[Ovmsdev] v2.2.2
Thu Jan 17 09:22:21 HKT 2013
I've been running v2.2.2 in my car for a week now, and I've gotta say that this seems to be the most stable OVMS firmware I've seen to date. My car's connection to the server has been rock-solid (only one GPRS re-connection due to poor cellular coverage), and zero module reboots. An average of about 10KB of cellular data a day (an all-time low).
I'd like to give a big public thanks to Michael Balzer for all his hard work on this (and the v2 framework in general). His DebugCrash diagnostics, and re-working of the sprintf calls to his own library routines, seems to have nailed those strange random module reboots we were seeing. Thanks, Michael - most appreciated.
Rollout of this version has been slow. On the TMC server, today, there are just 6 cars running v2.x code. I really would like to encourage people to upgrade to this version, to let us get more data on it - you'll hopefully also get the benefit of more stability, lower cellular data usage, and a few bugs have been fixed since v1.5.1.
On 13 Jan, 2013, at 4:29 PM, Mark Webb-Johnson wrote:
> I've released firmware v2.2.2 to the github repository. The change log is as follows:
> 2013-01-11 2.2.2 Firmware 2.2.2
> #94 v2 firmware re-work for multiple vehicle support
> #95 Valet Mode - Tesla Roadster - Trunk open is working off bonnet
> #96 Server: Support for historical data messages
> #97 CAN overflow (lockups)
> #99 Update vehicle/Car Module/VoltAmpera/voltampera_canbusnotes.txt
> #72 #72 Add GPS support for cars without it
> ### v2.x firmware, first release
> Internal GPS integration
> Basic support for Renault Twizy
> Volt/Ampera work-in-progress
> Framework sprintf rework
> First draft of OVMS Development document
> Twizy user guide v1.0.1
> The .hex files have been built for all configurations. I (and others) have tested this in hardware v2 vehicles, but so far this is pretty much untested with v1 hardware (in particular for Tesla Roadster). I would appreciate it if you guys could test it and make sure it is ok for v1 hardware in Roadsters.
> Once you upgrade firmware to v2, you will need to either (a) SMS "MODULE" command again to include the fourth parameter vehicle type "TR", or (b) use the iOS App to set feature #14 to "TR". You will require this for the CAN bus stuff to work. I have updated the Tesla Roadster user guide to reflect this new parameter.
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130117/4f4f1771/attachment.htm>
