[Ovmsdev] OVMS Android localization
Patrick Kapsch patrick.kapsch at mac.com
Thu May 9 11:32:22 HKT 2013
Mark,
I'm the german volunteer (@craxgt)
You can send me all the phrases to translate. I'm happy to help!
Patrick
Am 09.05.2013 um 03:00 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
> Kevin,
> Looks like @openvehicles didn't get copied on those replies. I found one for Dutch and another for German in your @zerocarbonworld list, and have DM'd both to get it going.
> Thanks, Mark.
> On 9 May, 2013, at 2:53 AM, Kevin Sharpe ZCW wrote:
>> Hi Mark,
>> Lots of volunteers came forward on twitter... did you see the tweets?
>> Kevin
>> On 8 May 2013, at 16:31, "Mark Webb-Johnson" <mark at webb-johnson.net> wrote:
>>> Denis,
>>> I did a quick review, and the strings seem to be correctly put in the resource file. I don't see any hard-coded.
>>> Attached is the strings.xml. I hope it is self-explanatory. Only about 120 to translate.
>>> If others can step forward for German, Norwegian and Dutch, that would be helpful. Please let us know you 'grab it', here, to avoid duplication of effort.
>>> P.S. Description of the Android localisation process is here: http://developer.android.com/guide/topics/resources/localization.html
>>> P.P.S. I look forward to seeing the translations for the first string "<string name="app_name">Open Vehicle</string>" :-)
>>> <strings.xml>
>>> On 8 May, 2013, at 12:28 AM, Denis KRAUTH <denis.krauth at gmail.com> wrote:
>>>> Hi,
>>>> If you provide me the file with the strings to translate, I will do it for French.
>>>> I think every user would rather see the messages in his native language than in English.
>>>> Denis (aka Kratus)
>>>> De : ovmsdev-bounces at lists.teslaclub.hk [mailto:ovmsdev-bounces at lists.teslaclub.hk] De la part de Mark Webb-Johnson
>>>> Envoyé : samedi 4 mai 2013 15:28
>>>> À : OVMS Developers
>>>> Objet : Re: [Ovmsdev] OVMS Android localization
>>>> Here are some stats, from the Android app (google play store version), based on Active installs (trying to remove the install-once-to-see-what-it-is crowd):
>>>> YOUR APP
>>>> [X]
>>>> English (United States)
>>>> 42.50%
>>>> [X]
>>>> English (United Kingdom)
>>>> 8.75%
>>>> [X]
>>>> German (Germany)
>>>> 8.33%
>>>> Norwegian (Norway)
>>>> 6.67%
>>>> Dutch (Netherlands)
>>>> 5.00%
>>>> French (France)
>>>> 3.75%
>>>> German (Switzerland)
>>>> 2.92%
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130509/197c0f53/attachment.htm>
