[Ovmsdev] OVMS Android localization
Denis KRAUTH denis.krauth at wanadoo.fr
Fri May 10 18:10:14 HKT 2013
Mark,
Thank you for the APK.
I ironed out some translations, and attached the new version of the French
translation file.
I found some strings that seem not localizable and are probably hard-coded:
“Demonstration Car”
“live”
 “just now” “kph”
“CHARGING”
 “SLIDE TO CHARGE”
“Valet Mode Activated”
“Valet Mode Deactivated”
“Vehicle Locked”
“Vehicle Unlocked”
“Vehicle Awake”
“Push Notifications”
“Push notifications received for your registered vehicles are archived
here.”
“Command unenplemented”
“Module Rebooted”
and the strings displayed beside the parking and the antenna symbol (, “x
min”, “x hours”, etc)
Tires pressure seems to be hard-coded in psi. Here we use kPa. Can this be
changed in the app?
Denis.
De : ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] De la part de Mark Webb-Johnson
Envoyé : jeudi 9 mai 2013 16:00
À : OVMS Developers
Objet : Re: [Ovmsdev] OVMS Android localization
Denis,
You can try from:
 <http://www.openvehicles.com/downloads/OVMS.3.1.3.beta1.apk>
Your translations seem fine, and come up in the App perfectly. The only
change I had to make was that apostrophes (') need to be escaped (\'). I've
committed to github, so you can see the revisions there (as you point out
res/values-fr/strings.xml).
Thanks, Mark.
On 9 May, 2013, at 7:39 PM, "Denis KRAUTH" <
<mailto:denis.krauth at wanadoo.fr> denis.krauth at wanadoo.fr> wrote:
Hi Mark,
Thank you for the file with the strings.
I did the translation into French, the values-fr\strings.xml is attached.
I also attached a French app description, for Play Store submission.
Following thoughts :
-          Many things require much more words in French than in English, so
I translated the app name as “OVMS”.
-          This is my first Android translation, but I did many in the past
on the now defunct webOS platform, and experience told me that translations
need to be checked in their context in the app. So I’d like to test my
translations within the app to be able to correct some of them if they are
wrong or don’t display well in their captions. Could you send me an APK so I
can test the translations?
-          I made the assumption: Wakeup Car = Preheating/cooling of the
cabin (would make sense on my Ampera, but I don’t know what it does on the
Tesla Roadster)
Denis.
De :  <mailto:ovmsdev-bounces at lists.teslaclub.hk>
ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-
<mailto:bounces at lists.teslaclub.hk> bounces at lists.teslaclub.hk] De la part
Envoyé : mercredi 8 mai 2013 15:31
À : OVMS Developers
Denis,
I did a quick review, and the strings seem to be correctly put in the
resource file. I don't see any hard-coded.
Attached is the strings.xml. I hope it is self-explanatory. Only about 120
to translate.
If others can step forward for German, Norwegian and Dutch, that would be
helpful. Please let us know you 'grab it', here, to avoid duplication of
effort.
P.S. Description of the Android localisation process is here:
<http://developer.android.com/guide/topics/resources/localization.html>
P.P.S. I look forward to seeing the translations for the first string
"<string name="app_name">Open Vehicle</string>" :-)
<AppStore
Description.txt><strings.xml>_______________________________________________
OvmsDev mailing list
 <mailto:OvmsDev at lists.teslaclub.hk> OvmsDev at lists.teslaclub.hk
 <http://lists.teslaclub.hk/mailman/listinfo/ovmsdev>
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130510/d54c1381/attachment.htm>
Type: text/xml
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130510/d54c1381/attachment-0002.xml>
