[Ovmsdev] OVMS Android localization
Denis KRAUTH
denis.krauth at wanadoo.fr
Sun May 12 02:42:49 HKT 2013
Mark,
In addition to my previous message, I parsed the source files on github.
I am no java developer, but I think following strings need to be made
localizable too:
In src / com / openvehicles / OVMS / api / ApiTask.java
337 mCarData.car_speed_units =
(mCarData.car_distance_units_raw.equals("M"))?"mph":"kph";
// kph should be localizable (km/h for
example)
573 mCarData.car_tpms_fl_p =
String.format("%.1f%s",mCarData.car_tpms_fl_p_raw, "psi");
574 mCarData.car_tpms_fr_p =
String.format("%.1f%s",mCarData.car_tpms_fr_p_raw, "psi");
575 mCarData.car_tpms_rl_p =
String.format("%.1f%s",mCarData.car_tpms_rl_p_raw, "psi");
576 mCarData.car_tpms_rr_p =
String.format("%.1f%s",mCarData.car_tpms_rr_p_raw, "psi");
// kPa should be used (and conversion
performed) when metric units are selected, instead of psi.
In src / com / openvehicles / OVMS / receiver / C2DMReceiver.java
64 Toast.makeText(context, "Push Notification
Registered", Toast.LENGTH_SHORT).show();
In src / com / openvehicles / OVMS / ui / CarFragment.java
119 menu.setHeaderTitle("Homelink");
179 tv.setText("1 min");
183 tv.setText(String.format("%d days",days));
187 tv.setText(String.format("%d hours",hours));
191 tv.setText(String.format("%d mins",minutes));
195 tv.setText(String.format("%d mins",minutes));
213 tv.setText("just now");
215 tv.setText("1 min");
217 tv.setText(String.format("%d days",days));
219 tv.setText(String.format("%d hours",hours));
221 tv.setText(String.format("%d mins",minutes));
223 tv.setText(String.format("%d mins",minutes));
In src / com / openvehicles / OVMS / ui / MapFragment.java
98 String lastReportDate =
pCarData.car_lastupdated == null ? "-" :
new SimpleDateFormat("MMM d, k:mm:ss").format(pCarData.car_lastupdated);
100 OverlayItem overlayItem = new
OverlayItem(mLastGeoPoint, pCarData.sel_vehicleid,
String.format("Last reported:
%s", lastReportDate));
In src / com / openvehicles / OVMS / utils / CarsStorage.java
86 demoCar.sel_vehicle_label = "Demonstration
Car";
In src / com / openvehicles / OVMS / utils / OVMSNotifications.java
37 addNotification("Push Notifications", "Push notifications
received for your registered vehicles are archived here.");
Regarding notifications, I dont know if there is a mechanism in Android
(there is one in webOS, thats why I ask) that allows to translate dynamic
strings, so that typical notification strings can be translated too.
If there is such a mechanism, it should be added in OVMSNotifications.java
in functions such as public void addNotification(String title, String
message)
Then, the list of the notifications that can potentially be send from the
module would be needed to add the corresponding translations to the
translations resources file.
PS: Sorry, I just saw the messages from today, and that you already worked
on it, but I think there are still some Ive listed above that are still
missing.
Denis.
Mark,
Thank you for the APK.
I ironed out some translations, and attached the new version of the French
translation file.
I found some strings that seem not localizable and are probably hard-coded:
Demonstration Car
live
just now
kph
CHARGING
SLIDE TO CHARGE
Valet Mode Activated
Valet Mode Deactivated
Vehicle Locked
Vehicle Unlocked
Vehicle Awake
Push Notifications
Push notifications received for your registered vehicles are archived
here.
Command unenplemented
Module Rebooted
and the strings displayed beside the parking and the antenna symbol (, x
min, x hours, etc)
Tires pressure seems to be hard-coded in psi. Here we use kPa. Can this be
changed in the app?
Denis.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130511/00bb75d3/attachment-0001.html>
