[Ovmsdev] Still having major comms problems
Mon Nov 18 15:00:08 HKT 2013
Matt,
The only thing I can suggest is if you have a USB-RS232 adaptor (or a laptop with RS232), when you get in a state the module is not responding to SMS and has not GPRS connection, plug in to the DIAG port of the module and log the output. The DIAG port is a tap into the communications between the modem and the MCU. It operates at 9600baud N-8-1.
On 15 Nov, 2013, at 5:35 pm, Matt Beard OVMS <smvo at mxf.org.uk> wrote:
> Is there anything I can do at this end to verify that it is a fault rather than an issue with my mobile operator (though I have tried 3 SIM cards from 2 companies)
> Matt
> On 15 November 2013 01:15, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Matt,
> The "A" in those log records show those to be App disconnections. It would be a "C" for car.
> The server logs seem to show your car resetting cellular connection an average of 3 times a day (or put another way, managing to maintain the cellular connection for an average of 8 hours), over the past 3 weeks. By comparison, mine resets an average of 15 times a day (as I have really poor coverage at home).
> If you really suspect the hardware is a problem, we can arrange to swap it. eMail me (support (at) openvehicles (dot) com) your postal address.
> On 15 Nov, 2013, at 1:24 am, Matt Beard <matt at beard.tv> wrote:
> > My OVMS unit is still very flaky - to the point where it is severely limiting my ability to test the changes I have made to the iMiev code.
> > The unit no longer even responds to SMS text messages.
> > The most recent entries in the server logs are as follows:
> > {"h_data":"#68 A got error Broken pipe","h_recordnumber":"10055","h_timestamp":"2013-11-14 12:24:51"},
> > {"h_data":"#88 A got error Broken pipe","h_recordnumber":"10448","h_timestamp":"2013-11-14 12:38:00"},
> > {"h_data":"#88 A got error Broken pipe","h_recordnumber":"10458","h_timestamp":"2013-11-14 12:38:18"},
> > {"h_data":"#51 A got error Broken pipe","h_recordnumber":"12368","h_timestamp":"2013-11-14 13:40:20"},
> > {"h_data":"#71 A got error Broken pipe","h_recordnumber":"13440","h_timestamp":"2013-11-14 14:04:25"},
> > {"h_data":"#101 A got error Broken pipe","h_recordnumber":"19708","h_timestamp":"2013-11-14 16:57:57"}]
> > Any ideas?
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20131118/f3f8a27f/attachment.html>
