[Ovmsdev] Android App
Wed Jan 30 23:59:41 HKT 2013
Mark,
I do already support doors1 bit 7. Not bit 6 as it is labeled "hand
brake applied", and not the parking time as I thought that needs to be a
time value, not a simple second count. I'll try to add support for these.
So the App logic is only using the state of bit7 and the "parking" info
itself is correct then -- I just wasn't used to it, as the old App never
displayed it.
Strange remains it showed a parking time a few times, but it hasn't done
so in a while and I can't remember any special condition that might have
caused this.
Am 30.01.2013 01:29, schrieb Mark Webb-Johnson:
> Michael,
>> my parktime is always 0, as I currently have no parking detection,
>> but the App shows it as parking.
>> It shows "just now" most of the time (also right now), but I also saw
>> some "x minutes" displays there. doors1 bit7 is set correctly by the
>> Twizy.
> I think the best way is for you to add support for car_doors1 [bit 7]
> and [bit 6] (the 'car on' and 'park' bits).
> Because your firmware is always saying 'car off' (car_doors1 [bit 7]
> unset), the apps will think it is parked. And, as the parking timer is
> not coded, the apps will also think 'parked just now'.
> The Apps don't use parktime to determine whether the car is parked or
> not, they use car_doors1 [bit 7] (whether the car is ON of OFF).
>> The USSD code entry only allows digits, at least "*" and "#" also
>> need to be allowed.
> OK.
> On 30 Jan, 2013, at 12:10 AM, Michael Balzer wrote:
>> Mark,
>> but the App shows it as parking. It shows "just now" most of the time
>> (also right now), but I also saw some "x minutes" displays there.
>> doors1 bit7 is set correctly by the Twizy.
>> I found the joystick now, that could have passed as a "hidden"
>> feature ;-)
>> need to be allowed.
>> Am 29.01.2013 02:37, schrieb Mark Webb-Johnson:
>>>> - constantly shows "parking", although the Twizy does not feed the
>>>> parking timer
>>> I just tested on my Roadster, with both Android and iOS Apps, and
>>> this seems to work as it should (for me).
>>> The logic in the Apps is that the car is parked if "!carstarted and
>>> parktime>0".
>>> Carstarted is:
>>> unsigned char car_doors1 [bit 7]
>>> A bit used to signal whether the car is turned on or off. Set to
>>> 1 if the car ignition switch is ON, otherwise 0.
>>> There is a little bit of code in the vehicle_voltampera to handle
>>> the parking timer. As we don't know the 'car on' signal for the
>>> Volt/Ampera, yet, we just use the gear selector PARK.
>>> else if ((CANctrl & 0x07) == 5) // Acceptance Filter 5
>>> (RXF5) = CAN ID 135
>>> if (can_databuffer[0] == 0)
>>> { // Car is in PARK
>>> car_doors1 |= 0x40; // NOT PARK
>>> car_doors1 &= ~0x80; // CAR OFF
>>> if (car_parktime == 0)
>>> car_parktime = car_time-1; // Record it as 1 second
>>> ago, so non zero report
>>> net_req_notification(NET_NOTIFY_ENV);
>>> else
>>> { // Car is not in PARK
>>> car_doors1 &= ~0x40; // PARK
>>> car_doors1 |= 0x80; // CAR ON
>>> if (car_parktime != 0)
>>> car_parktime = 0; // No longer parking
>>> Also, initialise car_time to zero, and increment it in the vehicle
>>> ticker1().
>>>>> ...as well as all the new function and parameter settings.
>>>> I haven't seen a function call / parameter setup utility -- is that
>>>> a hidden feature, or no UI yet, or a bug on my device?
>>> The icon is not ideal at the moment. Go to settings, then the little
>>> pencil icon to go to the car settings, then press the icon that
>>> looks like a joystick in the top right. That is the control menu.
>>> From there, we have Features and Parameters.
>>> On 24 Jan, 2013, at 10:29 PM, Michael Balzer wrote:
>>>> Mark,
>>>> a short report for my HTC Desire HD / Android 2.3.5:
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130130/63472c99/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130130/63472c99/attachment.vcf>
