[Ovmsdev] DIAG port to bluetooth
Thu Jun 20 16:56:56 HKT 2013
Giannis,
You are having the same problem as me - we both have Parrots in our cars :-)
Work I have done on this so far:
I investigated USB serial adaptors to the Parrot. The FTDI driver is in the Parrot Android, but there are some problems with loading it (you can hack it from the adb shell, or from an App with root access). Parrot themselves say it is not yet supported, but planned for future.
I investigated bluetooth. Prior to the latest firmware it didn't work at all. With the latest 2.1.1 firmware I have had more success. I managed to get bluetooth to my Pebble smartwatch working (which means I can control Parrot volume from my wrist), but so far I haven't managed to get bluetooth SPP working. It should work, so maybe just me,
From the OVMS hardware point of view, things are not so easy. The PIC18F is very limited and it is hard to get extra connections. It should be possible to disconnect the connection to the modem and instead go to a bluetooth module on that single ASYNC port (both 5v and 3.3v lines are available on the OVMS v2 board). I have heard, but not tried, that it might be possible to get a software async working on one of the free I/O pins - low baud rate with no flow control.
I am working on more sophisticated hardware with 6 ASYNC ports and 2 CAN buses! But, the bluetooth situation is a mess at the moment (Android supports bluetooth 2.2 but not BLE 4.0, and iPhone supports BLE 4.0 but not bluetooth 2.2 - good grief).
If you don't need the modem, the easiest would be to try to cut the RX+TX lines from the PIC to the MODEM and use them for your bluetooth module. The comms is at 9600 baud.
On 20 Jun, 2013, at 3:41 PM, Giannis Bakas wrote:
> Hi all,
> is it possible to use a serial to bluetooth dongle on the DIAG port of the module
> to get data via bluetooth, requesting data with "MSG commands"? What I want
> to do is to use OVMS like a bridge between my car and my parrot device (Android device)
> in order to visualize the data I get to the screen. I want to avoid the SIM card and to get
> data from the server.
> Best regards,
> Giannis
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130620/01f8bc10/attachment.html>
