[Ovmsdev] Volt/Ampera
Fri Jan 18 16:18:52 HKT 2013
Michael,
Is the request ID 0x7e4, and do you have a trace of this? is it just a 1 byte response, with the following range:
0/2 - 40 = -40 celcius
255/2 - 40 = +87.5 celcius
The other source listed this as:
"*H2 Outside Temp Filtered", "OAT Filtered","22801F","((A-40)/2)",-20,50,"C", 7E4
Which is slightly different. For example byte value 100 gives:
(100/2) - 40 = +10 celcius
or (100-40)/2 = +30 celcius
On 18 Jan, 2013, at 2:35 PM, Michael Jochum wrote:
> Temp = 801f / 2 - 40
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130118/36ca2ea9/attachment.htm>
