[Ovmsdev] OVMS Android localization
Denis KRAUTH
denis.krauth at wanadoo.fr
Thu May 9 19:39:55 HKT 2013
Hi Mark,
Thank you for the file with the strings.
I did the translation into French, the values-fr\strings.xml is attached.
I also attached a French app description, for Play Store submission.
Following thoughts :
- Many things require much more words in French than in English, so
I translated the app name as OVMS.
- This is my first Android translation, but I did many in the past
on the now defunct webOS platform, and experience told me that translations
need to be checked in their context in the app. So Id like to test my
translations within the app to be able to correct some of them if they are
wrong or dont display well in their captions. Could you send me an APK so I
can test the translations?
- I made the assumption: Wakeup Car = Preheating/cooling of the
cabin (would make sense on my Ampera, but I dont know what it does on the
Tesla Roadster)
Denis.
De : ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] De la part de Mark Webb-Johnson
Envoyé : mercredi 8 mai 2013 15:31
À : OVMS Developers
Objet : Re: [Ovmsdev] OVMS Android localization
Denis,
I did a quick review, and the strings seem to be correctly put in the
resource file. I don't see any hard-coded.
Attached is the strings.xml. I hope it is self-explanatory. Only about 120
to translate.
If others can step forward for German, Norwegian and Dutch, that would be
helpful. Please let us know you 'grab it', here, to avoid duplication of
effort.
P.S. Description of the Android localisation process is here:
http://developer.android.com/guide/topics/resources/localization.html
P.P.S. I look forward to seeing the translations for the first string
"<string name="app_name">Open Vehicle</string>" :-)
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130509/070f34d8/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
Name: AppStore Description.txt
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130509/070f34d8/attachment-0001.txt>
Type: text/xml
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130509/070f34d8/attachment-0001.xml>
