[Ovmsdev] missing the charge connector icon
Mon Jun 17 08:54:57 HKT 2013
Kevin,
Can you let me have your vehicle ID and the GMT date+time this happened. I'll then have a look in the server logs to see why.
On 15 Jun, 2013, at 9:52 PM, Kevin Sharpe ZCW wrote:
> I've noticed a number of times that the iPhone app is missing the charge connector icon when a Tesla Roadster standard mode charge has completed. Interestingly, the app is still showing the charge port as white on the 'car' tab indicating (I guess) that power is connected.
> Removing the connector from the car, closing the flap, opening the flap, and reconnecting will allow the app to recover and continue displaying the connector icon as normal. Sending a chargestart text message will also work (sometimes).
> I'm using app version 1.3.5 (20130604) and firmware 2.3.1/TR/V2
> A stat text returns "Standard – Charging Stopped"
> Any ideas what's wrong?
> <IMG_2659.png>
> 		Kevin Sharpe | Founder & Patron
> Tel: +44 122 566 7544 ext: 800 | Skype: zerocarbonworld
> kevin.sharpe at zerocarbonworld.org | www.zerocarbonworld.org | twitter.com/zerocarbonworld
> Zero Carbon World is a UK Registered Charity #1141347 _______________________________________________
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130617/1914bd69/attachment.htm>
