[Ovmsdev] test works, what next
Mon Jan 7 15:12:20 HKT 2013
Nikolay,
congratulations :-)
Mark already said it: look for "car_" variables, these will transport
common properties. "can_" variables are currently vehicle locals, see my
previous suggestion on renaming these to reflect their vehicle specific
nature. Only common properties and commands will currently be supported
by the Apps -- adding vehicle specific code and UIs to the Apps is the
next main todo.
Note there are some variables already in the Twizy code, that
could/should become common. Generally, the more vehicles turn up to need
some value, the more likely it will become common.
Without App support, you still can do vehicle specific data collection
and analysis by sending "H" MSGs to the server. "H" msg types are
basically free-form, they can transport all vehicle specific data to the
server and to any client. There are multiple examples in the Twizy code
for that, and I've added user guides and a perl utility "cmd.pl" to
query them from the server last night, take a look. The output is simple
CSV format, so you can load that into any spreadsheet or database.
For text messages, note there is already an App msg defined ("P" = push
message), the only current caveat is, the Apps (at least the Android
one) will only process these if backgrounded. That certainly can be
fixed soon, so push messages will become a fully functional SMS alternative.
Am 06.01.2013 15:04, schrieb Nikolay Shishkov:
> Thanks to Michael, Mark and google the code now works.
> I am fetching SOC, pack current, pack voltage, and pack average
> temperature.
> So what next?
> The current code is based on the Twizy, I have changed the
> implementation of the Debug command and am getting correct values...
> but I would like to have the STATE command work too, and I will
> implement a custom one too (based on the Twizy code) so it will report
> what I want it to report. There is for example no range.
> How to go about with integrating server and android/iphone app?
> In the simplest form I would like to have at least SOC, Temperature,
> Pack voltage, Pack current, a some kind of text or bit map for state
> (like charged, charging enabled, plugged, waiting temp) there are some
> more states, some additional parameters like PWM signal for charge
> power, and eventual errors and warnings - there is a warning "please
> charge to full soon" for example. These can also be bits or text.
> From the Twizy code I can see how to handle this for the sms commands,
> and I see some ways of generating semicolon separated message to the
> server... but would that mean that the message will be later
> understood/presented by the apps?
> I would also like to have the SOC notifications - low SOC, charge
> finished, charge stopped - I can also fix this the Twizy way.
> Very exciting!
> Thanks,
> Nikolay
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130107/fec1d785/attachment.html>
Type: text/x-vcard
URL: <http://lists.teslaclub.hk/pipermail/ovmsdev/attachments/20130107/fec1d785/attachment.vcf>
