[Ovmsdev] Vehicle Support Checklist
Tue Jan 29 09:44:19 HKT 2013
I've updated the development document with some vehicle module development checklists. You can use these checklists to know what vehicle parameters the OVMS system supports, and how you can map a specific vehicle to these.
The Tesla Roadster supports 100% of these (obviously). It would be good to use these ongoing for other vehicles, both as a target list to get to 100% support, and as a worksheet for both CAN bus information and progress.
I hope you find them useful.
Parameter
Purpose
Vehicle Support Notes
Vehicle Identification
car_type
Vehicle type identified
car_vin
Vehicle VIN
Parameter
Purpose
GPS Status
Vehicle GPS
Does the vehicle have a built-in GPS? If so, complete the following.
car_gpslock
Set to record GPS lock
car_stale_gps
Denotes GPS data staleness
car_latitude
Latitude of the vehicle
car_longitude
Longitude of the vehicle
car_direction
Direction of the vehicle
car_altitude
Altitude of the vehicle
Parameter
Purpose
Tire Pressure Monitoring System
TPMS
Does the vehicle have a TPMS? If so, complete the following.
car_stale_tpms
Denotes TPMS data staleness
car_tpms_t
The temperatures of each wheel
car_tpms_p
The pressures of each wheel
Parameter
Purpose
Driving Status
car_doors1 [bit7]
Set if the car ignition is ON
car_speed
The speed of the vehicle
car_trip
The vehicle trip counter
car_odometer
The vehicle odometer
Parameter
Purpose
Vehicle Environment
car_stale_ambient
Ambient temperature staleness
car_ambient_temp
Ambient temperature
car_stale_temps
Other Temperature staleness
car_tpem
Temperature of the PEM
car_tmotor
Temperature of the MOTOR
car_tbattery
Temperature of the BATTERY
car_doors1 [bit 0]
Set if front left door OPEN
car_doors1 [bit 1]
Set if front right door OPEN
car_doors2 [bit 6]
Set if bonnet is OPEN
car_doors2 [bit 7]
Set if trunk is OPEN
car_doors1 [bit 2]
Set if charge port is OPEN
car_doors1 [bit 6]
Set if handbrake is ON
car_doors2 [bit 5]
Set if headlights ON
car_doors3 [bit 1]
Set if vehicle is AWAKE (or if not supported just follow ignition)
car_doors2 [bit 4]
Set if valet mode is ENABLED
car_doors2 [bit 3]
Set if vehicle is LOCKED
car_lockstate
4=locked, 5=unlocked (deprecated)
car_doors4 [bit 2]
Set if alarm SOUNDING
car_time
Time (in seconds)
car_parktime
Time (seconds) vehicle parked
Parameter
Purpose
Battery Status
car_SOC
State of charge percentage
car_idealrange
Ideal range
car_estrange
Estimated range
Parameter
Purpose
Charging Status
car_doors1 [bit 3]
Set if pilot signal ON
car_doors1 [bit 4]
Set if vehicle CHARGING
car_linevoltage
Line voltage while charging
car_chargecurrent
Line current while charging
car_chargemode
Vehicle Mode
car_chargestate
Charging state
car_chargesubstate
Charging sub-state
car_chargelimit
Charge current limit
car_chargeduration
Charge duration (minutes)
car_chargekwh
Charge kWh put into battery
car_stale_timer
Charge timer staleness
car_timermode
Charge timer mode
car_timerstart
Charge timer schedule
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130129/51f10dc5/attachment-0001.html>
