[Ovmsdev] OBD-II Cables
Nikki Gordon-Bloomfield nikki at littlecollie.com
Wed Jul 31 14:52:59 HKT 2013
Hi Mark,
I think the length is okay, but perhaps it's worth ordering some cables with right and left-hand exit points for the ODBII cable.
For Twizy owners, the exit of the cable isn't important as the ODBII port is in the glove box. On the Volt, the cable exits the ODBII plug on the correct side -- at least in the British one -- but I think the C-Zero and LEAF would benefit from cables which exit the other side of the ODBII port.
Maybe a C-Zero owner could confirm? Exiting the ODBII plug on the other side would I believe, give a more aesthetically pleasing installation.
Anyone else have any thoughts?
Nikki.
On 31 Jul 2013, at 02:33, Mark Webb-Johnson <mark at webb-johnson.net> wrote:
> I'm going to order another batch of OBD-II cables (changing factory because the one I used the last few times is so unresponsive).
> Is the current 1metre cable length good, or should I order them longer?
