[Ovmsdev] Power usage / sleep mode
Sat Jan 19 21:36:53 HKT 2013
Mark,
I just checked in the 12V alert function.
It's straight forward and compiles ok, but I cannot test if it triggers
and resets correctly under real use conditions -- I've got no power
supply with adjustable voltage.
As most 12V batteries will be standard lead acid ones, I've set the
trigger thresholds to reasonable values for these: The alert will be
triggered on voltage drop below 11.5 V and reset on voltage above 11.9 V.
Am 19.01.2013 11:10, schrieb Michael Balzer:
> Mark,
> for the Twizy and maybe other cars, a wakeup from activity on the CAN
> bus could also be an option. I remember reading about that in the
> SIM908 manual. The OVMS could generally sleep while the Twizy is off,
> maybe with an optional timed wakeup every 10-15 minutes for 1-2
> minutes to detect GPS position changes.
> Btw, the SIM908 hardware design contains detailed info on the sleep
> modes and power usages:
> http://www.mt-system.ru/sites/default/files/sim908-c_hardware_design_v1.03.pdf
> Thanks for bringing the 12V monitoring to my attention.
> I'll now first add an SMS alert on the 12V power line getting too low,
> that's easy to implement and will remind users to charge.
> Am 19.01.2013 10:47, schrieb Mark Webb-Johnson:
>> Here are the power usage figures from my bench, using v1 hardware:
>>   * PIC (normal mode) on, modem powered down (by power toggle
>>     switch): 35mA - 42mA
>>   * PIC (normal mode) on, modem on, gps off: 75mA
>>   * PIC (normal mode) on, modem on,gps on: 120mA
>>   * Very short-lived bursts to 160mA at times, presumably while
>>     transmitting on GSM
>> Playing with AT+CSCLK=2, the modem seems to drop to almost no power
>> usage (perhaps 45mA), with a CR on the async port waking it up.
>> Looking at the PIC18F2685 data sheet, it seems that with an external
>> 20MHz oscillator, the normal power consumption is around 30mA to
>> 40mA. Switching to an internal 4MHz oscillator reduces that to 5.3mA,
>> and internal 1MHz oscillator to 3mA. Sleep mode is 2µA.
>> I'll play around with it. So far, it seems it is quite easy to go
>> into low-power sleep mode. It is getting back out that is the tricky bit.
>> On 19 Jan, 2013, at 8:50 AM, Mark Webb-Johnson <mark at webb-johnson.net
>> <mailto:mark at webb-johnson.net>> wrote:
>>> Michael,
>>> Urgh. Glad that you managed to recover it.
>>> The TMC forums have a few theads at the moment of Model S cars with
>>> 12V battery issues, and the Tesla Roadster's little 12V battery
>>> seems to need replacing every 13 to 25 months.
>>> For Roadsters, OVMS is not run off that little 12V battery, so we
>>> haven't seen this issue.
>>> The good news is that we did anticipate this sort of thing (except
>>> were expecting to see it more on ICE cars with OBDII monitoring). We
>>> added 12V power line monitoring, through an ADC, into the v2
>>> hardware. Looking at your logs for the past few days is interesting
>>> (I don't think there is anything private in their apart from the
>>> vehicleid and odometer, which I have obscured, so hope you don't
>>> mind me posting here). The 12v line reading is the second to last
>>> column:
>>>     2013-01-14 06:39:53.930886 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 128,0,0,13,17,4,0,YYYY9,28,0,-127,0,120,-1,15.0,0
>>>     2013-01-14 06:59:54.871517 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.7,0
>>>     2013-01-14 07:05:26.666203 -0500 info  main: #34 C XXXXXXX rx
>>>     2013-01-14 07:05:46.498420 -0500 info  main: #34 C XXXXXXX rx
>>>     2013-01-14 07:06:04.864927 -0500 info  main: #34 C XXXXXXX rx
>>>     2013-01-14 07:30:07.228738 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.6,0
>>>     2013-01-14 08:29:57.461316 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.5,0
>>>     2013-01-14 09:29:48.441380 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.4,0
>>>     2013-01-14 11:29:30.755176 -0500 info  main: #34 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.3,0
>>>     2013-01-14 15:05:36.688666 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.2,0
>>>     2013-01-14 16:05:35.111552 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.7,0
>>>     2013-01-14 16:36:35.755630 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-14 18:38:18.404933 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-14 21:04:47.187479 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.1,0
>>>     2013-01-15 02:04:22.801440 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,12.0,0
>>>     2013-01-15 09:03:13.233483 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.9,0
>>>     2013-01-15 11:02:54.400624 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-15 12:02:44.724576 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-15 13:02:34.285593 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.8,0
>>>     2013-01-15 16:02:09.372087 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-15 17:02:00.235001 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-15 19:01:41.695938 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 02:00:40.126355 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.6,0
>>>     2013-01-16 06:00:03.073862 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.5,0
>>>     2013-01-16 11:59:01.907094 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.4,0
>>>     2013-01-16 15:58:22.520731 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.3,0
>>>     2013-01-16 17:22:48.691426 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 17:30:10.701329 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 17:30:21.837740 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.2,0
>>>     2013-01-16 17:36:37.811552 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 17:46:01.164994 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 17:48:35.257576 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 17:56:49.565932 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:01:15.186127 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:02:46.866156 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:02:54.217581 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:10:29.930408 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:10:38.723483 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:11:12.459758 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:18:31.863177 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:19:03.123286 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:43:55.355803 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 18:58:43.567326 -0500 info  main: #54 C XXXXXXX rx
>>>     2013-01-16 22:58:15.314101 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.1,0
>>>     2013-01-17 01:57:50.181011 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,11.0,0
>>>     2013-01-17 02:57:40.587918 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,10.9,0
>>>     2013-01-17 03:57:30.418056 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,10.8,0
>>>     2013-01-17 04:57:19.241415 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,10.6,0
>>>     2013-01-17 05:57:10.622186 -0500 info  main: #54 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,10.3,0
>>>     2013-01-17 06:32:32.593533 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,10.0,0
>>>     2013-01-17 07:32:23.932656 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,9.4,0
>>>     2013-01-17 08:32:13.374380 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,7.9,0
>>>     2013-01-17 09:32:03.204557 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,7.2,0
>>>     2013-01-17 10:31:52.551362 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,6.5,0
>>>     2013-01-17 11:31:41.821330 -0500 info  main: #55 C XXXXXXX rx
>>>     msg D 0,0,0,14,15,4,0,ZZZZ0,0,0,-127,0,0,-1,6.7,0
>>>     2013-01-17 12:58:48.540906 -0500 info  main: #60 C XXXXXXX rx
>>>     msg D 128,0,0,13,1,2,0,ZZZZ8,0,0,-127,0,120,-1,15.1,0
>>> It shows 15v at the start (I guess when the car is on and charging
>>> it), then 12.7v at 2013-01-14 06am EST, then falls gradually to
>>> 11.0v at 2013-01-17 01am EST. At that point it seems to fall faster,
>>> down to the last report (just 10 hours later)  6.7v at 2013-01-17
>>> 11am EST.
>>> My original thought to handle this was to have two thresholds.
>>> At the first threshold, the PIC would turn off the modem and
>>> re-awake only once every 12 hours, for 2 minutes, before going back
>>> to sleep.
>>> At the second threshold, the PIC would turn off the modem, and go to
>>> a deep sleep itself. In this mode, once power was restored it would
>>> reset itself.
>>> Exit from either mode would be the 12v power line going back above
>>> the first threshold plus some safety margin.
>>> This weekend, I'll get some exact power measurements from the v2
>>> hardware module, so we know what we are dealing with:
>>>   * Just the PIC (modem powered down)
>>>   * PIC + MODEM
>>>   * PIC + MODEM + GPS
>>> Last time I tested this, on v1 hardware without GPS, these were the
>>> figures for PIC + MODEM:
>>>   * Idle: 40mA @12V
>>>   * Cellular Network Registration: 100mA @12V
>>>   * Network activity: 80mA @12V
>>> On 18 Jan, 2013, at 10:47 PM, Michael Balzer <dexter at expeedo.de
>>> <mailto:dexter at expeedo.de>> wrote:
>>>> Mark, List,
>>>> yesterday my Twizy was temporarily dead... because of the OVMS
>>>> power usage.
>>>> I had not driven for 5 days. The Twizy has a very small 12V battery
>>>> with only 14 Ah capacity, and it only gets charged while charging
>>>> the Twizy and while driving (from the main battery).
>>>> The OVMS with GPS activated needs a constant current of ~110 mA
>>>> according to my measurement, thus sucking that battery empty within
>>>> 4-5 days, maybe fewer. I'll make the power warning much more
>>>> prominent in the Twizy user guide.
>>>> Have there been any considerations yet about using the sleep mode
>>>> of the PIC and/or SIM chipset?
>>>> Regards,
>>>> Michael
>>>> <dexter.vcf>_______________________________________________
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130119/bb8f54af/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130119/bb8f54af/attachment-0002.vcf>
