[Ovmsdev] Can-re tool
Sun Nov 3 10:11:19 HKT 2013
Sharanga,
How have you installed EV and Common::Sense?
They need to be installed into the perl system on the box. It sounds like you may have put them in the plugins directory of CAN-RE-TOOL?
On 1 Nov, 2013, at 10:36 pm, support at nirvtek.com wrote:
> Hi
> I don't know whether this is the right list for this.
> I can't get the can-re tool to run on Windows. I downloaded EV.pm and common::sense, but it yields this:
> common/sense.pm did not return a true value at ../plugins/EV.pm line 121, <DATA>
> line 451.
> BEGIN failed--compilation aborted at ../plugins/EV.pm line 121, <DATA> line 451.
> Compilation failed in require at canretool.pl line 38, <DATA> line 451.
> BEGIN failed--compilation aborted at canretool.pl line 38, <DATA> line 451.
> !help
> Thanks
> Sharanga
> Nirvtek
