[Ovmsdev] [Open-Vehicle-Monitoring-System] Driven km and Charge done message (#105)
Denis KRAUTH
denis.krauth at gmail.com
Wed May 8 00:32:00 HKT 2013
Yes, a reminder that the car is fully charged makes sense.
At the moment, My Ampera is sharing the same charger with a Leaf at work.
Denis (aka Kratus)
De : ovmsdev-bounces at lists.teslaclub.hk
[mailto:ovmsdev-bounces at lists.teslaclub.hk] De la part de Michael Jochum
Envoyé : dimanche 5 mai 2013 11:59
À : OVMS Developers
Objet : Re: [Ovmsdev] [Open-Vehicle-Monitoring-System] Driven km and Charge
done message (#105)
Hi,
i implement the "charge complete" message, cause at work i have some probs
with the voltage. I must reduce the current to 14,5A to get the charge done.
But sometimes i got an error too. Second is that i got a reminder that my
car is full and i can release the cord so an other car can charge.
I think a "switch" is a good idea. So the user can got the messages he want.
Now we have a other part to think about:
We can set the Volt/Ampera to start the charge based on departure time. But
now the OVMS sends every 28 MInutes a message "not charging" until charge
starts. I know that this is a problem since we don't have the right CAN ID.
I'm still looking for.
Do you think we can stop sending this messages without having the ID?
Bye
Michael J.
Am 03.05.2013 um 12:53 schrieb Michael Balzer <dexter at expeedo.de>:
Mark, Michael,
for the Twizy I've been sending alerts on charge completion from the
beginning. That's my preference, but I also received no complaints from
other users up to now. If you're limited to SMS, this is also the only
sensible way IMO, you'd otherwise need to query the charge state manually
using the "STAT?" command.
So may be the configuration could be on the App side? The App could check
for the notification text.
I also send an additional optional alert on partial completion (sufficient
charge level = "topping off"), that can be set by the "CA" command -- IMO
quite useful and as well suitable as a standard function.
Am 03.05.2013 02:51, schrieb Mark Webb-Johnson:
Michael (J),
I merged this.
I'm a unsure about the message when charge is done part. You have it set to
alert whenever a charge completes (even if normally up to 100% SOC), which
is not normally. We would usually only alert if the charge is interrupted.
Michael B: What do you do for Twizy on this? Do we need a standard option
that the user can set to be alerted whenever a charge is completed (no
matter succeed / fail)?
Begin forwarded message:
Subject: [Open-Vehicle-Monitoring-System] Driven km and Charge done message
(#105)
Date: 3 May, 2013 3:55:48 AM GMT+08:00
Add CAN ID with driven km on Battery for calc for expected km
Add Messagen when Charhe is done
_____
Commit Summary
* Driven km and Charge done message
File Changes
* M vehicle/OVMS.X/net_msg.c
<https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105/files#dif
f-0> (1)
* M vehicle/OVMS.X/vehicle_voltampera.c
f-1> (32)
Patch Links:
https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.patch
https://github.com/markwj/Open-Vehicle-Monitoring-System/pull/105.diff
OvmsDev mailing list
OvmsDev at lists.teslaclub.hk
<dexter.vcf>_______________________________________________
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130507/c2709017/attachment.html>
