[Ovmsdev] Tesla Roadster - COOLDOWN (not working for me)
Mon Jun 3 08:30:01 HKT 2013
Richard,
Very helpful.
So, the algorithm you use is: range mode 13A, charge for N mins, then performance mode for 10 seconds, then range mode, rinse and repeat?
Your cycles vary in time. 2min41s, 1min36s, 2min07s, 1min31s, 2min26s, etc. What is the trigger for the decision to end a cooling cycle?
I'll try it again tonight, after my drive home, with 2min cycles range->performance->(delay 10s)->range, and see if I get a different result.
On 3 Jun, 2013, at 1:43 AM, rgjones at sbcglobal.net wrote:
> Hello Mark,
> With Tattler cooldown I run range mode at 13A. Seem to recall lower A did not induce cooling.
> At the end of a cooling cycle I switch mode to perf, wait 10s then switch back to range.
> This resets' the cooling behaviour without the wear on the contactors due to repeated stop/start charge.
> Usually in range/13A the first cooling cycle comes within 3mins.
> I have seen a few times fairly recently where no cooling cycles occurred even after 30mins of charging. stopping and starting charge magically got it working again. Only seen this rarely, usually it works fine.
> It seems that the ambient (outside) temp sensor greatly affects the cooling activity in the charge.
> Any charge, even in a cool well ventilated area seems to cause the ambient sensor to show way above real ambient temperature for a while. Seems it is not well located and gets heat from the motor/pem/battery.
> Even here in temperate San Diego I ventilate my garage.
> Cooling the battery transfers heat to the environment. An enclosed garage is going to warm up of course.
> FYI here are some logs showing cooling behaviour.
> Some are from cooldown, others are during range and standard charging.
> Note, the ambient temp behavior throughout the charge.
> Perhaps someone can figure out the correlation to cooling activity.
> Hope this helps,
> Richard
> Mar 30 17:47:05 Cooldown started.Battery 24C/50%/43%, target 19C, 45min remaining, ambient 17C)
> Mar 30 17:48:37 Cool cycle 1 started. Battery 24C/50%/43%, ambient 18C)
> Mar 30 17:51:17 Cool cycle 1 ended after 2min41s. Battery 23C/50%/43%, ambient 21C)
> Mar 30 17:52:07 Cool update: Battery 23C/50%/43%/113mi, ambient 21C, 1 cycle 5min22s, <1kWh, 40min re
> Mar 30 17:57:11 Cool update: Battery 23C/50%/43%/114mi, ambient 20C, 1 cycle 5min22s, <1kWh, 35min re
> Mar 30 17:58:02 Cool cycle 2 started. Battery 23C/51%/43%, ambient 20C)
> Mar 30 17:59:37 Cool cycle 2 ended after 1min36s. Battery 22C/51%/43%, ambient 22C)
> Mar 30 18:02:14 Cool update: Battery 22C/51%/43%/115mi, ambient 22C, 2 cycles 5min53s, 1kWh, 30min re
> Mar 30 18:07:02 Cool cycle 3 started. Battery 22C/51%/43%, ambient 21C)
> Mar 30 18:07:21 Cool update: Battery 22C/51%/43%/116mi, ambient 21C, 3 cycles* 4min30s, 1kWh, 25min r
> Mar 30 18:09:10 Cool cycle 3 ended after 2min07s. Battery 21C/51%/43%, ambient 23C)
> Mar 30 18:12:19 Cool update: Battery 21C/51%/43%/117mi, ambient 23C, 3 cycles 8min31s, 1kWh, 20min re
> Mar 30 18:16:26 Cool cycle 4 started. Battery 21C/52%/43%, ambient 22C)
> Mar 30 18:17:21 Cool update: Battery 21C/52%/43%/117mi, ambient 22C, 4 cycles* 7min20s, 2kWh, 15min r
> Mar 30 18:17:57 Cool cycle 4 ended after 1min31s. Battery 21C/52%/43%, ambient 23C)
> Mar 30 18:22:23 Cool update: Battery 21C/52%/43%/118mi, ambient 22C, 4 cycles 9min26s, 2kWh, 10min re
> Mar 30 18:26:20 Cool cycle 5 started. Battery 21C/52%/43%, ambient 22C)
> Mar 30 18:27:27 Cool update: Battery 21C/52%/43%/119mi, ambient 22C, 5 cycles* 9min03s, 2kWh, 5min re
> Mar 30 18:28:44 Cool cycle 5 ended after 2min26s. Battery 20C/52%/43%, ambient 24C)
> Mar 30 18:32:32 Cool update: Battery 20C/53%/43%/120mi, ambient 23C, 5 cycles 12min47s, 2kWh, 0min re
> Mar 30 18:32:56 Cooldown stopped. Over time limit.Battery 20C was 24C, 5 cooling cycles, 10min21s of
> Apr 19 20:34:59 Charge Started: Mode: Range, target 180mi.Battery 29C/30%(R)/53mi, ambient 27C245V,
> Apr 19 20:36:29 Cool cycle 1 started. Battery 29C/34%(R), ambient 27C)
> Apr 19 20:38:57 Cool cycle 1 ended after 2min28s. Battery 27C/34%(R), ambient 30C)
> Apr 19 20:40:02 Charge update:Battery 27C/34%(R)/78mi, ambient 31C242V, 16/30A, limit 16A<1kWh use
> Apr 19 20:45:07 Charge update:Battery 27C/35%(R)/79mi, ambient 29C242V, 16/30A, limit 16A<1kWh use
> Apr 19 20:46:05 Cool cycle 2 started. Battery 27C/35%(R), ambient 28C)
> Apr 19 20:47:16 Cool cycle 2 ended after 1min12s. Battery 27C/35%(R), ambient 30C)
> Apr 19 20:50:08 Charge update:Battery 27C/35%(R)/80mi, ambient 29C241V, 16/30A, limit 16A1kWh used
> Apr 19 20:53:36 Cool cycle 3 started. Battery 27C/35%(R), ambient 28C)
> Apr 19 20:54:29 battery=27C, pem=37C, motor=42C, outside=29C, cabin=29C, Tattler=43C)
> Apr 19 20:55:08 Cool cycle 3 ended after 1min29s. Battery 26C/35%(R), ambient 30C)
> Apr 19 20:55:26 Charge update:Battery 26C/35%(R)/81mi, ambient 30C243V, 16/30A, limit 16A1kWh used
> Apr 19 21:00:16 Charge update:Battery 26C/36%(R)/82mi, ambient 29C243V, 16/30A, limit 16A1kWh used
> Apr 19 21:02:00 Cool cycle 4 started. Battery 26C/36%(R), ambient 28C)
> Apr 19 21:03:15 Cool cycle 4 ended after 1min12s. Battery 25C/36%(R), ambient 30C)
> Apr 19 21:05:20 Charge update:Battery 25C/36%(R)/83mi, ambient 30C243V, 16/30A, limit 16A2kWh used
> Apr 19 21:10:25 Charge update:Battery 25C/37%(R)/84mi, ambient 28C243V, 16/30A, limit 16A2kWh used
> Apr 19 21:11:38 Cool cycle 5 started. Battery 25C/37%(R), ambient 28C)
> Apr 19 21:13:04 Cool cycle 5 ended after 1min27s. Battery 25C/37%(R), ambient 30C)
> Apr 19 21:15:25 Charge update:Battery 24C/37%(R)/85mi, ambient 29C241V, 16/30A, limit 16A2kWh used
> Apr 19 21:20:31 Cool cycle 6 started. Battery 25C/37%(R), ambient 28C)
> Apr 19 21:20:48 Charge update:Battery 25C/37%(R)/86mi, ambient 28C242V, 16/30A, limit 16A3kWh used
> Apr 19 21:21:42 Cool cycle 6 ended after 1min11s. Battery 24C/37%(R), ambient 29C)
> Apr 19 21:25:37 Charge update:Battery 24C/38%(R)/86mi, ambient 28C243V, 16/30A, limit 16A3kWh used
> Apr 19 21:30:38 Charge update:Battery 24C/38%(R)/88mi, ambient 27C243V, 16/30A, limit 16A3kWh used
> Apr 19 21:32:16 Cool cycle 7 started. Battery 24C/38%(R), ambient 27C)
> Apr 19 21:33:20 Cool cycle 7 ended after 1min05s. Battery 24C/38%(R), ambient 28C)
> Apr 19 21:35:41 Charge update:Battery 23C/39%(R)/89mi, ambient 28C244V, 16/30A, limit 16A4kWh used
> Apr 19 21:40:04 Cool cycle 8 started. Battery 24C/39%(R), ambient 27C)
> Apr 19 21:40:45 Charge update:Battery 24C/39%(R)/90mi, ambient 27C244V, 16/30A, limit 16A4kWh used
> Apr 19 21:41:20 Cool cycle 8 ended after 1min17s. Battery 23C/39%(R), ambient 28C)
> Apr 19 21:45:49 Charge update:Battery 23C/40%(R)/91mi, ambient 27C242V, 16/30A, limit 16A4kWh used
> Apr 19 21:50:50 Charge update:Battery 23C/40%(R)/92mi, ambient 27C243V, 16/30A, limit 16A4kWh used
> Apr 19 21:51:21 Cool cycle 9 started. Battery 23C/40%(R), ambient 26C)
> Apr 19 21:52:25 Cool cycle 9 ended after 1min07s. Battery 23C/40%(R), ambient 27C)
> Apr 19 21:55:54 Charge update:Battery 23C/41%(R)/93mi, ambient 27C241V, 16/30A, limit 16A5kWh used
> Apr 19 22:01:00 Charge update:Battery 23C/41%(R)/94mi, ambient 26C240V, 16/30A, limit 16A5kWh used
> Apr 19 22:06:02 Charge update:Battery 23C/41%(R)/95mi, ambient 26C243V, 16/30A, limit 16A5kWh used
> Apr 19 22:09:46 Cool cycle 10 started. Battery 23C/42%(R), ambient 25C)
> Apr 19 22:11:05 Charge update:Battery 22C/42%(R)/96mi, ambient 26C241V, 16/30A, limit 16A6kWh used
> Apr 19 22:11:24 Cool cycle 10 ended after 1min35s. Battery 22C/42%(R), ambient 27C)
> Apr 19 22:16:11 Charge update:Battery 22C/42%(R)/97mi, ambient 26C241V, 16/30A, limit 16A6kWh used
> Apr 19 22:20:07 Cool cycle 11 started. Battery 22C/43%(R), ambient 25C)
> Apr 19 22:21:11 Charge update:Battery 22C/43%(R)/98mi, ambient 26C242V, 16/30A, limit 16A6kWh used
> Apr 19 22:21:31 Cool cycle 11 ended after 1min13s. Battery 22C/43%(R), ambient 26C)
> Apr 19 22:26:15 Charge update:Battery 22C/43%(R)/99mi, ambient 26C244V, 16/30A, limit 16A7kWh used
> Apr 19 22:30:42 Cool cycle 12 started. Battery 22C/44%(R), ambient 25C)
> Apr 19 22:31:14 Charge update:Battery 22C/44%(R)/100mi, ambient 25C244V, 16/30A, limit 16A7kWh use
> Apr 19 22:31:53 Cool cycle 12 ended after 1min13s. Battery 22C/44%(R), ambient 26C)
> Apr 19 22:36:15 Charge update:Battery 21C/44%(R)/101mi, ambient 25C244V, 16/30A, limit 16A7kWh use
> Apr 19 22:41:19 Charge update:Battery 21C/44%(R)/102mi, ambient 25C244V, 16/30A, limit 16A8kWh use
> Apr 19 22:45:04 Charge stopped:Battery 22C/45%(S)/103mi, ambient 24C8kWh used, 2hr10min)
> Apr 19 22:45:21 Charge Started: Mode: Range, target 180mi.Battery 22C/44%(R)/79mi, ambient 24C246V,
> Apr 19 22:46:39 Cool cycle 1 started. Battery 22C/45%(R), ambient 24C)
> Apr 19 22:48:26 Cool cycle 1 ended after 1min47s. Battery 21C/45%(R), ambient 26C)
> Apr 19 22:50:05 Charge update:Battery 21C/45%(R)/104mi, ambient 26C243V, 16/30A, limit 16A<1kWh us
> Apr 19 22:55:06 Charge update:Battery 21C/46%(R)/105mi, ambient 25C244V, 16/30A, limit 16A1kWh use
> Apr 19 22:57:30 Cool cycle 2 started. Battery 21C/46%(R), ambient 24C)
> Apr 19 22:58:48 Cool cycle 2 ended after 1min19s. Battery 21C/46%(R), ambient 25C)
> Apr 19 23:00:12 Charge update:Battery 20C/46%(R)/106mi, ambient 25C244V, 16/30A, limit 16A1kWh use
> Apr 19 23:05:15 Charge update:Battery 21C/47%(R)/107mi, ambient 24C243V, 16/30A, limit 16A1kWh use
> Apr 19 23:10:17 Charge update:Battery 21C/47%(R)/108mi, ambient 24C244V, 16/30A, limit 16A2kWh use
> Apr 19 23:13:40 Cool cycle 3 started. Battery 21C/47%(R), ambient 23C)
> Apr 19 23:14:56 Cool cycle 3 ended after 1min15s. Battery 20C/47%(R), ambient 24C)
> Apr 19 23:15:21 Charge update:Battery 20C/47%(R)/109mi, ambient 25C243V, 16/30A, limit 16A2kWh use
> Apr 19 23:20:23 Charge update:Battery 20C/48%(R)/110mi, ambient 24C241V, 16/30A, limit 16A2kWh use
> Apr 19 23:25:26 Charge update:Battery 20C/49%(R)/112mi, ambient 23C242V, 16/30A, limit 16A3kWh use
> Apr 19 23:26:32 Cool cycle 4 started. Battery 21C/49%(R), ambient 23C)
> Apr 19 23:28:26 Cool cycle 4 ended after 1min53s. Battery 20C/49%(R), ambient 25C)
> Apr 19 23:30:28 Charge update:Battery 20C/49%(R)/113mi, ambient 24C243V, 16/30A, limit 16A3kWh use
> Apr 19 23:35:29 Charge update:Battery 20C/50%(R)/114mi, ambient 23C242V, 16/30A, limit 16A3kWh use
> Apr 19 23:38:31 Cool cycle 5 started. Battery 20C/50%(R), ambient 23C)
> Apr 19 23:39:54 Cool cycle 5 ended after 1min25s. Battery 20C/50%(R), ambient 24C)
> Apr 19 23:40:27 Charge update:Battery 19C/50%(R)/115mi, ambient 24C243V, 16/30A, limit 16A4kWh use
> Apr 19 23:45:33 Charge update:Battery 20C/50%(R)/116mi, ambient 23C244V, 16/30A, limit 16A4kWh use
> Apr 19 23:50:35 Charge update:Battery 20C/51%(R)/117mi, ambient 23C244V, 16/30A, limit 16A4kWh use
> Apr 19 23:55:38 Charge update:Battery 20C/51%(R)/118mi, ambient 22C244V, 16/30A, limit 16A5kWh use
> Apr 19 23:55:57 Cool cycle 6 started. Battery 20C/51%(R), ambient 22C)
> Apr 19 23:57:13 Cool cycle 6 ended after 1min23s. Battery 19C/51%(R), ambient 23C)
> Apr 20 00:00:44 Charge update:Battery 19C/52%(R)/119mi, ambient 23C243V, 16/30A, limit 16A5kWh use
> Apr 20 00:05:47 Charge update:Battery 19C/52%(R)/120mi, ambient 22C245V, 16/30A, limit 16A5kWh use
> Apr 20 00:10:50 Charge update:Battery 20C/53%(R)/121mi, ambient 22C243V, 16/30A, limit 16A6kWh use
> Apr 20 00:11:17 Cool cycle 7 started. Battery 20C/53%(R), ambient 22C)
> Apr 20 00:13:48 Cool cycle 7 ended after 2min30s. Battery 19C/53%(R), ambient 24C)
> Apr 20 00:15:54 Charge update:Battery 19C/53%(R)/122mi, ambient 23C244V, 16/30A, limit 16A6kWh use
> Apr 20 00:20:56 Charge update:Battery 19C/54%(R)/123mi, ambient 22C246V, 16/30A, limit 16A6kWh use
> Apr 20 00:24:02 Cool cycle 8 started. Battery 19C/54%(R), ambient 22C)
> Apr 20 00:25:48 Cool cycle 8 ended after 1min45s. Battery 19C/54%(R), ambient 23C)
> Apr 20 00:26:06 Charge update:Battery 19C/54%(R)/124mi, ambient 23C245V, 16/30A, limit 16A7kWh use
> Apr 20 00:30:57 Charge update:Battery 19C/54%(R)/125mi, ambient 22C244V, 16/30A, limit 16A7kWh use
> Apr 20 00:36:01 Charge update:Battery 19C/55%(R)/126mi, ambient 22C246V, 16/30A, limit 16A7kWh use
> Apr 20 00:41:02 Charge update:Battery 19C/55%(R)/127mi, ambient 22C241V, 16/30A, limit 16A7kWh use
> Apr 20 00:42:17 Cool cycle 9 started. Battery 19C/55%(R), ambient 21C)
> Apr 20 00:43:59 Cool cycle 9 ended after 1min41s. Battery 18C/56%(R), ambient 22C)
> Apr 20 00:46:05 Charge update:Battery 18C/56%(R)/129mi, ambient 22C242V, 16/30A, limit 16A8kWh use
> Apr 20 00:51:09 Charge update:Battery 18C/56%(R)/130mi, ambient 22C242V, 16/30A, limit 16A8kWh use
> Apr 20 00:56:11 Charge update:Battery 19C/57%(R)/131mi, ambient 21C243V, 16/30A, limit 16A8kWh use
> Apr 20 01:01:16 Charge update:Battery 19C/57%(R)/132mi, ambient 21C242V, 16/30A, limit 16A9kWh use
> Apr 20 01:04:19 Cool cycle 10 started. Battery 19C/58%(R), ambient 21C)
> Apr 20 01:05:53 Cool cycle 10 ended after 1min37s. Battery 18C/58%(R), ambient 22C)
> Apr 20 01:06:18 Charge update:Battery 18C/58%(R)/133mi, ambient 22C244V, 16/30A, limit 16A9kWh use
> Apr 20 01:11:24 Charge update:Battery 18C/58%(R)/134mi, ambient 21C244V, 16/30A, limit 16A9kWh use
> Apr 20 01:15:23 Cool cycle 11 started. Battery 19C/58%(R), ambient 21C)
> Apr 20 01:16:27 Charge update:Battery 18C/58%(R)/135mi, ambient 21C244V, 16/30A, limit 16A10kWh us
> Apr 20 01:18:32 Cool cycle 11 ended after 3min07s. Battery 18C/59%(R), ambient 23C)
> Apr 20 01:21:32 Charge update:Battery 18C/59%(R)/136mi, ambient 22C245V, 16/30A, limit 16A10kWh us
> Apr 20 01:26:36 Charge update:Battery 18C/59%(R)/137mi, ambient 21C245V, 16/30A, limit 16A10kWh us
> Apr 20 01:31:36 Charge update:Battery 18C/60%(R)/138mi, ambient 21C245V, 16/30A, limit 16A11kWh us
> Apr 20 01:32:46 Cool cycle 12 started. Battery 18C/60%(R), ambient 21C)
> Apr 20 01:35:03 Cool cycle 12 ended after 2min20s. Battery 18C/60%(R), ambient 22C)
> Apr 20 01:36:43 Charge update:Battery 17C/60%(R)/139mi, ambient 22C243V, 16/30A, limit 16A11kWh us
> Apr 20 01:41:46 Charge update:Battery 18C/61%(R)/140mi, ambient 21C244V, 16/30A, limit 16A11kWh us
> Apr 20 01:46:47 Charge update:Battery 18C/61%(R)/142mi, ambient 20C243V, 16/30A, limit 16A12kWh us
> Apr 20 01:51:52 Charge update:Battery 18C/62%(R)/143mi, ambient 20C244V, 16/30A, limit 16A12kWh us
> Apr 20 01:56:16 Cool cycle 13 started. Battery 18C/62%(R), ambient 20C)
> Apr 20 01:56:57 Charge update:Battery 18C/62%(R)/144mi, ambient 20C244V, 16/30A, limit 16A12kWh us
> Apr 20 01:58:26 Cool cycle 13 ended after 2min10s. Battery 17C/62%(R), ambient 21C)
> Apr 20 02:02:00 Charge update:Battery 17C/62%(R)/144mi, ambient 21C245V, 16/30A, limit 16A13kWh us
> Apr 20 02:07:03 Charge update:Battery 18C/63%(R)/146mi, ambient 20C245V, 16/30A, limit 16A13kWh us
> Apr 20 02:12:05 Charge update:Battery 18C/63%(R)/147mi, ambient 20C245V, 16/30A, limit 16A13kWh us
> Apr 20 02:17:10 Charge update:Battery 18C/64%(R)/148mi, ambient 20C245V, 16/30A, limit 16A14kWh us
> Apr 20 02:22:11 Charge update:Battery 18C/64%(R)/149mi, ambient 20C245V, 16/30A, limit 16A14kWh us
> Apr 20 02:24:46 Cool cycle 14 started. Battery 18C/65%(R), ambient 19C)
> Apr 20 02:26:47 Cool cycle 14 ended after 2min02s. Battery 17C/65%(R), ambient 20C)
> Apr 20 02:27:12 Charge update:Battery 17C/65%(R)/150mi, ambient 21C243V, 16/30A, limit 16A14kWh us
> Apr 20 02:32:15 Charge update:Battery 17C/65%(R)/151mi, ambient 20C244V, 16/30A, limit 16A15kWh us
> Apr 20 02:37:16 Cool cycle 15 started. Battery 18C/66%(R), ambient 20C)
> Apr 20 02:37:33 Charge update:Battery 18C/66%(R)/152mi, ambient 20C243V, 16/30A, limit 16A15kWh us
> Apr 20 02:42:19 Charge update:Battery 17C/66%(R)/153mi, ambient 21C245V, 16/30A, limit 16A15kWh us
> Apr 20 02:42:39 Cool cycle 15 ended after 5min03s. Battery 17C/66%(R), ambient 21C)
> Apr 20 02:47:23 Charge update:Battery 17C/67%(R)/155mi, ambient 20C244V, 16/30A, limit 16A16kWh us
> Apr 20 02:52:24 Charge update:Battery 17C/67%(R)/155mi, ambient 20C244V, 16/30A, limit 16A16kWh us
> Apr 20 02:57:30 Charge update:Battery 17C/67%(R)/156mi, ambient 19C245V, 16/30A, limit 16A16kWh us
> Apr 20 03:02:12 Cool cycle 16 started. Battery 17C/68%(R), ambient 19C)
> Apr 20 03:02:30 Charge update:Battery 17C/68%(R)/157mi, ambient 19C244V, 16/30A, limit 16A17kWh us
> Apr 20 03:05:29 Cool cycle 16 ended after 3min16s. Battery 16C/68%(R), ambient 20C)
> Apr 20 03:07:32 Charge update:Battery 16C/68%(R)/159mi, ambient 20C244V, 16/30A, limit 16A17kWh us
> Apr 20 03:12:31 Charge update:Battery 16C/69%(R)/160mi, ambient 19C245V, 16/30A, limit 16A17kWh us
> Apr 20 03:17:34 Charge update:Battery 17C/69%(R)/161mi, ambient 19C244V, 16/30A, limit 16A18kWh us
> Apr 20 03:22:36 Charge update:Battery 17C/70%(R)/162mi, ambient 19C245V, 16/30A, limit 16A18kWh us
> Apr 20 03:27:42 Charge update:Battery 17C/70%(R)/163mi, ambient 19C244V, 16/30A, limit 16A18kWh us
> Apr 20 03:32:46 Charge update:Battery 17C/71%(R)/164mi, ambient 19C244V, 16/30A, limit 16A19kWh us
> Apr 20 03:37:47 Charge update:Battery 17C/71%(R)/165mi, ambient 18C246V, 16/30A, limit 16A19kWh us
> Apr 20 03:39:52 Cool cycle 17 started. Battery 17C/71%(R), ambient 18C)
> Apr 20 03:42:51 Charge update:Battery 16C/71%(R)/166mi, ambient 19C244V, 16/30A, limit 16A19kWh us
> Apr 20 03:43:11 Cool cycle 17 ended after 3min13s. Battery 16C/71%(R), ambient 19C)
> Apr 20 03:47:56 Charge update:Battery 16C/72%(R)/167mi, ambient 19C244V, 16/30A, limit 16A20kWh us
> Apr 20 03:52:57 Charge update:Battery 16C/72%(R)/168mi, ambient 18C244V, 16/30A, limit 16A20kWh us
> Apr 20 03:58:03 Charge update:Battery 17C/73%(R)/169mi, ambient 18C244V, 16/30A, limit 16A20kWh us
> Apr 20 04:03:07 Charge update:Battery 17C/73%(R)/171mi, ambient 18C244V, 16/30A, limit 16A21kWh us
> Apr 20 04:08:12 Charge update:Battery 17C/74%(R)/172mi, ambient 18C243V, 16/30A, limit 16A21kWh us
> Apr 20 04:13:12 Charge update:Battery 17C/74%(R)/173mi, ambient 18C242V, 16/30A, limit 16A21kWh us
> Apr 20 04:18:18 Charge update:Battery 17C/75%(R)/174mi, ambient 18C242V, 16/30A, limit 16A22kWh us
> Apr 20 04:20:37 Cool cycle 18 started. Battery 17C/75%(R), ambient 18C)
> Apr 20 04:23:21 Charge update:Battery 16C/75%(R)/175mi, ambient 18C242V, 16/30A, limit 16A22kWh us
> Apr 20 04:28:22 Charge update:Battery 16C/75%(R)/176mi, ambient 19C243V, 16/30A, limit 16A22kWh us
> Apr 20 04:30:15 Cool cycle 18 ended after 9min37s. Battery 16C/75%(R), ambient 19C)
> Apr 20 04:33:26 Charge update:Battery 16C/76%(R)/177mi, ambient 19C244V, 16/30A, limit 16A23kWh us
> Apr 20 04:38:31 Charge update:Battery 16C/76%(R)/178mi, ambient 18C243V, 16/30A, limit 16A23kWh us
> Apr 20 04:43:34 Charge update:Battery 16C/77%(R)/179mi, ambient 18C242V, 16/30A, limit 16A23kWh us
> Apr 20 04:45:45 Charge complete: Reached target range.Charging is stopped.23kWh used, 6hr01minBatt
> Apr 20 05:30:04 Car is parked, unlocked. Car is Stopped Charging 246V, 0/30A, limit 16ABattery 16C
> Apr 20 06:06:40 Charge Started: Mode: Range, target 180mi.Battery 16C/87%(R)/160mi, ambient 16C245V
> Apr 20 06:07:00 Charge complete: Reached target range.Charging is stopped.<1kWh used, <1minBattery
> May 13 15:01:44 Cooldown started.Battery 25C/95%(R), target 3 cycles, 45min remaining, ambient 25C)
> May 13 15:03:31 Cool cycle 1 started. Battery 25C/84%(R), ambient 25C)
> May 13 15:05:18 Cool cycle 1 ended after 1min47s. Battery 24C/84%(R), ambient 27C)
> May 13 15:07:02 Cool update: Battery 24C/85%(R)/199mi, ambient 27C, 1 cycle 3min34s, of 2 remaining<
> May 13 15:12:03 Cool update: Battery 24C/85%(R)/200mi, ambient 26C, 1 cycle 3min34s, of 2 remaining<
> May 13 15:17:07 Cool update: Battery 24C/85%(R)/201mi, ambient 26C, 1 cycle 3min34s, of 2 remaining1
> May 13 15:21:13 Cool cycle 2 started. Battery 24C/85%(R), ambient 26C)
> May 13 15:22:08 Cool update: Battery 24C/85%(R)/201mi, ambient 27C, 2 cycles* 2min43s, of 1 remainin
> May 13 15:22:27 Cool cycle 2 ended after 1min06s. Battery 24C/85%(R), ambient 27C)
> May 13 15:27:14 Cool update: Battery 24C/86%(R)/202mi, ambient 27C, 2 cycles 3min59s, of 1 remaining
> May 13 15:29:04 Cool cycle 3 started. Battery 24C/86%(R), ambient 27C)
> May 13 15:30:21 Cool cycle 3 ended after 1min15s. Battery 23C/86%(R), ambient 28C)
> May 13 15:30:41 Cooldown complete. Completed target cooling cycles..Battery 23C was 25C, 3 cooling c
> May 13 15:30:47 charge at 0am)
> Standard mode charge from a low SOC - note, only one cooling cycle
> May 24 00:00:39 Charge Started: Mode: Standard, target 35%.Battery 25C/24%(S)/43mi, ambient 21C241V
> May 24 00:02:11 Cool cycle 1 started. Battery 25C/24%(S), ambient 21C)
> May 24 00:04:16 Cool cycle 1 ended after 2min05s. Battery 24C/25%(S), ambient 24C)
> May 24 00:05:43 Charge update:Battery 24C/25%(S)/44mi, ambient 24C238V, 24/40A, limit 24A1kWh used
> May 24 00:10:46 Charge update:Battery 24C/26%(S)/46mi, ambient 23C239V, 24/40A, limit 24A1kWh used
> May 24 00:15:49 Charge update:Battery 24C/27%(S)/48mi, ambient 22C238V, 24/40A, limit 24A2kWh used
> May 24 00:20:50 Charge update:Battery 24C/28%(S)/50mi, ambient 22C238V, 24/40A, limit 24A2kWh used
> May 24 00:25:53 Charge update:Battery 24C/29%(S)/51mi, ambient 22C239V, 24/40A, limit 24A3kWh used
> May 24 00:30:54 Charge update:Battery 24C/30%(S)/53mi, ambient 22C239V, 24/40A, limit 24A3kWh used
> May 24 00:35:57 Charge update:Battery 24C/31%(S)/55mi, ambient 22C238V, 24/40A, limit 24A3kWh used
> May 24 00:41:01 Charge update:Battery 24C/32%(S)/57mi, ambient 21C238V, 24/40A, limit 24A4kWh used
> May 24 00:46:04 Charge update:Battery 24C/33%(S)/58mi, ambient 21C239V, 24/40A, limit 24A4kWh used
> May 24 00:51:09 Charge update:Battery 24C/34%(S)/60mi, ambient 21C239V, 24/40A, limit 24A5kWh used
> May 24 00:55:52 Charge complete: Reached target SOC.Charging is stopped. Scheduled Start at 12am5kW
> A long range charge from low SOC. See the extra cooling cycles.
> This on a J charger and stopped early. Current shows an error as the voltage and pilot goes away on this model of charger when manually stopping.
> May 24 10:18:57 Charge Started: Mode: Range, target 222mi.Battery 24C/49%(R)/87mi, ambient 20C204V,
> May 24 10:20:19 Cool cycle 1 started. Battery 24C/49%(R), ambient 20C)
> May 24 10:22:22 Cool cycle 1 ended after 2min01s. Battery 23C/49%(R), ambient 22C)
> May 24 10:29:22 Cool cycle 2 started. Battery 23C/50%(R), ambient 21C)
> May 24 10:30:39 Cool cycle 2 ended after 1min19s. Battery 23C/50%(R), ambient 22C)
> May 24 10:33:51 Charge update:Battery 22C/50%(R)/116mi, ambient 22C200V, 30/30A, limit 70A1kWh use
> May 24 10:39:19 Cool cycle 3 started. Battery 23C/51%(R), ambient 21C)
> May 24 10:40:30 Cool cycle 3 ended after 1min11s. Battery 22C/51%(R), ambient 23C)
> May 24 10:48:52 Charge update:Battery 22C/53%(R)/121mi, ambient 22C199V, 30/30A, limit 70A3kWh use
> May 24 10:50:11 Cool cycle 4 started. Battery 22C/53%(R), ambient 22C)
> May 24 10:51:52 Cool cycle 4 ended after 1min42s. Battery 22C/53%(R), ambient 23C)
> May 24 11:00:14 Cool cycle 5 started. Battery 22C/54%(R), ambient 22C)
> May 24 11:01:32 Cool cycle 5 ended after 1min19s. Battery 21C/55%(R), ambient 23C)
> May 24 11:03:54 Charge update:Battery 21C/55%(R)/126mi, ambient 23C200V, 30/30A, limit 70A4kWh use
> May 24 11:12:36 Cool cycle 6 started. Battery 22C/56%(R), ambient 22C)
> May 24 11:13:57 Cool cycle 6 ended after 1min19s. Battery 21C/57%(R), ambient 23C)
> May 24 11:19:03 Charge update:Battery 21C/57%(R)/132mi, ambient 22C199V, 30/30A, limit 70A6kWh use
> May 24 11:27:41 Cool cycle 7 started. Battery 21C/59%(R), ambient 22C)
> May 24 11:29:00 Cool cycle 7 ended after 1min18s. Battery 21C/59%(R), ambient 23C)
> May 24 11:34:09 Charge update:Battery 21C/59%(R)/137mi, ambient 22C199V, 30/30A, limit 70A7kWh use
> May 24 11:44:08 Cool cycle 8 started. Battery 21C/61%(R), ambient 22C)
> May 24 11:45:27 Cool cycle 8 ended after 1min16s. Battery 21C/61%(R), ambient 22C)
> May 24 11:49:07 Charge update:Battery 21C/62%(R)/142mi, ambient 22C199V, 30/30A, limit 70A9kWh use
> May 24 12:00:59 Cool cycle 9 started. Battery 21C/64%(R), ambient 21C)
> May 24 12:02:13 Cool cycle 9 ended after 1min15s. Battery 21C/64%(R), ambient 22C)
> May 24 12:04:09 Charge update:Battery 21C/64%(R)/148mi, ambient 22C201V, 30/30A, limit 70A10kWh us
> May 24 12:15:39 Cool cycle 10 started. Battery 21C/66%(R), ambient 21C)
> May 24 12:17:32 Cool cycle 10 ended after 1min55s. Battery 20C/66%(R), ambient 23C)
> May 24 12:19:14 Charge update:Battery 20C/66%(R)/153mi, ambient 23C198V, 30/30A, limit 70A12kWh us
> May 24 12:26:49 Cool cycle 11 started. Battery 21C/67%(R), ambient 22C)
> May 24 12:28:35 Cool cycle 11 ended after 1min43s. Battery 20C/67%(R), ambient 23C)
> May 24 12:34:19 Charge update:Battery 20C/68%(R)/158mi, ambient 22C198V, 30/30A, limit 70A13kWh us
> May 24 12:40:23 Cool cycle 12 started. Battery 20C/69%(R), ambient 22C)
> May 24 12:41:55 Cool cycle 12 ended after 1min31s. Battery 20C/69%(R), ambient 23C)
> May 24 12:49:20 Charge update:Battery 20C/70%(R)/163mi, ambient 22C200V, 30/30A, limit 70A15kWh us
> May 24 12:59:07 Cool cycle 13 started. Battery 20C/72%(R), ambient 22C)
> May 24 13:00:36 Cool cycle 13 ended after 1min27s. Battery 20C/72%(R), ambient 23C)
> May 24 13:04:20 Charge update:Battery 20C/73%(R)/169mi, ambient 22C199V, 30/30A, limit 70A16kWh us
> May 24 13:19:23 Charge update:Battery 20C/75%(R)/174mi, ambient 21C200V, 30/30A, limit 70A18kWh us
> May 24 13:20:00 Cool cycle 14 started. Battery 20C/75%(R), ambient 21C)
> May 24 13:21:26 Cool cycle 14 ended after 1min29s. Battery 20C/75%(R), ambient 22C)
> May 24 13:34:23 Charge update:Battery 20C/77%(R)/179mi, ambient 22C200V, 30/30A, limit 70A19kWh us
> May 24 13:40:54 Cool cycle 15 started. Battery 20C/78%(R), ambient 21C)
> May 24 13:42:23 Cool cycle 15 ended after 1min28s. Battery 20C/78%(R), ambient 22C)
> May 24 13:49:21 Charge update:Battery 20C/79%(R)/185mi, ambient 22C201V, 30/30A, limit 70A21kWh us
> May 24 13:52:14 CAC=147.68)
> May 24 14:01:17 Cool cycle 16 started. Battery 20C/81%(R), ambient 21C)
> May 24 14:02:43 Cool cycle 16 ended after 1min29s. Battery 20C/81%(R), ambient 22C)
> May 24 14:04:24 Charge update:Battery 19C/81%(R)/190mi, ambient 22C201V, 30/30A, limit 70A22kWh us
> May 24 14:19:31 Charge update:Battery 20C/83%(R)/195mi, ambient 21C199V, 30/30A, limit 70A24kWh us
> May 24 14:21:53 Cool cycle 17 started. Battery 20C/84%(R), ambient 21C)
> May 24 14:23:26 Cool cycle 17 ended after 1min32s. Battery 20C/84%(R), ambient 22C)
> May 24 14:31:23 Charge stoppedERROR: CHECK EVSE/BREAKER:Battery 20C/85%(S)/200mi, ambient 22C 3V,
> --- On Sun, 6/2/13, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> Subject: [Ovmsdev] Tesla Roadster - COOLDOWN (not working for me)
> To: "OVMS Developers" <ovmsdev at lists.teslaclub.hk>
> Date: Sunday, June 2, 2013, 6:39 AM
> It was blistering hot today in Hong Kong, so when I got home from a drive I thought I'd try to get cool down working again. I set the car to 220V 10A and 13A range mode charges, and here is what I got:
> 2013-06-02 02:26:24.653242 -0400 info main: #102 C EV915 rx msg S 72,K,3,0,prepare,range,282,240,10,0,100,0,10,13,3,0,0,-1,155.40,-1
> 2013-06-02 02:26:26.433171 -0400 info main: #102 C EV915 rx msg S 72,K,223,0,charging,range,282,240,10,0,100,0,5,1,3,0,0,-1,155.40,-1
> 2013-06-02 02:26:31.811202 -0400 info main: #102 C EV915 rx msg D 124,8,4,44,74,39,130,143065,0,163,38,2,120,120,13.1,33,13.1,0
> 2013-06-02 02:26:31.812661 -0400 info main: #102 C EV915 rx msg S 72,K,221,0,charging,range,282,240,10,0,100,0,5,1,3,0,0,-1,155.40,-1
> 2013-06-02 02:27:18.411345 -0400 info main: #102 C EV915 rx msg S 72,K,222,10,charging,range,282,240,10,0,100,0,5,1,3,0,0,-1,155.40,483
> 2013-06-02 02:27:31.869285 -0400 info main: #102 C EV915 rx msg S 72,K,223,10,charging,range,282,240,10,1,100,0,5,1,3,0,0,-1,155.40,483
> 2013-06-02 02:27:31.871196 -0400 info main: #102 C EV915 rx msg D 124,8,4,46,71,40,130,143065,0,223,38,2,120,120,13.0,33,13.1,0
> 2013-06-02 02:28:33.931349 -0400 info main: #102 C EV915 rx msg S 72,K,223,10,charging,range,282,240,10,2,100,0,5,1,3,0,0,-1,155.40,482
> 2013-06-02 02:28:33.933551 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,69,40,130,143065,0,283,39,2,120,119,13.0,33,13.1,0
> 2013-06-02 02:29:34.969362 -0400 info main: #102 C EV915 rx msg S 72,K,220,10,charging,range,282,240,10,3,100,0,5,1,3,0,0,-1,155.40,487
> 2013-06-02 02:29:34.971570 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,67,40,130,143065,0,344,39,2,120,118,13.0,33,13.1,0
> 2013-06-02 02:30:35.208051 -0400 info main: #102 C EV915 rx msg S 72,K,221,10,charging,range,282,240,10,4,100,0,5,1,3,0,0,-1,155.40,482
> 2013-06-02 02:30:35.210313 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,65,40,130,143065,0,404,39,2,120,117,13.0,33,13.1,0
> 2013-06-02 02:31:36.708542 -0400 info main: #102 C EV915 rx msg S 72,K,221,10,charging,range,283,240,10,5,100,0,5,1,3,0,0,-1,155.40,474
> 2013-06-02 02:31:36.710902 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,64,40,130,143065,0,464,39,2,120,115,13.1,33,13.1,0
> 2013-06-02 02:32:30.467402 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,63,40,130,143065,0,524,39,2,120,120,13.1,33,13.1,0
> 2013-06-02 02:32:48.448194 -0400 info main: #102 C EV915 rx msg S 72,K,221,13,charging,range,283,240,13,6,100,0,5,1,3,0,0,-1,155.40,485
> 2013-06-02 02:32:48.450414 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,63,40,130,143065,0,534,39,2,120,120,13.0,33,13.1,0
> 2013-06-02 02:33:42.125427 -0400 info main: #102 C EV915 rx msg S 72,K,223,13,charging,range,283,240,13,7,100,0,5,1,3,0,0,-1,155.40,344
> 2013-06-02 02:33:42.127944 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,61,40,130,143065,0,594,39,2,120,120,13.0,33,13.1,0
> 2013-06-02 02:34:43.083457 -0400 info main: #102 C EV915 rx msg S 72,K,220,13,charging,range,283,240,13,8,100,0,5,1,3,0,0,-1,155.40,343
> 2013-06-02 02:34:43.085865 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,60,40,130,143065,0,655,39,2,120,120,13.0,33,13.1,0
> 2013-06-02 02:35:57.476830 -0400 info main: #102 C EV915 rx msg S 72,K,220,13,charging,range,283,242,13,9,100,0,5,1,3,0,0,-1,155.40,343
> 2013-06-02 02:35:57.479805 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,59,40,130,143065,0,716,39,2,120,120,13.1,33,13.1,0
> 2013-06-02 02:36:19.381948 -0400 info main: #102 C EV915 rx msg S 72,K,221,13,charging,range,283,242,13,9,100,0,5,1,3,0,0,-1,155.40,343
> 2013-06-02 02:36:19.387764 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,59,40,130,143065,0,746,39,2,120,117,13.1,33,13.1,0
> 2013-06-02 02:36:20.064292 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,59,40,130,143065,0,746,39,2,120,116,13.1,33,13.1,0
> 2013-06-02 02:38:08.322698 -0400 info main: #102 C EV915 rx msg S 72,K,222,13,charging,range,283,242,13,11,100,0,5,1,3,0,0,-1,155.40,340
> 2013-06-02 02:38:08.324403 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,57,40,130,143065,0,837,39,2,120,119,13.1,33,13.1,0
> 2013-06-02 02:47:48.833122 -0400 info main: #102 C EV915 rx msg S 72,K,223,13,charging,range,285,242,13,21,100,1,5,1,3,0,0,-1,155.40,353
> 2013-06-02 02:47:48.834882 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,52,37,130,143065,0,1435,45,2,120,117,13.0,33,13.1,0
> 2013-06-02 02:53:03.289711 -0400 info main: #102 C EV915 rx msg S 73,K,221,13,charging,range,286,243,13,26,100,1,5,1,3,0,0,-1,155.40,362
> 2013-06-02 02:53:03.293934 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,51,37,130,143065,0,1748,47,2,120,111,13.0,33,13.1,0
> 2013-06-02 02:53:18.948786 -0400 info main: #102 C EV915 rx msg D 124,8,4,48,51,37,130,143065,0,1769,47,2,120,116,13.0,33,13.1,0
> 2013-06-02 02:53:54.371628 -0400 info main: #102 C EV915 rx msg S 73,K,3,0,stopped,range,286,243,13,26,100,1,3,21,3,0,0,-1,155.40,362
> 2013-06-02 02:53:55.111864 -0400 info main: #102 C EV915 rx msg D 108,8,4,47,51,37,130,143065,0,1779,47,2,120,119,13.0,33,13.1,0
> 2013-06-02 02:53:55.113231 -0400 info main: #102 C EV915 rx msg S 73,K,1,0,stopped,range,286,243,13,26,100,1,3,21,3,0,0,-1,155.40,362
> 2013-06-02 02:53:55.114938 -0400 info main: #102 C EV915 rx msg D 108,8,4,45,50,37,130,143065,0,1809,47,2,120,120,13.1,33,13.1,0
> 2013-06-02 02:54:05.867679 -0400 info main: #102 C EV915 rx msg D 108,8,4,45,50,37,130,143065,0,1809,47,2,120,118,13.1,33,13.1,0
> 2013-06-02 02:54:08.290338 -0400 info main: #102 C EV915 rx msg D 108,8,4,45,50,37,130,143065,0,1819,47,2,120,118,13.1,33,13.1,0
> 2013-06-02 02:54:18.749731 -0400 info main: #102 C EV915 rx msg D 108,8,4,44,50,37,130,143065,0,1830,47,2,120,117,13.1,33,13.1,0
> 2013-06-02 02:54:27.467551 -0400 info main: #102 C EV915 rx msg S 73,K,86,0,charging,range,286,243,10,26,100,1,5,1,3,0,0,-1,155.40,362
> 2013-06-02 02:54:27.947474 -0400 info main: #102 C EV915 rx msg S 73,K,221,0,charging,range,286,243,10,27,100,1,5,1,3,0,0,-1,155.40,-1
> 2013-06-02 02:54:32.591240 -0400 info main: #102 C EV915 rx msg D 124,8,4,44,50,37,130,143065,0,1840,47,2,120,119,13.1,33,13.1,0
> 2013-06-02 02:54:32.592638 -0400 info main: #102 C EV915 rx msg S 73,K,222,0,charging,range,286,243,10,27,100,1,5,1,3,0,0,-1,155.40,-1
> 2013-06-02 02:56:35.248727 -0400 info main: #102 C EV915 rx msg S 73,K,220,10,charging,range,286,243,10,29,100,1,5,1,3,0,0,-1,155.40,498
> 2013-06-02 02:56:35.252732 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,50,37,130,143065,0,1970,48,2,120,120,13.0,33,13.1,0
> 2013-06-02 02:57:36.643939 -0400 info main: #102 C EV915 rx msg S 73,K,222,10,charging,range,286,243,10,29,100,1,5,1,3,0,0,-1,155.40,504
> 2013-06-02 02:57:36.646202 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,50,37,130,143065,0,2000,48,2,120,117,13.1,33,13.1,0
> 2013-06-02 02:58:41.228929 -0400 info main: #102 C EV915 rx msg S 73,K,222,10,charging,range,286,243,10,30,100,1,5,1,3,0,0,-1,155.40,508
> 2013-06-02 02:58:41.231097 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,49,37,130,143065,0,2060,49,2,120,116,13.0,33,13.1,0
> 2013-06-02 02:59:14.084569 -0400 info main: #102 C EV915 rx msg S 73,K,222,10,charging,range,286,243,10,31,100,1,5,1,3,0,0,-1,155.40,513
> 2013-06-02 02:59:14.087038 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,49,37,130,143065,0,2120,49,2,120,114,13.0,33,13.1,0
> 2013-06-02 03:00:53.585786 -0400 info main: #102 C EV915 rx msg S 73,K,220,10,charging,range,286,243,10,32,100,1,5,1,3,0,0,-1,155.40,508
> 2013-06-02 03:00:53.588020 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,49,37,130,143065,0,2180,49,2,120,113,13.0,33,13.1,0
> 2013-06-02 03:01:17.004554 -0400 info main: #102 C EV915 rx msg S 73,K,221,10,charging,range,286,243,10,33,100,1,5,1,3,0,0,-1,155.40,513
> 2013-06-02 03:01:17.006333 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,49,38,130,143065,0,2251,50,2,120,120,13.1,33,13.1,0
> 2013-06-02 03:02:20.183015 -0400 info main: #102 C EV915 rx msg S 73,K,219,10,charging,range,286,243,10,34,100,1,5,1,3,0,0,-1,155.40,518
> 2013-06-02 03:02:20.186090 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,48,38,130,143065,0,2311,50,2,120,120,13.0,33,13.1,0
> 2013-06-02 03:03:20.463407 -0400 info main: #102 C EV915 rx msg S 73,K,220,10,charging,range,286,243,10,35,100,2,5,1,3,0,0,-1,155.40,512
> 2013-06-02 03:03:20.465812 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,48,38,130,143065,0,2371,51,2,120,119,13.0,33,13.1,0
> 2013-06-02 03:04:22.479305 -0400 info main: #102 C EV915 rx msg S 73,K,221,10,charging,range,286,243,10,36,100,2,5,1,3,0,0,-1,155.40,512
> 2013-06-02 03:04:22.480838 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,48,38,130,143065,0,2431,51,2,120,118,13.0,33,13.1,0
> 2013-06-02 03:05:22.922594 -0400 info main: #102 C EV915 rx msg S 73,K,222,10,charging,range,288,243,10,37,100,2,5,1,3,0,0,-1,155.40,513
> 2013-06-02 03:05:22.924902 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,48,38,130,143065,0,2491,52,2,120,117,13.0,33,13.1,0
> 2013-06-02 03:08:22.920905 -0400 info main: #102 C EV915 rx msg S 73,K,221,10,charging,range,288,245,10,40,100,2,5,1,3,0,0,-1,155.40,518
> 2013-06-02 03:08:22.922656 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,47,38,130,143065,0,2672,53,2,120,116,13.0,33,13.1,0
> 2013-06-02 03:18:50.728261 -0400 info main: #102 C EV915 rx msg S 74,K,221,10,charging,range,290,245,10,50,100,2,5,1,3,0,0,-1,155.40,417
> 2013-06-02 03:18:50.730062 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,46,38,130,143065,0,3267,55,2,120,112,13.1,33,13.1,0
> 2013-06-02 03:28:19.623012 -0400 info main: #102 C EV915 rx msg S 74,K,221,10,charging,range,291,246,10,60,100,2,5,1,3,0,0,-1,155.40,423
> 2013-06-02 03:28:19.628428 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,45,38,130,143065,0,3874,57,2,120,120,13.0,33,13.1,0
> 2013-06-02 03:38:19.014530 -0400 info main: #102 C EV915 rx msg S 74,K,219,10,charging,range,291,248,10,70,100,3,5,1,3,0,0,-1,155.40,418
> 2013-06-02 03:38:19.016185 -0400 info main: #102 C EV915 rx msg D 124,8,4,47,44,38,130,143065,0,4467,57,2,120,116,13.0,33,13.1,0
> 2013-06-02 03:48:16.329201 -0400 info main: #102 C EV915 rx msg S 75,K,220,10,charging,range,294,250,10,80,100,3,5,1,3,0,0,-1,155.40,429
> 2013-06-02 03:48:16.330915 -0400 info main: #102 C EV915 rx msg D 124,8,4,46,43,38,130,143065,0,5069,58,2,120,120,13.0,33,13.1,0
> 2013-06-02 03:58:16.439588 -0400 info main: #102 C EV915 rx msg S 75,K,221,10,charging,range,294,250,10,90,100,4,5,1,3,0,0,-1,155.40,421
> 2013-06-02 03:58:16.441272 -0400 info main: #102 C EV915 rx msg D 124,8,4,46,42,39,130,143065,0,5666,59,2,120,118,13.1,33,13.1,0
> 2013-06-02 04:08:13.068713 -0400 info main: #102 C EV915 rx msg S 75,K,219,10,charging,range,296,251,10,100,100,4,5,1,3,0,0,-1,155.40,400
> 2013-06-02 04:08:13.070848 -0400 info main: #102 C EV915 rx msg D 124,8,4,46,42,39,130,143065,0,6262,58,2,120,116,13.1,33,13.1,0
> 2013-06-02 04:18:11.402837 -0400 info main: #102 C EV915 rx msg S 76,K,221,10,charging,range,298,253,10,110,100,4,5,1,3,0,0,-1,155.40,397
> 2013-06-02 04:18:11.404683 -0400 info main: #102 C EV915 rx msg D 124,8,4,46,42,39,130,143065,0,6859,56,2,120,115,13.1,33,13.1,0
> Decoding it, at 02:26 the PEM was at 44C, motor at 74C, and ESS at 39C. Ambient (garage open on 1 side) was 38C.
> I left it for 8 minutes, after which time the PEM was at 48C, motor at 63C and ESS at 40C. Ambient was 39C.
> I tried increasing current to 13A (again 220V, range mode), and left it for a while.
> After 21 minutes, PEM was 48C, motor was 51C, ESS was 37C and ambient was 47C. That is a total of 29 minutes so far, and I've managed to cool the ESS 39C->37C, but heat up my garage 38C->47C.
> I restarted the range mode charge at 10A and this time left it for about an hour. After that, PEM was 46C, motor 42C, ESS 39C, and my garage a blistering 59C.
> This pretty much recreates my experiments from last summer. After more than an hour, the ESS temperature was unchanged, but I had managed to heat up my garage from 38C to 59C. Not sure if the term 'cool down' is appropriate for this :-(
> Does any of you do cool down regularly (manually, or with Tattler)? If you do, what settings do you use (voltage, current, duration) and what sort of temperature drop on the ESS do you see? Last year, it was suggested I try at a higher current, but that seems to defeat the purpose. Any suggestions?
> -----Inline Attachment Follows-----
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130603/420d9ed7/attachment-0001.html>
