[Ovmsdev] Crashes with streaming mode
Wed May 1 18:18:57 HKT 2013
Mark,
I also see the current modem communication layer as a problem source.
The read buffer only takes 128 bytes, which will not be sufficient for
many situations -- e.g. a GPS response now needs already two NMEA
sentences adding up to about 108 bytes -- come in another modem answer
before the buffer gets handled, and bang we go...
The multiplex mode is quite interesting, didn't know this before --
although a really fully asynchronous modem comm handling would not need
that, I think. But it would need more buffer RAM...
Hm... the SIM908 manual says: "In Multiplex mode, it is recommended to
use the hardware flow control."
As far as I understand the circuit schemes the current hardware does not
connect RTS/CTS (pins 66+67) -- right?
Am 30.04.2013 03:28, schrieb Mark Webb-Johnson:
> Michael,
> Looking at the design for 3G modules, I noticed something recommended
> for those modules that seems to be supported for the SIM900 base we
> use (both SIM900 OVMS v1 and SIM908 OVMS v2). CMUX mode.
> http://www.m2m-platforms.com/seminars/2007seminar_material/Telit_CMUX_2_M2M_Platforms_seminar_2007.pdf
> This is GSM 7.10 TE-MS multiplexor protocol.
> The main problem we have is co-ordinating all the different comms
> channels of OVMS onto a single serial link to the modem. Incoming
> SMSes, status indicators, outgoing GPRS TCP data, etc, all run over
> each other.
> The CMUX protocol appears to allow us to have 3 (or 4?) virtual async
> links, over a single physical async port. We could use one for SMS,
> another for TCP, and a third for GPS polling. The 3G modules even
> allow the GPS NMEA data to be streamed back over one of the virtual
> ports (but I don't think that is available in the SIM908 module we use
> - hard to tell as the CMUX documents focus on SIM900 not SIM908 [the
> SIM908 embeds SIM900 and adds GPS]).
> It would mean some major restructuring of the comms layer (NET), and
> we would have to build a small library to encode/decode GSM 7.10, but
> may be a much more stable approach in the long-term.
> SIMCOM seem to implement a subset of the full GSM 7.10 functionality.
> Here's the manual on it for SIM900:
> http://www.mt-system.ru/sites/default/files/sim900_multiplexer_user_manual_application_note_v1.3.pdf
> On 29 Apr, 2013, at 11:48 PM, Michael Balzer wrote:
>> Am 28.04.2013 17:06, schrieb Michael Balzer:
>>> I just checked in my fix for the USSD reply handler. My tests with
>>> streaming enabled did not produce any more crashes, so I think that
>>> was the problem.
>> I was wrong, it's still crashing. I have to dig deeper it seems.
>> Has anyone observed crashes with streaming mode on other vehicles, or
>> is this a Twizy specific bug now?
>> Thanks,
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130501/6d3a4f13/attachment-0001.html>
Name: not available
Type: image/png
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130501/6d3a4f13/attachment-0001.png>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130501/6d3a4f13/attachment-0001.vcf>
