[Ovmsdev] Advanced Charge Control (ACC)
Sat Jun 1 19:16:52 HKT 2013
Nikki,
It will fire off the internal event callbacks, so will work with any vehicle module (or other plugin) that honors those callbacks.
You should be able to implement the relay control as a plugin module, for vehicle modules without charge control.
On 1 Jun, 2013, at 7:11 PM, Nikki Gordon-Bloomfield <nikki at littlecollie.com> wrote:
> Can we get this working for twizy too, using the io ports on the OVMS hardware to trigger a NC relay?
> Nikki.
> Sent from my iPhone
> On 1 Jun 2013, at 10:55, Michael Jochum <mikeljo at mac.com> wrote:
>> Hi mark,
>> didi you read the Model S Manual and play with it? ;-))
>> Bye
>> michael
>> Am 31.05.2013 um 15:56 schrieb Mark Webb-Johnson <mark at webb-johnson.net>:
>>> We have the concept of a 'charge location'. This is an area (square, because it is easiest) around a GPS location. An area of 200m x 200m, centred on the charge location, should be sufficient for gps inaccuracies. Up to 5 such charge locations can be defined (I'm thinking home, work, and one other).
>>> Once the car enters a charge location, an action can be triggered. At the moment, I'm only thinking of automatic home link activation, but others are possible.
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130601/0b804a2c/attachment.html>
