[Ovmsdev] OBD-II Cables
Matt Beard OVMS smvo at mxf.org.uk
Wed Jul 31 18:00:54 HKT 2013
I would love to be able to confirm... but I am still without my C-Zero. I
will confirm when I get it back!
Matt
On 31 July 2013 07:52, Nikki Gordon-Bloomfield <nikki at littlecollie.com>wrote:
> Hi Mark,
> I think the length is okay, but perhaps it's worth ordering some cables
> with right and left-hand exit points for the ODBII cable.
> For Twizy owners, the exit of the cable isn't important as the ODBII port
> is in the glove box. On the Volt, the cable exits the ODBII plug on the
> correct side -- at least in the British one -- but I think the C-Zero and
> LEAF would benefit from cables which exit the other side of the ODBII port.
> Maybe a C-Zero owner could confirm? Exiting the ODBII plug on the other
> side would I believe, give a more aesthetically pleasing installation.
> Anyone else have any thoughts?
> Nikki.
> On 31 Jul 2013, at 02:33, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> > I'm going to order another batch of OBD-II cables (changing factory
> because the one I used the last few times is so unresponsive).
> > Is the current 1metre cable length good, or should I order them longer?
> > Regards, Mark.
> > OvmsDev mailing list
> > OvmsDev at lists.teslaclub.hk
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130731/32a16cca/attachment.htm>
