[Ovmsdev] Power usage / sleep mode
Tue Jan 29 05:05:14 HKT 2013
Done :-)
Also, as the Twizy (and I suppose other cars as well) charges the 12V
battery further on as long as it's plugged in, I now use the plug in
status (car_linevoltage + car_chargecurrent) to detect a 12V charge status.
After plug-out, the OVMS waits for 10 minutes (time for the 12V battery
to calm down) until taking the new ref voltage. That will still be a bit
above the nominal voltage, but the span should be short enough to allow
for taking a new ref even if taking the car for the next drive soon
after charging.
I hope this will work on other cars as well without change/config, but
it will now need the car_linevoltage and car_chargecurrent reflecting
the actual plugin status. If a car cannot provide this info, we can
introduce a new vehicle hook for a function that checks for a valid
calibration time.
Am 26.01.2013 22:05, schrieb Michael Balzer:
> I've got a flaw in there: as the code begins taking ref max values
> right after charging ends, the ref gets too high. After charging my
> current ref is now 14.7 due to that bug, should be around 12.7.
> I need to factor in the voltage decay after end of charge. I'll see if
> I can get that in without introducing a new timer variable...
> @Mikeljo: "> 13" is correct (just ensures ref-13 > 0), your change to
> "> 130" is not correct, as the ref can be much lower.
> ...also consider using stp_l2f() for the STAT message, see the DIAG
> message for a copy source.
> I really should document the stp functions...
> Am 25.01.2013 17:16, schrieb Mark Webb-Johnson:
>> Michael,
>> Seems like a sensible approach.
>> Your car is now showing "11.9,0,12.2".
>> I'll try it in my car over the weekend.
>> On 25 Jan, 2013, at 9:16 PM, Michael Balzer <dexter at expeedo.de> wrote:
>>> Mark, Tom,
>>> I just checked in the auto calibration implementation.
>>> It works by taking the maximum voltage reading while the car is off
>>> and not charging as the reference voltage, so it should adapt to all
>>> possible variations.
>>> Alert is triggered if current reading is at/below ref - 1.3V, which
>>> should fit for all cases.
>>> The alert now also includes the reference, and it can be queried by
>>> the "DIAG" SMS command. It's also now included as a new field in the
>>> environment message ("D").
>>> Am 22.01.2013 04:19, schrieb Mark Webb-Johnson:
>>>> Tom,
>>>> My understanding is that the 2.x cars work the same way. The 12V
>>>> battery is just for emergency systems.
>>>> Presumably if the main pack fails (fuse blows, whatever), the 1.5
>>>> cars have no way of running hazard warning lights, brake lights, etc.
>>>> It would still be useful to see the stability of that 12V line, on
>>>> the v1.5 Tesla Roadsters.
>>>> Regards, Mark.
>>>> On 21 Jan, 2013, at 12:48 AM, Tom Saxton <tom at idleloop.com> wrote:
>>>>> on 1/19/13 10:08 PM, Mark Webb-Johnson wrote:
>>>>>> If anyone has a 1.x roadster with a v2 hardware module, and has
>>>>>> recently
>>>>>> parked it for some days, it would be helpful if you could send me
>>>>>> the
>>>>>> date/time range and your vehicleid.
>>>>> I don't think the v1.5 Roadster has a 12V battery. It's my
>>>>> understanding
>>>>> that it uses a DC-to-DC converter on one of the ESS sheets to
>>>>> power the 12V
>>>>> systems when the car is off.
>>>>> Tom
>>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130128/244e63b2/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130128/244e63b2/attachment-0002.vcf>
