[Ovmsdev] Power usage / sleep mode
Tue Jan 29 09:38:46 HKT 2013
Michael B,
For the stp_* functions, can you give me some text and I'll add it to the developer's guide.
Thanks, Mark.
On 27 Jan, 2013, at 5:05 AM, Michael Balzer wrote:
> I've got a flaw in there: as the code begins taking ref max values right after charging ends, the ref gets too high. After charging my current ref is now 14.7 due to that bug, should be around 12.7.
> I need to factor in the voltage decay after end of charge. I'll see if I can get that in without introducing a new timer variable...
> @Mikeljo: "> 13" is correct (just ensures ref-13 > 0), your change to "> 130" is not correct, as the ref can be much lower.
> ...also consider using stp_l2f() for the STAT message, see the DIAG message for a copy source.
> I really should document the stp functions...
> Am 25.01.2013 17:16, schrieb Mark Webb-Johnson:
>> Michael,
>> Seems like a sensible approach.
>> Your car is now showing "11.9,0,12.2".
>> I'll try it in my car over the weekend.
>> On 25 Jan, 2013, at 9:16 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark, Tom,
>>> I just checked in the auto calibration implementation.
>>> It works by taking the maximum voltage reading while the car is off and not charging as the reference voltage, so it should adapt to all possible variations.
>>> Alert is triggered if current reading is at/below ref - 1.3V, which should fit for all cases.
>>> The alert now also includes the reference, and it can be queried by the "DIAG" SMS command. It's also now included as a new field in the environment message ("D").
>>> Am 22.01.2013 04:19, schrieb Mark Webb-Johnson:
>>>> Tom,
>>>> My understanding is that the 2.x cars work the same way. The 12V battery is just for emergency systems.
>>>> Presumably if the main pack fails (fuse blows, whatever), the 1.5 cars have no way of running hazard warning lights, brake lights, etc.
>>>> It would still be useful to see the stability of that 12V line, on the v1.5 Tesla Roadsters.
>>>> Regards, Mark.
>>>> On 21 Jan, 2013, at 12:48 AM, Tom Saxton <tom at idleloop.com> wrote:
>>>>> on 1/19/13 10:08 PM, Mark Webb-Johnson wrote:
>>>>>> If anyone has a 1.x roadster with a v2 hardware module, and has recently
>>>>>> parked it for some days, it would be helpful if you could send me the
>>>>>> date/time range and your vehicleid.
>>>>> I don't think the v1.5 Roadster has a 12V battery. It's my understanding
>>>>> that it uses a DC-to-DC converter on one of the ESS sheets to power the 12V
>>>>> systems when the car is off.
>>>>> Tom
>>>>> OvmsDev mailing list
