[Ovmsdev] some partial success
Thu Jan 3 02:24:28 HKT 2013
Nikolay,
btw, there's a more detailed HOWTO on the server in "docs":
https://github.com/markwj/Open-Vehicle-Monitoring-System/blob/master/docs/HOWTO.server.txt
Am 02.01.2013 11:43, schrieb Michael Balzer:
> Nikolay,
> the documentation needs some updates, the vehicle type parameter is new.
> Easiest GPRS test is done by using the standard server and the iOS or
> Android App.
> To set up your own OVMS server, you need a public IP, a mysqld and
> perl. See "server" directory in the git repository.
> Set up some mysql schema e.g. "ovms" and access, prime the schema
> using "mysql ovms < ovms_server.sql" and change "ovms_server.conf"
> accordingly.
> To be able to connect your module, manually add an entry to the
> ovms_cars table like this:
> insert into ovms_cars set vehicleid='...', carpass='...',
> userpass='...', changed=now();
> The server is started by "./ovms_server.pl" (or "perl ovms_server.pl"
> if non-UNIX). Configure your module using "GPRS" and "SERVER" and you
> should see log output from the server (stdout).
> It's best to start without paranoid mode, so you can read what's
> happening.
> Btw: I had trouble with my first SIM card as well in the beginning.
> That was network/provider related, after letting the module on for
> some hours, the GPRS registration suddenly succeeded and has been
> quick + stable since.
> Am 02.01.2013 10:05, schrieb Nikolay Shishkov:
>> Thanks Mark,
>> Looking at the code the VEHICLE TYPE is the 4th parameter of the
>> MODULE command.
>> I will test this today and report back.
>> I was looking at the user guide for Tesla and the MODULE command has
>> listed 3 parameters...
>> I forgot to mention that I tested 2 different sim cards in Sweden:
>> 1- mini sim format (like iphone 4) with adapter, operator 3 - did
>> not work, the error code is blinking too fast for me to reliably
>> count it.
>> 2 - standard sim format, operator telia - worked for sms
>> Still haven't tested the gprs function. Any good advice on how to
>> test the GPRS function - can I setup a simple server to just register
>> the incoming messages?
>> Nikolay
>> *From:* Mark Webb-Johnson <mark at webb-johnson.net>
>> *To:* OVMS Developers <ovmsdev at lists.teslaclub.hk>
>> *Sent:* Wednesday, January 2, 2013 2:28 AM
>> *Subject:* Re: [Ovmsdev] some partial success
>> Nikolay,
>>> Unfortunately it did not seem to work. On STAT request the response
>>> was generated from the net_sms code and not my new code for the
>>> Think EV.
>> So long as you've registered the hook correctly, it should work. Are
>> you sure you set the module correctly to TC so your vehicle module is
>> the one actually used? This is the SMS MODULE command (I think it is
>> the last parameter).
>> You can SMS PARAMS? or MODULE? to see what parameters are set.
>>> Also - what are the capabilities used for?
>>> What does "C6,C200-207" mean? I get the 200 to 207 are the extra
>>> commands but how are they plugged to the rest of the code?
>> This is a new v2.x thing, used to tell the App what the capabilities
>> of the vehicle module are. We don't use it at the moment, but plan to
>> use this in the app code in order to customise the functions and
>> appearance on a per-vehicle-module basis. For example, if the vehicle
>> module is able to support a lock/unlock command, the capabilities
>> will tell the Apps that, and the apps can update the UI appropriately.
>>> f I reprogram the board, do I need to restart it somehow? Or is it
>>> enough to just reprogram it from the mplab x and the board will restart?
>> The board will restart automatically after being programmed by
>> MPLAB-X. If you want to restart it, you can also SMS RESET or just
>> pull the power.
>> On 2 Jan, 2013, at 9:22 AM, Nikolay Shishkov wrote:
>>> A quick report.
>>> I manged to flash the firmware and register a phone.
>>> I also started on a Think EV file based on the Twizy one. I setup
>>> the CAN filters and changed the code to handle a state of charge
>>> message.
>>> Think EV.
>>> On checking the code all seems fine - my stat function was plugged
>>> correctly.
>>> I will continue tomorrow, but wanted to ask if anyone has good ideas
>>> to try?
>>> If I reprogram the board, do I need to restart it somehow? Or is it
>>> Any help is appreciated,
>>> Nikolay
>>> *From:* Michael Balzer <dexter at expeedo.de <mailto:dexter at expeedo.de>>
>>> *To:* ovmsdev at lists.teslaclub.hk <mailto:ovmsdev at lists.teslaclub.hk>
>>> *Sent:* Tuesday, January 1, 2013 9:37 PM
>>> *Subject:* Re: [Ovmsdev] sprintf / crashes
>>> Mark,
>>> transparent chunk splitting seems to be non-trivial, so I split my
>>> data transfers. Everything's working fine again, so I'll merge into
>>> the master next if you don't object.
>>> Btw, AT+CIPSEND? gave me 1460 bytes, so that's supposed to be the
>>> size limit we should keep in mind until we find a better solution.
>>> @Nikolay: please note, that's the total size that can be sent within
>>> one net_msg_start() ... net_msg_send(), the buffer size
>>> (net_scratchpad) further limits a single MSG line to currently 199
>>> bytes max.
>>> Am 31.12.2012 16:23, schrieb Michael Balzer:
>>>> Mark,
>>>> I think I found my link dropping problem: scanning a diag log I
>>>> took, I found out CIPSEND will fail with a plain "ERROR" if the
>>>> data size exceeds about 1500 bytes. I guess that's either the
>>>> SIM908 buffer size or the max network packet size. I thought the
>>>> SIM908 would handle dividing data into packets as needed. The
>>>> SIM908 manual mentions the max packet size depends on network
>>>> status and should be queried by "AT+CIPSEND?". After the overrun
>>>> net_state_activity() will not recognize "ERROR" to terminate the
>>>> pending msg, so will run into the timeout and start a network re-init.
>>>> My battery status data exceeds 1500 bytes on first run and later on
>>>> if enough cells need updates. I'll think about how to split up data
>>>> packets into multiple CIPSENDs. Would be nice if the net functions
>>>> take care of this transparently.
>>>> A secondary issue turned up from the diag log: the SIM908 crashed
>>>> in the middle of a CIPSEND command while the module continued to
>>>> run normally. The module still thought it's in NET_STATE_READY, so
>>>> did not re-initalize the modem. The connection could then be
>>>> established on the next CIPSTART, but the complete INIT stuff had
>>>> not been done. So it seems independant SIM908 resets need to be
>>>> handled as well, and they can occur anytime. I'll see if I can
>>>> solve that too.
>>>> Regards,
>>>> Michael
>>>> Am 30.12.2012 15:42, schrieb Michael Balzer:
>>>>> I hesitate to merge into the master because I currently have link
>>>>> / connectivity problems, especially during driving. I introduced a
>>>>> GPS logging to optimize my antenna positions and managed to get
>>>>> some really nice tracks three days ago, so I don't think this is
>>>>> related to my changes... but I'm not 100% sure. I tried different
>>>>> antenna positions and another GSM network, but the connection
>>>>> keeps dropping when moving the car, and GPS position updates need
>>>>> minutes. Could be weather conditions ...or some tricky race
>>>>> condition bug?
>>>> OvmsDev mailing list
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130102/bd1812ef/attachment.htm>
Type: text/x-vcard
URL: <http://lists.openvehicles.com/pipermail/ovmsdev/attachments/20130102/bd1812ef/attachment-0002.vcf>
