[Ovmsdev] OVMS / globalsimcard.co.uk howto change the Roaming Profile
Wed Jun 5 11:14:49 HKT 2013
If you set the roaming profile on the sim, using a phone, then put the sim in the OVMS module, does it remember it?
We could issue the command to switch profile, during initialisation, but don't know what the command is... I did look, a year or so ago, but couldn't find how it was done.
On 4 Jun, 2013, at 10:04 PM, Michael Gerber gerber energie systeme wrote:
> Mark,
> My OVMS uses the globalsimcard. Using the SIM in Italy and UK requires
> the use of the "Prime" Roaming Profile, in the rest of Europe you must
> use "Global" Profile.
> Is there a solution to change the Roaming Profile via OVMS?
> Thx, with sunny regards
> michael gerber, germany
