[Ovmsdev] Volt issues.
Nikki Gordon-Bloomfield nikki at littlecollie.com
Sun Jul 28 13:46:21 HKT 2013
Hi Michael,
I'm using the connector under the wheel on the right-hand side (drivers side) . I'll try the other one too at some point.
Nikki.
On 27 Jul 2013, at 23:45, Michael Jochum <mikeljo at mac.com> wrote:
> Hi,
> now you are happy, i think.
> Witch Connector do you use?
> Remember that the bus is only active when the car is on. And it is only active for a minute every hour when the car is charging.
> Bye
> Michael J.
> Am 27.07.2013 um 23:13 schrieb Nikki Gordon-Bloomfield <nikki at littlecollie.com>:
>> Great! After 10 mins it started working.
>> Nikki.
>> Sent from my iPhone
>>> On 27 Jul 2013, at 21:28, Michael Jochum <mikeljo at me.com> wrote:
>>> Hi,
>>> Congrats.
>>> And.... You Must Set Feature #15. CAN Write to 1
>>> Bye
>>> Von unterwegs gesendet
>>>> Am 27.07.2013 um 22:20 schrieb Nikki Gordon-Bloomfield <nikki at littlecollie.com>:
>>>> Correction: I've got 2.3.3/VA/V2
>>>>> On 27 Jul 2013, at 21:18, Nikki Gordon-Bloomfield <nikki at littlecollie.com> wrote:
>>>>> Hey folks,
>>>>> Finally got the Volt today -- a replacement for our Twizy -- and so got to putting OVMS in the car.
>>>>> The first thing we did was ref lash the module with the latest 2.3.2 firmware. Then checked that it was set to VA in vehicle type.
>>>>> Logging into OVMS and texting the module gets a response. I'm even picking up the VIN number from the car..
>>>>> But what I'm not getting is the battery SOC, nor does the parking timer appear to be correct.
>>>>> Thoughts? I've got quite a few Ampera/Volt folks in the UK who would like to install, and I said I'd go first.
>>>>> Nikki.
>>>> OvmsDev mailing list
