and drain that 12V battery as quickly?
>>> Possibly. We haven’t handled that yet, and our tests with it so far have
>>> not been very successful. The biggest power draw is the modem. Best we can
>>> do is shut that down and delay-loop-spin if 12V gets to low.
>>>    - We can use the 12V monitoring system already built into OVMS to
>>>    set an early-warning alert if voltages start to drop, right?
>>> Yes. The leaf also seems to have 12V level in a can bus signal, which
>>> shouldn’t need to be calibrated and may give us a better result.
>>> But a quick question: can I run OVMS alongside LEAFSpy, using an ODBII
>>> splitter?
>>> Hmmm. Without special handling, that would be problematic. We would both
>>> end up polling the same things, and one/both of us would get confused.
>>> I should have thought that we can listen on the bus first, and make sure
>>> there are no polling signals for N seconds, before we start polling
>>> ourselves. Similarly, if we see a polling signal/reply, we can back off.
>>> But, one concern is that in my tests last weekend, I tried a CAN bus logger
>>> and OBD-II with leaf spy together, but didn’t see much. All I saw were some
>>> replies:
>>> 1382228933.303 R11 797 02 10 C0 00 00 00 00 00
>>> 1382229549.511 R11 797 03 22 12 4E 00 00 00 00
>>> 1382229799.599 R11 797 03 22 11 5D 00 00 00 00
>>> 1382230050.688 R11 797 03 22 13 2A 00 00 00 00
>>> 1382230425.777 R11 797 03 22 12 55 00 00 00 00
>>> 1382230869.926 R11 797 03 22 13 04 00 00 00 00
>>> so, it looks like I can see someone else polling (and can back off
>>> appropriately), but I don’t think I can listen to their replies as if I was
>>> polling myself! That would be cool (so long as leaf spy and ovms were
>>> polling for the exact same things), and I don’t see why it wouldn’t work,
>>> but I just didn’t see that behaviour when I T’ed the bus last weekend.
>>> On 22 Oct, 2013, at 4:23 pm, Nikki Gordon-Bloomfield <
>>> nikki at aminorjourney.com> wrote:
>>> Mark,
>>> Regarding the 12V drain. As I understand it, the 12V battery gets
>>> charged when the car is plugged in and the main traction battery is getting
>>> charged. When the car is plugged in and it is NOT charging, the on-board
>>> computer wakes up every n seconds and polls its various systems. Because
>>> this uses more power than normal 'standby' mode, it quickly drains the
>>> battery. If we assume most owners are not going to leave their cars plugged
>>> in for days at a time, the issue should be moot, although it's worth
>>> playing on the cautious side.
>>> Instances of 12V drainage in LEAFs are almost exclusively related to
>>> cars which have sat plugged in at charging stations for extended periods of
>>> time, such as when their owners go on holiday.  Last time I went abroad, I
>>> kept my LEAF plugged in, but did the following:
>>>    - Left the car on the first night without a full charge. I think SOC
>>>    was about 25% if I remember correctly.
>>>    - Set the car's timer to charge every night while I was away with an
>>>    80 percent 'limited' charge profile, starting at midnight, and finishing at
>>>    half-past midnight.
>>>    - On a standard 16 amp EVSE, this meant that the car slowly charged
>>>    over the course of the week, getting topped up a little more every night.
>>>    Because the 12V battery was charged too during that period, I was able to
>>>    keep it happy also, preventing any horrible 'soft-brick' scenarios.
>>> What does this tell us? First, I'm pretty sure the 12V battery DOES get
>>> charged when the main traction back gets charged. But when the car is
>>> plugged in and not charging, NOTHING gets charged and the 12V battery gets
>>> drained at a far faster rate than it would be if it was left alone for a
>>> few weeks.
>>> But I think it also tells us some other important things.
>>>    - IN most situations, (everyday ones, at least) 12V battery drain
>>>    shouldn't be a problem. I'm happy to be the Guinea pig for this one when
>>>    Kevin gets the OVMS hardware through customs.
>>>    - The only risk to the car occurs when the car is parked for long
>>>    periods without being plugged in -- or when it is plugged in but hasn't
>>>    charged for x hours/days. A work-around here would be to use the parking
>>>    timer combined with a 'last-charged' timer. If the timer > 24 hours, per
>>>    say, could we put the OVMS into some form of low-power mode, so it doesn't
>>>    poll the car and drain that 12V battery as quickly? I know from my Twizy
>>>    that the OVMS system really does have a very low power drain, so I'm
>>>    assuming any massive power drains associated with OVMS come from the car's
>>>    on-board CAN hardware waking up and communicating with the module?
>>>    - If done correctly, it's possible to keep the car plugged in for
>>>    long periods of time, without adversely affecting the 12V battery.  This is
>>>    a matter of driver education more than anything else.
>>> I also think it's worth noting that many LEAFs which have had 12V
>>> battery issues are ones which have either spent a lot of time sitting on
>>> dealer lots, or are regularly left for long periods of time. It's my
>>> opinion that like any car, the LEAF benefits from being driven daily… ;)
>>> As soon as Kevin gets the hardware through customs, I'm willing to give
>>> this all a go. But a quick question: can I run OVMS alongside LEAFSpy,
>>> using an ODBII splitter?
>>> Nikki.
>>> P.S. FYI, Nissan has changed the position of the ODB port on the 2013
>>> model year cars. It's now behind a small panel to the right of the driver's
>>> right (left in LHD countries) knee. Orientation is also moved too. Here's a
>>> photo of new vs old.
>>> <IMG_0525.jpeg> -- You'll notice the new car has an extra port too. Not
>>> sure what it's for…
>>> <IMG_0528.jpeg> Old port is right under the dash, with the catch-side
>>> facing to the driver's left.
>>> On 22 Oct 2013, at 02:11, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>> OK, here's an update...
>>> I went through the logs we captured, and had a look at Leaf Spy. I even
>>> purchased a copy of Leaf Spy Pro (even though I don't have a Leaf) just as
>>> a donation to say thank you to Turbo3 for pushing this approach and working
>>> out so much of the mechanics of it.
>>> I spent an evening reading through the "Using clone ELM327 Bluetooth
>>> OBDII adapter with Leaf" on mynissanleaf.com<http://www.mynissanleaf.com/viewtopic.php?f=44&t=12098> (all
>>> 238 pages of it!), and got a good understanding of the history of where CAN
>>> decoding on the Nissan Leaf is, and where it is headed.
>>> Bottom line:
>>>    - There are two CAN buses in the Nissan Leaf that are useful to us:
>>>    the EV CAN bus and the CAR CAN bus.
>>>    - The standard OVMS OBD-II cable connects to the CAR CAN bus. By
>>>    passive listening on the bus, we can see some EV information, and all of
>>>    the car information.
>>>    - The EV CAN bus is also available on the OBD-II socket. By passive
>>>    listening on the bus, we can see all the EV information, but little-to-no
>>>    car information.
>>>    - OVMS V2 hardware can only connect to one bus.
>>>    - Someone worked out that active requests for information from the
>>>    controllers (PID polling, as opposed to passive listening) are bridged. You
>>>    can request information from a controller on the EV CAN bus, via the CAR
>>>    CAN bus, and the car will bridge the requests between the buses. This
>>>    appears to work bi-directionally.
>>>    - There is a slight nasty in that if the car is off (asleep), active
>>>    polling the EV controller causes it to wake up and you can hear a little
>>>    12V relay click near the front of the car each time you poll. We don't want
>>>    to poll too fast when the car is asleep (off) and not charging, to avoid
>>>    wearing out that relay.
>>>    - The OBD-II connector has 12V power (both switched and
>>>    non-switched) that we can use for OVMS, powered by an automotive 12V lead
>>>    acid battery. We do need to take care because apparently that 12V battery
>>>    is only charged when you drive or once every five days when the car is
>>>    unplugged (and not at all when the car is plugged in). There is a CAR CAN
>>>    message to show the 12V battery voltage (and OVMS V2 can also measure
>>>    directly).
>>>    - There is 'active discussion' in the community on how things like
>>>    SOC%, battery capacity, ideal and estimated ranges, should be determined.
>>>    Nissan made a mess of it, and the users are struggling to agree on a
>>>    uniform approach to a correct way of doing things.
>>> I think our plan of attack should be:
>>>    1. Use a standard V2 module, with standard OVMS OBD-II cable, to
>>>    connect to the CAR CAN bus.
>>>    2. Use passive CAN listening, for the car information (doors, speed,
>>>    on/off, etc) as much as possible.
>>>    3. Use active CAN polling, bridged to the EV CAN bus, for the EV
>>>    information that we need.
>>>    4. Agree our own user-centric approach of how to represent capacity,
>>>    SOC, ideal and estimated ranges.
>>> It has been quite frustrating looking at the community documentation for
>>> CAN bus messages in the Leaf. The documentation doesn't match what I am
>>> seeing, and is not at all clear. A lot of people are sharing, but some seem
>>> to be holding back and saying things like "here are some clues to what I've
>>> found, so go look for it yourself". Some closed source. Not the way I like
>>> to do things.
>>> There is one very good thread on the active CAN bus polling, here:
>>> http://www.mynissanleaf.com/viewtopic.php?f=44&t=11676
>>> A good background read (34 pages) on Leaf CAN bus passive monitoring is
>>> here:
>>> http://www.mynissanleaf.com/viewtopic.php?f=8&t=4131
>>> and I recommend everyone involved in this to read that thread (only 12
>>> pages) to get a good understanding.
>>> There are two spreadsheets tracking Leaf CAN bus messages:
>>> https://docs.google.com/spreadsheet/ccc?key=0AuDGAXnbchK0dDc4T05oNE04aVZtUzB6S19DT1RwaHc&authkey=CJi03v4F&hl=en_US&authkey=CJi03v4F#gid=0
>>> https://docs.google.com/spreadsheet/ccc?key=0An7gtcYL2Oy0dGRaSWl6VTV2eXBQMy1ON2xZSzlMUXc#gid=5
>>> So, what I'm going to do now is to setup a framework in the
>>> vehicle_nissanleaf module to do passive listening on the CAR CAN bus, and
>>> active polling of the information on the EV CAN bus (bridged via CAR CAN
>>> bus). Once the framework is done, I'll test it in the local Hong Kong Leaf,
>>> and ask you guys to help.
>>> I do need one or two people with the following equipment to help out:
>>> Good and frequent access to a Nissan Leaf
>>> OVMS v2 Module
>>> OVMS v2 OBD-II cable
>>> PICKIT2 or PICKIT3 programmer
>>> RS232-to-USB adaptor and laptop (or laptop with RS232 port)
>>> This is to run the framework in their car, and capture RS232 output from
>>> the DIAG port.
>>> So, volunteers please.
>>> On 19 Oct, 2013, at 11:23 pm, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>> I met up with a local Leaf owner (George) and spent a few hours in the
>>> car logging stuff off the main CAN bus. The car is a 2011 model, I think
>>> (the VIN model year is U/V, which makes no sense).
>>> Good news it that the OVMS cables are fine. The ‘right hand’ ovms obdii
>>> cable appears to be the best for the right hand drive nissan leafs. The
>>> OBDII connector is under the steering wheel, parallel with the car
>>> direction of travel, short side on the left, so using a right-hand cable
>>> directs the cable towards the front of the car, which should be easiest for
>>> routing.
>>> I managed to get quite a few log files, using a standard CAN USB adaptor
>>> at 512kbps.
>>> Bad news is I am having trouble correlating lots of the messages against
>>> the published spreadsheets of Leaf can bus messages. Some messages are
>>> partially correct, but many are missing / don’t match up. The car also
>>> seems to go to sleep during charging, although the leaf spy could update
>>> the SOC ok. The 0x5b3 SOC+GIDS message wasn’t visible on the bus at all.
>>> I think we are going to have to use PID polling to get the data we need.
>>> On 16 Oct, 2013, at 10:31 pm, Mark Webb-Johnson <mark at webb-johnson.net>
>>> wrote:
>>> Anyone feeling brave?
>>> I’ve just committed a nissan leaf module (set vehicle id to NL) that
>>> will monitor the can bus and pickup the SOC%. That is all it does at the
>>> moment, but it should work.
>>> On 16 Oct, 2013, at 2:49 pm, Nikki Gordon-Bloomfield <
>>> nikki at littlecollie.com> wrote:
>>> I've already messages mark C. Let's hope he has it :) I know he and his
>>> husband have done a lot of logging.
>>> Sent from my iPhone
>>> On 16 Oct 2013, at 07:02, Robert Sharpe <
>>> robert.sharpe at evergreen-consulting.co.uk> wrote:
>>> Hi Mark,
>>> >I think the fastest way to get this done is for me to do it with a
>>> local Leaf owner.
>>> That sounds like a good idea.
>>> >Can someone tell me which CarCAN bus message to look for, which byte(s)
>>> to access, and how to convert to percentage SOC?
>>> >The document at
>>> https://docs.google.com/spreadsheet/ccc?key=0An7gtcYL2Oy0dGRaSWl6VTV2eXBQMy1ON2xZSzlMUXc#gid=5 suggests
>>> ID 5B3 tracks SOH and Gids. But how to convert to percentage SOC?
>>> Is @nufkin (Mark C) on this list? He has done some analysis of codes.
>>> There is always the authors of the other projects that read Leaf data.
>>> Rob
>>> On Oct 16, 2013, at 6.33AM, Mark Webb-Johnson wrote:
>>> I think the fastest way to get this done is for me to do it with a local
>>> Leaf owner.
>>> If I can get basic support working, then perhaps someone else (or
>>> others) with better knowledge of the Leaf scene, can take over to get the
>>> advanced stuff working.
>>> So, I'm going to try to get some Leaf Spy traces, as well as CAN bus
>>> logs for parked, charging and driving. Then, get the basic module working
>>> with SOC%, GPS location, door status, drive/park and charge monitor.
>>> My biggest confusion at the moment is SOC% in the Leaf. There is a lot
>>> of talk about gids, etc, but I've never gone into it too deeply.
>>> The document at
>>> https://docs.google.com/spreadsheet/ccc?key=0An7gtcYL2Oy0dGRaSWl6VTV2eXBQMy1ON2xZSzlMUXc#gid=5suggests ID 5B3 tracks SOH and Gids. But how to convert to percentage SOC?
>>> On 16 Oct, 2013, at 1:03 pm, Evergreen <
>>> robert.sharpe at evergreen-consulting.co.uk">target="_blank">robert.sharpe at evergreen-consulting.co.uk<robert.sharpe at evergreen-consulting.co.uk>>
>>> wrote:
>>> That's great news.
>>> Rob
>>> On 16 Oct 2013, at 06:00, Mark Webb-Johnson <
>>> mark at webb-johnson.net">target="_blank">mark at webb-johnson.net<mark at webb-johnson.net>>
>>> wrote:
>>> P.S. I'm trying to find a friendly Leaf owner in Hong Kong to co-operate
>>> with this. There are 200+ Leafs here, and no carwings coverage at all, but
>>> most are in government service and relatively few in private hands.
>>> I think my fishing expedition on the forums may have come up with a
>>> bite. A Hong Kong Leaf owner who is willing to help.
>>> I'll let you know how it pans out (over the next couple of days), but if
>>> I can get access to a local Leaf, getting the basic support working should
>>> be much faster.
>>> On 15 Oct, 2013, at 1:00 pm, Mark Webb-Johnson <
>>> wrote:
>>> Barry,
>>> Thanks for the history. I really think we can get what we need from the
>>> single car CAN bus.
>>> I'll extract the relevant sections from the developers guide tonight,
>>> and post them here. The first step is to see which of those 'virtual car'
>>> pieces of information are available on the car CAN bus, and see if they
>>> match-up.
>>> I really would like to see a dump (and dump) of the car CAN bus, as well
>>> as a trace from the leaf spy program. The captioned google docs spreadsheet
>>> for leaf can bus messages is quite confusing - it would be good to be able
>>> to compare that against what is actually seen on the bus.
>>> On 15 Oct, 2013, at 11:45 am, Barry Gershenfeld <
>>> gbarry42 at gmail.com">target="_blank">gbarry42 at gmail.com<gbarry42 at gmail.com>>
>>> wrote:
>>> Early development assumed you had to get the EV info from the EV-CAN
>>> buss.  Somewhere during the development of Leaf Spy they kept finding
>>> desirable info on the car-CAN buss and so eventually determined that all if
>>> could be gotten from the car-CAN.  As a bonus, the ELM dongle no longer has
>>> to be modified to read the EV buss.
>>> The original reporting efforts started with the "GID" meter, and the
>>> early work involved Gary G. building a data recorder as well as a program
>>> to analyze the logs.  I'm sure that's precisely what you have in mind as
>>> well.  There were downloadable logs--he invited others to install the
>>> analyzer and try to find meaningful messages therein.  But as it was early
>>> development, they were probably gotten from the EV-CAN.  I don't know if
>>> any more recent logs from the car CAN buss are posted.
>>> As a matter of fact, I suspect Gary would be happy to have his analyzing
>>> program used.  It would be nice output the data into the same format that
>>> it uses.  Or at least write a converter.
>>> I naturally have some interest, being a LEAF owner and PIC hacker.  I'll
>>> see if I can make head or tail of the developer's guide.
>>> On Mon, Oct 14, 2013 at 7:04 PM, Mark Webb-Johnson <
>>> > wrote:
>>> Developers guide is here:
>>> https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/OVMS_Development.pdf?raw=true
>>> I would rather the actual development discussions take place here on
>>> this list. A lot of smart people here, with experience getting these
>>> vehicle modules working.
>>> The biggest concern for me is whether we can get everything we need off
>>> one CAN bus...
>>> OvmsDev at lists.teslaclub.hk">target="_blank">OvmsDev at lists.teslaclub.hk<OvmsDev at lists.teslaclub.hk>
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131120/2067c5ab/attachment-0001.html>
;$FILEVERSION=1.1
;$STARTTIME=41597.6384175463
;   C:\Users\Jeremy\Documents\remotesocreqevbus.trc
;   Start time: 11/19/2013 15:19:19.276.0
;   Message Number
;   |         Time Offset (ms)
;   |         |        Type
;   |         |        |        ID (hex)
;   |         |        |        |     Data Length Code
;   |         |        |        |     |   Data Bytes (hex) ...
     1)     21256.9  Rx         068C  1  00
     2)     21306.9  Rx         056E  1  46
     3)     21331.2  Rx         01D4  8  A0 6D 00 00 42 06 40 60
     4)     21331.4  Rx         01F2  8  08 64 00 00 00 01 01 06
     5)     21331.6  Rx         05A9  8  FF FF FC FF FF F0 00 00
     6)     21341.5  Rx         01D4  8  9C 6D 00 00 82 06 40 18
     7)     21341.7  Rx         01F2  8  08 64 00 00 00 01 02 07
     8)     21341.9  Rx         050A  6  06 00 00 17 00 00
     9)     21351.7  Rx         01D4  8  9C 6D 00 00 C2 06 40 DF
    10)     21351.9  Rx         01F2  8  08 64 00 00 00 01 03 08
    11)     21361.9  Rx         01D4  8  9C 6D 00 00 02 06 40 13
    12)     21362.1  Rx         01F2  8  08 64 00 00 00 01 00 05
    13)     21362.3  Rx         050B  6  00 00 00 C0 00 00
    14)     21372.1  Rx         01D4  8  9C 6D 00 00 42 06 40 D4
    15)     21372.4  Rx         01F2  8  08 64 00 00 00 01 01 06
    16)     21382.4  Rx         01D4  8  9C 6D 00 00 82 06 60 5B
    17)     21382.6  Rx         01F2  8  08 64 00 00 00 02 02 08
    18)     21392.6  Rx         01D4  8  9C 6D 00 00 C2 06 60 9C
    19)     21392.9  Rx         01F2  8  08 64 00 00 00 02 03 09
    20)     21402.9  Rx         01D4  8  9C 6D 00 00 02 06 60 50
    21)     21403.1  Rx         01F2  8  08 64 00 00 00 02 00 06
    22)     21403.3  Rx         05B9  5  07 FF 07 FF 28
    23)     21407.0  Rx         056E  1  46
    24)     21413.1  Rx         01D4  8  9C 6D 00 00 42 06 60 97
    25)     21413.4  Rx         01F2  8  08 64 00 00 00 02 01 07
    26)     21423.4  Rx         01D4  8  9C 6D 00 00 82 06 60 5B
    27)     21423.6  Rx         01F2  8  08 64 00 00 00 02 02 08
    28)     21423.8  Rx         050C  6  00 00 00 01 5D 5F
    29)     21433.6  Rx         01D4  8  9C 6D 00 00 C2 06 60 9C
    30)     21433.8  Rx         01F2  8  08 64 00 00 00 04 03 0B
    31)     21443.8  Rx         01D4  8  9C 6D 00 00 02 06 60 50
    32)     21444.1  Rx         01F2  8  08 64 00 00 00 04 00 08
    33)     21444.3  Rx         050A  6  06 20 00 17 00 00
    34)     21454.0  Rx         01D4  8  9C 6D 00 00 42 06 60 97
    35)     21454.3  Rx         01F2  8  08 64 00 00 00 04 01 09
    36)     21462.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
    37)     21463.4  Rx         054B  8  00 08 80 00 04 00 00 00
    38)     21464.3  Rx         01D4  8  9C 6D 00 00 82 06 60 5B
    39)     21464.6  Rx         01F2  8  08 64 00 00 00 04 02 0A
    40)     21464.8  Rx         050B  6  00 00 00 C0 00 00
    41)     21465.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
    42)     21466.4  Rx         054F  8  14 00 00 00 0B 40 00 1E
    43)     21474.6  Rx         01D4  8  9C 6D 00 00 C2 06 60 9C
    44)     21474.9  Rx         01F2  8  08 64 00 00 00 04 03 0B
    45)     21484.8  Rx         01D4  8  9F 6D 00 00 02 06 60 59
    46)     21485.0  Rx         01F2  8  08 64 00 00 00 04 00 08
    47)     21495.0  Rx         01D4  8  9F 6D 00 00 42 06 60 9E
    48)     21495.3  Rx         01F2  8  08 64 00 00 00 04 01 09
    49)     21505.3  Rx         01D4  8  9F 6D 00 00 82 06 60 52
    50)     21505.5  Rx         01F2  8  08 64 00 00 00 04 02 0A
    51)     21506.9  Rx         056E  1  46
    52)     21515.5  Rx         01D4  8  9F 6D 00 00 C2 06 60 95
    53)     21515.7  Rx         01F2  8  08 64 00 00 00 04 03 0B
    54)     21525.7  Rx         01D4  8  9F 6D 00 00 02 06 60 59
    55)     21525.9  Rx         01F2  8  08 64 00 00 00 04 00 08
    56)     21526.1  Rx         050C  6  00 00 00 02 5D 63
    57)     21535.9  Rx         01D4  8  9F 6D 00 00 42 06 60 9E
    58)     21536.2  Rx         01F2  8  08 64 00 00 00 04 01 09
    59)     21546.1  Rx         01D4  8  9F 6D 00 00 82 06 60 52
    60)     21546.4  Rx         01F2  8  08 64 00 00 00 04 02 0A
    61)     21546.6  Rx         050A  6  06 40 00 17 00 00
    62)     21550.4  Rx         054A  8  12 00 70 02 00 00 00 3A
    63)     21551.3  Rx         054B  8  00 08 80 00 04 00 00 00
    64)     21552.2  Rx         01DB  8  7F E0 FF C6 00 00 00 DE
    65)     21552.4  Rx         01DC  8  FF FF FF FF 1F FF FC 6B
    66)     21552.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
    67)     21553.4  Rx         054F  8  49 00 00 00 0B 80 08 3F
    68)     21556.5  Rx         01D4  8  9F 6D 00 00 C2 06 60 95
    69)     21556.7  Rx         01F2  8  08 64 00 00 00 04 03 0B
    70)     21562.2  Rx         01DB  8  00 00 FF C6 00 00 01 91
    71)     21562.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
    72)     21566.7  Rx         01D4  8  9F 6D 00 00 02 06 60 59
    73)     21567.0  Rx         01F2  8  08 64 00 00 00 04 00 08
    74)     21567.1  Rx         050B  6  00 00 00 C0 00 00
    75)     21572.2  Rx         01DB  8  00 00 FF C6 00 00 02 9B
    76)     21572.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
    77)     21576.9  Rx         01D4  8  9F 6D 00 00 42 06 60 9E
    78)     21577.2  Rx         01F2  8  08 64 00 00 00 04 01 09
    79)     21578.8  Rx         0380  8  00 04 10 21 00 00 00 03
    80)     21582.2  Rx         01DB  8  00 00 FF C6 00 00 03 1E
    81)     21582.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
    82)     21587.2  Rx         01D4  8  9F 6D 00 00 82 06 60 52
    83)     21587.4  Rx         01F2  8  08 64 00 00 00 04 02 0A
    84)     21588.8  Rx         0380  8  02 04 10 21 00 00 00 16
    85)     21592.2  Rx         01DB  8  00 00 C0 06 00 00 00 A6
    86)     21592.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
    87)     21597.4  Rx         01D4  8  9F 6D 00 00 C2 06 60 95
    88)     21597.7  Rx         01F2  8  08 64 00 00 00 04 03 0B
    89)     21602.2  Rx         01DB  8  00 00 C0 06 00 00 01 23
    90)     21602.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
    91)     21606.8  Rx         056E  1  46
    92)     21607.7  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
    93)     21607.9  Rx         01F2  8  08 64 00 00 00 04 00 08
    94)     21612.2  Rx         01DB  8  00 00 C0 06 00 00 02 29
    95)     21612.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
    96)     21617.9  Rx         01D4  8  A0 6D 00 00 42 06 60 23
    97)     21618.2  Rx         01F2  8  08 64 00 00 00 04 01 09
    98)     21619.7  Rx         01DA  8  FF 00 00 00 7F FE 01 97
    99)     21622.2  Rx         01DB  8  00 00 C0 06 00 00 03 AC
   100)     21622.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   101)     21628.2  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   102)     21628.5  Rx         01F2  8  08 64 00 00 00 04 02 0A
   103)     21628.7  Rx         050C  6  00 00 00 03 5D F4
   104)     21629.7  Rx         01DA  8  FF 00 00 00 7F FE 02 9D
   105)     21632.2  Rx         01DB  8  00 00 C0 06 00 00 00 A6
   106)     21632.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   107)     21638.5  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   108)     21638.7  Rx         01F2  8  08 64 00 00 00 05 03 0C
   109)     21639.7  Rx         01DA  8  01 00 00 00 7F FE 03 6D
   110)     21642.4  Rx         01DB  8  00 00 C0 06 00 00 01 23
   111)     21642.6  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   112)     21642.8  Rx         055B  8  AB 40 AA 00 FF C0 10 19
   113)     21648.7  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   114)     21649.0  Rx         01F2  8  08 64 00 00 00 07 00 0B
   115)     21649.2  Rx         050A  6  06 60 00 17 00 00
   116)     21649.7  Rx         01DA  8  01 00 00 00 7F FE 00 67
   117)     21650.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
   118)     21651.4  Rx         054B  8  00 08 80 00 04 00 00 00
   119)     21652.2  Rx         01DB  8  00 20 C0 26 00 00 02 37
   120)     21652.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   121)     21652.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   122)     21653.4  Rx         054F  8  49 00 00 00 0B C0 08 3F
   123)     21659.0  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   124)     21659.2  Rx         01F2  8  08 64 00 00 00 07 01 0C
   125)     21659.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   126)     21662.1  Rx         01DB  8  00 20 C0 26 00 00 03 B2
   127)     21662.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   128)     21668.9  Rx         0380  8  02 04 10 21 00 00 00 27
   129)     21669.1  Rx         05BF  8  00 00 00 00 10 00 00 00
   130)     21669.4  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   131)     21669.6  Rx         01F2  8  08 64 00 00 00 07 02 0D
   132)     21669.9  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   133)     21670.1  Rx         050B  6  00 00 00 C0 00 00
   134)     21672.2  Rx         01DB  8  00 00 C0 26 00 00 00 E9
   135)     21672.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   136)     21679.5  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   137)     21679.7  Rx         01F2  8  08 64 00 00 00 07 03 0E
   138)     21679.9  Rx         01DA  8  01 00 00 00 7F FF 03 FA
   139)     21682.2  Rx         01DB  8  00 00 C0 26 00 00 01 6C
   140)     21682.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   141)     21689.7  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   142)     21689.9  Rx         01DA  8  01 00 00 00 7F FF 00 F0
   143)     21690.1  Rx         01F2  8  08 64 00 00 00 07 00 0B
   144)     21692.1  Rx         01DB  8  00 00 C0 26 00 00 02 66
   145)     21692.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   146)     21699.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   147)     21699.9  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   148)     21700.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   149)     21702.2  Rx         01DB  8  00 00 C0 26 00 00 03 E3
   150)     21702.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   151)     21706.8  Rx         056E  1  46
   152)     21709.7  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   153)     21710.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   154)     21710.2  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   155)     21710.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
   156)     21712.2  Rx         01DB  8  00 00 C0 26 00 00 00 E9
   157)     21712.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   158)     21719.7  Rx         01DA  8  01 00 00 00 7F FF 03 FA
   159)     21720.4  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   160)     21720.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
   161)     21722.1  Rx         01DB  8  00 00 C0 26 00 00 01 6C
   162)     21722.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   163)     21729.7  Rx         01DA  8  01 00 00 00 7F FF 00 F0
   164)     21730.7  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   165)     21730.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   166)     21731.1  Rx         050C  6  00 00 00 00 5D C8
   167)     21732.2  Rx         01DB  8  00 00 C0 26 00 00 02 66
   168)     21732.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   169)     21739.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   170)     21740.9  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   171)     21741.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   172)     21742.3  Rx         01DB  8  00 00 C0 26 00 00 03 E3
   173)     21742.6  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   174)     21742.8  Rx         055B  8  AB 00 55 00 FF C0 11 79
   175)     21749.7  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   176)     21750.5  Rx         054A  8  12 00 70 02 00 00 00 3A
   177)     21751.1  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   178)     21751.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
   179)     21751.6  Rx         050A  6  06 00 00 17 00 00
   180)     21751.9  Rx         054B  8  00 08 80 00 04 00 00 00
   181)     21752.2  Rx         01DB  8  00 00 C0 26 00 00 00 E9
   182)     21752.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   183)     21752.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   184)     21753.5  Rx         054F  8  49 00 00 00 0B 00 08 3F
   185)     21759.7  Rx         01DA  8  01 00 00 00 7F FF 03 FA
   186)     21761.4  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   187)     21761.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
   188)     21762.2  Rx         01DB  8  00 00 C0 26 00 00 01 6C
   189)     21762.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   190)     21769.0  Rx         0380  8  02 04 10 21 00 00 00 38
   191)     21769.3  Rx         05BF  8  00 00 00 00 18 00 00 19
   192)     21769.7  Rx         01DA  8  01 00 00 00 7F FF 00 F0
   193)     21771.6  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   194)     21771.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   195)     21772.1  Rx         050B  6  00 00 00 C0 00 00
   196)     21772.3  Rx         01DB  8  00 00 C0 26 00 00 02 66
   197)     21772.6  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   198)     21779.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   199)     21781.9  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   200)     21782.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   201)     21782.3  Rx         01DB  8  00 00 C0 26 00 00 03 E3
   202)     21782.6  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   203)     21789.7  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   204)     21792.1  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   205)     21792.3  Rx         01DB  8  00 00 C0 26 00 00 00 E9
   206)     21792.6  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   207)     21792.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   208)     21799.7  Rx         01DA  8  01 00 00 00 7F FF 03 FA
   209)     21802.1  Rx         01DB  8  00 00 C0 26 00 00 01 6C
   210)     21802.4  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   211)     21802.6  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   212)     21802.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
   213)     21806.8  Rx         056E  1  46
   214)     21809.7  Rx         01DA  8  01 00 00 00 7F FF 00 F0
   215)     21809.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   216)     21812.2  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   217)     21812.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   218)     21812.6  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   219)     21812.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   220)     21819.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   221)     21822.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   222)     21822.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   223)     21822.9  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   224)     21823.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   225)     21829.7  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   226)     21832.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   227)     21832.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   228)     21833.1  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   229)     21833.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
   230)     21833.6  Rx         050C  6  00 00 00 01 B2 31
   231)     21839.7  Rx         01DA  8  01 00 00 00 7F FF 03 FA
   232)     21842.3  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   233)     21842.6  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   234)     21842.8  Rx         055B  8  AB 00 55 00 FF C0 12 73
   235)     21843.3  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   236)     21843.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
   237)     21843.8  Rx         05A9  8  FF FF FC FF FF F0 00 00
   238)     21849.7  Rx         01DA  8  01 00 00 00 7F FF 00 F0
   239)     21850.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
   240)     21851.6  Rx         054B  8  00 08 80 00 04 00 00 00
   241)     21852.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   242)     21852.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   243)     21852.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   244)     21853.6  Rx         054F  8  49 00 00 00 0B 40 08 3F
   245)     21853.8  Rx         01D4  8  A0 6D 00 00 02 06 60 E4
   246)     21854.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   247)     21854.3  Rx         050A  6  06 20 00 17 00 00
   248)     21859.7  Rx         01DA  8  01 00 00 00 7F FF 01 75
   249)     21862.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   250)     21862.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   251)     21863.8  Rx         01D4  8  A0 6D 00 00 42 06 60 23
   252)     21864.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   253)     21869.1  Rx         0380  8  02 04 10 21 00 00 00 05
   254)     21869.4  Rx         05BF  8  00 00 00 00 18 00 00 2A
   255)     21869.7  Rx         01DA  8  01 00 00 00 7F FF 02 7F
   256)     21872.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   257)     21872.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   258)     21874.1  Rx         01D4  8  A0 6D 00 00 82 06 60 EF
   259)     21874.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
   260)     21874.5  Rx         050B  6  00 00 00 C0 00 00
   261)     21879.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   262)     21882.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   263)     21882.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   264)     21884.3  Rx         01D4  8  A0 6D 00 00 C2 06 60 28
   265)     21884.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
   266)     21889.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   267)     21892.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   268)     21892.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   269)     21894.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   270)     21894.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   271)     21899.7  Rx         01DA  8  01 00 00 00 00 01 01 15
   272)     21902.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   273)     21902.3  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   274)     21904.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   275)     21905.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   276)     21906.9  Rx         056E  1  46
   277)     21909.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
   278)     21909.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   279)     21912.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   280)     21912.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   281)     21915.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
   282)     21915.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
   283)     21915.4  Rx         05B9  5  07 FF 07 FF 28
   284)     21919.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   285)     21922.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   286)     21922.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   287)     21925.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   288)     21925.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
   289)     21929.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   290)     21932.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   291)     21932.3  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   292)     21935.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   293)     21935.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   294)     21936.0  Rx         050C  6  00 00 00 02 B2 0D
   295)     21939.7  Rx         01DA  8  01 00 00 00 00 01 01 15
   296)     21942.3  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   297)     21942.5  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   298)     21942.8  Rx         055B  8  AB 00 55 00 FF C0 13 F6
   299)     21945.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   300)     21946.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   301)     21949.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
   302)     21950.6  Rx         054A  8  12 00 70 02 00 00 00 3A
   303)     21951.7  Rx         054B  8  00 08 80 00 04 00 00 00
   304)     21952.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   305)     21952.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   306)     21952.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   307)     21953.6  Rx         054F  8  49 00 00 00 0B 80 08 3F
   308)     21956.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
   309)     21956.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
   310)     21956.5  Rx         050A  6  06 40 00 17 00 00
   311)     21959.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   312)     21962.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   313)     21962.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   314)     21966.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   315)     21966.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
   316)     21969.2  Rx         0380  8  02 04 10 21 00 00 00 16
   317)     21969.5  Rx         05BF  8  00 00 00 00 18 00 00 3B
   318)     21969.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   319)     21972.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   320)     21972.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   321)     21976.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   322)     21976.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   323)     21977.0  Rx         050B  6  00 00 00 C0 00 00
   324)     21979.7  Rx         01DA  8  01 00 00 00 00 01 01 15
   325)     21982.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   326)     21982.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   327)     21986.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   328)     21987.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   329)     21989.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
   330)     21992.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   331)     21992.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   332)     21996.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
   333)     21997.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
   334)     21999.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   335)     22002.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   336)     22002.4  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   337)     22006.8  Rx         056E  1  46
   338)     22007.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   339)     22007.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
   340)     22009.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   341)     22009.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   342)     22012.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   343)     22012.3  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   344)     22017.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   345)     22017.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   346)     22019.7  Rx         01DA  8  01 00 00 00 00 01 01 15
   347)     22022.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   348)     22022.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   349)     22027.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   350)     22027.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   351)     22029.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
   352)     22032.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   353)     22032.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   354)     22037.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
   355)     22038.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
   356)     22038.4  Rx         050C  6  00 00 00 03 B2 9A
   357)     22039.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   358)     22042.3  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   359)     22042.5  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   360)     22042.8  Rx         055B  8  AB 00 55 00 FF C0 10 FC
   361)     22048.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   362)     22048.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
   363)     22049.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   364)     22050.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
   365)     22051.8  Rx         054B  8  00 08 80 00 04 00 00 00
   366)     22052.4  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   367)     22052.7  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   368)     22053.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   369)     22053.2  Rx         05BC  8  FF C3 29 3A A8 05 20 78
   370)     22053.4  Rx         05C0  8  40 50 76 00 8C 00 1E 00
   371)     22053.7  Rx         054F  8  49 00 00 00 0B C0 08 3F
   372)     22058.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   373)     22058.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   374)     22058.9  Rx         050A  6  06 60 00 17 00 00
   375)     22059.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   376)     22062.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   377)     22062.3  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   378)     22068.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   379)     22068.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   380)     22069.2  Rx         0380  8  02 04 10 21 00 00 00 27
   381)     22069.5  Rx         05BF  8  00 00 00 00 18 00 00 08
   382)     22069.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
   383)     22072.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   384)     22072.4  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   385)     22078.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
   386)     22079.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
   387)     22079.4  Rx         050B  6  00 00 00 C0 00 00
   388)     22079.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
   389)     22082.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   390)     22082.3  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   391)     22089.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   392)     22089.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
   393)     22089.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   394)     22092.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   395)     22092.3  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   396)     22099.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   397)     22099.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   398)     22099.9  Rx         01DA  8  01 00 00 00 00 01 01 15
   399)     22102.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   400)     22102.3  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   401)     22106.9  Rx         056E  1  46
   402)     22109.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   403)     22109.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
   404)     22110.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   405)     22110.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   406)     22112.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   407)     22112.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   408)     22119.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   409)     22119.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
   410)     22120.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
   411)     22122.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   412)     22122.3  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   413)     22129.7  Rx         01DA  8  01 00 00 00 00 01 00 90
   414)     22130.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   415)     22130.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
   416)     22132.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   417)     22132.3  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   418)     22139.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   419)     22140.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   420)     22140.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   421)     22140.8  Rx         050C  6  00 00 00 00 B2 A6
   422)     22142.3  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   423)     22142.5  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   424)     22142.8  Rx         055B  8  AB 00 55 00 FF C0 11 79
   425)     22149.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   426)     22150.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   427)     22150.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   428)     22151.1  Rx         054A  8  12 00 70 02 00 00 00 3A
   429)     22151.8  Rx         054B  8  00 08 80 00 04 00 00 00
   430)     22152.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   431)     22152.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   432)     22152.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   433)     22153.8  Rx         054F  8  49 00 00 00 0B 00 08 3F
   434)     22159.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   435)     22160.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
   436)     22161.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
   437)     22161.4  Rx         050A  6  06 00 00 17 00 00
   438)     22162.1  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   439)     22162.3  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   440)     22169.4  Rx         0380  8  02 04 10 21 00 00 00 38
   441)     22169.6  Rx         05BF  8  00 00 00 00 18 00 00 19
   442)     22169.9  Rx         01DA  8  01 00 00 00 00 01 00 90
   443)     22171.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   444)     22171.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
   445)     22172.1  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   446)     22172.4  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   447)     22179.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   448)     22181.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   449)     22181.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   450)     22181.8  Rx         050B  6  00 00 00 C0 00 00
   451)     22182.1  Rx         01DB  8  00 20 C0 2E 00 00 03 02
   452)     22182.4  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   453)     22189.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   454)     22191.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   455)     22191.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   456)     22192.1  Rx         01DB  8  00 20 C0 2E 00 00 00 08
   457)     22192.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   458)     22199.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   459)     22201.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
   460)     22202.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
   461)     22202.3  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   462)     22202.5  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   463)     22206.9  Rx         056E  1  46
   464)     22209.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   465)     22209.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   466)     22212.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   467)     22212.3  Rx         01DB  8  00 00 C0 2E 00 00 02 D6
   468)     22212.6  Rx         01DC  8  FF FF FF FF 05 54 C6 73
   469)     22212.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
   470)     22219.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   471)     22222.1  Rx         01DB  8  00 00 C0 2E 00 00 03 53
   472)     22222.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   473)     22222.5  Rx         01DC  8  FF FF FF FF 08 C0 C7 88
   474)     22222.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   475)     22229.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   476)     22232.1  Rx         01DB  8  00 00 C0 2E 00 00 00 59
   477)     22232.3  Rx         01DC  8  FF FF FF FF 0C C0 D4 87
   478)     22232.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   479)     22232.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   480)     22239.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   481)     22242.3  Rx         01DB  8  00 00 C0 2E 00 00 01 DC
   482)     22242.5  Rx         01DC  8  FF FF FF FF 01 0C C5 67
   483)     22242.7  Rx         055B  8  AB 00 AA 00 FF C0 12 34
   484)     22243.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
   485)     22243.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
   486)     22243.4  Rx         050C  6  00 00 00 01 B2 31
   487)     22249.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   488)     22250.9  Rx         054A  8  A0 00 70 02 00 00 00 3A
   489)     22251.8  Rx         054B  8  00 08 80 00 04 00 00 00
   490)     22252.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   491)     22252.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   492)     22252.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   493)     22253.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   494)     22253.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
   495)     22253.9  Rx         054F  8  49 00 00 00 0B 40 08 3F
   496)     22259.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   497)     22262.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   498)     22262.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   499)     22263.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   500)     22263.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   501)     22263.8  Rx         050A  6  06 20 00 17 00 00
   502)     22269.5  Rx         0380  8  02 04 10 21 00 00 00 05
   503)     22269.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
   504)     22270.0  Rx         05BF  8  00 00 00 00 18 00 00 2A
   505)     22272.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   506)     22272.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   507)     22273.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   508)     22273.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   509)     22279.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   510)     22282.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   511)     22282.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   512)     22283.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
   513)     22284.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
   514)     22284.2  Rx         050B  6  00 00 00 C0 00 00
   515)     22289.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   516)     22292.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   517)     22292.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   518)     22294.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   519)     22294.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
   520)     22299.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   521)     22302.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   522)     22302.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   523)     22304.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   524)     22304.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   525)     22306.9  Rx         056E  1  46
   526)     22309.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   527)     22309.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   528)     22312.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   529)     22312.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   530)     22314.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   531)     22314.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   532)     22319.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   533)     22322.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   534)     22322.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   535)     22324.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
   536)     22325.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
   537)     22329.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   538)     22332.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   539)     22332.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   540)     22335.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   541)     22335.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
   542)     22339.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   543)     22342.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   544)     22342.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   545)     22342.7  Rx         055B  8  AB 00 AA 00 FF C0 13 B1
   546)     22345.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   547)     22345.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   548)     22345.8  Rx         050C  6  00 00 00 02 5D 63
   549)     22349.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   550)     22351.0  Rx         054A  8  12 00 70 02 00 00 00 3A
   551)     22351.9  Rx         054B  8  00 08 80 00 04 00 00 00
   552)     22352.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   553)     22352.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   554)     22353.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   555)     22353.9  Rx         054F  8  49 00 00 00 0B 80 08 3F
   556)     22355.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   557)     22355.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   558)     22356.0  Rx         05A9  8  FF FF FC 0E 83 40 00 00
   559)     22359.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   560)     22362.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   561)     22362.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   562)     22365.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
   563)     22366.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
   564)     22366.2  Rx         050A  6  06 40 00 17 00 00
   565)     22369.6  Rx         0380  8  02 04 10 21 00 00 00 16
   566)     22369.8  Rx         01DA  8  01 00 00 00 00 01 00 90
   567)     22370.0  Rx         05BF  8  00 00 00 00 18 00 00 3B
   568)     22372.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   569)     22372.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   570)     22376.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   571)     22376.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
   572)     22379.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   573)     22382.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   574)     22382.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   575)     22386.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   576)     22386.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   577)     22386.7  Rx         050B  6  00 00 00 C0 00 00
   578)     22389.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   579)     22392.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   580)     22392.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   581)     22396.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   582)     22396.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   583)     22399.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   584)     22402.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   585)     22402.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   586)     22406.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
   587)     22407.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
   588)     22407.0  Rx         056E  1  46
   589)     22409.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   590)     22409.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   591)     22412.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   592)     22412.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   593)     22416.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   594)     22417.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
   595)     22419.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   596)     22422.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   597)     22422.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   598)     22427.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   599)     22427.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   600)     22427.6  Rx         05B9  5  00 78 07 FF 28
   601)     22429.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   602)     22432.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   603)     22432.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   604)     22437.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   605)     22437.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   606)     22439.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   607)     22442.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   608)     22442.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   609)     22442.7  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
   610)     22447.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
   611)     22447.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
   612)     22448.1  Rx         050C  6  00 00 00 03 5D F4
   613)     22449.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   614)     22451.0  Rx         054A  8  A0 00 70 02 00 00 00 3A
   615)     22452.0  Rx         054B  8  00 08 80 00 04 00 00 00
   616)     22452.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   617)     22452.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   618)     22453.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   619)     22454.0  Rx         054F  8  49 00 00 00 0B C0 08 3F
   620)     22457.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   621)     22458.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
   622)     22459.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   623)     22462.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   624)     22462.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   625)     22468.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   626)     22468.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   627)     22468.6  Rx         050A  6  06 60 00 17 00 00
   628)     22469.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   629)     22469.8  Rx         0380  8  02 04 10 21 00 00 00 27
   630)     22470.1  Rx         05BF  8  00 00 00 00 18 00 00 08
   631)     22472.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   632)     22472.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   633)     22478.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   634)     22478.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   635)     22479.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   636)     22482.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   637)     22482.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   638)     22488.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
   639)     22488.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   640)     22489.1  Rx         050B  6  00 00 00 C0 00 00
   641)     22489.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   642)     22492.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   643)     22492.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   644)     22498.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   645)     22499.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   646)     22499.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   647)     22502.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   648)     22502.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   649)     22506.9  Rx         056E  1  46
   650)     22509.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   651)     22509.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   652)     22509.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   653)     22509.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   654)     22512.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   655)     22512.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   656)     22519.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   657)     22519.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   658)     22519.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   659)     22522.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   660)     22522.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   661)     22529.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   662)     22529.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
   663)     22530.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
   664)     22532.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   665)     22532.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   666)     22539.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   667)     22539.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   668)     22540.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   669)     22542.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   670)     22542.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   671)     22542.7  Rx         055B  8  AB 00 AA 00 FF C0 11 3E
   672)     22549.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   673)     22550.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   674)     22550.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   675)     22550.6  Rx         050C  6  00 00 00 00 5D C8
   676)     22551.1  Rx         054A  8  12 00 70 02 00 00 00 3A
   677)     22552.1  Rx         054B  8  00 08 80 00 04 00 00 00
   678)     22552.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   679)     22552.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   680)     22552.8  Rx         05BC  8  29 03 2C 3A A9 05 40 32
   681)     22553.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   682)     22553.4  Rx         05C0  8  80 74 74 00 8C D0 18 00
   683)     22554.1  Rx         054F  8  49 00 00 00 0B 00 08 3F
   684)     22559.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   685)     22560.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   686)     22560.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   687)     22562.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   688)     22562.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   689)     22569.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   690)     22569.8  Rx         0380  8  02 04 10 21 00 00 00 38
   691)     22570.1  Rx         05BF  8  00 00 00 00 18 00 00 19
   692)     22570.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
   693)     22570.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   694)     22571.0  Rx         050A  6  06 00 00 17 00 00
   695)     22572.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   696)     22572.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   697)     22579.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   698)     22580.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   699)     22581.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   700)     22582.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   701)     22582.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   702)     22589.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   703)     22591.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   704)     22591.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   705)     22591.5  Rx         050B  6  00 00 00 C0 00 00
   706)     22592.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   707)     22592.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   708)     22599.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   709)     22601.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   710)     22601.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   711)     22602.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   712)     22602.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   713)     22606.9  Rx         056E  1  46
   714)     22609.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   715)     22609.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   716)     22611.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
   717)     22611.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   718)     22612.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   719)     22612.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   720)     22619.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   721)     22621.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   722)     22622.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   723)     22622.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   724)     22622.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   725)     22629.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   726)     22632.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   727)     22632.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   728)     22632.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   729)     22632.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   730)     22639.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   731)     22642.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   732)     22642.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   733)     22642.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   734)     22642.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   735)     22643.2  Rx         055B  8  AB 00 AA 00 FF C0 12 34
   736)     22649.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   737)     22651.2  Rx         054A  8  A0 00 70 02 00 00 00 3A
   738)     22652.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   739)     22652.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   740)     22652.5  Rx         054B  8  00 08 80 00 04 00 00 00
   741)     22652.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
   742)     22653.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
   743)     22653.2  Rx         050C  6  00 00 00 01 5D 5F
   744)     22653.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   745)     22654.2  Rx         054F  8  49 00 00 00 0B 40 08 3F
   746)     22659.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   747)     22662.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   748)     22662.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   749)     22662.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   750)     22663.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   751)     22669.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   752)     22669.9  Rx         0380  8  02 04 10 21 00 00 00 05
   753)     22670.1  Rx         05BF  8  00 00 00 00 18 00 00 2A
   754)     22672.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   755)     22672.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   756)     22673.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   757)     22673.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   758)     22673.5  Rx         050A  6  06 20 00 17 00 00
   759)     22679.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   760)     22682.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   761)     22682.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   762)     22683.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   763)     22683.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   764)     22689.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   765)     22692.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   766)     22692.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   767)     22693.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
   768)     22693.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   769)     22694.0  Rx         050B  6  00 00 00 C0 00 00
   770)     22699.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   771)     22702.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   772)     22702.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   773)     22703.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   774)     22704.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
   775)     22707.0  Rx         056E  1  46
   776)     22709.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   777)     22709.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   778)     22712.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   779)     22712.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   780)     22714.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   781)     22714.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   782)     22719.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
   783)     22722.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   784)     22722.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   785)     22724.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   786)     22724.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   787)     22729.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   788)     22732.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   789)     22732.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   790)     22734.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
   791)     22734.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   792)     22739.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   793)     22742.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   794)     22742.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   795)     22742.7  Rx         055B  8  AB 00 55 00 FF C0 13 F6
   796)     22744.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   797)     22745.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
   798)     22749.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   799)     22751.3  Rx         054A  8  12 00 70 02 00 00 00 3A
   800)     22752.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   801)     22752.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   802)     22752.5  Rx         054B  8  00 08 80 00 04 00 00 00
   803)     22753.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   804)     22754.2  Rx         054F  8  49 00 00 00 0B 80 08 3F
   805)     22755.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   806)     22755.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   807)     22755.5  Rx         050C  6  00 00 00 02 B2 0D
   808)     22759.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   809)     22762.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   810)     22762.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   811)     22765.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   812)     22765.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   813)     22769.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   814)     22769.9  Rx         0380  8  02 04 10 21 00 00 00 16
   815)     22770.2  Rx         05BF  8  00 00 00 00 18 00 00 3B
   816)     22772.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   817)     22772.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   818)     22775.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
   819)     22775.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
   820)     22775.9  Rx         050A  6  06 40 00 17 00 00
   821)     22779.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   822)     22782.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   823)     22782.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   824)     22785.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   825)     22785.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
   826)     22789.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   827)     22792.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   828)     22792.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   829)     22795.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   830)     22796.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   831)     22796.4  Rx         050B  6  00 00 00 C0 00 00
   832)     22799.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   833)     22802.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   834)     22802.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   835)     22806.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   836)     22806.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   837)     22807.2  Rx         056E  1  46
   838)     22809.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   839)     22809.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   840)     22812.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   841)     22812.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   842)     22816.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
   843)     22816.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
   844)     22819.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   845)     22822.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   846)     22822.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   847)     22826.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   848)     22826.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
   849)     22829.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
   850)     22832.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   851)     22832.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   852)     22836.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   853)     22837.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   854)     22839.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   855)     22842.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   856)     22842.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   857)     22842.7  Rx         055B  8  AB 00 55 00 FF C0 10 FC
   858)     22847.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   859)     22847.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   860)     22849.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   861)     22851.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
   862)     22852.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   863)     22852.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   864)     22852.5  Rx         054B  8  00 08 80 00 04 00 00 00
   865)     22853.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   866)     22854.3  Rx         054F  8  49 00 00 00 0B C0 08 3F
   867)     22857.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
   868)     22857.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   869)     22858.0  Rx         050C  6  00 00 00 03 B2 9A
   870)     22859.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   871)     22862.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   872)     22862.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   873)     22867.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   874)     22867.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
   875)     22868.1  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
   876)     22869.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   877)     22870.1  Rx         0380  8  02 04 10 21 00 00 00 27
   878)     22870.4  Rx         05BF  8  00 00 00 00 18 00 00 08
   879)     22872.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   880)     22872.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   881)     22878.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   882)     22878.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   883)     22878.4  Rx         050A  6  06 60 00 17 00 00
   884)     22879.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   885)     22882.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   886)     22882.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   887)     22888.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   888)     22888.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   889)     22889.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   890)     22892.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   891)     22892.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   892)     22898.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
   893)     22898.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
   894)     22898.8  Rx         050B  6  00 00 00 C0 00 00
   895)     22899.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   896)     22902.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   897)     22902.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   898)     22907.0  Rx         056E  1  46
   899)     22908.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   900)     22908.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
   901)     22909.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   902)     22909.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   903)     22912.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   904)     22912.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   905)     22918.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   906)     22919.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   907)     22919.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   908)     22922.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   909)     22922.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   910)     22929.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   911)     22929.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   912)     22929.6  Rx         01DA  8  01 00 00 00 00 01 00 90
   913)     22932.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   914)     22932.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   915)     22939.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
   916)     22939.6  Rx         01DA  8  01 00 00 00 00 01 01 15
   917)     22939.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
   918)     22940.0  Rx         05B9  5  00 78 67 FF 28
   919)     22942.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   920)     22942.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   921)     22942.7  Rx         055B  8  AB 00 55 00 FF C0 11 79
   922)     22949.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   923)     22949.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   924)     22950.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
   925)     22951.4  Rx         054A  8  12 00 70 02 00 00 00 3A
   926)     22952.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   927)     22952.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   928)     22952.5  Rx         054B  8  00 08 80 00 04 00 00 00
   929)     22953.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   930)     22954.4  Rx         054F  8  49 00 00 00 0B 00 08 3F
   931)     22959.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   932)     22959.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   933)     22960.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   934)     22960.4  Rx         050C  6  00 00 00 00 B2 A6
   935)     22962.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   936)     22962.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   937)     22969.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   938)     22970.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   939)     22970.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   940)     22970.6  Rx         0380  8  02 04 10 21 00 00 00 38
   941)     22970.8  Rx         05BF  8  00 00 00 00 18 00 00 19
   942)     22972.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   943)     22972.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   944)     22979.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   945)     22980.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
   946)     22980.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
   947)     22980.8  Rx         050A  6  06 00 00 17 00 00
   948)     22982.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   949)     22982.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   950)     22989.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   951)     22990.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   952)     22990.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
   953)     22992.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   954)     22992.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   955)     22999.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   956)     23000.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   957)     23001.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   958)     23001.3  Rx         050B  6  00 00 00 C0 00 00
   959)     23002.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   960)     23002.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   961)     23007.0  Rx         056E  1  46
   962)     23009.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   963)     23009.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
   964)     23011.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   965)     23011.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   966)     23012.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   967)     23012.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   968)     23019.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   969)     23021.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
   970)     23021.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
   971)     23022.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   972)     23022.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   973)     23029.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
   974)     23031.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
   975)     23031.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
   976)     23032.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
   977)     23032.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
   978)     23039.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
   979)     23041.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
   980)     23042.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
   981)     23042.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
   982)     23042.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
   983)     23042.7  Rx         055B  8  AB 00 55 00 FF C0 12 73
   984)     23049.5  Rx         01DA  8  01 00 00 00 00 01 00 90
   985)     23051.5  Rx         054A  8  A0 00 70 02 00 00 00 3A
   986)     23052.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
   987)     23052.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
   988)     23052.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
   989)     23052.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
   990)     23053.0  Rx         054B  8  00 08 80 00 04 00 00 00
   991)     23053.3  Rx         05BC  8  29 03 29 3A A8 06 21 4A
   992)     23053.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
   993)     23053.7  Rx         05C0  8  C0 74 74 00 8C D0 18 00
   994)     23054.5  Rx         054F  8  49 00 00 00 0B 40 08 3F
   995)     23059.5  Rx         01DA  8  01 00 00 00 00 01 01 15
   996)     23062.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
   997)     23062.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
   998)     23062.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
   999)     23062.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1000)     23062.9  Rx         050C  6  00 00 00 01 B2 31
  1001)     23069.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1002)     23070.3  Rx         0380  8  02 04 10 21 00 00 00 05
  1003)     23070.5  Rx         05BF  8  00 00 00 00 18 00 00 2A
  1004)     23072.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1005)     23072.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1006)     23072.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1007)     23072.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1008)     23079.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1009)     23082.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1010)     23082.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1011)     23082.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1012)     23083.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1013)     23083.2  Rx         050A  6  06 20 00 17 00 00
  1014)     23089.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  1015)     23092.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1016)     23092.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1017)     23093.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1018)     23093.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1019)     23099.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  1020)     23102.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1021)     23102.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1022)     23103.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1023)     23103.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1024)     23103.7  Rx         050B  6  00 00 00 C0 00 00
  1025)     23107.1  Rx         056E  1  46
  1026)     23109.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1027)     23109.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1028)     23112.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1029)     23112.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1030)     23113.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1031)     23113.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1032)     23119.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1033)     23122.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1034)     23122.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1035)     23123.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1036)     23123.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1037)     23129.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  1038)     23132.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1039)     23132.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1040)     23134.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1041)     23134.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1042)     23139.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  1043)     23142.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1044)     23142.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1045)     23142.6  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  1046)     23144.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1047)     23144.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1048)     23149.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1049)     23151.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  1050)     23152.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1051)     23152.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1052)     23152.6  Rx         054B  8  00 08 80 00 04 00 00 00
  1053)     23153.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1054)     23154.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1055)     23154.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1056)     23155.0  Rx         054F  8  49 00 00 00 0B 80 08 3F
  1057)     23159.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1058)     23162.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1059)     23162.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1060)     23164.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1061)     23165.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1062)     23165.2  Rx         050C  6  00 00 00 02 B2 0D
  1063)     23169.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  1064)     23170.4  Rx         0380  8  02 04 10 21 00 00 00 16
  1065)     23170.6  Rx         05BF  8  00 00 00 00 18 00 00 3B
  1066)     23172.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1067)     23172.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1068)     23175.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1069)     23175.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1070)     23179.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1071)     23182.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1072)     23182.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1073)     23185.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1074)     23185.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1075)     23185.6  Rx         050A  6  06 40 00 17 00 00
  1076)     23189.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1077)     23192.0  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  1078)     23192.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1079)     23195.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1080)     23195.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1081)     23199.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1082)     23202.0  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1083)     23202.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1084)     23205.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1085)     23205.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1086)     23206.1  Rx         050B  6  00 00 00 C0 00 00
  1087)     23207.1  Rx         056E  1  46
  1088)     23209.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1089)     23209.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1090)     23212.0  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  1091)     23212.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1092)     23215.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1093)     23216.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1094)     23219.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  1095)     23222.0  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  1096)     23222.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1097)     23226.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1098)     23226.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1099)     23229.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1100)     23232.0  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  1101)     23232.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1102)     23236.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1103)     23236.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1104)     23239.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1105)     23242.2  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1106)     23242.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1107)     23242.6  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  1108)     23246.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1109)     23246.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1110)     23249.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1111)     23251.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1112)     23252.0  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  1113)     23252.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1114)     23252.6  Rx         054B  8  00 08 80 00 04 00 00 00
  1115)     23253.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1116)     23254.6  Rx         054F  8  49 00 00 00 0B C0 08 3F
  1117)     23257.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1118)     23257.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1119)     23259.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1120)     23261.9  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  1121)     23262.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1122)     23267.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1123)     23267.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1124)     23267.6  Rx         050C  6  00 00 00 03 5D F4
  1125)     23269.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1126)     23270.5  Rx         0380  8  02 04 10 21 00 00 00 27
  1127)     23270.7  Rx         05BF  8  00 00 00 00 18 00 00 08
  1128)     23272.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1129)     23272.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1130)     23277.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1131)     23277.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1132)     23279.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1133)     23282.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1134)     23282.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1135)     23287.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1136)     23287.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1137)     23288.1  Rx         050A  6  06 60 00 17 00 00
  1138)     23289.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1139)     23291.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1140)     23292.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1141)     23297.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1142)     23298.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1143)     23299.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  1144)     23302.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1145)     23302.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1146)     23307.0  Rx         056E  1  46
  1147)     23308.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1148)     23308.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1149)     23308.5  Rx         050B  6  00 00 00 C0 00 00
  1150)     23309.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1151)     23309.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1152)     23312.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1153)     23312.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1154)     23318.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1155)     23318.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1156)     23319.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1157)     23321.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1158)     23322.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1159)     23328.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1160)     23328.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1161)     23329.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1162)     23332.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1163)     23332.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1164)     23338.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1165)     23339.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1166)     23339.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1167)     23342.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1168)     23342.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1169)     23342.6  Rx         055B  8  AB 00 AA 00 FF C0 11 3E
  1170)     23349.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1171)     23349.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1172)     23349.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1173)     23351.7  Rx         054A  8  12 00 70 02 00 00 00 3A
  1174)     23352.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1175)     23352.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1176)     23352.7  Rx         054B  8  00 08 80 00 04 00 00 00
  1177)     23353.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1178)     23354.7  Rx         054F  8  49 00 00 00 0B 00 08 3F
  1179)     23359.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1180)     23359.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1181)     23359.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1182)     23362.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1183)     23362.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1184)     23369.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1185)     23369.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1186)     23369.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1187)     23370.1  Rx         050C  6  00 00 00 00 5D C8
  1188)     23370.6  Rx         0380  8  02 04 10 21 00 00 00 38
  1189)     23370.8  Rx         05BF  8  00 00 00 00 18 00 00 19
  1190)     23371.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1191)     23372.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1192)     23379.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1193)     23379.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1194)     23380.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1195)     23380.3  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  1196)     23382.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1197)     23382.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1198)     23389.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1199)     23390.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1200)     23390.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1201)     23390.5  Rx         050A  6  06 00 00 17 00 00
  1202)     23391.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1203)     23392.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1204)     23399.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1205)     23400.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1206)     23400.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1207)     23401.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1208)     23402.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1209)     23407.1  Rx         056E  1  46
  1210)     23409.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1211)     23409.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1212)     23410.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1213)     23410.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1214)     23411.0  Rx         050B  6  00 00 00 C0 00 00
  1215)     23412.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1216)     23412.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1217)     23419.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1218)     23420.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1219)     23421.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1220)     23421.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1221)     23422.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1222)     23429.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1223)     23431.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1224)     23431.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1225)     23432.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1226)     23432.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1227)     23439.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1228)     23441.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1229)     23441.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1230)     23442.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1231)     23442.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1232)     23442.6  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  1233)     23449.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1234)     23451.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1235)     23451.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1236)     23452.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1237)     23452.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1238)     23452.5  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1239)     23452.7  Rx         05B9  5  40 78 61 4A 28
  1240)     23453.8  Rx         054B  8  00 08 80 00 04 00 00 00
  1241)     23454.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1242)     23455.8  Rx         054F  8  49 00 00 00 0B 40 08 3F
  1243)     23459.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1244)     23461.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1245)     23462.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1246)     23462.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1247)     23462.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1248)     23469.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1249)     23470.7  Rx         0380  8  02 04 10 21 00 00 00 05
  1250)     23470.9  Rx         05BF  8  00 00 00 00 18 00 00 2A
  1251)     23471.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1252)     23472.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1253)     23472.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1254)     23472.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1255)     23472.9  Rx         050C  6  00 00 00 01 5D 5F
  1256)     23479.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1257)     23481.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1258)     23482.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1259)     23482.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1260)     23482.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1261)     23489.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1262)     23491.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1263)     23492.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1264)     23492.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1265)     23492.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1266)     23492.9  Rx         050A  6  06 20 00 17 00 00
  1267)     23499.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1268)     23501.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1269)     23502.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1270)     23502.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1271)     23503.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1272)     23507.1  Rx         056E  1  46
  1273)     23509.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1274)     23509.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1275)     23511.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1276)     23512.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1277)     23513.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1278)     23513.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1279)     23513.5  Rx         050B  6  00 00 00 C0 00 00
  1280)     23519.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1281)     23521.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1282)     23522.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1283)     23523.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1284)     23523.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1285)     23529.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1286)     23531.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1287)     23532.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1288)     23533.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1289)     23533.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1290)     23539.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1291)     23542.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1292)     23542.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1293)     23542.6  Rx         055B  8  AB 00 AA 00 FF C0 13 B1
  1294)     23543.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1295)     23544.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1296)     23549.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1297)     23551.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  1298)     23552.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1299)     23552.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1300)     23552.7  Rx         05BC  8  29 03 2C 3A A9 06 40 96
  1301)     23553.0  Rx         054B  8  00 08 80 00 04 00 00 00
  1302)     23553.2  Rx         05C0  8  40 76 76 00 8C 08 18 00
  1303)     23553.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1304)     23554.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1305)     23554.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1306)     23554.8  Rx         054F  8  49 00 00 00 0B 80 08 3F
  1307)     23559.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1308)     23561.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1309)     23562.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1310)     23564.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1311)     23564.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1312)     23569.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1313)     23570.8  Rx         0380  8  02 04 10 21 00 00 00 16
  1314)     23571.0  Rx         05BF  8  00 00 00 00 18 00 00 3B
  1315)     23571.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1316)     23572.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1317)     23574.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1318)     23574.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1319)     23574.9  Rx         050C  6  00 00 00 02 5D 63
  1320)     23579.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1321)     23581.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1322)     23582.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1323)     23584.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1324)     23584.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1325)     23589.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1326)     23591.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1327)     23592.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1328)     23594.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1329)     23595.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1330)     23595.4  Rx         050A  6  06 40 00 17 00 00
  1331)     23599.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1332)     23601.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1333)     23602.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1334)     23605.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1335)     23605.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1336)     23607.1  Rx         056E  1  86
  1337)     23609.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1338)     23609.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1339)     23612.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1340)     23612.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1341)     23615.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1342)     23615.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1343)     23615.9  Rx         050B  6  00 00 00 C0 00 00
  1344)     23619.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1345)     23621.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1346)     23622.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1347)     23625.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1348)     23625.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1349)     23629.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1350)     23631.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1351)     23632.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1352)     23635.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1353)     23636.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1354)     23639.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1355)     23642.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1356)     23642.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1357)     23642.6  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  1358)     23646.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1359)     23646.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1360)     23649.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1361)     23651.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1362)     23652.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1363)     23652.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1364)     23653.0  Rx         054B  8  00 08 80 00 04 00 00 00
  1365)     23653.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1366)     23655.0  Rx         054F  8  49 00 00 00 0B C0 08 3F
  1367)     23656.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1368)     23656.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1369)     23659.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1370)     23661.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1371)     23662.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1372)     23666.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1373)     23666.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1374)     23669.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1375)     23670.9  Rx         0380  8  02 04 10 21 00 00 00 27
  1376)     23671.1  Rx         05BF  8  00 00 00 00 18 00 00 08
  1377)     23671.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1378)     23672.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1379)     23676.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1380)     23677.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1381)     23677.4  Rx         050C  6  00 00 00 03 5D F4
  1382)     23679.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1383)     23681.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1384)     23682.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1385)     23687.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1386)     23687.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1387)     23689.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1388)     23691.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1389)     23692.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1390)     23697.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1391)     23697.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1392)     23697.8  Rx         050A  6  06 60 00 17 00 00
  1393)     23699.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1394)     23701.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1395)     23702.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1396)     23707.1  Rx         056E  1  86
  1397)     23707.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1398)     23707.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1399)     23709.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1400)     23709.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1401)     23711.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1402)     23712.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1403)     23717.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1404)     23718.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1405)     23718.3  Rx         050B  6  00 00 00 C0 00 00
  1406)     23719.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1407)     23721.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1408)     23722.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1409)     23728.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1410)     23728.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1411)     23729.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1412)     23731.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1413)     23732.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1414)     23738.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1415)     23738.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1416)     23739.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1417)     23742.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1418)     23742.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1419)     23742.6  Rx         055B  8  AB 00 55 00 FF C0 11 79
  1420)     23748.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1421)     23748.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1422)     23749.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1423)     23751.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1424)     23752.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1425)     23752.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  1426)     23753.0  Rx         054B  8  00 08 80 00 04 00 00 00
  1427)     23754.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1428)     23755.0  Rx         054F  8  49 00 00 00 0B 00 08 3F
  1429)     23758.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1430)     23759.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1431)     23759.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1432)     23761.9  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1433)     23762.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1434)     23769.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1435)     23769.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1436)     23769.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  1437)     23771.0  Rx         0380  8  02 04 10 21 00 00 00 38
  1438)     23771.2  Rx         05BF  8  00 00 00 00 18 00 00 19
  1439)     23771.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1440)     23772.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1441)     23779.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1442)     23779.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1443)     23779.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1444)     23780.0  Rx         050C  6  00 00 00 00 B2 A6
  1445)     23781.9  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  1446)     23782.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1447)     23789.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1448)     23789.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1449)     23789.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1450)     23791.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1451)     23792.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1452)     23799.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1453)     23799.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1454)     23800.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1455)     23800.3  Rx         050A  6  06 00 00 17 00 00
  1456)     23801.9  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1457)     23802.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1458)     23807.1  Rx         056E  1  86
  1459)     23809.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1460)     23809.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1461)     23810.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1462)     23810.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1463)     23811.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1464)     23812.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1465)     23819.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1466)     23820.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1467)     23820.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1468)     23820.8  Rx         050B  6  00 00 00 C0 00 00
  1469)     23821.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1470)     23822.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1471)     23829.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1472)     23830.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1473)     23830.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1474)     23831.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1475)     23832.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1476)     23839.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1477)     23840.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1478)     23841.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1479)     23842.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1480)     23842.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1481)     23842.6  Rx         055B  8  AB 00 55 00 FF C0 12 73
  1482)     23849.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1483)     23851.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1484)     23851.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1485)     23851.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1486)     23852.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1487)     23852.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1488)     23853.1  Rx         054B  8  00 08 80 00 04 00 00 00
  1489)     23854.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1490)     23855.1  Rx         054F  8  49 00 00 00 0B 40 08 3F
  1491)     23859.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  1492)     23861.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1493)     23861.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1494)     23861.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1495)     23862.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1496)     23869.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1497)     23871.1  Rx         0380  8  02 04 10 21 00 00 00 05
  1498)     23871.3  Rx         05BF  8  00 00 00 00 18 00 00 2A
  1499)     23871.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1500)     23871.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1501)     23872.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1502)     23872.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1503)     23879.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1504)     23881.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1505)     23882.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1506)     23882.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1507)     23882.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1508)     23882.7  Rx         050C  6  00 00 00 01 B2 31
  1509)     23889.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  1510)     23891.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1511)     23892.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1512)     23892.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1513)     23892.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1514)     23892.9  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  1515)     23899.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1516)     23901.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1517)     23902.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1518)     23902.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1519)     23902.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1520)     23902.8  Rx         050A  6  06 20 00 17 00 00
  1521)     23907.3  Rx         056E  1  86
  1522)     23909.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1523)     23909.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1524)     23911.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1525)     23912.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1526)     23912.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1527)     23912.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1528)     23919.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1529)     23921.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1530)     23922.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1531)     23922.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1532)     23923.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1533)     23923.2  Rx         050B  6  00 00 00 C0 00 00
  1534)     23929.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1535)     23931.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1536)     23932.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1537)     23933.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1538)     23933.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1539)     23939.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1540)     23942.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1541)     23942.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1542)     23942.6  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  1543)     23943.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1544)     23943.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1545)     23949.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1546)     23951.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1547)     23952.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1548)     23952.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  1549)     23953.1  Rx         054B  8  00 08 80 00 04 00 00 00
  1550)     23953.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1551)     23953.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1552)     23954.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1553)     23955.1  Rx         054F  8  49 00 00 00 0B 80 08 3F
  1554)     23959.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1555)     23961.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1556)     23962.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1557)     23963.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1558)     23964.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1559)     23964.1  Rx         05B9  5  40 78 61 4A 28
  1560)     23969.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1561)     23971.2  Rx         0380  8  02 04 10 21 00 00 00 16
  1562)     23971.5  Rx         05BF  8  00 00 00 00 18 00 00 3B
  1563)     23971.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1564)     23972.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1565)     23974.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1566)     23974.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1567)     23979.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1568)     23981.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1569)     23982.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1570)     23984.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1571)     23984.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1572)     23984.7  Rx         050C  6  00 00 00 02 B2 0D
  1573)     23989.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1574)     23991.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1575)     23992.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1576)     23994.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1577)     23994.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1578)     23999.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1579)     24001.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1580)     24002.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1581)     24004.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1582)     24004.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1583)     24005.1  Rx         050A  6  06 40 00 17 00 00
  1584)     24007.3  Rx         056E  1  86
  1585)     24009.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1586)     24009.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1587)     24011.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1588)     24012.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1589)     24014.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1590)     24015.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1591)     24019.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1592)     24021.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1593)     24022.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1594)     24025.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1595)     24025.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1596)     24025.6  Rx         050B  6  00 00 00 C0 00 00
  1597)     24029.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1598)     24031.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1599)     24032.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1600)     24035.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1601)     24035.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1602)     24039.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1603)     24042.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1604)     24042.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1605)     24042.5  Rx         055B  8  AB 00 55 00 FF C0 10 FC
  1606)     24045.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1607)     24045.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1608)     24049.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1609)     24052.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1610)     24052.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1611)     24052.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1612)     24052.9  Rx         05BC  8  29 03 29 3A A8 04 1F FF
  1613)     24053.2  Rx         05C0  8  80 74 74 00 8C D0 18 00
  1614)     24053.4  Rx         054B  8  00 08 80 00 04 00 00 00
  1615)     24054.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1616)     24055.2  Rx         054F  8  49 00 00 00 0B C0 08 3F
  1617)     24055.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1618)     24056.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1619)     24059.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1620)     24061.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1621)     24062.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1622)     24066.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1623)     24066.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1624)     24069.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1625)     24071.3  Rx         0380  8  02 04 10 21 00 00 00 27
  1626)     24071.6  Rx         05BF  8  00 00 00 00 18 00 00 08
  1627)     24071.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1628)     24072.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1629)     24076.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1630)     24076.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1631)     24079.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1632)     24081.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1633)     24082.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1634)     24086.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1635)     24086.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1636)     24087.1  Rx         050C  6  00 00 00 03 B2 9A
  1637)     24089.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1638)     24091.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1639)     24092.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1640)     24096.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1641)     24097.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1642)     24099.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1643)     24101.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1644)     24102.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1645)     24107.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1646)     24107.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1647)     24107.5  Rx         050A  6  06 60 00 17 00 00
  1648)     24107.7  Rx         056E  1  86
  1649)     24109.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1650)     24109.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1651)     24111.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1652)     24112.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1653)     24117.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1654)     24117.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1655)     24119.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1656)     24121.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1657)     24122.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1658)     24127.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1659)     24127.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1660)     24128.0  Rx         050B  6  00 00 00 C0 00 00
  1661)     24129.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1662)     24131.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1663)     24132.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1664)     24137.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1665)     24138.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1666)     24139.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1667)     24142.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1668)     24142.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1669)     24142.5  Rx         055B  8  AB 00 55 00 FF C0 11 79
  1670)     24148.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1671)     24148.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1672)     24149.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1673)     24151.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1674)     24152.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1675)     24152.3  Rx         054A  8  12 00 70 02 00 00 00 3A
  1676)     24153.3  Rx         054B  8  00 08 80 00 04 00 00 00
  1677)     24154.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1678)     24155.3  Rx         054F  8  49 00 00 00 0B 00 08 3F
  1679)     24158.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1680)     24158.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1681)     24159.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1682)     24161.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1683)     24162.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1684)     24168.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1685)     24168.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1686)     24169.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1687)     24171.4  Rx         0380  8  02 04 10 21 00 00 00 38
  1688)     24171.7  Rx         05BF  8  00 00 00 00 18 00 00 19
  1689)     24171.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1690)     24172.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1691)     24178.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1692)     24179.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1693)     24179.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1694)     24181.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1695)     24182.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1696)     24189.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1697)     24189.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1698)     24189.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1699)     24189.8  Rx         050C  6  00 00 00 00 B2 A6
  1700)     24191.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1701)     24192.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1702)     24199.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1703)     24199.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1704)     24199.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1705)     24201.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1706)     24202.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1707)     24207.2  Rx         056E  1  86
  1708)     24209.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1709)     24209.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1710)     24209.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1711)     24210.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1712)     24210.2  Rx         050A  6  06 00 00 17 00 00
  1713)     24211.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1714)     24212.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1715)     24219.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1716)     24219.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1717)     24220.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1718)     24221.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1719)     24222.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1720)     24229.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1721)     24230.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1722)     24230.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1723)     24230.5  Rx         050B  6  00 00 00 C0 00 00
  1724)     24231.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1725)     24232.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1726)     24239.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1727)     24240.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1728)     24240.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1729)     24242.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1730)     24242.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1731)     24242.5  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  1732)     24249.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1733)     24250.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1734)     24250.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1735)     24251.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1736)     24252.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1737)     24252.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1738)     24253.4  Rx         054B  8  00 08 80 00 04 00 00 00
  1739)     24254.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1740)     24255.4  Rx         054F  8  49 00 00 00 0B 40 08 3F
  1741)     24259.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1742)     24260.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1743)     24261.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1744)     24261.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1745)     24262.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1746)     24269.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1747)     24271.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1748)     24271.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1749)     24271.5  Rx         0380  8  02 04 10 21 00 00 00 05
  1750)     24271.7  Rx         05BF  8  00 00 00 00 18 00 00 2A
  1751)     24272.0  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  1752)     24272.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1753)     24279.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1754)     24281.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1755)     24281.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1756)     24281.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1757)     24282.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1758)     24289.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1759)     24291.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1760)     24291.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1761)     24292.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1762)     24292.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1763)     24292.4  Rx         050C  6  00 00 00 01 5D 5F
  1764)     24299.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  1765)     24301.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1766)     24302.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1767)     24302.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1768)     24302.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1769)     24307.2  Rx         056E  1  86
  1770)     24309.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1771)     24309.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1772)     24311.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1773)     24312.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1774)     24312.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1775)     24312.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1776)     24312.8  Rx         050A  6  06 20 00 17 00 00
  1777)     24319.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1778)     24321.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1779)     24322.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1780)     24322.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1781)     24322.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1782)     24329.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1783)     24331.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1784)     24332.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1785)     24332.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1786)     24332.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1787)     24332.9  Rx         050B  6  00 00 00 C0 00 00
  1788)     24339.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1789)     24342.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1790)     24342.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1791)     24342.5  Rx         055B  8  AB 00 AA 00 FF C0 13 B1
  1792)     24342.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1793)     24343.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1794)     24349.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1795)     24351.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1796)     24352.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1797)     24352.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  1798)     24352.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1799)     24353.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1800)     24353.5  Rx         054B  8  00 08 80 00 04 00 00 00
  1801)     24354.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1802)     24355.5  Rx         054F  8  49 00 00 00 0B 80 08 3F
  1803)     24359.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1804)     24361.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1805)     24362.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1806)     24363.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1807)     24363.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1808)     24369.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1809)     24371.6  Rx         0380  8  02 04 10 21 00 00 00 16
  1810)     24371.8  Rx         05BF  8  00 00 00 00 18 00 00 3B
  1811)     24372.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1812)     24372.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1813)     24373.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1814)     24373.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1815)     24379.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1816)     24381.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1817)     24382.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1818)     24383.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1819)     24384.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1820)     24389.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1821)     24391.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1822)     24392.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1823)     24394.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1824)     24394.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1825)     24394.4  Rx         050C  6  00 00 00 02 5D 63
  1826)     24399.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1827)     24401.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1828)     24402.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1829)     24404.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1830)     24404.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1831)     24404.6  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  1832)     24407.3  Rx         056E  1  86
  1833)     24409.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1834)     24409.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1835)     24411.8  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  1836)     24412.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1837)     24414.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1838)     24414.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1839)     24414.9  Rx         050A  6  06 40 00 17 00 00
  1840)     24419.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1841)     24421.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1842)     24422.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1843)     24424.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1844)     24424.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1845)     24429.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1846)     24431.8  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  1847)     24432.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1848)     24434.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1849)     24435.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1850)     24435.3  Rx         050B  6  00 00 00 C0 00 00
  1851)     24439.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1852)     24442.0  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1853)     24442.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1854)     24442.5  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  1855)     24445.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1856)     24445.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1857)     24449.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1858)     24451.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1859)     24452.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1860)     24452.5  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1861)     24453.5  Rx         054B  8  00 08 80 00 04 00 00 00
  1862)     24454.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1863)     24455.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1864)     24455.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1865)     24455.8  Rx         054F  8  49 00 00 00 0B C0 08 3F
  1866)     24459.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1867)     24461.8  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  1868)     24462.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1869)     24465.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1870)     24465.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1871)     24469.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1872)     24471.7  Rx         0380  8  02 04 10 21 00 00 00 27
  1873)     24471.9  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  1874)     24472.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1875)     24472.4  Rx         05BF  8  00 00 00 00 18 00 00 08
  1876)     24475.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1877)     24476.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1878)     24476.3  Rx         05B9  5  40 78 61 4A 28
  1879)     24479.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1880)     24481.8  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  1881)     24482.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1882)     24486.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1883)     24486.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1884)     24489.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1885)     24491.8  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  1886)     24492.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1887)     24496.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1888)     24496.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1889)     24496.8  Rx         050C  6  00 00 00 03 5D F4
  1890)     24499.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1891)     24501.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1892)     24502.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1893)     24506.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1894)     24506.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1895)     24507.3  Rx         056E  1  86
  1896)     24509.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1897)     24509.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1898)     24511.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1899)     24512.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1900)     24516.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1901)     24517.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1902)     24517.3  Rx         050A  6  06 60 00 17 00 00
  1903)     24519.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1904)     24521.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1905)     24522.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1906)     24527.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1907)     24527.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1908)     24529.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1909)     24531.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1910)     24532.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1911)     24537.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1912)     24537.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1913)     24537.8  Rx         050B  6  00 00 00 C0 00 00
  1914)     24539.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1915)     24542.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1916)     24542.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1917)     24542.5  Rx         055B  8  AB 00 AA 00 FF C0 11 3E
  1918)     24547.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1919)     24547.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1920)     24549.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1921)     24552.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1922)     24552.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1923)     24552.7  Rx         054A  8  12 00 70 02 00 00 00 3A
  1924)     24552.9  Rx         05BC  8  29 03 2C 3A A9 05 20 78
  1925)     24553.1  Rx         05C0  8  C0 74 74 00 8C D0 18 00
  1926)     24553.6  Rx         054B  8  00 08 80 00 04 00 00 00
  1927)     24554.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1928)     24555.6  Rx         054F  8  49 00 00 00 0B 00 08 3F
  1929)     24557.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1930)     24558.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1931)     24559.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1932)     24561.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1933)     24562.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1934)     24568.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1935)     24568.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1936)     24569.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1937)     24571.7  Rx         0380  8  02 04 10 21 00 00 00 38
  1938)     24572.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1939)     24572.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1940)     24572.4  Rx         05BF  8  00 00 00 00 18 00 00 19
  1941)     24578.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1942)     24578.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1943)     24579.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1944)     24581.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1945)     24582.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1946)     24588.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1947)     24588.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1948)     24589.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1949)     24591.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1950)     24592.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1951)     24598.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1952)     24599.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1953)     24599.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1954)     24599.5  Rx         050C  6  00 00 00 00 5D C8
  1955)     24601.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1956)     24602.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1957)     24607.3  Rx         056E  1  86
  1958)     24609.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1959)     24609.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  1960)     24609.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1961)     24609.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  1962)     24611.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1963)     24612.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1964)     24619.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1965)     24619.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1966)     24619.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1967)     24619.9  Rx         050A  6  06 00 00 17 00 00
  1968)     24621.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1969)     24622.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1970)     24629.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1971)     24629.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1972)     24629.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1973)     24631.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  1974)     24632.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  1975)     24639.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  1976)     24639.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  1977)     24640.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  1978)     24640.2  Rx         050B  6  00 00 00 C0 00 00
  1979)     24641.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  1980)     24642.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  1981)     24642.4  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  1982)     24649.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  1983)     24650.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  1984)     24650.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  1985)     24651.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  1986)     24652.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  1987)     24652.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
  1988)     24653.7  Rx         054B  8  00 08 80 00 04 00 00 00
  1989)     24654.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  1990)     24655.6  Rx         054F  8  49 00 00 00 0B 40 08 3F
  1991)     24659.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  1992)     24660.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  1993)     24660.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  1994)     24661.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  1995)     24662.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  1996)     24669.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  1997)     24670.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  1998)     24670.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  1999)     24671.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2000)     24672.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2001)     24672.3  Rx         0380  8  02 04 10 21 00 00 00 05
  2002)     24672.5  Rx         05BF  8  00 00 00 00 18 00 00 2A
  2003)     24679.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2004)     24680.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2005)     24681.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2006)     24681.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2007)     24682.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2008)     24689.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2009)     24691.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2010)     24691.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2011)     24691.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2012)     24692.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2013)     24699.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2014)     24701.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2015)     24701.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2016)     24701.7  Rx         050C  6  00 00 00 01 5D 5F
  2017)     24702.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2018)     24702.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2019)     24707.3  Rx         056E  1  86
  2020)     24709.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2021)     24709.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2022)     24711.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2023)     24711.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2024)     24711.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2025)     24712.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2026)     24719.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2027)     24721.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2028)     24721.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2029)     24722.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2030)     24722.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2031)     24722.6  Rx         050A  6  06 20 00 17 00 00
  2032)     24729.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2033)     24731.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2034)     24732.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2035)     24732.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2036)     24732.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2037)     24739.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2038)     24742.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2039)     24742.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2040)     24742.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2041)     24742.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2042)     24742.9  Rx         050B  6  00 00 00 C0 00 00
  2043)     24743.1  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  2044)     24749.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2045)     24751.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2046)     24752.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2047)     24752.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2048)     24752.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2049)     24752.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  2050)     24753.8  Rx         054B  8  00 08 80 00 04 00 00 00
  2051)     24754.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2052)     24755.8  Rx         054F  8  49 00 00 00 0B 80 08 3F
  2053)     24759.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2054)     24761.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2055)     24762.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2056)     24762.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2057)     24763.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2058)     24769.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2059)     24771.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2060)     24772.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2061)     24772.3  Rx         0380  8  02 04 10 21 00 00 00 16
  2062)     24772.5  Rx         05BF  8  00 00 00 00 18 00 00 3B
  2063)     24772.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2064)     24773.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2065)     24779.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2066)     24781.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2067)     24782.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2068)     24783.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2069)     24783.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2070)     24789.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2071)     24791.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2072)     24792.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2073)     24793.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2074)     24793.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2075)     24799.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2076)     24801.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2077)     24802.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2078)     24803.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2079)     24804.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2080)     24804.1  Rx         050C  6  00 00 00 02 B2 0D
  2081)     24807.4  Rx         056E  1  86
  2082)     24809.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2083)     24809.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2084)     24811.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2085)     24812.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2086)     24813.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2087)     24814.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2088)     24819.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2089)     24821.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2090)     24822.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2091)     24824.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2092)     24824.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2093)     24824.6  Rx         050A  6  06 40 00 17 00 00
  2094)     24829.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2095)     24831.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2096)     24832.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2097)     24834.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2098)     24834.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2099)     24839.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2100)     24842.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2101)     24842.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2102)     24842.5  Rx         055B  8  AB 00 55 00 FF C0 10 FC
  2103)     24844.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2104)     24844.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2105)     24845.1  Rx         050B  6  00 00 00 C0 00 00
  2106)     24849.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2107)     24851.8  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  2108)     24852.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2109)     24852.8  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2110)     24853.8  Rx         054B  8  00 08 80 00 04 00 00 00
  2111)     24854.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2112)     24855.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2113)     24855.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2114)     24855.9  Rx         054F  8  49 00 00 00 0B C0 08 3F
  2115)     24859.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2116)     24861.8  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  2117)     24862.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2118)     24865.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2119)     24865.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2120)     24869.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2121)     24871.8  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  2122)     24872.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2123)     24872.3  Rx         0380  8  02 04 10 21 00 00 00 27
  2124)     24872.5  Rx         05BF  8  00 00 00 00 18 00 00 08
  2125)     24875.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2126)     24875.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2127)     24879.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2128)     24881.8  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  2129)     24882.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2130)     24885.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2131)     24885.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2132)     24889.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2133)     24891.8  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  2134)     24892.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2135)     24895.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2136)     24896.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2137)     24899.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2138)     24901.8  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  2139)     24902.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2140)     24906.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2141)     24906.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2142)     24906.6  Rx         050C  6  00 00 00 03 B2 9A
  2143)     24907.4  Rx         056E  1  86
  2144)     24909.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2145)     24909.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2146)     24911.8  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  2147)     24912.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2148)     24916.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2149)     24916.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2150)     24916.8  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  2151)     24919.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2152)     24921.8  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  2153)     24922.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2154)     24926.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2155)     24926.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2156)     24927.1  Rx         050A  6  06 60 00 17 00 00
  2157)     24929.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2158)     24931.8  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  2159)     24932.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2160)     24936.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2161)     24937.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2162)     24939.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2163)     24941.9  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  2164)     24942.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2165)     24942.4  Rx         055B  8  AB 00 55 00 FF C0 11 79
  2166)     24947.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2167)     24947.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2168)     24947.5  Rx         050B  6  00 00 00 C0 00 00
  2169)     24949.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2170)     24951.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2171)     24952.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2172)     24952.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  2173)     24953.9  Rx         054B  8  00 08 80 00 04 00 00 00
  2174)     24954.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2175)     24955.9  Rx         054F  8  49 00 00 00 0B 00 08 3F
  2176)     24957.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2177)     24957.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2178)     24959.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2179)     24961.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2180)     24962.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2181)     24967.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2182)     24967.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2183)     24969.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2184)     24971.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2185)     24972.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2186)     24972.2  Rx         0380  8  02 04 10 21 00 00 00 38
  2187)     24972.5  Rx         05BF  8  00 00 00 00 18 00 00 19
  2188)     24977.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2189)     24978.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2190)     24979.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  2191)     24981.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2192)     24982.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2193)     24988.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2194)     24988.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2195)     24988.5  Rx         05B9  5  40 78 61 4A 28
  2196)     24989.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2197)     24991.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2198)     24992.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2199)     24998.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2200)     24998.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2201)     24999.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2202)     25001.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2203)     25002.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2204)     25007.4  Rx         056E  1  86
  2205)     25008.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2206)     25008.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2207)     25009.0  Rx         050C  6  00 00 00 00 B2 A6
  2208)     25009.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2209)     25009.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2210)     25011.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2211)     25012.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2212)     25018.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2213)     25019.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2214)     25019.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  2215)     25021.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2216)     25022.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2217)     25029.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2218)     25029.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2219)     25029.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2220)     25029.7  Rx         050A  6  06 00 00 17 00 00
  2221)     25031.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2222)     25032.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2223)     25039.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2224)     25039.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2225)     25039.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2226)     25042.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2227)     25042.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2228)     25042.4  Rx         055B  8  AB 00 55 00 FF C0 12 73
  2229)     25049.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2230)     25049.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2231)     25049.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2232)     25050.0  Rx         050B  6  00 00 00 C0 00 00
  2233)     25052.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2234)     25052.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2235)     25052.6  Rx         05BC  8  29 03 29 3A A8 05 40 32
  2236)     25052.8  Rx         05C0  8  40 76 76 00 8C 08 18 00
  2237)     25053.0  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2238)     25054.0  Rx         054B  8  00 08 80 00 04 00 00 00
  2239)     25055.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2240)     25056.0  Rx         054F  8  49 00 00 00 0B 40 08 3F
  2241)     25059.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2242)     25059.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2243)     25060.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2244)     25061.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2245)     25062.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2246)     25069.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2247)     25069.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2248)     25070.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2249)     25071.8  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2250)     25072.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2251)     25072.3  Rx         0380  8  02 04 10 21 00 00 00 05
  2252)     25072.5  Rx         05BF  8  00 00 00 00 18 00 00 2A
  2253)     25079.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2254)     25080.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2255)     25080.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2256)     25081.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2257)     25082.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2258)     25089.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2259)     25090.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2260)     25090.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2261)     25091.7  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  2262)     25092.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2263)     25099.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2264)     25100.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2265)     25101.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2266)     25101.8  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  2267)     25102.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2268)     25107.4  Rx         056E  1  86
  2269)     25109.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2270)     25109.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2271)     25111.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2272)     25111.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2273)     25111.4  Rx         050C  6  00 00 00 01 B2 31
  2274)     25111.8  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  2275)     25112.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2276)     25119.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2277)     25121.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2278)     25121.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2279)     25121.8  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  2280)     25122.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2281)     25129.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2282)     25131.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2283)     25131.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2284)     25131.9  Rx         01DB  8  00 20 C0 2A 00 00 02 DF
  2285)     25132.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2286)     25132.4  Rx         050A  6  06 20 00 17 00 00
  2287)     25139.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2288)     25141.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2289)     25141.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2290)     25142.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2291)     25142.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2292)     25142.6  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  2293)     25149.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2294)     25151.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2295)     25152.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2296)     25152.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2297)     25152.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2298)     25152.7  Rx         050B  6  00 00 00 C0 00 00
  2299)     25153.0  Rx         054A  8  12 00 70 02 00 00 00 3A
  2300)     25154.0  Rx         054B  8  00 08 80 00 04 00 00 00
  2301)     25155.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2302)     25156.0  Rx         054F  8  49 00 00 00 0B 80 08 3F
  2303)     25159.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2304)     25161.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2305)     25162.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2306)     25162.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2307)     25162.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2308)     25169.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2309)     25171.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2310)     25172.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2311)     25172.4  Rx         0380  8  02 04 10 21 00 00 00 16
  2312)     25172.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2313)     25172.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2314)     25173.1  Rx         05BF  8  00 00 00 00 18 00 00 3B
  2315)     25179.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2316)     25181.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2317)     25182.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2318)     25182.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2319)     25182.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2320)     25189.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2321)     25191.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2322)     25192.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2323)     25192.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2324)     25193.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2325)     25199.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2326)     25201.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2327)     25202.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2328)     25203.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2329)     25203.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2330)     25207.4  Rx         056E  1  86
  2331)     25209.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2332)     25209.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2333)     25211.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2334)     25212.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2335)     25213.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2336)     25213.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2337)     25213.8  Rx         050C  6  00 00 00 02 B2 0D
  2338)     25219.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2339)     25221.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2340)     25222.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2341)     25223.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2342)     25223.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2343)     25229.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2344)     25231.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2345)     25232.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2346)     25233.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2347)     25234.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2348)     25234.3  Rx         050A  6  06 40 00 17 00 00
  2349)     25239.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2350)     25241.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2351)     25242.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2352)     25242.4  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  2353)     25244.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2354)     25244.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2355)     25249.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2356)     25251.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2357)     25251.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2358)     25253.1  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2359)     25254.1  Rx         054B  8  00 08 80 00 04 00 00 00
  2360)     25254.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2361)     25254.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2362)     25254.8  Rx         050B  6  00 00 00 C0 00 00
  2363)     25255.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2364)     25256.1  Rx         054F  8  49 00 00 00 0B C0 08 3F
  2365)     25259.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2366)     25261.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2367)     25262.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2368)     25264.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2369)     25264.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2370)     25269.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2371)     25271.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2372)     25272.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2373)     25272.5  Rx         0380  8  02 04 10 21 00 00 00 27
  2374)     25272.7  Rx         05BF  8  00 00 00 00 18 00 00 08
  2375)     25274.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2376)     25275.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2377)     25279.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2378)     25281.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2379)     25281.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2380)     25285.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2381)     25285.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2382)     25289.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2383)     25291.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2384)     25292.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2385)     25295.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2386)     25295.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2387)     25299.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2388)     25301.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2389)     25301.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2390)     25305.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2391)     25305.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2392)     25307.5  Rx         056E  1  86
  2393)     25309.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2394)     25309.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2395)     25311.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2396)     25312.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2397)     25315.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2398)     25316.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2399)     25316.3  Rx         050C  6  00 00 00 03 5D F4
  2400)     25319.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2401)     25321.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2402)     25322.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2403)     25326.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2404)     25326.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2405)     25329.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2406)     25331.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2407)     25331.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2408)     25336.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2409)     25336.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2410)     25336.7  Rx         050A  6  06 60 00 17 00 00
  2411)     25339.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2412)     25341.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2413)     25342.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2414)     25342.3  Rx         055B  8  AB 00 AA 00 FF C0 11 3E
  2415)     25346.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2416)     25346.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2417)     25349.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2418)     25351.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2419)     25351.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2420)     25353.2  Rx         054A  8  12 00 70 02 00 00 00 3A
  2421)     25354.2  Rx         054B  8  00 08 80 00 04 00 00 00
  2422)     25355.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2423)     25356.2  Rx         054F  8  49 00 00 00 0B 00 08 3F
  2424)     25356.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2425)     25357.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2426)     25357.3  Rx         050B  6  00 00 00 C0 00 00
  2427)     25359.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2428)     25361.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2429)     25361.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2430)     25367.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2431)     25367.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2432)     25369.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2433)     25371.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2434)     25372.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2435)     25372.6  Rx         0380  8  02 04 10 21 00 00 00 38
  2436)     25372.8  Rx         05BF  8  00 00 00 00 18 00 00 19
  2437)     25377.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2438)     25377.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2439)     25379.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2440)     25381.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2441)     25381.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2442)     25387.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2443)     25387.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2444)     25389.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2445)     25391.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2446)     25391.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2447)     25397.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2448)     25398.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2449)     25399.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2450)     25401.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2451)     25402.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2452)     25407.4  Rx         056E  1  86
  2453)     25408.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2454)     25408.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2455)     25409.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  2456)     25409.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2457)     25411.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2458)     25411.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2459)     25418.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2460)     25418.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2461)     25418.8  Rx         050C  6  00 00 00 00 5D C8
  2462)     25419.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2463)     25421.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2464)     25421.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2465)     25428.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2466)     25428.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2467)     25429.0  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  2468)     25429.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2469)     25431.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2470)     25431.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2471)     25438.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2472)     25439.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2473)     25439.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2474)     25439.5  Rx         050A  6  06 00 00 17 00 00
  2475)     25441.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2476)     25442.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2477)     25442.4  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  2478)     25449.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2479)     25449.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  2480)     25449.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2481)     25451.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2482)     25452.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2483)     25453.3  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2484)     25454.3  Rx         054B  8  00 08 80 00 04 00 00 00
  2485)     25455.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2486)     25456.3  Rx         054F  8  49 00 00 00 0B 40 08 3F
  2487)     25459.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2488)     25459.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2489)     25459.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2490)     25459.7  Rx         050B  6  00 00 00 C0 00 00
  2491)     25461.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2492)     25462.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2493)     25469.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2494)     25469.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2495)     25469.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2496)     25471.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2497)     25472.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2498)     25472.6  Rx         0380  8  02 04 10 21 00 00 00 05
  2499)     25472.9  Rx         05BF  8  00 00 00 00 18 00 00 2A
  2500)     25479.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2501)     25479.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2502)     25480.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2503)     25481.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2504)     25481.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2505)     25489.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2506)     25489.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2507)     25490.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2508)     25491.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2509)     25491.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2510)     25499.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  2511)     25500.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2512)     25500.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2513)     25500.6  Rx         05B9  5  40 78 61 4A 28
  2514)     25501.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2515)     25501.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2516)     25507.4  Rx         056E  1  86
  2517)     25509.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2518)     25509.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2519)     25510.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2520)     25510.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2521)     25511.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2522)     25511.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2523)     25519.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2524)     25520.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2525)     25520.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2526)     25521.2  Rx         050C  6  00 00 00 01 5D 5F
  2527)     25521.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2528)     25521.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2529)     25529.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2530)     25530.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2531)     25531.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2532)     25531.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2533)     25531.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2534)     25539.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2535)     25541.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2536)     25541.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2537)     25541.6  Rx         050A  6  06 20 00 17 00 00
  2538)     25541.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2539)     25542.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2540)     25542.4  Rx         055B  8  AB 00 AA 00 FF C0 13 B1
  2541)     25549.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2542)     25551.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2543)     25551.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2544)     25552.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2545)     25552.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2546)     25552.5  Rx         05BC  8  29 03 2C 3A A9 06 21 4A
  2547)     25552.8  Rx         05C0  8  80 74 74 00 8C D0 18 00
  2548)     25553.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  2549)     25554.3  Rx         054B  8  00 08 80 00 04 00 00 00
  2550)     25555.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2551)     25556.4  Rx         054F  8  49 00 00 00 0B 80 08 3F
  2552)     25559.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2553)     25561.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2554)     25561.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2555)     25562.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2556)     25562.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2557)     25562.6  Rx         050B  6  00 00 00 C0 00 00
  2558)     25569.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2559)     25571.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2560)     25571.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2561)     25572.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2562)     25572.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2563)     25572.8  Rx         0380  8  02 04 10 21 00 00 00 16
  2564)     25573.0  Rx         05BF  8  00 00 00 00 18 00 00 3B
  2565)     25579.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2566)     25581.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2567)     25581.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2568)     25582.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2569)     25582.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2570)     25589.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2571)     25591.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2572)     25591.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2573)     25592.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2574)     25592.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2575)     25599.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2576)     25601.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2577)     25601.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2578)     25602.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2579)     25602.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2580)     25607.5  Rx         056E  1  86
  2581)     25609.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2582)     25609.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2583)     25611.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2584)     25611.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2585)     25612.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2586)     25613.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2587)     25619.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2588)     25621.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2589)     25621.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2590)     25623.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2591)     25623.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2592)     25623.5  Rx         050C  6  00 00 00 02 5D 63
  2593)     25629.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2594)     25631.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2595)     25631.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2596)     25633.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2597)     25633.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2598)     25639.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2599)     25641.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2600)     25642.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2601)     25642.3  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  2602)     25643.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2603)     25643.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2604)     25644.0  Rx         050A  6  06 40 00 17 00 00
  2605)     25649.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2606)     25651.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2607)     25651.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2608)     25653.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2609)     25653.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2610)     25654.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2611)     25654.4  Rx         054B  8  00 08 80 00 04 00 00 00
  2612)     25655.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2613)     25656.4  Rx         054F  8  49 00 00 00 0B C0 08 3F
  2614)     25659.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2615)     25661.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2616)     25661.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2617)     25664.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2618)     25664.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2619)     25664.5  Rx         050B  6  00 00 00 C0 00 00
  2620)     25669.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2621)     25671.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2622)     25671.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2623)     25672.8  Rx         0380  8  02 04 10 21 00 00 00 27
  2624)     25673.1  Rx         05BF  8  00 00 00 00 18 00 00 08
  2625)     25674.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2626)     25674.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2627)     25679.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2628)     25681.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2629)     25681.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2630)     25684.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2631)     25684.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2632)     25689.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2633)     25691.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2634)     25691.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2635)     25694.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2636)     25695.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2637)     25699.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2638)     25701.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2639)     25701.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2640)     25705.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2641)     25705.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2642)     25707.6  Rx         056E  1  86
  2643)     25709.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2644)     25709.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2645)     25711.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2646)     25711.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2647)     25715.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2648)     25715.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2649)     25719.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2650)     25721.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2651)     25721.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2652)     25725.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2653)     25725.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2654)     25726.0  Rx         050C  6  00 00 00 03 5D F4
  2655)     25729.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2656)     25731.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2657)     25731.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2658)     25735.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2659)     25736.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2660)     25739.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2661)     25741.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2662)     25742.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2663)     25742.4  Rx         055B  8  AB 00 55 00 FF C0 11 79
  2664)     25746.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2665)     25746.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2666)     25746.5  Rx         050A  6  06 60 00 17 00 00
  2667)     25749.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2668)     25751.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2669)     25751.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2670)     25753.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  2671)     25754.5  Rx         054B  8  00 08 80 00 04 00 00 00
  2672)     25755.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2673)     25756.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2674)     25756.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2675)     25756.8  Rx         054F  8  49 00 00 00 0B 00 08 3F
  2676)     25759.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2677)     25761.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2678)     25761.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2679)     25766.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2680)     25766.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2681)     25767.0  Rx         050B  6  00 00 00 C0 00 00
  2682)     25769.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2683)     25771.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2684)     25771.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2685)     25773.0  Rx         0380  8  02 04 10 21 00 00 00 38
  2686)     25773.2  Rx         05BF  8  00 00 00 00 18 00 00 19
  2687)     25776.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2688)     25777.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2689)     25779.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2690)     25781.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2691)     25781.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2692)     25787.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2693)     25787.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2694)     25789.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2695)     25791.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2696)     25791.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2697)     25797.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2698)     25797.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2699)     25799.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2700)     25801.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2701)     25801.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2702)     25807.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2703)     25807.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2704)     25807.8  Rx         056E  1  86
  2705)     25809.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2706)     25809.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2707)     25811.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2708)     25811.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2709)     25817.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2710)     25818.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2711)     25819.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2712)     25821.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2713)     25821.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2714)     25828.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2715)     25828.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2716)     25828.5  Rx         050C  6  00 00 00 00 B2 A6
  2717)     25829.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2718)     25831.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2719)     25831.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2720)     25838.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2721)     25838.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2722)     25839.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2723)     25841.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2724)     25842.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2725)     25842.3  Rx         055B  8  AB 00 55 00 FF C0 12 73
  2726)     25848.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2727)     25848.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2728)     25849.0  Rx         050A  6  06 00 00 17 00 00
  2729)     25849.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  2730)     25851.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2731)     25851.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2732)     25853.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2733)     25854.6  Rx         054B  8  00 08 80 00 04 00 00 00
  2734)     25855.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2735)     25856.6  Rx         054F  8  49 00 00 00 0B 40 08 3F
  2736)     25858.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2737)     25859.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2738)     25859.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  2739)     25861.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2740)     25861.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2741)     25868.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2742)     25869.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2743)     25869.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2744)     25869.7  Rx         050B  6  00 00 00 C0 00 00
  2745)     25871.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2746)     25871.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2747)     25873.1  Rx         0380  8  02 04 10 21 00 00 00 05
  2748)     25873.3  Rx         05BF  8  00 00 00 00 18 00 00 2A
  2749)     25879.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2750)     25879.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2751)     25879.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2752)     25881.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2753)     25881.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2754)     25889.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2755)     25889.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2756)     25889.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2757)     25891.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2758)     25891.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2759)     25899.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2760)     25899.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2761)     25900.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2762)     25901.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2763)     25901.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2764)     25907.5  Rx         056E  1  86
  2765)     25909.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2766)     25909.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2767)     25909.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2768)     25910.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2769)     25911.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2770)     25911.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2771)     25919.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2772)     25920.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2773)     25920.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2774)     25921.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2775)     25921.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2776)     25929.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2777)     25930.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2778)     25930.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2779)     25930.9  Rx         050C  6  00 00 00 01 B2 31
  2780)     25931.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2781)     25931.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2782)     25939.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2783)     25940.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2784)     25940.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2785)     25941.2  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  2786)     25941.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2787)     25942.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2788)     25942.3  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  2789)     25949.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2790)     25951.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2791)     25951.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2792)     25951.4  Rx         050A  6  06 20 00 17 00 00
  2793)     25951.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2794)     25951.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2795)     25953.7  Rx         054A  8  12 00 70 02 00 00 00 3A
  2796)     25954.7  Rx         054B  8  00 08 80 00 04 00 00 00
  2797)     25955.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2798)     25956.7  Rx         054F  8  49 00 00 00 0B 80 08 3F
  2799)     25959.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2800)     25961.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2801)     25961.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2802)     25961.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2803)     25961.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2804)     25969.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2805)     25971.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2806)     25971.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2807)     25971.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2808)     25972.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2809)     25972.3  Rx         050B  6  00 00 00 C0 00 00
  2810)     25973.2  Rx         0380  8  02 04 10 21 00 00 00 16
  2811)     25973.5  Rx         05BF  8  00 00 00 00 18 00 00 3B
  2812)     25979.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2813)     25981.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2814)     25981.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2815)     25982.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2816)     25982.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2817)     25989.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2818)     25991.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2819)     25991.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2820)     25992.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2821)     25992.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2822)     25999.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2823)     26001.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2824)     26001.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2825)     26002.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2826)     26002.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2827)     26007.6  Rx         056E  1  86
  2828)     26009.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2829)     26009.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2830)     26011.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2831)     26011.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2832)     26012.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2833)     26012.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2834)     26012.8  Rx         05B9  5  40 78 61 4A 28
  2835)     26018.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2836)     26021.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2837)     26021.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2838)     26022.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2839)     26022.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2840)     26029.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2841)     26031.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2842)     26031.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2843)     26032.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2844)     26033.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2845)     26033.3  Rx         050C  6  00 00 00 02 B2 0D
  2846)     26039.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2847)     26041.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2848)     26042.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2849)     26042.3  Rx         055B  8  AB 00 55 00 FF C0 10 FC
  2850)     26043.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2851)     26043.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2852)     26048.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  2853)     26052.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2854)     26052.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2855)     26052.4  Rx         05BC  8  29 03 29 3A A8 06 40 96
  2856)     26052.7  Rx         05C0  8  C0 74 74 00 8C D0 18 00
  2857)     26053.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2858)     26053.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2859)     26053.8  Rx         050A  6  06 40 00 17 00 00
  2860)     26054.1  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2861)     26054.7  Rx         054B  8  00 08 80 00 04 00 00 00
  2862)     26055.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2863)     26056.7  Rx         054F  8  49 00 00 00 0B C0 08 3F
  2864)     26059.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  2865)     26061.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2866)     26061.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2867)     26063.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2868)     26063.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2869)     26068.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2870)     26071.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2871)     26071.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2872)     26073.3  Rx         0380  8  02 04 10 21 00 00 00 27
  2873)     26073.6  Rx         05BF  8  00 00 00 00 18 00 00 08
  2874)     26073.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2875)     26074.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2876)     26074.3  Rx         050B  6  00 00 00 C0 00 00
  2877)     26078.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2878)     26081.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2879)     26081.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2880)     26084.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2881)     26084.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2882)     26089.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2883)     26091.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2884)     26091.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2885)     26094.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2886)     26094.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2887)     26098.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2888)     26101.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2889)     26101.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2890)     26104.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2891)     26104.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2892)     26107.6  Rx         056E  1  86
  2893)     26108.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2894)     26109.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2895)     26111.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2896)     26111.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2897)     26114.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2898)     26115.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2899)     26118.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2900)     26121.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2901)     26121.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2902)     26125.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2903)     26125.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2904)     26128.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  2905)     26131.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2906)     26131.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2907)     26135.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2908)     26135.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2909)     26135.8  Rx         050C  6  00 00 00 03 B2 9A
  2910)     26138.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2911)     26141.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2912)     26142.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2913)     26142.3  Rx         055B  8  AB 00 55 00 FF C0 11 79
  2914)     26145.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2915)     26145.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2916)     26148.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2917)     26151.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2918)     26151.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2919)     26153.8  Rx         054A  8  12 00 70 02 00 00 00 3A
  2920)     26154.8  Rx         054B  8  00 08 80 00 04 00 00 00
  2921)     26155.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2922)     26156.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2923)     26156.2  Rx         050A  6  06 60 00 17 00 00
  2924)     26156.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2925)     26157.8  Rx         054F  8  49 00 00 00 0B 00 08 3F
  2926)     26158.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2927)     26161.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2928)     26161.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2929)     26166.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2930)     26166.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2931)     26169.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  2932)     26171.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2933)     26171.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2934)     26173.4  Rx         0380  8  02 04 10 21 00 00 00 38
  2935)     26173.6  Rx         05BF  8  00 00 00 00 18 00 00 19
  2936)     26176.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2937)     26176.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2938)     26176.7  Rx         050B  6  00 00 00 C0 00 00
  2939)     26178.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2940)     26181.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2941)     26181.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2942)     26186.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2943)     26186.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2944)     26188.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2945)     26191.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2946)     26191.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2947)     26196.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2948)     26197.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2949)     26198.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2950)     26201.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2951)     26201.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2952)     26207.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2953)     26207.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2954)     26207.6  Rx         056E  1  86
  2955)     26208.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  2956)     26209.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  2957)     26211.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2958)     26211.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2959)     26217.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2960)     26217.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2961)     26218.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2962)     26221.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2963)     26221.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2964)     26227.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2965)     26227.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2966)     26228.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2967)     26231.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2968)     26231.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2969)     26237.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2970)     26238.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  2971)     26238.2  Rx         050C  6  00 00 00 00 B2 A6
  2972)     26238.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  2973)     26241.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  2974)     26242.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  2975)     26242.2  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  2976)     26248.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  2977)     26248.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  2978)     26248.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  2979)     26251.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  2980)     26251.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  2981)     26253.9  Rx         054A  8  A0 00 70 02 00 00 00 3A
  2982)     26254.9  Rx         054B  8  00 08 80 00 04 00 00 00
  2983)     26255.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  2984)     26256.9  Rx         054F  8  49 00 00 00 0B 40 08 3F
  2985)     26258.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  2986)     26258.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  2987)     26258.7  Rx         050A  6  06 00 00 17 00 00
  2988)     26258.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  2989)     26261.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  2990)     26261.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  2991)     26268.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  2992)     26268.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  2993)     26268.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  2994)     26271.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  2995)     26271.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  2996)     26273.5  Rx         0380  8  02 04 10 21 00 00 00 05
  2997)     26273.7  Rx         05BF  8  00 00 00 00 18 00 00 2A
  2998)     26278.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  2999)     26278.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3000)     26279.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3001)     26279.4  Rx         050B  6  00 00 00 C0 00 00
  3002)     26281.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3003)     26281.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3004)     26288.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3005)     26289.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3006)     26289.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3007)     26291.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3008)     26291.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3009)     26298.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3010)     26299.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3011)     26299.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3012)     26301.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3013)     26301.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3014)     26307.6  Rx         056E  1  86
  3015)     26308.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3016)     26309.1  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3017)     26309.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3018)     26309.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3019)     26311.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3020)     26311.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3021)     26318.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3022)     26319.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3023)     26319.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3024)     26321.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3025)     26321.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3026)     26328.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3027)     26329.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3028)     26330.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3029)     26331.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3030)     26331.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3031)     26338.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3032)     26340.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3033)     26340.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3034)     26340.6  Rx         050C  6  00 00 00 01 5D 5F
  3035)     26341.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3036)     26342.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3037)     26342.3  Rx         055B  8  AB 00 AA 00 FF C0 13 B1
  3038)     26348.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3039)     26350.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3040)     26350.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3041)     26351.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3042)     26351.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3043)     26353.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  3044)     26354.9  Rx         054B  8  00 08 80 00 04 00 00 00
  3045)     26355.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3046)     26356.9  Rx         054F  8  49 00 00 00 0B 80 08 3F
  3047)     26358.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3048)     26360.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3049)     26360.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3050)     26361.1  Rx         050A  6  06 20 00 17 00 00
  3051)     26361.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3052)     26361.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3053)     26368.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3054)     26370.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3055)     26371.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3056)     26371.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3057)     26371.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3058)     26373.5  Rx         0380  8  02 04 10 21 00 00 00 16
  3059)     26373.8  Rx         05BF  8  00 00 00 00 18 00 00 3B
  3060)     26378.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3061)     26381.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3062)     26381.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3063)     26381.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3064)     26381.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3065)     26382.1  Rx         050B  6  00 00 00 C0 00 00
  3066)     26388.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3067)     26391.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3068)     26391.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3069)     26391.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3070)     26392.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3071)     26398.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3072)     26401.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3073)     26401.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3074)     26402.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3075)     26402.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3076)     26407.6  Rx         056E  1  86
  3077)     26408.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3078)     26409.1  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3079)     26411.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3080)     26411.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3081)     26412.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3082)     26412.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3083)     26418.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3084)     26421.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3085)     26421.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3086)     26422.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3087)     26422.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3088)     26428.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3089)     26431.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3090)     26431.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3091)     26432.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3092)     26432.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3093)     26438.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3094)     26441.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3095)     26442.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3096)     26442.2  Rx         055B  8  AB 00 AA 00 FF C0 10 BB
  3097)     26442.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3098)     26442.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3099)     26443.1  Rx         050C  6  00 00 00 02 5D 63
  3100)     26448.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3101)     26451.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3102)     26451.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3103)     26452.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3104)     26453.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3105)     26453.3  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  3106)     26454.0  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3107)     26455.0  Rx         054B  8  00 08 80 00 04 00 00 00
  3108)     26456.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3109)     26457.0  Rx         054F  8  49 00 00 00 0B C0 08 3F
  3110)     26458.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3111)     26461.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3112)     26461.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3113)     26463.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3114)     26463.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3115)     26463.6  Rx         050A  6  06 40 00 17 00 00
  3116)     26468.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3117)     26471.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3118)     26471.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3119)     26473.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3120)     26473.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3121)     26473.8  Rx         0380  8  02 04 10 21 00 00 00 27
  3122)     26474.0  Rx         05BF  8  00 00 00 00 18 00 00 08
  3123)     26478.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3124)     26481.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3125)     26481.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3126)     26483.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3127)     26483.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3128)     26484.0  Rx         050B  6  00 00 00 C0 00 00
  3129)     26488.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3130)     26491.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3131)     26491.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3132)     26493.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3133)     26494.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3134)     26498.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3135)     26501.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3136)     26501.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3137)     26504.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3138)     26504.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3139)     26507.7  Rx         056E  1  86
  3140)     26508.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3141)     26509.1  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3142)     26511.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3143)     26511.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3144)     26514.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3145)     26514.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3146)     26518.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3147)     26521.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3148)     26521.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3149)     26524.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3150)     26524.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3151)     26524.9  Rx         05B9  5  40 78 61 4A 28
  3152)     26528.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3153)     26531.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3154)     26531.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3155)     26534.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3156)     26535.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3157)     26538.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3158)     26541.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3159)     26542.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3160)     26542.2  Rx         055B  8  AB 00 AA 00 FF C0 11 3E
  3161)     26545.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3162)     26545.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3163)     26545.5  Rx         050C  6  00 00 00 03 5D F4
  3164)     26548.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3165)     26551.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3166)     26552.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3167)     26552.4  Rx         05BC  8  29 03 2C 3A A9 04 1F FF
  3168)     26552.6  Rx         05C0  8  40 76 76 00 8C 08 18 00
  3169)     26554.1  Rx         054A  8  12 00 70 02 00 00 00 3A
  3170)     26555.1  Rx         054B  8  00 08 80 00 04 00 00 00
  3171)     26555.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3172)     26555.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3173)     26556.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3174)     26557.1  Rx         054F  8  49 00 00 00 0B 00 08 3F
  3175)     26558.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3176)     26561.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3177)     26561.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3178)     26565.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3179)     26565.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3180)     26566.0  Rx         050A  6  06 60 00 17 00 00
  3181)     26568.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  3182)     26571.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3183)     26571.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3184)     26573.7  Rx         0380  8  02 04 10 21 00 00 00 38
  3185)     26574.0  Rx         05BF  8  00 00 00 00 18 00 00 19
  3186)     26575.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3187)     26576.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3188)     26578.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3189)     26581.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3190)     26581.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3191)     26585.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3192)     26586.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3193)     26586.4  Rx         050B  6  00 00 00 C0 00 00
  3194)     26588.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3195)     26591.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3196)     26591.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3197)     26596.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3198)     26596.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3199)     26598.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3200)     26601.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3201)     26601.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3202)     26606.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3203)     26606.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3204)     26607.7  Rx         056E  1  86
  3205)     26608.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3206)     26609.1  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3207)     26611.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3208)     26611.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3209)     26616.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3210)     26616.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3211)     26618.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3212)     26621.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3213)     26621.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3214)     26626.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3215)     26627.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3216)     26628.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3217)     26631.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3218)     26631.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3219)     26637.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3220)     26637.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3221)     26638.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3222)     26641.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3223)     26642.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3224)     26642.2  Rx         055B  8  AB 00 AA 00 FF C0 12 34
  3225)     26647.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3226)     26647.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3227)     26647.9  Rx         050C  6  00 00 00 00 5D C8
  3228)     26648.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  3229)     26651.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3230)     26651.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3231)     26654.2  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3232)     26655.2  Rx         054B  8  00 08 80 00 04 00 00 00
  3233)     26656.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3234)     26657.2  Rx         054F  8  49 00 00 00 0B 40 08 3F
  3235)     26657.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3236)     26658.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3237)     26658.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3238)     26661.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3239)     26661.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3240)     26667.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3241)     26668.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3242)     26668.4  Rx         050A  6  06 00 00 17 00 00
  3243)     26668.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3244)     26671.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3245)     26671.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3246)     26673.8  Rx         0380  8  02 04 10 21 00 00 00 05
  3247)     26674.1  Rx         05BF  8  00 00 00 00 18 00 00 2A
  3248)     26678.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3249)     26678.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3250)     26678.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3251)     26681.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3252)     26681.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3253)     26688.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3254)     26688.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3255)     26688.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  3256)     26689.1  Rx         050B  6  00 00 00 C0 00 00
  3257)     26691.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3258)     26691.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3259)     26698.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3260)     26698.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  3261)     26699.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3262)     26701.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3263)     26701.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3264)     26707.6  Rx         056E  1  86
  3265)     26708.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3266)     26709.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3267)     26709.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3268)     26709.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3269)     26711.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3270)     26711.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3271)     26718.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3272)     26719.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3273)     26719.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3274)     26721.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3275)     26721.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3276)     26728.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  3277)     26729.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3278)     26729.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3279)     26731.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3280)     26731.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3281)     26738.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3282)     26739.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3283)     26739.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3284)     26741.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3285)     26742.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3286)     26742.2  Rx         055B  8  AB 00 55 00 FF C0 13 F6
  3287)     26748.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3288)     26749.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3289)     26750.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3290)     26750.3  Rx         050C  6  00 00 00 01 5D 5F
  3291)     26751.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3292)     26751.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3293)     26754.3  Rx         054A  8  12 00 70 02 00 00 00 3A
  3294)     26755.2  Rx         054B  8  00 08 80 00 04 00 00 00
  3295)     26756.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3296)     26757.2  Rx         054F  8  49 00 00 00 0B 80 08 3F
  3297)     26758.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3298)     26760.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3299)     26760.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3300)     26761.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3301)     26761.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3302)     26768.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  3303)     26770.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3304)     26770.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3305)     26770.7  Rx         050A  6  06 20 00 17 00 00
  3306)     26771.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3307)     26771.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3308)     26773.9  Rx         0380  8  02 04 10 21 00 00 00 16
  3309)     26774.2  Rx         05BF  8  00 00 00 00 18 00 00 3B
  3310)     26778.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3311)     26780.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3312)     26780.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3313)     26781.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3314)     26781.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3315)     26788.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3316)     26790.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3317)     26791.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3318)     26791.2  Rx         050B  6  00 00 00 C0 00 00
  3319)     26791.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3320)     26791.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3321)     26798.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3322)     26801.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3323)     26801.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3324)     26801.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3325)     26801.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3326)     26807.6  Rx         056E  1  86
  3327)     26808.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3328)     26809.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3329)     26811.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3330)     26811.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3331)     26811.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3332)     26812.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3333)     26818.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3334)     26821.5  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  3335)     26821.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3336)     26822.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3337)     26822.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3338)     26828.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3339)     26831.5  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  3340)     26831.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3341)     26831.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3342)     26832.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3343)     26838.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3344)     26841.7  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  3345)     26841.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3346)     26842.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3347)     26842.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3348)     26842.6  Rx         055B  8  AB 00 55 00 E6 40 10 63
  3349)     26848.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  3350)     26851.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3351)     26851.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3352)     26852.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3353)     26852.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3354)     26852.7  Rx         050C  6  00 00 00 02 B2 0D
  3355)     26854.3  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3356)     26855.3  Rx         054B  8  00 08 80 00 04 00 00 00
  3357)     26856.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3358)     26857.2  Rx         054F  8  49 00 00 00 0B C0 08 3F
  3359)     26858.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3360)     26861.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3361)     26861.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3362)     26862.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3363)     26862.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3364)     26868.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3365)     26871.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3366)     26871.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3367)     26872.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3368)     26873.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3369)     26873.2  Rx         050A  6  06 40 00 17 00 00
  3370)     26874.0  Rx         0380  8  02 04 10 21 00 00 00 27
  3371)     26874.3  Rx         05BF  8  00 00 00 00 18 00 00 08
  3372)     26878.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3373)     26881.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3374)     26881.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3375)     26883.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3376)     26883.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3377)     26888.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3378)     26891.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3379)     26891.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3380)     26893.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3381)     26893.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3382)     26893.6  Rx         050B  6  00 00 00 C0 00 00
  3383)     26898.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3384)     26901.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3385)     26901.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3386)     26903.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3387)     26903.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3388)     26907.7  Rx         056E  1  86
  3389)     26908.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3390)     26909.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3391)     26911.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3392)     26911.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3393)     26913.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3394)     26914.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3395)     26918.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3396)     26921.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3397)     26921.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3398)     26923.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3399)     26924.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3400)     26928.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3401)     26931.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3402)     26931.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3403)     26934.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3404)     26934.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3405)     26938.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3406)     26941.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3407)     26941.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3408)     26942.1  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  3409)     26944.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3410)     26944.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3411)     26948.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3412)     26951.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3413)     26951.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3414)     26954.3  Rx         054A  8  12 00 70 02 00 00 00 3A
  3415)     26954.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3416)     26954.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3417)     26955.2  Rx         050C  6  00 00 00 03 B2 9A
  3418)     26955.4  Rx         054B  8  00 08 80 00 04 00 00 00
  3419)     26956.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3420)     26957.3  Rx         054F  8  49 00 00 00 0B 00 08 3F
  3421)     26958.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3422)     26961.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3423)     26961.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3424)     26965.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3425)     26965.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3426)     26965.4  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  3427)     26968.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3428)     26971.5  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3429)     26971.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3430)     26974.1  Rx         0380  8  02 04 10 21 00 00 00 38
  3431)     26974.4  Rx         05BF  8  00 00 00 00 18 00 00 19
  3432)     26975.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3433)     26975.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3434)     26975.6  Rx         050A  6  06 60 00 17 00 00
  3435)     26978.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3436)     26981.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3437)     26981.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3438)     26985.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3439)     26985.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3440)     26988.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3441)     26991.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3442)     26991.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3443)     26995.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3444)     26995.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3445)     26996.1  Rx         050B  6  00 00 00 C0 00 00
  3446)     26998.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3447)     27001.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3448)     27001.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3449)     27005.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3450)     27006.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3451)     27007.7  Rx         056E  1  86
  3452)     27008.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3453)     27009.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3454)     27011.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3455)     27011.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3456)     27016.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3457)     27016.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3458)     27018.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3459)     27021.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3460)     27021.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3461)     27026.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3462)     27026.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3463)     27028.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3464)     27031.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3465)     27031.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3466)     27036.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3467)     27036.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3468)     27037.0  Rx         05B9  5  40 78 61 4A 28
  3469)     27038.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3470)     27041.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3471)     27041.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3472)     27042.1  Rx         055B  8  AB 00 55 00 E6 40 12 EC
  3473)     27046.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3474)     27047.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3475)     27048.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3476)     27051.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3477)     27052.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3478)     27052.3  Rx         05BC  8  29 03 29 3A A8 05 20 78
  3479)     27052.5  Rx         05C0  8  80 74 74 00 8C D0 18 00
  3480)     27054.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3481)     27055.4  Rx         054B  8  00 08 80 00 04 00 00 00
  3482)     27056.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3483)     27057.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3484)     27057.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3485)     27057.6  Rx         050C  6  00 00 00 00 B2 A6
  3486)     27057.8  Rx         054F  8  49 00 00 00 0B 40 08 3F
  3487)     27058.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3488)     27061.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3489)     27061.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3490)     27067.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3491)     27067.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3492)     27068.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3493)     27071.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3494)     27071.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3495)     27074.2  Rx         0380  8  02 04 10 21 00 00 00 05
  3496)     27074.4  Rx         05BF  8  00 00 00 00 18 00 00 2A
  3497)     27077.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3498)     27077.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3499)     27078.1  Rx         050A  6  06 00 00 17 00 00
  3500)     27078.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3501)     27081.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3502)     27081.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3503)     27087.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3504)     27088.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3505)     27088.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3506)     27091.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3507)     27091.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3508)     27098.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3509)     27098.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3510)     27098.5  Rx         050B  6  00 00 00 C0 00 00
  3511)     27098.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3512)     27101.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3513)     27101.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3514)     27107.6  Rx         056E  1  86
  3515)     27108.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3516)     27108.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3517)     27108.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3518)     27109.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3519)     27111.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3520)     27111.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3521)     27118.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3522)     27118.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3523)     27119.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3524)     27121.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3525)     27121.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3526)     27128.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3527)     27128.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3528)     27129.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3529)     27131.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3530)     27131.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3531)     27138.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3532)     27139.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3533)     27139.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3534)     27141.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3535)     27141.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3536)     27142.1  Rx         055B  8  AB 00 55 00 E6 40 13 69
  3537)     27148.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3538)     27149.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3539)     27149.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3540)     27151.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3541)     27151.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3542)     27154.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  3543)     27155.5  Rx         054B  8  00 08 80 00 04 00 00 00
  3544)     27156.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3545)     27157.5  Rx         054F  8  49 00 00 00 0B 80 08 3F
  3546)     27158.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3547)     27159.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3548)     27159.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3549)     27160.0  Rx         050C  6  00 00 00 01 B2 31
  3550)     27161.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3551)     27161.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3552)     27168.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3553)     27169.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3554)     27170.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3555)     27171.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3556)     27171.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3557)     27174.3  Rx         0380  8  02 04 10 21 00 00 00 16
  3558)     27174.5  Rx         05BF  8  00 00 00 00 18 00 00 3B
  3559)     27178.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3560)     27180.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3561)     27180.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3562)     27180.5  Rx         050A  6  06 20 00 17 00 00
  3563)     27181.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3564)     27181.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3565)     27188.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3566)     27190.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3567)     27190.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3568)     27191.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3569)     27191.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3570)     27198.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3571)     27200.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3572)     27200.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3573)     27200.9  Rx         050B  6  00 00 00 C0 00 00
  3574)     27201.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3575)     27201.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3576)     27207.6  Rx         056E  1  86
  3577)     27208.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3578)     27208.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3579)     27210.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3580)     27211.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3581)     27211.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3582)     27211.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3583)     27218.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3584)     27221.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3585)     27221.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3586)     27221.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3587)     27221.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3588)     27228.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3589)     27231.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3590)     27231.5  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3591)     27231.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3592)     27231.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3593)     27238.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3594)     27241.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3595)     27241.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3596)     27241.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3597)     27242.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3598)     27242.4  Rx         055B  8  AB 00 AA 00 E6 40 10 24
  3599)     27248.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3600)     27251.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3601)     27251.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3602)     27251.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3603)     27252.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3604)     27254.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3605)     27255.6  Rx         054B  8  00 08 80 00 04 00 00 00
  3606)     27256.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3607)     27257.6  Rx         054F  8  49 00 00 00 0B C0 08 3F
  3608)     27258.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  3609)     27261.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3610)     27261.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3611)     27262.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3612)     27262.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3613)     27262.5  Rx         050C  6  00 00 00 02 5D 63
  3614)     27268.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3615)     27271.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3616)     27271.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3617)     27272.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3618)     27272.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3619)     27274.4  Rx         0380  8  02 04 10 21 00 00 00 27
  3620)     27274.7  Rx         05BF  8  00 00 00 00 18 00 00 08
  3621)     27278.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3622)     27281.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3623)     27281.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3624)     27282.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3625)     27282.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3626)     27282.9  Rx         050A  6  06 40 00 17 00 00
  3627)     27288.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3628)     27291.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3629)     27291.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3630)     27292.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3631)     27292.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3632)     27298.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3633)     27301.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3634)     27301.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3635)     27302.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3636)     27303.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3637)     27303.4  Rx         050B  6  00 00 00 C0 00 00
  3638)     27307.8  Rx         056E  1  86
  3639)     27308.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3640)     27308.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3641)     27311.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3642)     27311.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3643)     27313.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3644)     27313.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3645)     27318.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3646)     27321.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3647)     27321.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3648)     27323.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3649)     27323.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3650)     27328.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3651)     27331.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3652)     27331.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3653)     27333.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3654)     27333.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3655)     27338.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3656)     27341.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3657)     27341.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3658)     27342.0  Rx         055B  8  AB 00 AA 00 E6 40 11 A1
  3659)     27343.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3660)     27344.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3661)     27348.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3662)     27351.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3663)     27351.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3664)     27354.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3665)     27354.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3666)     27354.7  Rx         054A  8  12 00 70 02 00 00 00 3A
  3667)     27355.6  Rx         054B  8  00 08 80 00 04 00 00 00
  3668)     27356.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3669)     27357.6  Rx         054F  8  49 00 00 00 0B 00 08 3F
  3670)     27358.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3671)     27361.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3672)     27361.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3673)     27364.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3674)     27364.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3675)     27364.9  Rx         050C  6  00 00 00 03 5D F4
  3676)     27368.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3677)     27371.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3678)     27371.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3679)     27374.5  Rx         0380  8  02 04 10 21 00 00 00 38
  3680)     27374.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3681)     27375.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3682)     27375.2  Rx         05BF  8  00 00 00 00 18 00 00 19
  3683)     27378.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3684)     27381.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3685)     27381.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3686)     27384.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3687)     27385.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3688)     27385.3  Rx         050A  6  06 60 00 17 00 00
  3689)     27388.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3690)     27391.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3691)     27391.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3692)     27395.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3693)     27395.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3694)     27398.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3695)     27401.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3696)     27401.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3697)     27405.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3698)     27405.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3699)     27405.8  Rx         050B  6  00 00 00 C0 00 00
  3700)     27407.8  Rx         056E  1  86
  3701)     27408.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3702)     27408.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3703)     27411.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3704)     27411.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3705)     27415.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3706)     27415.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3707)     27418.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3708)     27421.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3709)     27421.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3710)     27425.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3711)     27426.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3712)     27428.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3713)     27431.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3714)     27431.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3715)     27436.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3716)     27436.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3717)     27438.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3718)     27441.6  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  3719)     27441.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3720)     27442.0  Rx         055B  8  AB 00 AA 00 E6 40 12 AB
  3721)     27446.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3722)     27446.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3723)     27448.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3724)     27451.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3725)     27451.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3726)     27454.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3727)     27455.7  Rx         054B  8  00 08 80 00 04 00 00 00
  3728)     27456.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3729)     27456.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3730)     27457.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3731)     27457.7  Rx         054F  8  49 00 00 00 0B 40 08 3F
  3732)     27458.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3733)     27461.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3734)     27461.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3735)     27466.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3736)     27467.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3737)     27467.3  Rx         050C  6  00 00 00 00 5D C8
  3738)     27468.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3739)     27471.4  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  3740)     27471.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3741)     27474.5  Rx         0380  8  02 04 10 21 00 00 00 05
  3742)     27474.8  Rx         05BF  8  00 00 00 00 18 00 00 2A
  3743)     27477.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3744)     27477.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3745)     27477.6  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  3746)     27478.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3747)     27481.4  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  3748)     27481.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3749)     27487.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3750)     27487.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3751)     27487.8  Rx         050A  6  06 00 00 17 00 00
  3752)     27488.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3753)     27491.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3754)     27491.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3755)     27497.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3756)     27497.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3757)     27498.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3758)     27501.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3759)     27501.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3760)     27507.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3761)     27508.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3762)     27508.3  Rx         050B  6  00 00 00 C0 00 00
  3763)     27508.3  Rx         056E  1  86
  3764)     27508.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3765)     27508.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3766)     27511.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3767)     27511.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3768)     27518.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3769)     27518.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3770)     27518.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3771)     27521.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3772)     27521.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3773)     27528.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3774)     27528.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3775)     27528.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  3776)     27531.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3777)     27531.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3778)     27538.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3779)     27538.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  3780)     27539.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3781)     27541.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3782)     27541.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3783)     27542.0  Rx         055B  8  AB 00 AA 00 E6 40 13 2E
  3784)     27548.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3785)     27548.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3786)     27549.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3787)     27549.3  Rx         05B9  5  40 78 61 4A 28
  3788)     27551.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3789)     27551.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3790)     27552.2  Rx         05BC  8  29 03 2C 3A A9 05 40 32
  3791)     27552.4  Rx         05C0  8  C0 74 74 00 8C D0 18 00
  3792)     27554.8  Rx         054A  8  12 00 70 02 00 00 00 3A
  3793)     27555.8  Rx         054B  8  00 08 80 00 04 00 00 00
  3794)     27556.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3795)     27557.8  Rx         054F  8  49 00 00 00 0B 80 08 3F
  3796)     27558.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3797)     27559.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3798)     27559.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3799)     27561.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3800)     27561.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3801)     27568.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3802)     27569.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3803)     27569.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3804)     27569.7  Rx         050C  6  00 00 00 01 5D 5F
  3805)     27571.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3806)     27571.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3807)     27574.7  Rx         0380  8  02 04 10 21 00 00 00 16
  3808)     27574.9  Rx         05BF  8  00 00 00 00 18 00 00 3B
  3809)     27578.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3810)     27579.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3811)     27579.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3812)     27581.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3813)     27581.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3814)     27588.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3815)     27589.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3816)     27590.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3817)     27590.2  Rx         050A  6  06 20 00 17 00 00
  3818)     27591.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3819)     27591.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3820)     27598.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3821)     27600.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3822)     27600.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3823)     27601.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3824)     27601.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3825)     27607.7  Rx         056E  1  86
  3826)     27608.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3827)     27608.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3828)     27610.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3829)     27610.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3830)     27610.7  Rx         050B  6  00 00 00 C0 00 00
  3831)     27611.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3832)     27611.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3833)     27618.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3834)     27620.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3835)     27620.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3836)     27621.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3837)     27621.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3838)     27628.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3839)     27630.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3840)     27631.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3841)     27631.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3842)     27631.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3843)     27638.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3844)     27640.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3845)     27641.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3846)     27641.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3847)     27641.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3848)     27642.0  Rx         055B  8  AB 00 AA 00 E6 40 10 24
  3849)     27648.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3850)     27651.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3851)     27651.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3852)     27651.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3853)     27651.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3854)     27654.8  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3855)     27655.8  Rx         054B  8  00 08 80 00 04 00 00 00
  3856)     27656.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3857)     27657.8  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  3858)     27658.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3859)     27661.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3860)     27661.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3861)     27661.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3862)     27662.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3863)     27668.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3864)     27671.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3865)     27671.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3866)     27671.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3867)     27672.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3868)     27672.3  Rx         050C  6  00 00 00 02 5D 63
  3869)     27674.8  Rx         0380  8  02 04 10 21 00 00 00 27
  3870)     27675.1  Rx         05BF  8  00 00 00 00 18 00 00 08
  3871)     27678.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3872)     27681.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3873)     27681.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3874)     27681.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3875)     27682.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3876)     27688.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3877)     27691.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3878)     27691.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3879)     27692.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3880)     27692.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3881)     27692.6  Rx         050A  6  06 40 00 17 00 00
  3882)     27698.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3883)     27701.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3884)     27701.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3885)     27702.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3886)     27702.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3887)     27707.8  Rx         056E  1  86
  3888)     27708.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3889)     27708.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3890)     27711.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3891)     27711.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3892)     27712.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3893)     27712.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3894)     27713.1  Rx         050B  6  00 00 00 C0 00 00
  3895)     27718.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3896)     27721.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3897)     27721.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3898)     27722.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3899)     27723.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3900)     27728.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3901)     27731.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3902)     27731.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3903)     27733.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3904)     27733.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3905)     27738.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3906)     27741.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3907)     27741.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3908)     27742.0  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  3909)     27743.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3910)     27743.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3911)     27748.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3912)     27751.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3913)     27751.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3914)     27753.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3915)     27753.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3916)     27754.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  3917)     27755.9  Rx         054B  8  00 08 80 00 04 00 00 00
  3918)     27756.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3919)     27757.9  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  3920)     27758.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3921)     27761.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3922)     27761.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3923)     27763.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3924)     27764.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3925)     27768.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  3926)     27771.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3927)     27771.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3928)     27774.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3929)     27774.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3930)     27774.6  Rx         050C  6  00 00 00 03 B2 9A
  3931)     27774.9  Rx         0380  8  02 04 10 21 00 00 00 38
  3932)     27775.1  Rx         05BF  8  00 00 00 00 18 00 00 19
  3933)     27778.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  3934)     27781.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3935)     27781.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3936)     27784.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3937)     27784.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3938)     27788.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3939)     27791.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3940)     27791.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3941)     27794.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3942)     27794.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3943)     27795.0  Rx         050A  6  06 60 00 17 00 00
  3944)     27798.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3945)     27801.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3946)     27801.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3947)     27804.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3948)     27805.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3949)     27807.8  Rx         056E  1  86
  3950)     27808.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3951)     27808.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  3952)     27811.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3953)     27811.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3954)     27815.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3955)     27815.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3956)     27815.5  Rx         050B  6  00 00 00 C0 00 00
  3957)     27818.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3958)     27821.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  3959)     27821.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3960)     27825.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3961)     27825.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3962)     27828.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3963)     27831.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  3964)     27831.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3965)     27835.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3966)     27835.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3967)     27838.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3968)     27841.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  3969)     27841.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3970)     27842.0  Rx         055B  8  AB 00 55 00 E6 40 12 EC
  3971)     27845.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3972)     27846.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  3973)     27848.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  3974)     27851.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  3975)     27851.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  3976)     27855.0  Rx         054A  8  A0 00 70 02 00 00 00 3A
  3977)     27856.0  Rx         054B  8  00 08 80 00 04 00 00 00
  3978)     27856.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  3979)     27856.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  3980)     27857.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  3981)     27858.0  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  3982)     27858.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  3983)     27861.4  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  3984)     27861.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  3985)     27866.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  3986)     27866.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  3987)     27868.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  3988)     27871.4  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  3989)     27871.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  3990)     27875.0  Rx         0380  8  02 04 10 21 00 00 00 05
  3991)     27875.2  Rx         05BF  8  00 00 00 00 18 00 00 2A
  3992)     27876.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  3993)     27876.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  3994)     27877.1  Rx         050C  6  00 00 00 00 B2 A6
  3995)     27878.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  3996)     27881.3  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  3997)     27881.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  3998)     27886.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  3999)     27887.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4000)     27888.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  4001)     27891.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4002)     27891.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4003)     27897.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4004)     27897.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4005)     27897.5  Rx         050A  6  06 00 00 17 00 00
  4006)     27898.6  Rx         01DA  8  01 00 00 00 00 01 01 15
  4007)     27901.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4008)     27901.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4009)     27907.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4010)     27907.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4011)     27907.9  Rx         056E  1  86
  4012)     27908.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4013)     27908.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4014)     27911.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4015)     27911.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4016)     27917.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4017)     27917.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4018)     27918.0  Rx         050B  6  00 00 00 C0 00 00
  4019)     27918.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4020)     27921.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4021)     27921.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4022)     27927.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4023)     27928.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4024)     27928.6  Rx         01DA  8  01 00 00 00 00 01 00 90
  4025)     27931.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4026)     27931.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4027)     27938.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4028)     27938.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4029)     27938.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4030)     27941.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4031)     27941.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4032)     27942.0  Rx         055B  8  AB 00 55 00 E6 40 13 69
  4033)     27948.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4034)     27948.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4035)     27948.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4036)     27951.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4037)     27951.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4038)     27955.1  Rx         054A  8  12 00 70 02 00 00 00 3A
  4039)     27956.1  Rx         054B  8  00 08 80 00 04 00 00 00
  4040)     27957.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4041)     27958.1  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  4042)     27958.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4043)     27958.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4044)     27959.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4045)     27961.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4046)     27961.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4047)     27968.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4048)     27968.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4049)     27969.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4050)     27971.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4051)     27971.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4052)     27975.1  Rx         0380  8  02 04 10 21 00 00 00 16
  4053)     27975.4  Rx         05BF  8  00 00 00 00 18 00 00 3B
  4054)     27978.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4055)     27979.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4056)     27979.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4057)     27979.5  Rx         050C  6  00 00 00 01 B2 31
  4058)     27981.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4059)     27981.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4060)     27988.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4061)     27989.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4062)     27989.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4063)     27989.7  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  4064)     27991.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4065)     27991.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4066)     27998.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4067)     27999.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4068)     27999.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4069)     28000.0  Rx         050A  6  06 20 00 17 00 00
  4070)     28001.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4071)     28001.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4072)     28007.8  Rx         056E  1  86
  4073)     28008.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4074)     28008.8  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4075)     28009.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4076)     28010.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4077)     28011.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4078)     28011.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4079)     28018.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4080)     28020.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4081)     28020.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4082)     28020.4  Rx         050B  6  00 00 00 C0 00 00
  4083)     28021.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4084)     28021.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4085)     28028.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4086)     28030.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4087)     28030.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4088)     28031.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4089)     28031.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4090)     28038.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4091)     28040.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4092)     28040.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4093)     28041.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4094)     28041.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4095)     28042.0  Rx         055B  8  AB 00 55 00 E6 40 10 63
  4096)     28048.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4097)     28050.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4098)     28051.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4099)     28051.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4100)     28051.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4101)     28052.2  Rx         05BC  8  29 03 29 3A A8 06 21 4A
  4102)     28052.4  Rx         05C0  8  40 76 76 00 8C 08 18 00
  4103)     28055.1  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4104)     28056.2  Rx         054B  8  00 08 80 00 04 00 00 00
  4105)     28057.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4106)     28058.1  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  4107)     28058.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4108)     28061.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4109)     28061.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4110)     28061.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4111)     28061.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4112)     28061.9  Rx         05B9  5  40 78 61 4A 28
  4113)     28068.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4114)     28071.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4115)     28071.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4116)     28071.7  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4117)     28071.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4118)     28075.2  Rx         0380  8  02 04 10 21 00 00 00 27
  4119)     28075.5  Rx         05BF  8  00 00 00 00 18 00 00 08
  4120)     28078.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4121)     28081.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4122)     28081.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4123)     28081.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4124)     28082.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4125)     28082.2  Rx         050C  6  00 00 00 02 B2 0D
  4126)     28088.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4127)     28091.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4128)     28091.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4129)     28091.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4130)     28092.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4131)     28098.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4132)     28101.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4133)     28101.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4134)     28101.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4135)     28102.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4136)     28102.3  Rx         050A  6  06 40 00 17 00 00
  4137)     28107.8  Rx         056E  1  86
  4138)     28108.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4139)     28108.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4140)     28111.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4141)     28111.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4142)     28112.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4143)     28112.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4144)     28118.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4145)     28121.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4146)     28121.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4147)     28122.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4148)     28122.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4149)     28122.9  Rx         050B  6  00 00 00 C0 00 00
  4150)     28128.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4151)     28131.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4152)     28131.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4153)     28132.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4154)     28132.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4155)     28138.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4156)     28141.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4157)     28141.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4158)     28142.0  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  4159)     28142.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4160)     28143.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4161)     28148.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4162)     28151.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4163)     28151.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4164)     28153.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4165)     28153.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4166)     28155.2  Rx         054A  8  12 00 70 02 00 00 00 3A
  4167)     28156.2  Rx         054B  8  00 08 80 00 04 00 00 00
  4168)     28157.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4169)     28158.2  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  4170)     28158.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4171)     28161.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4172)     28161.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4173)     28163.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4174)     28163.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4175)     28168.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4176)     28171.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4177)     28171.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4178)     28173.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4179)     28173.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4180)     28175.3  Rx         0380  8  02 04 10 21 00 00 00 38
  4181)     28175.5  Rx         05BF  8  00 00 00 00 18 00 00 19
  4182)     28178.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4183)     28181.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4184)     28181.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4185)     28183.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4186)     28184.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4187)     28184.3  Rx         050C  6  00 00 00 03 B2 9A
  4188)     28188.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4189)     28191.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4190)     28191.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4191)     28194.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4192)     28194.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4193)     28198.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4194)     28201.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4195)     28201.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4196)     28204.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4197)     28204.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4198)     28204.8  Rx         050A  6  06 60 00 17 00 00
  4199)     28207.9  Rx         056E  1  86
  4200)     28208.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4201)     28208.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  4202)     28211.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4203)     28211.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4204)     28214.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4205)     28214.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4206)     28218.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4207)     28221.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4208)     28221.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4209)     28224.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4210)     28225.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4211)     28225.3  Rx         050B  6  00 00 00 C0 00 00
  4212)     28228.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4213)     28231.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4214)     28231.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4215)     28235.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4216)     28235.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4217)     28238.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4218)     28241.5  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4219)     28241.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4220)     28241.9  Rx         055B  8  AB 00 AA 00 E6 40 12 AB
  4221)     28245.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4222)     28245.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4223)     28248.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4224)     28251.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4225)     28251.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4226)     28255.3  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4227)     28255.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4228)     28255.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4229)     28256.3  Rx         054B  8  00 08 80 00 04 00 00 00
  4230)     28257.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4231)     28258.3  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  4232)     28258.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4233)     28261.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4234)     28261.6  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4235)     28265.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4236)     28266.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4237)     28268.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4238)     28271.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4239)     28271.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4240)     28275.3  Rx         0380  8  02 04 10 21 00 00 00 05
  4241)     28275.6  Rx         05BF  8  00 00 00 00 18 00 00 2A
  4242)     28276.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4243)     28276.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4244)     28278.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4245)     28281.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4246)     28281.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4247)     28286.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4248)     28286.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4249)     28286.8  Rx         050C  6  00 00 00 00 5D C8
  4250)     28288.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4251)     28291.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4252)     28291.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4253)     28296.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4254)     28296.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4255)     28298.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4256)     28301.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4257)     28301.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4258)     28306.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4259)     28307.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4260)     28307.2  Rx         050A  6  06 00 00 17 00 00
  4261)     28308.0  Rx         056E  1  86
  4262)     28308.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4263)     28308.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  4264)     28311.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4265)     28311.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4266)     28317.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4267)     28317.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4268)     28318.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4269)     28321.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4270)     28321.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4271)     28327.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4272)     28327.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4273)     28327.7  Rx         050B  6  00 00 00 C0 00 00
  4274)     28328.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4275)     28331.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4276)     28331.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4277)     28337.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4278)     28337.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4279)     28338.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4280)     28341.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4281)     28341.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4282)     28341.9  Rx         055B  8  AB 00 AA 00 E6 00 13 B3
  4283)     28347.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4284)     28348.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4285)     28348.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4286)     28351.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4287)     28351.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4288)     28355.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  4289)     28356.4  Rx         054B  8  00 08 80 00 04 00 00 00
  4290)     28357.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4291)     28358.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4292)     28358.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4293)     28358.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4294)     28358.7  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  4295)     28361.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4296)     28361.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4297)     28368.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4298)     28368.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4299)     28368.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  4300)     28371.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4301)     28371.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4302)     28375.5  Rx         0380  8  02 04 10 21 00 00 00 16
  4303)     28375.7  Rx         05BF  8  00 00 00 00 18 00 00 3B
  4304)     28378.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4305)     28378.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4306)     28378.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4307)     28381.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4308)     28381.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4309)     28388.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4310)     28388.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4311)     28389.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4312)     28389.2  Rx         050C  6  00 00 00 01 5D 5F
  4313)     28391.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4314)     28391.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4315)     28398.5  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4316)     28398.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4317)     28399.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4318)     28401.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4319)     28401.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4320)     28407.9  Rx         056E  1  86
  4321)     28408.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4322)     28408.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  4323)     28409.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4324)     28409.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4325)     28409.6  Rx         050A  6  06 20 00 17 00 00
  4326)     28411.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4327)     28411.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4328)     28418.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4329)     28419.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4330)     28419.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4331)     28421.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4332)     28421.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4333)     28428.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4334)     28429.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4335)     28430.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4336)     28430.1  Rx         050B  6  00 00 00 C0 00 00
  4337)     28431.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4338)     28431.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4339)     28438.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4340)     28439.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4341)     28440.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4342)     28441.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4343)     28441.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4344)     28441.9  Rx         055B  8  AB 00 AA 00 E6 00 10 B9
  4345)     28448.5  Rx         01DA  8  01 00 00 00 00 01 00 90
  4346)     28450.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4347)     28450.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4348)     28451.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4349)     28451.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4350)     28455.5  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4351)     28456.4  Rx         054B  8  00 08 80 00 04 00 00 00
  4352)     28457.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4353)     28458.5  Rx         01DA  8  01 00 00 00 00 01 01 15
  4354)     28458.7  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  4355)     28460.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4356)     28460.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4357)     28461.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4358)     28461.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4359)     28468.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4360)     28470.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4361)     28470.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4362)     28471.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4363)     28471.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4364)     28475.6  Rx         0380  8  02 04 10 21 00 00 00 27
  4365)     28475.9  Rx         05BF  8  00 00 00 00 18 00 00 08
  4366)     28478.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4367)     28481.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4368)     28481.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4369)     28481.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4370)     28481.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4371)     28488.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4372)     28491.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4373)     28491.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4374)     28491.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4375)     28491.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4376)     28492.1  Rx         050C  6  00 00 00 02 5D 63
  4377)     28498.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4378)     28501.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4379)     28501.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4380)     28501.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4381)     28502.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4382)     28502.2  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  4383)     28507.9  Rx         056E  1  86
  4384)     28508.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4385)     28508.7  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4386)     28511.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4387)     28511.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4388)     28511.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4389)     28512.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4390)     28512.2  Rx         050A  6  06 40 00 17 00 00
  4391)     28518.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4392)     28521.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4393)     28521.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4394)     28521.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4395)     28522.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4396)     28528.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4397)     28531.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4398)     28531.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4399)     28532.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4400)     28532.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4401)     28532.6  Rx         050B  6  00 00 00 C0 00 00
  4402)     28538.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4403)     28541.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4404)     28541.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4405)     28541.9  Rx         055B  8  AB 00 AA 00 E6 00 11 3C
  4406)     28542.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4407)     28542.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4408)     28548.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4409)     28551.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4410)     28551.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4411)     28552.1  Rx         05BC  8  29 03 2C 3A A9 06 40 96
  4412)     28552.3  Rx         05C0  8  80 74 74 00 8C D0 18 00
  4413)     28552.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4414)     28552.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4415)     28555.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  4416)     28556.5  Rx         054B  8  00 08 80 00 04 00 00 00
  4417)     28557.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4418)     28558.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4419)     28558.7  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  4420)     28561.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4421)     28561.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4422)     28562.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4423)     28563.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4424)     28568.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4425)     28571.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4426)     28571.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4427)     28573.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4428)     28573.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4429)     28573.5  Rx         05B9  5  40 78 61 4A 28
  4430)     28575.6  Rx         0380  8  02 04 10 21 00 00 00 38
  4431)     28575.9  Rx         05BF  8  00 00 00 00 18 00 00 19
  4432)     28578.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4433)     28581.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4434)     28581.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4435)     28583.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4436)     28583.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4437)     28588.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4438)     28591.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4439)     28591.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4440)     28593.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4441)     28593.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4442)     28594.0  Rx         050C  6  00 00 00 03 5D F4
  4443)     28598.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4444)     28601.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4445)     28601.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4446)     28603.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4447)     28604.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4448)     28608.0  Rx         056E  1  86
  4449)     28608.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4450)     28608.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A E8
  4451)     28611.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4452)     28611.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4453)     28614.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4454)     28614.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4455)     28614.5  Rx         050A  6  06 60 00 17 00 00
  4456)     28618.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4457)     28621.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4458)     28621.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4459)     28624.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4460)     28624.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4461)     28628.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4462)     28631.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4463)     28631.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4464)     28634.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4465)     28634.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4466)     28635.0  Rx         050B  6  00 00 00 C0 00 00
  4467)     28638.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4468)     28641.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4469)     28641.7  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4470)     28641.9  Rx         055B  8  AB 00 AA 00 E6 00 12 36
  4471)     28644.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4472)     28645.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4473)     28648.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4474)     28651.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4475)     28651.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4476)     28655.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4477)     28655.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4478)     28655.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4479)     28656.6  Rx         054B  8  00 08 80 00 04 00 00 00
  4480)     28657.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4481)     28658.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4482)     28658.6  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  4483)     28661.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4484)     28661.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4485)     28665.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4486)     28665.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4487)     28668.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4488)     28671.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4489)     28671.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4490)     28675.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4491)     28675.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4492)     28676.0  Rx         0380  8  02 04 10 21 00 00 00 05
  4493)     28676.3  Rx         05BF  8  00 00 00 00 18 00 00 2A
  4494)     28678.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4495)     28681.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4496)     28681.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4497)     28685.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4498)     28686.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4499)     28688.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4500)     28691.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4501)     28691.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4502)     28696.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4503)     28696.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4504)     28696.5  Rx         050C  6  00 00 00 00 5D C8
  4505)     28698.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4506)     28701.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4507)     28701.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4508)     28706.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4509)     28706.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4510)     28708.0  Rx         056E  1  86
  4511)     28708.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4512)     28708.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4513)     28711.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4514)     28711.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4515)     28716.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4516)     28716.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4517)     28717.0  Rx         050A  6  06 00 00 17 00 00
  4518)     28718.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4519)     28721.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4520)     28721.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4521)     28726.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4522)     28727.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4523)     28728.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4524)     28731.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4525)     28731.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4526)     28737.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4527)     28737.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4528)     28737.4  Rx         050B  6  00 00 00 C0 00 00
  4529)     28738.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4530)     28741.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4531)     28741.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4532)     28741.9  Rx         055B  8  AB 00 55 00 E6 00 13 F4
  4533)     28747.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4534)     28747.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4535)     28748.4  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4536)     28751.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4537)     28751.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4538)     28755.6  Rx         054A  8  12 00 70 02 00 00 00 3A
  4539)     28756.7  Rx         054B  8  00 08 80 00 04 00 00 00
  4540)     28757.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4541)     28757.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4542)     28758.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4543)     28758.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4544)     28758.7  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  4545)     28761.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4546)     28761.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4547)     28767.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4548)     28768.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4549)     28768.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4550)     28771.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4551)     28771.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4552)     28775.9  Rx         0380  8  02 04 10 21 00 00 00 16
  4553)     28776.1  Rx         05BF  8  00 00 00 00 18 00 00 3B
  4554)     28778.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4555)     28778.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4556)     28778.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4557)     28781.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4558)     28781.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4559)     28788.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4560)     28788.5  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4561)     28788.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4562)     28791.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4563)     28791.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4564)     28798.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4565)     28798.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4566)     28798.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4567)     28799.1  Rx         050C  6  00 00 00 01 B2 31
  4568)     28801.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4569)     28801.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4570)     28807.9  Rx         056E  1  86
  4571)     28808.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4572)     28808.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4573)     28808.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4574)     28809.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4575)     28811.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4576)     28811.5  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4577)     28818.4  Rx         01DA  8  01 00 00 00 00 01 01 15
  4578)     28818.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4579)     28819.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4580)     28819.4  Rx         050A  6  06 20 00 17 00 00
  4581)     28821.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4582)     28821.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4583)     28828.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4584)     28829.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4585)     28829.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4586)     28831.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4587)     28831.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4588)     28838.4  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4589)     28839.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4590)     28839.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4591)     28839.9  Rx         050B  6  00 00 00 C0 00 00
  4592)     28841.4  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4593)     28841.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4594)     28841.9  Rx         055B  8  AB 00 55 00 E6 00 10 FE
  4595)     28848.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4596)     28849.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4597)     28850.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4598)     28851.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4599)     28851.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4600)     28855.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4601)     28856.6  Rx         054B  8  00 08 80 00 04 00 00 00
  4602)     28857.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4603)     28858.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  4604)     28858.6  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  4605)     28859.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4606)     28860.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4607)     28861.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4608)     28861.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4609)     28868.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4610)     28870.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4611)     28870.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4612)     28871.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4613)     28871.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4614)     28875.9  Rx         0380  8  02 04 10 21 00 00 00 27
  4615)     28876.1  Rx         05BF  8  00 00 00 00 18 00 00 08
  4616)     28878.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4617)     28880.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4618)     28880.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4619)     28881.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4620)     28881.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4621)     28888.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  4622)     28890.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4623)     28890.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4624)     28891.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4625)     28891.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4626)     28898.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  4627)     28900.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4628)     28901.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4629)     28901.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4630)     28901.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4631)     28901.7  Rx         050C  6  00 00 00 02 B2 0D
  4632)     28908.0  Rx         056E  1  86
  4633)     28908.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4634)     28908.6  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4635)     28911.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4636)     28911.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4637)     28911.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4638)     28911.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4639)     28918.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4640)     28921.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4641)     28921.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4642)     28921.6  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4643)     28921.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4644)     28922.0  Rx         050A  6  06 40 00 17 00 00
  4645)     28928.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  4646)     28931.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4647)     28931.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4648)     28931.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4649)     28931.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4650)     28938.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  4651)     28941.3  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4652)     28941.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4653)     28941.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4654)     28942.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4655)     28942.2  Rx         050B  6  00 00 00 C0 00 00
  4656)     28942.4  Rx         055B  8  AB 00 55 00 E6 00 11 7B
  4657)     28948.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4658)     28951.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4659)     28951.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4660)     28952.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4661)     28952.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4662)     28955.7  Rx         054A  8  12 00 70 02 00 00 00 3A
  4663)     28956.7  Rx         054B  8  00 08 80 00 04 00 00 00
  4664)     28957.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4665)     28958.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4666)     28958.7  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  4667)     28961.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4668)     28961.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4669)     28962.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4670)     28962.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4671)     28968.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4672)     28971.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4673)     28971.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4674)     28972.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4675)     28972.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4676)     28976.0  Rx         0380  8  02 04 10 21 00 00 00 38
  4677)     28976.2  Rx         05BF  8  00 00 00 00 18 00 00 19
  4678)     28978.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4679)     28981.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4680)     28981.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4681)     28982.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4682)     28983.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4683)     28988.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4684)     28991.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4685)     28991.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4686)     28993.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4687)     28993.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4688)     28998.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4689)     29001.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4690)     29001.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4691)     29003.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4692)     29003.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4693)     29003.7  Rx         050C  6  00 00 00 03 B2 9A
  4694)     29008.0  Rx         056E  1  86
  4695)     29008.3  Rx         01DA  8  01 00 00 00 00 01 00 90
  4696)     29008.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4697)     29011.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4698)     29011.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4699)     29013.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4700)     29013.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4701)     29013.9  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  4702)     29018.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4703)     29021.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4704)     29021.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4705)     29023.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4706)     29024.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4707)     29024.2  Rx         050A  6  06 60 00 17 00 00
  4708)     29028.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4709)     29031.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4710)     29031.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4711)     29033.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4712)     29034.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4713)     29038.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4714)     29041.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4715)     29041.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4716)     29041.8  Rx         055B  8  AB 00 55 00 E6 00 12 71
  4717)     29044.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4718)     29044.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4719)     29044.7  Rx         050B  6  00 00 00 C0 00 00
  4720)     29048.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4721)     29051.4  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4722)     29051.7  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4723)     29051.9  Rx         05BC  8  29 03 29 3A A8 04 1F FF
  4724)     29052.2  Rx         05C0  8  C0 74 74 00 8C D0 18 00
  4725)     29054.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4726)     29054.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4727)     29055.8  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4728)     29056.8  Rx         054B  8  00 08 80 00 04 00 00 00
  4729)     29057.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4730)     29058.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4731)     29058.8  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  4732)     29061.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4733)     29061.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4734)     29064.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4735)     29064.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4736)     29068.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4737)     29071.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4738)     29071.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4739)     29074.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4740)     29075.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4741)     29076.1  Rx         0380  8  02 04 10 21 00 00 00 05
  4742)     29076.4  Rx         05BF  8  00 00 00 00 18 00 00 2A
  4743)     29078.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4744)     29081.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4745)     29081.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4746)     29085.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4747)     29085.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4748)     29085.6  Rx         05B9  5  40 78 61 4A 28
  4749)     29088.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4750)     29091.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4751)     29091.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4752)     29095.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4753)     29095.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4754)     29098.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4755)     29101.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4756)     29101.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4757)     29105.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4758)     29105.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4759)     29106.1  Rx         050C  6  00 00 00 00 B2 A6
  4760)     29108.0  Rx         056E  1  86
  4761)     29108.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4762)     29108.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4763)     29111.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4764)     29111.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4765)     29115.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4766)     29116.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4767)     29118.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4768)     29121.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4769)     29121.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4770)     29126.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4771)     29126.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4772)     29126.6  Rx         050A  6  06 00 00 17 00 00
  4773)     29128.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4774)     29131.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4775)     29131.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4776)     29136.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4777)     29136.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4778)     29138.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4779)     29141.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4780)     29141.5  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4781)     29141.7  Rx         055B  8  AB 00 55 00 E6 00 13 F4
  4782)     29146.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4783)     29146.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4784)     29147.1  Rx         050B  6  00 00 00 C0 00 00
  4785)     29148.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4786)     29151.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4787)     29151.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4788)     29155.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  4789)     29156.9  Rx         054B  8  00 08 80 00 04 00 00 00
  4790)     29157.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4791)     29157.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4792)     29157.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4793)     29158.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4794)     29158.9  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  4795)     29161.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4796)     29161.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4797)     29167.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4798)     29167.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4799)     29168.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4800)     29171.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4801)     29171.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4802)     29176.2  Rx         0380  8  02 04 10 21 00 00 00 16
  4803)     29176.4  Rx         05BF  8  00 00 00 00 18 00 00 3B
  4804)     29177.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4805)     29177.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4806)     29178.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4807)     29181.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4808)     29181.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4809)     29187.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4810)     29187.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4811)     29188.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4812)     29191.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4813)     29191.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4814)     29197.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4815)     29198.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4816)     29198.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4817)     29201.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4818)     29201.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4819)     29207.9  Rx         056E  1  86
  4820)     29208.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4821)     29208.4  Rx         01DA  8  01 00 00 00 00 01 00 90
  4822)     29208.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4823)     29208.8  Rx         050C  6  00 00 00 01 B2 31
  4824)     29209.1  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4825)     29211.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4826)     29211.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4827)     29218.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4828)     29218.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4829)     29218.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4830)     29221.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4831)     29221.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4832)     29228.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4833)     29228.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4834)     29228.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4835)     29229.0  Rx         050A  6  06 20 00 17 00 00
  4836)     29231.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4837)     29231.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4838)     29238.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4839)     29238.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4840)     29239.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4841)     29241.3  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4842)     29241.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4843)     29241.7  Rx         055B  8  AB 00 AA 00 E6 00 10 B9
  4844)     29248.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4845)     29249.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4846)     29249.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4847)     29249.5  Rx         050B  6  00 00 00 C0 00 00
  4848)     29251.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4849)     29251.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4850)     29255.9  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4851)     29257.0  Rx         054B  8  00 08 80 00 04 00 00 00
  4852)     29257.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4853)     29258.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4854)     29258.9  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  4855)     29259.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4856)     29259.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4857)     29261.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4858)     29261.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4859)     29268.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4860)     29269.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4861)     29269.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4862)     29271.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4863)     29271.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4864)     29276.2  Rx         0380  8  02 04 10 21 00 00 00 27
  4865)     29276.5  Rx         05BF  8  00 00 00 00 18 00 00 08
  4866)     29278.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4867)     29279.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4868)     29280.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4869)     29281.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4870)     29281.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4871)     29288.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4872)     29290.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4873)     29290.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4874)     29291.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4875)     29291.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4876)     29298.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4877)     29300.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4878)     29300.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4879)     29301.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4880)     29301.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4881)     29307.9  Rx         056E  1  86
  4882)     29308.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4883)     29308.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4884)     29310.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4885)     29310.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4886)     29311.0  Rx         050C  6  00 00 00 02 5D 63
  4887)     29311.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4888)     29311.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4889)     29318.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4890)     29320.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4891)     29321.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4892)     29321.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4893)     29321.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4894)     29328.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4895)     29331.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4896)     29331.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4897)     29331.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4898)     29331.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4899)     29331.9  Rx         050A  6  06 40 00 17 00 00
  4900)     29338.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4901)     29341.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4902)     29341.5  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4903)     29341.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4904)     29341.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4905)     29342.2  Rx         055B  8  AB 00 AA 00 E6 00 11 3C
  4906)     29348.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4907)     29351.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4908)     29351.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4909)     29351.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4910)     29351.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4911)     29352.0  Rx         050B  6  00 00 00 C0 00 00
  4912)     29356.0  Rx         054A  8  12 00 70 02 00 00 00 3A
  4913)     29357.0  Rx         054B  8  00 08 80 00 04 00 00 00
  4914)     29358.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4915)     29358.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4916)     29359.0  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  4917)     29361.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4918)     29361.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4919)     29361.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4920)     29362.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4921)     29368.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4922)     29371.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4923)     29371.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4924)     29371.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4925)     29372.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4926)     29376.3  Rx         0380  8  02 04 10 21 00 00 00 38
  4927)     29376.6  Rx         05BF  8  00 00 00 00 18 00 00 19
  4928)     29378.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4929)     29381.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4930)     29381.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4931)     29382.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4932)     29382.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4933)     29388.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4934)     29391.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4935)     29391.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4936)     29392.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4937)     29392.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4938)     29398.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4939)     29401.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4940)     29401.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4941)     29402.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4942)     29403.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4943)     29408.0  Rx         056E  1  86
  4944)     29408.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4945)     29408.5  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  4946)     29411.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4947)     29411.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4948)     29412.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4949)     29413.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4950)     29413.4  Rx         050C  6  00 00 00 03 5D F4
  4951)     29418.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  4952)     29421.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4953)     29421.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4954)     29423.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4955)     29423.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4956)     29428.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4957)     29431.1  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4958)     29431.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4959)     29433.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4960)     29433.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4961)     29433.8  Rx         050A  6  06 60 00 17 00 00
  4962)     29438.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4963)     29441.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4964)     29441.5  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4965)     29441.7  Rx         055B  8  AB 00 AA 00 E6 00 12 36
  4966)     29443.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4967)     29443.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4968)     29448.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4969)     29451.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4970)     29451.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4971)     29453.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4972)     29454.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  4973)     29454.4  Rx         050B  6  00 00 00 C0 00 00
  4974)     29456.1  Rx         054A  8  A0 00 70 02 00 00 00 3A
  4975)     29457.1  Rx         054B  8  00 08 80 00 04 00 00 00
  4976)     29458.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  4977)     29458.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  4978)     29459.1  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  4979)     29461.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  4980)     29461.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  4981)     29464.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  4982)     29464.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  4983)     29468.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  4984)     29471.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  4985)     29471.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  4986)     29474.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  4987)     29474.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  4988)     29476.5  Rx         0380  8  02 04 10 21 00 00 00 05
  4989)     29476.8  Rx         05BF  8  00 00 00 00 18 00 00 2A
  4990)     29478.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  4991)     29481.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  4992)     29481.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  4993)     29484.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  4994)     29484.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  4995)     29488.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  4996)     29491.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  4997)     29491.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  4998)     29494.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  4999)     29495.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5000)     29498.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5001)     29501.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5002)     29501.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5003)     29505.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5004)     29505.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5005)     29508.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5006)     29508.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5007)     29508.5  Rx         056E  1  86
  5008)     29511.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5009)     29511.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5010)     29515.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5011)     29515.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5012)     29515.9  Rx         050C  6  00 00 00 00 5D C8
  5013)     29518.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5014)     29521.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5015)     29521.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5016)     29525.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5017)     29525.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5018)     29526.1  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  5019)     29528.2  Rx         01DA  8  01 00 00 00 00 01 00 90
  5020)     29531.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5021)     29531.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5022)     29535.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5023)     29536.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5024)     29536.3  Rx         050A  6  06 00 00 17 00 00
  5025)     29538.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  5026)     29541.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5027)     29541.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5028)     29541.7  Rx         055B  8  AB 00 AA 00 E6 00 13 B3
  5029)     29546.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5030)     29546.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5031)     29548.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5032)     29551.4  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5033)     29551.6  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5034)     29551.8  Rx         05BC  8  29 03 2C 3A A9 05 20 78
  5035)     29552.1  Rx         05C0  8  40 76 76 00 8C 08 18 00
  5036)     29556.2  Rx         054A  8  12 00 70 02 00 00 00 3A
  5037)     29556.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5038)     29556.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5039)     29556.9  Rx         050B  6  00 00 00 C0 00 00
  5040)     29557.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5041)     29558.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5042)     29558.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5043)     29559.1  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  5044)     29561.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5045)     29561.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5046)     29566.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5047)     29566.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5048)     29568.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5049)     29571.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5050)     29571.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5051)     29576.6  Rx         0380  8  02 04 10 21 00 00 00 16
  5052)     29576.8  Rx         05BF  8  00 00 00 00 18 00 00 3B
  5053)     29577.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5054)     29577.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5055)     29578.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5056)     29581.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5057)     29581.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5058)     29587.1  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5059)     29587.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5060)     29588.2  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5061)     29591.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5062)     29591.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5063)     29597.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5064)     29597.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5065)     29597.7  Rx         05B9  5  40 78 61 4A 28
  5066)     29598.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5067)     29601.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5068)     29601.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5069)     29607.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5070)     29607.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5071)     29608.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5072)     29608.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5073)     29608.5  Rx         056E  1  86
  5074)     29611.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5075)     29611.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5076)     29617.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5077)     29618.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5078)     29618.3  Rx         01DA  8  01 00 00 00 00 01 01 15
  5079)     29618.5  Rx         050C  6  00 00 00 01 5D 5F
  5080)     29621.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5081)     29621.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5082)     29628.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5083)     29628.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5084)     29628.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5085)     29631.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5086)     29631.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5087)     29638.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5088)     29638.4  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5089)     29638.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5090)     29638.8  Rx         050A  6  06 20 00 17 00 00
  5091)     29641.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5092)     29641.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5093)     29641.7  Rx         055B  8  AB 00 AA 00 E6 40 10 24
  5094)     29648.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5095)     29648.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5096)     29648.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5097)     29651.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5098)     29651.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5099)     29656.2  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5100)     29657.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5101)     29658.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5102)     29658.4  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5103)     29658.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5104)     29659.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5105)     29659.2  Rx         050B  6  00 00 00 C0 00 00
  5106)     29659.5  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  5107)     29661.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5108)     29661.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5109)     29668.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5110)     29669.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5111)     29669.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5112)     29671.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5113)     29671.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5114)     29676.6  Rx         0380  8  02 04 10 21 00 00 00 27
  5115)     29676.9  Rx         05BF  8  00 00 00 00 18 00 00 08
  5116)     29678.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5117)     29679.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5118)     29679.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5119)     29681.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5120)     29681.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5121)     29688.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5122)     29689.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5123)     29689.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5124)     29691.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5125)     29691.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5126)     29698.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5127)     29699.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5128)     29700.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5129)     29701.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5130)     29701.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5131)     29708.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5132)     29708.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5133)     29708.5  Rx         056E  1  86
  5134)     29710.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5135)     29710.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5136)     29711.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5137)     29711.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5138)     29718.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5139)     29720.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5140)     29720.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5141)     29720.7  Rx         050C  6  00 00 00 02 5D 63
  5142)     29721.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5143)     29721.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5144)     29728.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5145)     29730.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5146)     29730.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5147)     29731.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5148)     29731.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5149)     29738.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5150)     29740.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5151)     29741.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5152)     29741.1  Rx         050A  6  06 40 00 17 00 00
  5153)     29741.4  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5154)     29741.7  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5155)     29741.9  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  5156)     29748.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5157)     29751.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5158)     29751.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5159)     29751.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5160)     29751.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5161)     29756.3  Rx         054A  8  12 00 70 02 00 00 00 3A
  5162)     29757.3  Rx         054B  8  00 08 80 00 04 00 00 00
  5163)     29758.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5164)     29758.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5165)     29759.3  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  5166)     29761.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5167)     29761.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5168)     29761.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5169)     29761.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5170)     29761.9  Rx         050B  6  00 00 00 C0 00 00
  5171)     29768.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5172)     29771.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5173)     29771.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5174)     29771.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5175)     29771.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5176)     29776.7  Rx         0380  8  02 04 10 21 00 00 00 38
  5177)     29777.0  Rx         05BF  8  00 00 00 00 18 00 00 19
  5178)     29778.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5179)     29781.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5180)     29781.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5181)     29781.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5182)     29781.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5183)     29788.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5184)     29791.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5185)     29791.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5186)     29791.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5187)     29792.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5188)     29798.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5189)     29801.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5190)     29801.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5191)     29802.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5192)     29802.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5193)     29808.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5194)     29808.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5195)     29808.4  Rx         056E  1  86
  5196)     29811.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5197)     29811.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5198)     29812.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5199)     29812.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5200)     29818.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5201)     29821.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5202)     29821.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5203)     29822.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5204)     29822.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5205)     29823.1  Rx         050C  6  00 00 00 03 B2 9A
  5206)     29828.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5207)     29831.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5208)     29831.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5209)     29832.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5210)     29833.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5211)     29838.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5212)     29841.2  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5213)     29841.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5214)     29841.6  Rx         055B  8  AB 00 55 00 E6 40 12 EC
  5215)     29843.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5216)     29843.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5217)     29843.6  Rx         050A  6  06 60 00 17 00 00
  5218)     29848.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5219)     29851.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5220)     29851.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5221)     29853.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5222)     29853.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5223)     29856.4  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5224)     29857.4  Rx         054B  8  00 08 80 00 04 00 00 00
  5225)     29858.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5226)     29858.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5227)     29859.4  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  5228)     29861.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5229)     29861.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5230)     29863.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5231)     29863.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5232)     29864.1  Rx         050B  6  00 00 00 C0 00 00
  5233)     29868.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5234)     29871.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5235)     29871.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5236)     29873.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5237)     29874.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5238)     29876.9  Rx         0380  8  02 04 10 21 00 00 00 05
  5239)     29877.1  Rx         05BF  8  00 00 00 00 18 00 00 2A
  5240)     29878.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5241)     29881.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5242)     29881.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5243)     29884.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5244)     29884.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5245)     29888.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5246)     29891.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5247)     29891.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5248)     29894.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5249)     29894.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5250)     29898.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5251)     29901.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5252)     29901.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5253)     29904.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5254)     29904.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5255)     29908.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5256)     29908.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5257)     29908.5  Rx         056E  1  86
  5258)     29911.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5259)     29911.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5260)     29914.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5261)     29915.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5262)     29918.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5263)     29921.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5264)     29921.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5265)     29925.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5266)     29925.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5267)     29925.6  Rx         050C  6  00 00 00 00 B2 A6
  5268)     29928.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5269)     29931.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5270)     29931.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5271)     29935.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5272)     29935.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5273)     29938.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5274)     29941.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5275)     29941.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5276)     29941.7  Rx         055B  8  AB 00 55 00 E6 40 13 69
  5277)     29945.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5278)     29945.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5279)     29946.1  Rx         050A  6  06 00 00 17 00 00
  5280)     29948.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5281)     29951.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5282)     29951.3  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5283)     29955.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5284)     29956.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5285)     29956.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  5286)     29957.5  Rx         054B  8  00 08 80 00 04 00 00 00
  5287)     29958.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5288)     29958.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5289)     29959.5  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  5290)     29961.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5291)     29961.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5292)     29966.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5293)     29966.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5294)     29966.6  Rx         050B  6  00 00 00 C0 00 00
  5295)     29968.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5296)     29971.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5297)     29971.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5298)     29976.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5299)     29976.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5300)     29977.0  Rx         0380  8  02 04 10 21 00 00 00 16
  5301)     29977.2  Rx         05BF  8  00 00 00 00 18 00 00 3B
  5302)     29978.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5303)     29981.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5304)     29981.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5305)     29986.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5306)     29986.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5307)     29988.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5308)     29991.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5309)     29991.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5310)     29996.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5311)     29997.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5312)     29998.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5313)     30001.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5314)     30001.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5315)     30007.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5316)     30007.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5317)     30008.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5318)     30008.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5319)     30008.4  Rx         056E  1  86
  5320)     30011.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5321)     30011.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5322)     30017.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5323)     30017.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5324)     30018.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5325)     30021.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5326)     30021.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5327)     30027.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5328)     30027.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5329)     30028.1  Rx         050C  6  00 00 00 01 B2 31
  5330)     30028.3  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5331)     30031.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5332)     30031.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5333)     30037.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5334)     30038.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5335)     30038.3  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5336)     30038.5  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  5337)     30041.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5338)     30041.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5339)     30041.6  Rx         055B  8  AB 00 55 00 E6 40 10 63
  5340)     30048.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5341)     30048.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5342)     30048.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5343)     30048.7  Rx         050A  6  06 20 00 17 00 00
  5344)     30051.3  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5345)     30051.6  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5346)     30051.8  Rx         05BC  8  29 03 29 3A A8 05 40 32
  5347)     30052.0  Rx         05C0  8  80 74 74 00 8C D0 18 00
  5348)     30056.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5349)     30057.5  Rx         054B  8  00 08 80 00 04 00 00 00
  5350)     30058.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5351)     30058.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5352)     30058.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5353)     30058.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5354)     30059.5  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  5355)     30061.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5356)     30061.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5357)     30068.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5358)     30068.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5359)     30068.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5360)     30069.0  Rx         050B  6  00 00 00 C0 00 00
  5361)     30071.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5362)     30071.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5363)     30077.1  Rx         0380  8  02 04 10 21 00 00 00 27
  5364)     30077.3  Rx         05BF  8  00 00 00 00 18 00 00 08
  5365)     30078.1  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5366)     30078.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5367)     30079.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5368)     30081.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5369)     30081.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5370)     30088.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5371)     30089.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5372)     30089.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5373)     30091.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5374)     30091.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5375)     30098.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5376)     30099.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5377)     30099.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5378)     30101.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5379)     30101.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5380)     30108.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5381)     30108.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5382)     30108.4  Rx         056E  1  86
  5383)     30109.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5384)     30109.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5385)     30109.9  Rx         05B9  5  40 78 61 4A 28
  5386)     30111.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5387)     30111.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5388)     30118.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5389)     30119.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5390)     30120.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5391)     30121.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5392)     30121.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5393)     30128.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5394)     30130.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5395)     30130.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5396)     30130.4  Rx         050C  6  00 00 00 02 B2 0D
  5397)     30131.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5398)     30131.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5399)     30138.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5400)     30140.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5401)     30140.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5402)     30141.2  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5403)     30141.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5404)     30141.6  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  5405)     30148.1  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5406)     30150.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5407)     30150.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5408)     30150.9  Rx         050A  6  06 40 00 17 00 00
  5409)     30151.2  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5410)     30151.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5411)     30156.6  Rx         054A  8  12 00 70 02 00 00 00 3A
  5412)     30157.6  Rx         054B  8  00 08 80 00 04 00 00 00
  5413)     30158.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5414)     30158.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5415)     30159.6  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  5416)     30160.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5417)     30160.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5418)     30161.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5419)     30161.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5420)     30168.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5421)     30170.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5422)     30171.2  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5423)     30171.4  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5424)     30171.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5425)     30171.9  Rx         050B  6  00 00 00 C0 00 00
  5426)     30177.2  Rx         0380  8  02 04 10 21 00 00 00 38
  5427)     30177.5  Rx         05BF  8  00 00 00 00 18 00 00 19
  5428)     30178.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5429)     30181.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5430)     30181.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5431)     30181.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5432)     30181.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5433)     30188.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5434)     30191.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5435)     30191.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5436)     30191.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5437)     30191.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5438)     30198.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5439)     30201.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5440)     30201.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5441)     30201.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5442)     30201.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5443)     30208.1  Rx         01DA  8  01 00 00 00 00 01 00 90
  5444)     30208.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5445)     30208.4  Rx         056E  1  86
  5446)     30211.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5447)     30211.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5448)     30211.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5449)     30212.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5450)     30218.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5451)     30221.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5452)     30221.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5453)     30222.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5454)     30222.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5455)     30228.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5456)     30231.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5457)     30231.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5458)     30232.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5459)     30232.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5460)     30232.9  Rx         050C  6  00 00 00 03 B2 9A
  5461)     30238.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5462)     30241.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5463)     30241.4  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5464)     30241.6  Rx         055B  8  AB 00 AA 00 E6 40 12 AB
  5465)     30242.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5466)     30242.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5467)     30248.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5468)     30251.0  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5469)     30251.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5470)     30252.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5471)     30253.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5472)     30253.4  Rx         050A  6  06 60 00 17 00 00
  5473)     30256.7  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5474)     30257.7  Rx         054B  8  00 08 80 00 04 00 00 00
  5475)     30258.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5476)     30258.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5477)     30259.7  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  5478)     30261.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5479)     30261.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5480)     30263.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5481)     30263.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5482)     30268.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5483)     30270.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5484)     30271.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5485)     30273.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5486)     30273.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5487)     30273.8  Rx         050B  6  00 00 00 C0 00 00
  5488)     30277.3  Rx         0380  8  02 04 10 21 00 00 00 05
  5489)     30277.5  Rx         05BF  8  00 00 00 00 18 00 00 2A
  5490)     30278.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5491)     30281.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5492)     30281.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5493)     30283.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5494)     30283.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5495)     30288.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5496)     30290.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5497)     30291.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5498)     30293.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5499)     30294.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5500)     30298.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5501)     30300.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5502)     30301.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5503)     30304.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5504)     30304.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5505)     30308.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5506)     30308.3  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5507)     30308.4  Rx         056E  1  86
  5508)     30311.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5509)     30311.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5510)     30314.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5511)     30314.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5512)     30318.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5513)     30320.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5514)     30321.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5515)     30324.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5516)     30324.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5517)     30328.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5518)     30330.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5519)     30331.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5520)     30334.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5521)     30335.1  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5522)     30335.3  Rx         050C  6  00 00 00 00 5D C8
  5523)     30338.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5524)     30341.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5525)     30341.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5526)     30341.6  Rx         055B  8  AB 00 AA 00 E6 40 13 2E
  5527)     30345.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5528)     30345.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5529)     30348.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5530)     30350.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5531)     30351.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5532)     30355.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5533)     30355.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5534)     30355.8  Rx         050A  6  06 00 00 17 00 00
  5535)     30356.8  Rx         054A  8  12 00 70 02 00 00 00 3A
  5536)     30357.8  Rx         054B  8  00 08 80 00 04 00 00 00
  5537)     30358.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5538)     30358.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5539)     30359.8  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  5540)     30361.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5541)     30361.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5542)     30365.6  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5543)     30365.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5544)     30368.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5545)     30370.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5546)     30371.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5547)     30375.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5548)     30376.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5549)     30376.2  Rx         050B  6  00 00 00 C0 00 00
  5550)     30377.3  Rx         0380  8  02 04 10 21 00 00 00 16
  5551)     30377.6  Rx         05BF  8  00 00 00 00 18 00 00 3B
  5552)     30378.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5553)     30380.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5554)     30381.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5555)     30386.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5556)     30386.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5557)     30388.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5558)     30391.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5559)     30391.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5560)     30396.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5561)     30396.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5562)     30398.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5563)     30400.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5564)     30401.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5565)     30406.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5566)     30406.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5567)     30408.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5568)     30408.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5569)     30408.4  Rx         056E  1  86
  5570)     30410.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5571)     30411.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5572)     30416.8  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5573)     30417.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5574)     30418.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5575)     30420.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5576)     30421.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5577)     30427.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5578)     30427.3  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5579)     30428.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5580)     30430.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5581)     30431.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5582)     30437.3  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5583)     30437.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5584)     30437.7  Rx         050C  6  00 00 00 01 5D 5F
  5585)     30438.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5586)     30441.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5587)     30441.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5588)     30441.6  Rx         055B  8  AB 00 AA 00 E6 40 10 24
  5589)     30447.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5590)     30447.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5591)     30448.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5592)     30450.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5593)     30451.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5594)     30456.8  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5595)     30457.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5596)     30458.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5597)     30458.2  Rx         01DA  8  01 00 00 00 00 01 01 15
  5598)     30458.4  Rx         050A  6  06 20 00 17 00 00
  5599)     30458.7  Rx         054B  8  00 08 80 00 04 00 00 00
  5600)     30459.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5601)     30460.8  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  5602)     30461.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5603)     30461.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5604)     30468.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5605)     30468.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5606)     30468.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5607)     30470.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5608)     30471.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5609)     30477.4  Rx         0380  8  02 04 10 21 00 00 00 27
  5610)     30477.7  Rx         05BF  8  00 00 00 00 18 00 00 08
  5611)     30478.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5612)     30478.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5613)     30478.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5614)     30478.7  Rx         050B  6  00 00 00 C0 00 00
  5615)     30480.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5616)     30481.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5617)     30488.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5618)     30488.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5619)     30488.8  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5620)     30490.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5621)     30491.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5622)     30498.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5623)     30498.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5624)     30499.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5625)     30500.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5626)     30501.2  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5627)     30508.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5628)     30508.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5629)     30508.3  Rx         056E  1  86
  5630)     30509.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5631)     30509.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5632)     30510.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5633)     30511.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5634)     30518.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5635)     30519.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5636)     30519.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5637)     30520.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5638)     30521.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5639)     30528.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5640)     30529.5  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5641)     30529.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5642)     30530.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5643)     30531.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5644)     30538.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5645)     30539.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5646)     30540.0  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5647)     30540.2  Rx         050C  6  00 00 00 02 5D 63
  5648)     30541.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5649)     30541.4  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5650)     30541.6  Rx         055B  8  AB 00 AA 00 E6 40 11 A1
  5651)     30548.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5652)     30550.0  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5653)     30550.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5654)     30550.4  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  5655)     30551.3  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5656)     30551.5  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5657)     30551.8  Rx         05BC  8  29 03 2C 3A A9 06 21 4A
  5658)     30552.0  Rx         05C0  8  C0 74 74 00 8C D0 18 00
  5659)     30556.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  5660)     30557.9  Rx         054B  8  00 08 80 00 04 00 00 00
  5661)     30558.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5662)     30558.9  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5663)     30559.9  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  5664)     30560.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5665)     30560.5  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5666)     30560.7  Rx         050A  6  06 40 00 17 00 00
  5667)     30561.0  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5668)     30561.2  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5669)     30568.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5670)     30570.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5671)     30570.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5672)     30570.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5673)     30571.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5674)     30577.6  Rx         0380  8  02 04 10 21 00 00 00 38
  5675)     30577.8  Rx         05BF  8  00 00 00 00 18 00 00 19
  5676)     30578.1  Rx         01DA  8  01 00 00 00 00 01 01 15
  5677)     30580.7  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5678)     30580.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5679)     30581.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5680)     30581.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5681)     30581.6  Rx         050B  6  00 00 00 C0 00 00
  5682)     30588.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5683)     30590.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5684)     30591.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5685)     30591.4  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5686)     30591.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5687)     30598.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5688)     30600.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5689)     30601.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5690)     30601.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5691)     30601.6  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5692)     30607.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5693)     30608.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5694)     30608.3  Rx         056E  1  86
  5695)     30610.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5696)     30611.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5697)     30611.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5698)     30611.7  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5699)     30618.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5700)     30620.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5701)     30621.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5702)     30621.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5703)     30621.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5704)     30622.1  Rx         05B9  5  40 78 61 4A 28
  5705)     30627.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5706)     30630.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5707)     30631.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5708)     30631.9  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5709)     30632.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5710)     30637.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5711)     30641.1  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  5712)     30641.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5713)     30641.6  Rx         055B  8  AB 00 AA 00 E6 40 12 AB
  5714)     30642.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5715)     30642.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5716)     30642.6  Rx         050C  6  00 00 00 03 5D F4
  5717)     30648.0  Rx         01DA  8  01 00 00 00 00 01 00 90
  5718)     30650.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5719)     30651.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5720)     30652.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5721)     30652.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5722)     30657.0  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5723)     30657.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5724)     30658.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5725)     30659.0  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5726)     30659.9  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  5727)     30660.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5728)     30661.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5729)     30662.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5730)     30662.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5731)     30663.1  Rx         050A  6  06 60 00 17 00 00
  5732)     30667.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5733)     30670.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5734)     30671.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5735)     30672.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5736)     30673.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5737)     30677.7  Rx         0380  8  02 04 10 21 00 00 00 05
  5738)     30677.9  Rx         05BF  8  00 00 00 00 18 00 00 2A
  5739)     30678.2  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5740)     30680.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5741)     30681.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5742)     30683.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5743)     30683.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5744)     30683.6  Rx         050B  6  00 00 00 C0 00 00
  5745)     30687.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5746)     30690.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5747)     30691.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5748)     30693.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5749)     30693.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5750)     30697.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5751)     30700.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5752)     30701.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5753)     30703.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5754)     30703.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5755)     30707.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5756)     30708.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5757)     30708.3  Rx         056E  1  86
  5758)     30710.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5759)     30711.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5760)     30713.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5761)     30714.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5762)     30717.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5763)     30720.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5764)     30721.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5765)     30724.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5766)     30724.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5767)     30727.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5768)     30730.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5769)     30731.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5770)     30734.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5771)     30734.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5772)     30737.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5773)     30741.1  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5774)     30741.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5775)     30741.5  Rx         055B  8  AB 00 55 00 E6 40 13 69
  5776)     30744.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5777)     30744.9  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5778)     30745.0  Rx         050C  6  00 00 00 00 5D C8
  5779)     30747.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5780)     30750.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5781)     30751.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5782)     30754.8  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5783)     30755.1  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5784)     30757.1  Rx         054A  8  12 00 70 02 00 00 00 3A
  5785)     30757.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5786)     30758.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5787)     30759.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5788)     30760.0  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  5789)     30760.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5790)     30761.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5791)     30765.1  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5792)     30765.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5793)     30765.5  Rx         050A  6  06 00 00 17 00 00
  5794)     30767.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5795)     30770.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5796)     30771.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5797)     30775.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5798)     30775.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5799)     30777.7  Rx         0380  8  02 04 10 21 00 00 00 16
  5800)     30778.0  Rx         01DA  8  01 00 00 00 00 01 01 15
  5801)     30778.2  Rx         05BF  8  00 00 00 00 18 00 00 3B
  5802)     30780.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5803)     30781.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5804)     30785.6  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5805)     30785.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5806)     30786.0  Rx         050B  6  00 00 00 C0 00 00
  5807)     30787.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5808)     30790.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5809)     30791.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5810)     30795.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5811)     30796.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5812)     30797.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5813)     30800.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5814)     30801.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5815)     30806.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5816)     30806.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5817)     30807.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5818)     30808.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5819)     30808.3  Rx         056E  1  86
  5820)     30810.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5821)     30811.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5822)     30816.3  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5823)     30816.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5824)     30817.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5825)     30820.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5826)     30821.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5827)     30826.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5828)     30826.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5829)     30827.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5830)     30830.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5831)     30831.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5832)     30836.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5833)     30837.0  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5834)     30837.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5835)     30841.1  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5836)     30841.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5837)     30841.5  Rx         055B  8  AB 00 55 00 E6 40 10 63
  5838)     30847.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5839)     30847.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5840)     30847.5  Rx         050C  6  00 00 00 01 B2 31
  5841)     30847.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5842)     30850.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5843)     30851.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5844)     30857.1  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5845)     30857.4  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5846)     30857.6  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5847)     30857.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5848)     30858.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5849)     30859.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5850)     30860.1  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  5851)     30860.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5852)     30861.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5853)     30867.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5854)     30867.8  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5855)     30868.0  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5856)     30868.2  Rx         050A  6  06 20 00 17 00 00
  5857)     30870.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5858)     30871.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5859)     30877.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5860)     30878.0  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5861)     30878.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5862)     30878.4  Rx         0380  8  02 04 10 21 00 00 00 27
  5863)     30878.7  Rx         05BF  8  00 00 00 00 18 00 00 08
  5864)     30880.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5865)     30881.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5866)     30887.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5867)     30888.2  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5868)     30888.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5869)     30888.6  Rx         050B  6  00 00 00 C0 00 00
  5870)     30890.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5871)     30891.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5872)     30897.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5873)     30898.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5874)     30898.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5875)     30900.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5876)     30901.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5877)     30907.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5878)     30908.2  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5879)     30908.3  Rx         056E  1  86
  5880)     30908.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5881)     30908.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5882)     30910.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5883)     30911.1  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5884)     30917.9  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5885)     30918.7  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5886)     30918.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5887)     30920.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5888)     30921.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5889)     30927.9  Rx         01DA  8  01 00 00 00 00 01 00 90
  5890)     30928.9  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5891)     30929.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5892)     30930.9  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5893)     30931.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5894)     30937.9  Rx         01DA  8  01 00 00 00 00 01 01 15
  5895)     30939.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5896)     30939.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5897)     30941.0  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5898)     30941.3  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5899)     30941.5  Rx         055B  8  AB 00 55 00 E6 40 11 E6
  5900)     30947.9  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5901)     30949.5  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5902)     30949.7  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5903)     30949.9  Rx         050C  6  00 00 00 02 B2 0D
  5904)     30950.9  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5905)     30951.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5906)     30957.1  Rx         054A  8  12 00 70 02 00 00 00 3A
  5907)     30957.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5908)     30958.1  Rx         054B  8  00 08 80 00 04 00 00 00
  5909)     30959.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5910)     30959.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5911)     30959.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5912)     30960.1  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  5913)     30960.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5914)     30961.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5915)     30967.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  5916)     30969.8  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5917)     30970.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5918)     30970.3  Rx         050A  6  06 40 00 17 00 00
  5919)     30970.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5920)     30971.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5921)     30977.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  5922)     30978.0  Rx         0380  8  02 04 10 21 00 00 00 38
  5923)     30978.2  Rx         05BF  8  00 00 00 00 18 00 00 19
  5924)     30980.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5925)     30980.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5926)     30980.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5927)     30981.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5928)     30987.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5929)     30990.3  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5930)     30990.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5931)     30990.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  5932)     30991.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5933)     30991.2  Rx         050B  6  00 00 00 C0 00 00
  5934)     30997.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5935)     31000.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5936)     31000.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5937)     31001.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5938)     31001.2  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5939)     31007.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  5940)     31008.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  5941)     31008.1  Rx         056E  1  86
  5942)     31010.8  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5943)     31011.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5944)     31011.2  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5945)     31011.4  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5946)     31017.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  5947)     31020.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5948)     31021.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5949)     31021.2  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5950)     31021.5  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5951)     31027.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5952)     31030.7  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  5953)     31031.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5954)     31031.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5955)     31031.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5956)     31037.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5957)     31040.9  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  5958)     31041.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5959)     31041.4  Rx         055B  8  AB 00 55 00 E6 40 12 EC
  5960)     31041.6  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5961)     31041.9  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5962)     31047.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  5963)     31051.1  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5964)     31051.3  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5965)     31051.6  Rx         05BC  8  29 03 29 3A A8 06 40 96
  5966)     31051.8  Rx         05C0  8  40 76 76 00 8C 08 18 00
  5967)     31052.0  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5968)     31052.3  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5969)     31052.5  Rx         050C  6  00 00 00 03 B2 9A
  5970)     31057.2  Rx         054A  8  A0 00 70 02 00 00 00 3A
  5971)     31057.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  5972)     31058.2  Rx         054B  8  00 08 80 00 04 00 00 00
  5973)     31059.1  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  5974)     31060.2  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  5975)     31060.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  5976)     31061.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  5977)     31062.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  5978)     31062.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  5979)     31062.5  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  5980)     31067.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  5981)     31070.7  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  5982)     31071.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  5983)     31072.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  5984)     31072.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  5985)     31072.7  Rx         050A  6  06 60 00 17 00 00
  5986)     31077.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  5987)     31078.0  Rx         0380  8  02 04 10 21 00 00 00 05
  5988)     31078.3  Rx         05BF  8  00 00 00 00 18 00 00 2A
  5989)     31080.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  5990)     31081.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  5991)     31082.5  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  5992)     31082.8  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  5993)     31087.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  5994)     31090.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  5995)     31091.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  5996)     31092.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  5997)     31093.0  Rx         01F2  8  08 64 00 00 00 0A 02 00
  5998)     31093.1  Rx         050B  6  00 00 00 C0 00 00
  5999)     31097.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  6000)     31100.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6001)     31101.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6002)     31103.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6003)     31103.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6004)     31107.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6005)     31108.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  6006)     31108.2  Rx         056E  1  86
  6007)     31110.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6008)     31111.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6009)     31113.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6010)     31113.5  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6011)     31117.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6012)     31120.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6013)     31121.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6014)     31123.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6015)     31123.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6016)     31127.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6017)     31130.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6018)     31130.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6019)     31133.7  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6020)     31133.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6021)     31134.1  Rx         05B9  5  40 78 61 4A 28
  6022)     31137.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6023)     31140.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6024)     31141.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6025)     31141.4  Rx         055B  8  AB 00 55 00 E6 40 13 69
  6026)     31144.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6027)     31144.3  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6028)     31147.8  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6029)     31150.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6030)     31151.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6031)     31154.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6032)     31154.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6033)     31154.6  Rx         050C  6  00 00 00 00 B2 A6
  6034)     31157.3  Rx         054A  8  12 00 70 02 00 00 00 3A
  6035)     31157.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6036)     31158.2  Rx         054B  8  00 08 80 00 04 00 00 00
  6037)     31159.2  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6038)     31160.3  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  6039)     31160.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6040)     31160.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6041)     31164.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6042)     31164.7  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6043)     31167.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6044)     31170.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6045)     31171.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6046)     31174.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6047)     31174.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6048)     31175.1  Rx         050A  6  06 00 00 17 00 00
  6049)     31177.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6050)     31178.0  Rx         0380  8  02 04 10 21 00 00 00 16
  6051)     31178.3  Rx         05BF  8  00 00 00 00 18 00 00 3B
  6052)     31180.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6053)     31180.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6054)     31184.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6055)     31185.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6056)     31187.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6057)     31190.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6058)     31191.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6059)     31195.2  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6060)     31195.4  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6061)     31195.6  Rx         050B  6  00 00 00 C0 00 00
  6062)     31197.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6063)     31200.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6064)     31201.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6065)     31205.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6066)     31205.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6067)     31207.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6068)     31208.0  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  6069)     31208.2  Rx         056E  1  86
  6070)     31210.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6071)     31210.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6072)     31215.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6073)     31215.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6074)     31217.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6075)     31220.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6076)     31221.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6077)     31225.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6078)     31226.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6079)     31227.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6080)     31230.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6081)     31230.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6082)     31236.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6083)     31236.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6084)     31237.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6085)     31240.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6086)     31241.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6087)     31241.4  Rx         055B  8  AB 00 AA 00 E6 40 10 24
  6088)     31246.4  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6089)     31246.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6090)     31247.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6091)     31250.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6092)     31251.0  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6093)     31256.6  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6094)     31256.9  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6095)     31257.1  Rx         050C  6  00 00 00 01 5D 5F
  6096)     31257.3  Rx         054A  8  A0 00 70 02 00 00 00 3A
  6097)     31257.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6098)     31258.3  Rx         054B  8  00 08 80 00 04 00 00 00
  6099)     31259.3  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6100)     31260.3  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  6101)     31260.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6102)     31261.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6103)     31266.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6104)     31267.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6105)     31267.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6106)     31270.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6107)     31270.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6108)     31277.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6109)     31277.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6110)     31277.5  Rx         050A  6  06 20 00 17 00 00
  6111)     31277.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6112)     31278.1  Rx         0380  8  02 04 10 21 00 00 00 27
  6113)     31278.4  Rx         05BF  8  00 00 00 00 18 00 00 08
  6114)     31280.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6115)     31280.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6116)     31287.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6117)     31287.6  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6118)     31287.8  Rx         01DA  8  01 00 00 00 00 01 00 90
  6119)     31290.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6120)     31290.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6121)     31297.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6122)     31297.8  Rx         01DA  8  01 00 00 00 00 01 01 15
  6123)     31298.1  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6124)     31298.3  Rx         050B  6  00 00 00 C0 00 00
  6125)     31300.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6126)     31300.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6127)     31307.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6128)     31308.0  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6129)     31308.2  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6130)     31308.4  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  6131)     31308.6  Rx         056E  1  86
  6132)     31310.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6133)     31310.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6134)     31317.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6135)     31318.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6136)     31318.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6137)     31320.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6138)     31320.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6139)     31327.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6140)     31328.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6141)     31328.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6142)     31330.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6143)     31330.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6144)     31337.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6145)     31338.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6146)     31338.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6147)     31340.9  Rx         01DB  8  00 20 C0 2A 00 00 03 5A
  6148)     31341.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6149)     31341.3  Rx         055B  8  AB 00 AA 00 E6 40 11 A1
  6150)     31347.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6151)     31348.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6152)     31349.1  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6153)     31350.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6154)     31350.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6155)     31357.4  Rx         054A  8  12 00 70 02 00 00 00 3A
  6156)     31357.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6157)     31358.4  Rx         054B  8  00 08 80 00 04 00 00 00
  6158)     31359.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6159)     31359.3  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6160)     31359.5  Rx         050C  6  00 00 00 02 5D 63
  6161)     31359.8  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6162)     31360.4  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  6163)     31360.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6164)     31360.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6165)     31367.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6166)     31369.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6167)     31369.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6168)     31370.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6169)     31370.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6170)     31377.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6171)     31378.2  Rx         0380  8  02 04 10 21 00 00 00 38
  6172)     31378.5  Rx         05BF  8  00 00 00 00 18 00 00 19
  6173)     31379.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6174)     31379.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6175)     31380.0  Rx         050A  6  06 40 00 17 00 00
  6176)     31380.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6177)     31380.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6178)     31387.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6179)     31389.8  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6180)     31390.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6181)     31390.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6182)     31390.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6183)     31397.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6184)     31400.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6185)     31400.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6186)     31400.5  Rx         050B  6  00 00 00 C0 00 00
  6187)     31400.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6188)     31401.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6189)     31407.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6190)     31407.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  6191)     31408.2  Rx         056E  1  86
  6192)     31410.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6193)     31410.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6194)     31410.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6195)     31410.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6196)     31417.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6197)     31420.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6198)     31420.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6199)     31420.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6200)     31421.2  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6201)     31427.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6202)     31430.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6203)     31430.9  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6204)     31431.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6205)     31431.4  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6206)     31437.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6207)     31440.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6208)     31441.1  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6209)     31441.3  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6210)     31441.6  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6211)     31441.8  Rx         055B  8  AB 00 AA 00 E6 40 12 AB
  6212)     31447.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6213)     31450.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6214)     31450.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6215)     31451.3  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6216)     31451.5  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6217)     31457.5  Rx         054A  8  A0 00 70 02 00 00 00 3A
  6218)     31457.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6219)     31458.4  Rx         054B  8  00 08 80 00 04 00 00 00
  6220)     31459.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6221)     31460.4  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  6222)     31460.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6223)     31460.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6224)     31461.5  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6225)     31461.8  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6226)     31462.0  Rx         050C  6  00 00 00 03 5D F4
  6227)     31467.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6228)     31470.7  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  6229)     31470.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6230)     31471.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6231)     31472.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6232)     31477.7  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6233)     31478.3  Rx         0380  8  02 04 10 21 00 00 00 05
  6234)     31478.6  Rx         05BF  8  00 00 00 00 18 00 00 2A
  6235)     31480.7  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  6236)     31480.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6237)     31482.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6238)     31482.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6239)     31482.4  Rx         050A  6  06 60 00 17 00 00
  6240)     31487.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6241)     31490.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6242)     31490.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6243)     31492.2  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6244)     31492.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6245)     31497.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6246)     31500.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6247)     31500.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6248)     31502.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6249)     31502.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6250)     31502.9  Rx         050B  6  00 00 00 C0 00 00
  6251)     31507.7  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6252)     31507.9  Rx         055A  8  00 3E 3B 00 5F 3F 3A C8
  6253)     31508.2  Rx         056E  1  86
  6254)     31510.7  Rx         01DB  8  00 20 C0 2A 00 00 00 50
  6255)     31511.0  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6256)     31512.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6257)     31512.9  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6258)     31517.6  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6259)     31520.7  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  6260)     31520.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6261)     31522.9  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6262)     31523.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6263)     31527.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6264)     31530.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6265)     31530.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6266)     31533.1  Rx         01D4  8  F7 07 00 00 42 06 60 F9
  6267)     31533.4  Rx         01F2  8  08 64 00 00 00 0A 01 0F
  6268)     31537.7  Rx         01DA  8  01 00 00 00 00 01 01 15
  6269)     31540.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6270)     31541.1  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6271)     31541.3  Rx         055B  8  AB 00 AA 00 E6 40 13 2E
  6272)     31543.4  Rx         01D4  8  F7 07 00 00 82 06 60 35
  6273)     31543.7  Rx         01F2  8  08 64 00 00 00 0A 02 00
  6274)     31547.6  Rx         01DA  8  01 00 00 00 00 01 02 1F
  6275)     31551.0  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6276)     31551.2  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6277)     31551.5  Rx         05BC  8  29 03 2C 3A A9 04 1F FF
  6278)     31551.7  Rx         05C0  8  80 74 74 00 8C D0 18 00
  6279)     31553.7  Rx         01D4  8  F7 07 00 00 C2 06 60 F2
  6280)     31554.0  Rx         01F2  8  08 64 00 00 00 0A 03 01
  6281)     31557.5  Rx         054A  8  12 00 70 02 00 00 00 3A
  6282)     31557.8  Rx         01DA  8  01 00 00 00 00 01 03 9A
  6283)     31558.5  Rx         054B  8  00 08 80 00 04 00 00 00
  6284)     31559.5  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6285)     31560.5  Rx         054F  8  4A 00 00 00 0B 80 08 3F
  6286)     31560.7  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6287)     31561.0  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6288)     31564.0  Rx         01D4  8  F7 07 00 00 02 06 60 3E
  6289)     31564.2  Rx         01F2  8  08 64 00 00 00 0A 00 0E
  6290)     31564.5  Rx         050C  6  00 00 00 00 5D C8
  6291)     31567.7  Rx         01DA  8  01 00 00 00 00 01 00 90
  6292)     31570.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6293)     31570.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6294)     31574.1  Rx         01D4  8  F7 07 00 00 40 06 60 8A
  6295)     31574.4  Rx         01F2  8  00 64 60 00 00 37 01 0D
  6296)     31574.6  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  6297)     31577.6  Rx         01DA  8  01 00 00 00 00 00 01 82
  6298)     31578.4  Rx         0380  8  02 04 10 21 00 00 00 16
  6299)     31578.7  Rx         05BF  8  00 00 00 00 18 00 00 3B
  6300)     31580.7  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6301)     31580.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6302)     31584.4  Rx         01D4  8  F7 07 00 00 80 06 60 46
  6303)     31584.7  Rx         01F2  8  60 64 60 00 00 38 02 05
  6304)     31584.9  Rx         050A  6  06 00 00 17 00 00
  6305)     31587.7  Rx         01DA  8  01 00 00 00 00 00 02 88
  6306)     31588.4  Rx         0380  8  03 04 20 21 00 00 00 29
  6307)     31590.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6308)     31590.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6309)     31594.6  Rx         01D4  8  F7 07 00 00 C0 06 60 81
  6310)     31594.9  Rx         01F2  8  68 64 60 00 00 3A 03 00
  6311)     31597.6  Rx         01DA  8  01 00 00 00 00 00 03 0D
  6312)     31600.7  Rx         01DB  8  00 20 C0 2A 00 00 01 D5
  6313)     31600.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6314)     31604.9  Rx         01D4  8  F7 07 00 00 00 06 60 4D
  6315)     31605.1  Rx         01F2  8  68 64 60 00 00 3A 00 0D
  6316)     31605.3  Rx         050B  6  00 00 00 C0 00 00
  6317)     31607.7  Rx         01DA  8  01 00 00 00 00 00 00 07
  6318)     31607.9  Rx         055A  8  00 3E 3B 00 5F 3F 6A C8
  6319)     31608.3  Rx         056E  1  86
  6320)     31610.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6321)     31610.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6322)     31615.1  Rx         01D4  8  F7 07 00 00 40 06 60 8A
  6323)     31615.4  Rx         01F2  8  68 64 60 00 00 3A 01 0E
  6324)     31617.7  Rx         01DA  8  01 00 00 00 00 00 01 82
  6325)     31620.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6326)     31620.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6327)     31625.4  Rx         01D4  8  F7 07 00 00 80 06 60 46
  6328)     31625.6  Rx         01F2  8  68 64 60 00 00 3A 02 0F
  6329)     31627.6  Rx         01DA  8  01 00 00 00 00 00 02 88
  6330)     31630.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6331)     31630.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6332)     31635.6  Rx         01D4  8  F7 07 00 00 C0 06 60 81
  6333)     31635.8  Rx         01F2  8  68 64 60 00 00 3A 03 00
  6334)     31637.7  Rx         01DA  8  01 00 00 00 00 00 03 0D
  6335)     31640.8  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6336)     31641.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6337)     31641.3  Rx         055B  8  AB 00 AA 00 E6 40 20 84
  6338)     31645.9  Rx         01D4  8  F7 07 00 00 00 06 60 4D
  6339)     31646.2  Rx         01F2  8  68 64 60 00 00 3A 00 0D
  6340)     31646.3  Rx         05B9  5  40 78 61 4A 28
  6341)     31647.6  Rx         01DA  8  01 00 00 00 00 00 00 07
  6342)     31650.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6343)     31650.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6344)     31656.1  Rx         01D4  8  F7 07 00 00 40 06 60 8A
  6345)     31656.4  Rx         01F2  8  68 64 60 00 00 3A 01 0E
  6346)     31657.6  Rx         054A  8  A0 00 70 02 00 00 00 3A
  6347)     31657.8  Rx         01DA  8  01 00 00 00 00 00 01 82
  6348)     31658.6  Rx         054B  8  00 08 80 00 04 00 00 00
  6349)     31659.6  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6350)     31660.6  Rx         054F  8  4A 00 00 00 0B C0 08 3F
  6351)     31660.9  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6352)     31661.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6353)     31666.4  Rx         01D4  8  F7 07 00 00 80 06 60 46
  6354)     31666.7  Rx         01F2  8  68 64 60 00 00 3A 02 0F
  6355)     31666.8  Rx         050C  6  00 00 00 01 5D 5F
  6356)     31667.7  Rx         01DA  8  01 00 00 00 00 00 02 88
  6357)     31670.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6358)     31670.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6359)     31676.6  Rx         01D4  8  F7 07 00 00 C0 06 60 81
  6360)     31676.8  Rx         01F2  8  68 64 60 00 00 3A 03 00
  6361)     31677.6  Rx         01DA  8  01 00 00 00 00 00 03 0D
  6362)     31678.5  Rx         0380  8  03 04 20 21 00 00 00 3A
  6363)     31678.8  Rx         05BF  8  00 00 00 00 30 00 00 02
  6364)     31680.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6365)     31680.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6366)     31686.8  Rx         01D4  8  F7 07 00 00 00 06 60 4D
  6367)     31687.1  Rx         01F2  8  68 64 60 00 00 3A 00 0D
  6368)     31687.3  Rx         050A  6  06 20 00 17 00 00
  6369)     31687.7  Rx         01DA  8  01 00 00 00 00 00 00 07
  6370)     31690.7  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6371)     31690.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6372)     31697.1  Rx         01D4  8  F7 07 00 00 40 06 60 8A
  6373)     31697.3  Rx         01F2  8  68 64 60 00 00 3A 01 0E
  6374)     31697.6  Rx         01DA  8  01 00 00 00 00 00 01 82
  6375)     31700.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6376)     31700.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6377)     31707.3  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6378)     31707.5  Rx         01F2  8  68 64 60 00 00 3C 02 01
  6379)     31707.8  Rx         01DA  8  01 00 00 00 00 00 02 88
  6380)     31708.0  Rx         050B  6  00 00 00 C0 00 00
  6381)     31708.2  Rx         055A  8  00 3E 3B 00 5F 3F 6A C8
  6382)     31708.4  Rx         056E  1  86
  6383)     31710.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6384)     31710.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6385)     31717.5  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6386)     31717.8  Rx         01DA  8  01 00 00 00 00 00 83 84
  6387)     31718.0  Rx         01F2  8  68 64 60 00 00 3E 03 04
  6388)     31720.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6389)     31720.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6390)     31727.6  Rx         01DA  8  01 00 00 00 00 00 80 8E
  6391)     31727.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6392)     31728.1  Rx         01F2  8  68 64 60 00 00 3E 00 01
  6393)     31730.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6394)     31730.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6395)     31737.6  Rx         01DA  8  01 00 00 00 00 00 81 0B
  6396)     31738.0  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6397)     31738.3  Rx         01F2  8  68 64 60 00 00 3E 01 02
  6398)     31740.8  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6399)     31741.0  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6400)     31741.3  Rx         055B  8  AB 00 55 00 E6 40 21 46
  6401)     31747.6  Rx         01DA  8  01 00 00 00 00 00 82 01
  6402)     31748.3  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6403)     31748.5  Rx         01F2  8  68 64 60 00 00 3E 02 03
  6404)     31750.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6405)     31750.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6406)     31757.6  Rx         01DA  8  01 00 00 00 00 00 83 84
  6407)     31757.9  Rx         054A  8  12 00 70 02 00 00 00 3A
  6408)     31758.5  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6409)     31758.8  Rx         01F2  8  68 64 60 00 00 3E 03 04
  6410)     31759.0  Rx         054B  8  00 08 80 00 04 00 00 00
  6411)     31759.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6412)     31760.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6413)     31760.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6414)     31761.1  Rx         054F  8  4A 00 00 00 0B 00 08 3F
  6415)     31767.6  Rx         01DA  8  01 00 00 00 00 00 80 8E
  6416)     31768.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6417)     31769.1  Rx         01F2  8  68 64 60 00 00 3E 00 01
  6418)     31769.3  Rx         050C  6  00 00 00 02 B2 0D
  6419)     31770.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6420)     31770.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6421)     31777.6  Rx         01DA  8  01 00 00 00 00 00 81 0B
  6422)     31778.6  Rx         0380  8  03 04 20 21 00 00 00 07
  6423)     31778.9  Rx         05BF  8  00 00 00 00 30 00 00 13
  6424)     31779.1  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6425)     31779.4  Rx         01F2  8  68 64 60 00 00 3E 01 02
  6426)     31780.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6427)     31780.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6428)     31787.6  Rx         01DA  8  01 00 00 00 00 00 82 01
  6429)     31789.3  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6430)     31789.5  Rx         01F2  8  68 64 60 00 00 3E 02 03
  6431)     31789.8  Rx         050A  6  06 40 00 17 00 00
  6432)     31790.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6433)     31790.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6434)     31797.6  Rx         01DA  8  01 00 00 00 00 00 83 84
  6435)     31799.5  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6436)     31799.7  Rx         01F2  8  68 64 60 00 00 3E 03 04
  6437)     31800.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6438)     31800.9  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6439)     31807.6  Rx         01DA  8  01 00 00 00 00 00 80 8E
  6440)     31807.9  Rx         055A  8  00 3E 3B 00 5F 3F 82 D0
  6441)     31808.2  Rx         056E  1  86
  6442)     31809.7  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6443)     31810.0  Rx         01F2  8  68 64 60 00 00 3E 00 01
  6444)     31810.2  Rx         050B  6  00 00 00 C0 00 00
  6445)     31810.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6446)     31810.9  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6447)     31817.6  Rx         01DA  8  01 00 00 00 00 00 81 0B
  6448)     31819.9  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6449)     31820.2  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6450)     31820.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6451)     31820.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6452)     31827.6  Rx         01DA  8  01 00 00 00 00 00 82 01
  6453)     31830.2  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6454)     31830.4  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6455)     31830.7  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6456)     31830.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6457)     31837.6  Rx         01DA  8  01 00 00 00 00 00 83 84
  6458)     31840.4  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6459)     31840.7  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6460)     31840.9  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6461)     31841.1  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6462)     31841.3  Rx         055B  8  AB 00 55 00 E6 40 22 4C
  6463)     31847.6  Rx         01DA  8  01 00 00 00 00 00 80 8E
  6464)     31850.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6465)     31850.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6466)     31851.1  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6467)     31851.3  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6468)     31857.6  Rx         01DA  8  01 00 00 00 00 00 81 0B
  6469)     31857.9  Rx         054A  8  A0 00 70 02 00 00 00 3A
  6470)     31858.7  Rx         054B  8  00 08 80 00 04 00 00 00
  6471)     31859.7  Rx         054C  8  FF FF 00 00 00 F8 FF 00
  6472)     31860.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6473)     31860.8  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6474)     31861.1  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6475)     31861.3  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6476)     31861.6  Rx         054F  8  4A 00 00 00 0B 40 08 3F
  6477)     31867.6  Rx         01DA  8  01 00 00 00 00 00 82 01
  6478)     31870.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6479)     31870.9  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6480)     31871.2  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6481)     31871.4  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6482)     31871.6  Rx         050C  6  00 00 00 03 B2 9A
  6483)     31877.6  Rx         01DA  8  01 00 00 00 00 00 83 84
  6484)     31878.7  Rx         0380  8  03 04 20 21 00 00 00 18
  6485)     31878.9  Rx         05BF  8  00 00 00 00 30 00 00 24
  6486)     31880.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6487)     31880.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6488)     31881.4  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6489)     31881.7  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6490)     31887.6  Rx         01DA  8  01 00 00 00 00 00 80 8E
  6491)     31890.6  Rx         01DB  8  00 00 C0 2A 00 00 02 8E
  6492)     31890.8  Rx         01DC  8  6E 06 2F FD 05 54 C6 B1
  6493)     31891.6  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6494)     31891.9  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6495)     31892.1  Rx         050A  6  06 60 00 17 00 00
  6496)     31897.6  Rx         01DA  8  01 00 00 00 00 00 81 0B
  6497)     31900.6  Rx         01DB  8  00 00 C0 2A 00 00 03 0B
  6498)     31900.9  Rx         01DC  8  6E 06 2F FD 08 C0 C7 4A
  6499)     31901.9  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6500)     31902.1  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6501)     31907.6  Rx         01DA  8  01 00 00 00 00 00 82 01
  6502)     31907.8  Rx         055A  8  00 3E 3B 00 5F 3F 82 D0
  6503)     31908.2  Rx         056E  1  86
  6504)     31910.6  Rx         01DB  8  00 00 C0 2A 00 00 00 01
  6505)     31910.8  Rx         01DC  8  6E 06 2F FD 0C C0 D4 45
  6506)     31912.1  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6507)     31912.4  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6508)     31912.5  Rx         050B  6  00 00 00 00 00 00
  6509)     31920.6  Rx         01DB  8  00 00 C0 2A 00 00 01 84
  6510)     31920.8  Rx         01DC  8  6E 06 2F FD 01 0C C5 A5
  6511)     31922.3  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6512)     31922.6  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6513)     31932.5  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6514)     31932.7  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6515)     31942.8  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6516)     31943.0  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6517)     31953.0  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6518)     31953.2  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6519)     31963.3  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6520)     31963.5  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6521)     31973.5  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6522)     31973.7  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6523)     31973.9  Rx         050C  6  00 00 00 00 B2 A6
  6524)     31978.8  Rx         0380  8  03 04 20 21 00 00 00 29
  6525)     31979.1  Rx         05BF  8  00 00 00 00 30 00 00 35
  6526)     31983.8  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6527)     31984.0  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6528)     31994.0  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6529)     31994.2  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6530)     31994.4  Rx         050A  6  06 00 00 17 00 00
  6531)     32004.2  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6532)     32004.5  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6533)     32014.5  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6534)     32014.7  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6535)     32014.9  Rx         050B  6  00 00 00 00 00 00
  6536)     32018.9  Rx         0380  8  02 04 20 21 00 00 00 39
  6537)     32024.7  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6538)     32025.0  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6539)     32034.9  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6540)     32035.2  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6541)     32045.2  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6542)     32045.4  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6543)     32055.4  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6544)     32055.7  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6545)     32065.7  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6546)     32066.0  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6547)     32076.0  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6548)     32076.2  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6549)     32076.4  Rx         050C  6  00 00 00 01 B2 31
  6550)     32078.9  Rx         0380  8  02 04 20 21 00 00 00 06
  6551)     32079.2  Rx         05BF  8  00 00 00 00 38 00 00 0A
  6552)     32086.2  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6553)     32086.4  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6554)     32086.7  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  6555)     32096.5  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6556)     32096.7  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6557)     32096.9  Rx         050A  6  06 20 00 17 00 00
  6558)     32106.7  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6559)     32106.9  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6560)     32116.9  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6561)     32117.2  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6562)     32117.4  Rx         050B  6  00 00 00 00 00 00
  6563)     32127.1  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6564)     32127.4  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6565)     32137.4  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6566)     32137.6  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6567)     32147.6  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6568)     32147.9  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6569)     32157.9  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6570)     32158.1  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6571)     32158.3  Rx         05B9  5  40 78 61 4A 28
  6572)     32168.1  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6573)     32168.4  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6574)     32178.4  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6575)     32178.6  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6576)     32178.8  Rx         050C  6  00 00 00 02 B2 0D
  6577)     32188.6  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6578)     32188.8  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6579)     32198.9  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6580)     32199.1  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6581)     32199.3  Rx         050A  6  06 40 00 17 00 00
  6582)     32209.1  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6583)     32209.3  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6584)     32219.3  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6585)     32219.5  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6586)     32219.8  Rx         050B  6  00 00 00 00 00 00
  6587)     32229.6  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6588)     32229.9  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6589)     32239.8  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6590)     32240.0  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6591)     32250.0  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6592)     32250.3  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6593)     32260.3  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6594)     32260.5  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6595)     32270.6  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6596)     32270.8  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6597)     32280.8  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6598)     32281.0  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6599)     32281.2  Rx         050C  6  00 00 00 03 B2 9A
  6600)     32291.0  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6601)     32291.3  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6602)     32301.3  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6603)     32301.5  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6604)     32301.7  Rx         050A  6  06 60 00 17 00 00
  6605)     32311.5  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6606)     32311.7  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6607)     32321.8  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6608)     32322.0  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6609)     32322.2  Rx         050B  6  00 00 00 00 00 00
  6610)     32332.0  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6611)     32332.3  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6612)     32342.2  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6613)     32342.5  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6614)     32352.5  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6615)     32352.7  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6616)     32362.7  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6617)     32362.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6618)     32373.0  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6619)     32373.3  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6620)     32383.2  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6621)     32383.5  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6622)     32383.7  Rx         050C  6  00 00 00 00 B2 A6
  6623)     32393.4  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6624)     32393.7  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6625)     32403.7  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6626)     32403.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6627)     32404.2  Rx         050A  6  06 00 00 17 00 00
  6628)     32414.0  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6629)     32414.2  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6630)     32424.2  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6631)     32424.4  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6632)     32424.6  Rx         050B  6  00 00 00 00 00 00
  6633)     32434.4  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6634)     32434.7  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6635)     32444.6  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6636)     32444.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6637)     32454.9  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6638)     32455.1  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6639)     32465.2  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6640)     32465.4  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6641)     32475.4  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6642)     32475.7  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6643)     32485.7  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6644)     32485.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6645)     32486.1  Rx         050C  6  00 00 00 01 B2 31
  6646)     32495.9  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6647)     32496.1  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6648)     32506.1  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6649)     32506.4  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6650)     32506.6  Rx         050A  6  06 20 00 17 00 00
  6651)     32516.4  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6652)     32516.6  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6653)     32526.6  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6654)     32526.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6655)     32527.1  Rx         050B  6  00 00 00 00 00 00
  6656)     32536.9  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6657)     32537.1  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6658)     32547.1  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6659)     32547.3  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6660)     32557.4  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6661)     32557.6  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6662)     32567.6  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6663)     32567.8  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6664)     32577.9  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6665)     32578.1  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6666)     32588.1  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6667)     32588.4  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6668)     32588.6  Rx         050C  6  00 00 00 02 B2 0D
  6669)     32598.3  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6670)     32598.6  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6671)     32598.8  Rx         05A9  8  FF FF FC 0D 42 F0 00 00
  6672)     32608.6  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6673)     32608.9  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6674)     32609.0  Rx         050A  6  06 40 00 17 00 00
  6675)     32618.8  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6676)     32619.1  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6677)     32629.0  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6678)     32629.3  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6679)     32629.5  Rx         050B  6  00 00 00 00 00 00
  6680)     32639.3  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6681)     32639.5  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6682)     32649.5  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6683)     32649.8  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6684)     32659.8  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6685)     32660.0  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6686)     32670.0  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6687)     32670.2  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6688)     32670.4  Rx         05B9  5  40 78 61 4A 28
  6689)     32680.3  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6690)     32680.5  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6691)     32690.5  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6692)     32690.8  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6693)     32691.0  Rx         050C  6  00 00 00 03 B2 9A
  6694)     32700.8  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6695)     32701.0  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6696)     32711.0  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6697)     32711.2  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6698)     32711.5  Rx         050A  6  06 60 00 17 00 00
  6699)     32721.2  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6700)     32721.5  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6701)     32731.5  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6702)     32731.7  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6703)     32731.9  Rx         050B  6  00 00 00 00 00 00
  6704)     32741.7  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6705)     32742.0  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6706)     32751.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6707)     32752.2  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6708)     32762.2  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6709)     32762.4  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6710)     32772.4  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6711)     32772.7  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6712)     32782.7  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6713)     32783.0  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6714)     32792.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6715)     32793.2  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6716)     32793.4  Rx         050C  6  00 00 00 00 B2 A6
  6717)     32803.2  Rx         01D4  8  F7 07 00 02 40 06 60 A6
  6718)     32803.4  Rx         01F2  8  68 64 60 00 00 3F 01 03
  6719)     32813.4  Rx         01D4  8  F7 07 00 02 80 06 60 6A
  6720)     32813.7  Rx         01F2  8  68 64 60 00 00 3F 02 04
  6721)     32813.9  Rx         050A  6  06 00 00 17 00 00
  6722)     32823.7  Rx         01D4  8  F7 07 00 02 C0 06 60 AD
  6723)     32824.0  Rx         01F2  8  68 64 60 00 00 3F 03 05
  6724)     32833.9  Rx         01D4  8  F7 07 00 02 00 06 60 61
  6725)     32834.2  Rx         01F2  8  68 64 60 00 00 3F 00 02
  6726)     32834.3  Rx         050B  6  00 00 00 00 00 00
